Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Audi Q7 2016 3.0TDI (4M Chassis)
    Verified VCDS User Gavra's Avatar
    Mar 2015
    Melbourne/Belgrade
    Just went to check this car and I was not able to read more then half of modules. Thought it was my interface, but another one had same problem. Address 46 not available no response from controller . Is this a known issue with newer cars?
    Verified VCDS User rlarsen's Avatar
    May 2015
    Copenhagen, Denmark
    Are you using the beta VCDS 16.3.1 which should work with the new Q7 (4M) - or are you using VCDS 15.7.4 which doesn't support the new Q7 (4M) ??
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 19.6.2
    (HEX-V2)
  3. Likes Andy, Uwe liked this post
    Mar 2015
    Melbourne/Belgrade
    Just installed 16.3.1 and Gateway is now accessible, however CV2 at 46 still not available. With ODIS I have full accessibility to 46.
    Administrator Andy's Avatar
    Sector 7G
    Please post a complete AutoScan.
    FYI, here's a scan from an MLBevo Q7:
    http://forums.ross-tech.com/showthread.php?5633
    I don't see 46 in the Gateway list. Sometimes ODIS uses different address numbers compared to VCDS. What is the part number of the controller you can read with ODIS?
  6. Likes Uwe, DrPeter liked this post
    Mar 2015
    Melbourne/Belgrade
    Yes there is no 46 in gateway but module exist. I will try to get car back to me for more testing as it's Saturday and customer had to go.
    autoscan here :
    Saturday,02,April,2016,23:56:25:04865
    VCDS Version: 16.3.1.1
    Data version: 20160325
    VIN: WAUZZZ4M1GD001432   License Plate:
    Chassis Type: 4M (4M2)
    Scan: 01 02 03 06 08 09 13 15 16 17 18 19 28 36 3C 42 44 52 5F 69
              6C 6D 81 8B A5 AC CB
    CB-Rear Axle Steering -- Status: OK 0000
    Address 01: Engine (J623-CRTC)       Labels: None
       Part No SW: 4M0 907 401     HW: 059 907 309 B
       Component: 3.0TDI EDC17  H45 0003
       Revision: 91H45---
       Coding: 2A2A403A057E050335380000000000000000000000000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0114M0907401 001007
       ROD: EV_ECM30TDI0114M0907401.rod
       VCID: 66C84A289974CC0C2E-8032
    Address 02: Auto Trans (J217)       Labels: None
       Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
       Component: 0D5  30TDIRdW H03 1008
       Revision: --H03---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011.rod
       VCID: 3B7ECB5CB276A1E4A1-806E
       Part No SW: 4M0 907 379 K    HW: 4M0 907 379 K
       Component: ESP9 Premium  H08 0514
       Coding: 1C9830B230A20A97D6A25894187F56AAE6A6DA380C0C506B1A186A5567655B
       ASAM Dataset: EV_ESP9BOSCHAU736 011006
       ROD: EV_ESP9BOSCHAU736_AU73.rod
       VCID: 3F86BF4CA66EBDC48D-806A
       Part No SW: 4M0 959 760 E    HW: 4M0 959 760 E
       Component: MEM-BFS       008 0014
       Serial number: 00000143640801
       Coding: 000010000000B0410000210101010000110000313100000000000000000000
       ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
       ROD: EV_SCMDriveSideCONTIAU736_AU73.rod
       VCID: 3A70CE58BD4C98ECBA-806E
    Address 08: Auto HVAC (E87)       Labels: None
       Part No SW: 4M0 820 043 K    HW: 4M0 820 043 K
       Component: Klima Zone 4  H52 0052
       Coding: 6618481C5548401102620180800000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFrontBHTCAU736 001012
       ROD: EV_AirCondiFrontBHTCAU736.rod
       VCID: 2D5AF5047C023F542F-8078
       Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
       Component: J216 FLuftV  H05 0001
       Part No SW: 8W0 907 063 G    HW: 4M0 907 063 G
       Component: BCM1 MLBevo   H12 0215
