B7 Steering control module now isues with G85
berndh
C?ID=66436
Today I fitted a Passat B7 Steering wheel control module into my Passat B6 (2008) with DSG and MFL. Did the cabling and everything seems to work normal. However the G85 steering wheel angle sensor can not be calibrated. I tried using the ABS module, the STG16 and STG44. All say that it is not possible.
How can I perform a G85 Steering Wheel Angle sensor calibration with this new module? Apparently it is different from using the ABS module.
Looking at STG44 Measuring values 007, I don't see the first field changing when I rotate the wheel, however the torque (degr/sec) changes.
I get the following error:
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20121204300108
   Coding: 399A270002
   Shop #: WSC 00015 115 08193
   VCID: 75EA286DD4708B965D-8020
   Subsystem 1 - Part No SW: 3C8 959 537 B    HW: 3C8 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP  H4  0021
   Coding: E30000
1140738 - Steering angle sensor
                    Reset counter: 207
                    Mileage: 230821 km
                    Date: 2016.04.02
                    Time: 03:01:02
The scan:
5D-Operations -- Status: OK 0000
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.136 H08 1901
   VCID: 356AE86D5CF0CB969D-8060
02546 - Steering Limit Stop
                    Mileage: 230810 km
                    Temperature: 27.0°C
                    Voltage: 12.20 V
                    Voltage: 12.00 V
Bwant
C?ID=130834
How did you code the new module? The labels are incomplete in VCDS and yours look different to others I have seen.
berndh
C?ID=66436
I did code the module using the label files in vcds 15.7.4.
This module is from late b7 passat (2010>)
The previous modules are different in coding.
What exactly do you mean with wrong coded.
Bwant
C?ID=130834
I was looking at the coding of this module today in my car and some of the labels were not present. Were all the labels present when you coded?
berndh
C?ID=66436
Yes. They were present. I know what all the bits mean.
There is byte0 bit0 that can be set to have the g85 external. I was thinking for the passat the g85 is attached to the j527 module therefor this bit is set. You can also see that address 04 is showing OK. so I think there is nothing wrong with the communication. The procedure is simply different compared to the b6 (done via abs module)
berndh
C?ID=66436
Which module do you have and what is your coding?
Bwant
C?ID=130834
That's what I was thinking regarding your problem..if the G85 could be set differently. Would you mind sharing the labels with me? For some reason I don't get them all even though my vcds is up to date.
berndh
C?ID=66436
I don't get it for every bit. Only for the ones I set.
berndh
C?ID=66436
Problem solved. The slipring was not centered. That is why the g85 could not be calibrated.