       Coding: 07501943E16900CD010D8714583F00F9130331009000000000000000E20016810A4501AB32B706
       ASAM Dataset: EV_BCM1BOSCHAU736 014003
       ROD: EV_BCM1BOSCHAU736_AU49.rod
       Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C
       Component: WWS536 140901  042 0792
       Serial number:         140904150530
       Coding: 1BC7F7
       Serial number: 20174789
       Coding: 02006C
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 N    HW: 4M0 941 531 N
       Component: E1 - LDS  H05 0007
       Serial number: 18 03 2015  00015678
       Subsystem 4 - Part No SW: 4M0 857 511 A    HW: 4M0 857 511 A
       Component: Y7_Innenspieg  H08 0001
       Serial number: GX1CE124021511520120
       Coding: 030000
       Interior Light Module:
       Subsystem 5 - Part No SW: 4M0 947 135 AB    HW: 4M0 947 135
       Component: J528-Dachele  H12 0061
       Serial number: Q00006868
       Subsystem 6 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
       Component: SL-Q7NF/AU736  H09 0006
       Serial number: 00000000000000001577
    Address 13: Auto Dist. Reg (J428)       Labels: None
       Part No SW: 4M0 907 561 C    HW: 4M0 907 561
       Component: LRR4          H08 0160
       Coding: 3477E7FB70FFEC08949880A4
       ASAM Dataset: EV_ACCBOSCHAU736 001016
       ROD: EV_ACCBOSCHAU736.rod
       VCID: 3064EC706B3052BC04-8064
    Address 15: Airbags (J234)       Labels: None
       Part No SW: 4M0 959 655     HW: 4M0 959 655
       Component: Airbag10.44   H50 0084
       Serial number: 003L100027WN
       Coding: AAFCF0C00C80000098F600F3C00C00000000
       Shop #: WSC 52399 001 1048576
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: EV_AirbaAU10BPAAU736_AU73.rod
       VCID: 78F41450C3C04AFC8C-802C
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
       Component: BeltPretRevFL  205 2033
       Serial number: 4M0857705D0093P00517
       Coding: 88001B
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
       Component: BeltPretRevFR  205 2033
       Serial number: 4M0857706D0093P00580
       Coding: 88001B
       Subsystem 3 - Part No SW: -----------    HW: 442 062 603 15
       Serial number: 3577Y00A517C3232923T
       Subsystem 4 - Part No SW: -----------    HW: 442 062 603 15
       Serial number: 3587Y00A517C3231415P
       Subsystem 5 - Part No SW: -----------    HW: 442 0B2 603 15
       Serial number: 3517700B91A14CE6317G
       Subsystem 6 - Part No SW: -----------    HW: 442 0B2 603 15
       Serial number: 3527700B91A14CE0A32F
       Subsystem 7 - Part No SW: -----------    HW: 442 0C2 603 15
       Serial number: 3557500A7196FF96830S
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 442 0C2 603 15
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500A5196FF91834Q
       Pedestrian Protection Center:
       Subsystem 9 - Part No SW: -----------    HW: 442 0C2 605 14
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500C115397B3C1D9
       Subsystem 10 - Part No SW: -----------    HW: 442 420 611 14
       Component: PedPSensor_D2  21E 0887
       Serial number: I0M8U00A313216A4A7FL
       Subsystem 11 - Part No SW: -----------    HW: 442 420 611 14
       Component: PedPSensor_P2  21E 0887
       Serial number: I0N8U009D13216A2A4CN
       Central Sensor XY:
       Subsystem 12 - Part No SW: -----------    HW: 410 201 401 15
       Component: CentrSensorXY  1C8 0108
       Serial number: I0O7800A11196633E21S
       Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
       Component: Lenks.Modul   H11 0008
       ROD: EV_SMLSKLOAU736_AU49.rod
       VCID: 010279B4901A0B34BB-8054
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 4M0 920 781     HW: 4M0 920 781
       Component: TDIeRDWACC    H14 0243
       Coding: 040400E47C98000800A3E9603000600000000000
       ASAM Dataset: EV_DashBoardAU736 001018
       ROD: EV_DashBoardAU736.rod
       VCID: 6CDC38008798F65C78-8038
    Address 18: Aux. Heat (J364)       Labels: None
       Part No SW: 4M0 265 105 A    HW: 4M0 265 105 A
       Component: HSG           H08 0040
       Coding: 0D0F01
       ASAM Dataset: EV_AuxilParkHeateEBEAU736 001014
       ROD: EV_AuxilParkHeateEBEAU736.rod
       VCID: 254A0D2424F20714E7-8070
       Part No SW: 4M2 907 468 A    HW: 4M2 907 468 A
       Component: Gateway       H13 0078
       Revision: 3C110040    Serial number: 4043C003D15322
       Coding: 0301000100000F407F000000005900325C9200070C0000000100000000000000
       ASAM Dataset: EV_GatewCONTIAU736 002040
       ROD: EV_GatewCONTIAU736.rod
       VCID: 3668DA6889547C8C5E-8062
       Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
       Component: J453 MFL  H06 0002
       Serial number: 20141128141428 RD094
       Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
       Component: J367-BDMHella  H10 9041
       Serial number: 1031866303
    Address 28: HVAC, Rear (E265)       Labels: None
       Part No SW: 4M0 919 158 D    HW: 4M0 919 158 D
       Component: Klima Zone 2  H52 0051
       Coding: 000040000000000100820080000000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFondBHTCAU736 001012
       ROD: EV_AirCondiFondBHTCAU736.rod
       Component: MEM-FS        008 0014
       Serial number: 00000143640227
       ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
    Address 3C: Lane Change (J769)       Labels: None
       Part No SW: 4M0 907 566     HW: 4M0 907 566
       Component: MRR1Rear      H13 0140
       Revision: --------
       Coding: 1EE002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001015
       ROD: EV_RearRadarS1BoschAU736.rod
       VCID: 72E02678A5BC20ACB2-8026
       Part No SW: 4M0 959 793 C    HW: 4M0 959 793 C
       Component: TSG FS        009 0020
       Serial number: 0000141711036
       Coding: 001F9B0050000480000130B0
       ROD: EV_DCU2DriveSideMAXHCONT.rod
       VCID: 3E78C248A164B4CC86-806A
    Address 44: Steering Assist (J500)       Labels: None
       Part No SW: 4M0 909 144 E    HW: 4M0 909 144 B
       Component: EPS_MLBEVO1BS H17 0003
       Revision: --------    Serial number: 0000649758
       Coding: B0150101000101
       ASAM Dataset: EV_EPSVWBSAU736 006014
       ROD: EV_EPSVWBSAU736_AU49.rod
       VCID: 3162E974603A5BB40B-8064
       Part No SW: 4M0 959 792 C    HW: 4M0 959 792 C
       Component: TSG BFS       009 0020
       Serial number: 0000143699602
       Coding: 001F9B005C000480000130B0
       ROD: EV_DCU2PasseSideMAXHCONT.rod
       VCID: 3D7AC544AC62AFD49F-8068
       Part No SW: 4M0 035 021 B    HW: 4M0 035 021
       Component: MU-H-LND-EU   041 0358
       Serial number: A283C0FB000487
       Coding: 01370601FF0A000013111101000A00332F001BE5017001009E
       Shop #: WSC 23931 002 1048576
       VCID: 1E3822C801A4D4CCA6-804A
       Subsystem 1 - Part No SW: V03 959 802 CA    HW: -----------
       Component: ECE 2015  --- 0118
       Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
       Component: AU536_DU_HIGH  H43 0008
       Serial number: AUZ8Z9FJ4003H5
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4M0 919 615 D    HW: 4M0 919 615 D
       Component: ControlUnit_P  H14 0161
       Serial number: 23031500000000000026
       Component: Gracenote2  --- 1008
    Address 69: Trailer (J345)       Labels: None
       Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
       Component: Anhaenger     H18 0211
       Revision: 9A001002    Serial number: 0361756843
       Coding: 0110000202010000
       VCID: 336EE37C9A2669A479-8066
       Trailer Articulation Angle Sensor:
       Subsystem 1 - Part No SW: 4M0 907 811     HW: 4M0 907 811
       Component: G820 KNWINSEN  H18 0019
       Serial number: 2704
    Address 6C: Back-up Cam. (J772)       Labels: None
       Part No SW: 4M0 980 556     HW: 4M0 980 556
       Component: RVC Compact   H08 0130
       Coding: 0237060113002025000044
       ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 004008
       ROD: EV_CamSysRVRVCPANAMLBEv_AU49.rod
    Address 6D: Trunk Elect. (J605)       Labels: None
       Part No SW: 4M0 959 107     HW: 4M0 959 107
       Component: HDSG-Modul    H12 0142
       Revision: --------    Serial number: 29911353300000
       Coding: 00F0
       ASAM Dataset: EV_DeckLidCONTIAU736 001010
       VCID: 70E42C70ABB012BC44-8024
       Part No SW: 4M1 713 041 D    HW: 4M1 713 041 D
       Component: GSM-LL        H07 0066
       Revision: 0L0D5012    Serial number: 20150304000523
       ASAM Dataset: EV_GSMWaehlZFAU736 001013
       ROD: EV_GSMWaehlZFAU736_AU49.rod
       VCID: 26480A2859F40C0CEE-8072
    Address 8B: Adaptive Cruise 2 (J850)       Labels: None
       Part No SW: 4M0 907 541 C    HW: 4M0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU736 001016
       ROD: EV_ACC2BOSCHAU736_AU73.rod
       VCID: 2E58F2087104444C16-807A
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
       Part No SW: 4M0 907 217 B    HW: 4M0 907 217 A
       Component: BVS           H11 0023
       Coding: 0407030600000402032023A7CD0000B4B0F0C020C020
       ASAM Dataset: EV_BVSMLBevKOSTAAU736 002020
       ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
    Address AC: Reductant Control (J880)       Labels: None
       Part No SW: 4M0 907 355     HW: 4M0 907 355
       Component: SCR-Stg-G3H10 0003
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736.rod
       VCID: 6ED83208B184044C56-803A
    Address CB: Rear Axle Steering (J1019)       Labels: None
       Part No SW: 4M0 909 145 G    HW: 4M0 909 145 D
       Component: HAL_MLBevoH07 0607
       Revision: --------    Serial number: CCC_007_D_07_03
       Coding: 00852C
       ASAM Dataset: EV_RearAxleSteerZFAU736 005010
       ROD: EV_RearAxleSteerZFAU736_AU73.rod
       VCID: 346CE0609F286E9C60-8060
    End-------------------------(Elapsed Time: 06:49)--------------------------
    On display it have message Engine start error , yellow triangle and key icon. However car start and runs up to 3000rpm. Little confusing do.......and in 46 is key data stored , so there is 46 definitively. I will post HW number soon
  8. Likes Uwe liked this post
  9. #6
    Changed thread title to reflect 2016 model year (not 2015 as originally stated) and (brand new) 4M Chassis.
  10. #7
    Mar 2015
    Melbourne/Belgrade
    I will probably have car with me next week for whole one day. Is there something you may use from this car? Should I use full scan with all channels in all modules?
  11. Likes Uwe liked this post
  12. #8
    Mar 2015
    Melbourne/Belgrade
    I am waiting for answer please, should I use standard Controller Channel map or something different on this vehicle?
  13. #9
    Mar 2016
    I couldnt find module 46 on my Q7 (4M) using 15.7.4. Are we saying its there and accesible for coding under the Beta version?
    I need to find the link to download that and test with my Hex-Net interface!
  14. #10
    Mar 2015
    Melbourne/Belgrade
    No mate, I am saying car have 46 but VCDS can't see it (yet) , you can see auto-scan result above
