Thursday,31,March,2016,12:43:03:32785
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Chassis Type: 8W5
Scan: 01 02 03 08 09 15 16 17 18 19 2B 42 44 52 5F 69 6C 6D 81 82
A5 AC
Address 01: Engine
Address 02: Auto Trans (J217) Labels: None
Part No SW: 8W0 927 158 HW: 0D5 927 156 H
Component: 0D5 30TDIRdW H03 1004
Revision: --H03---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 7F3543A4E67D6DC607-802A
Part No SW: 8W0 907 379 J HW: 8W0 907 379 J
Component: ESP9 Plus H06 0579
Coding: 14AA309930A40A9655A248940085529266A5D2280C0C50AA12004A4966A54B
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ESP9BOSCHAU49X 011009
ROD: EV_ESP9BOSCHAU49X.rod
VCID: 4CAF2468E74B065ED2-8018
420352 - TPMS Warning; Front Left Tire
C1054 00 [032] - Pressure too Low
416768 - TPMS Warning; Front Right Tire
C1056 00 [032] - Pressure too Low
420096 - TPMS Warning; Rear Left Tire
C1058 00 [032] - Pressure too Low
417024 - TPMS Warning; Rear Right Tire
C105A 00 [032] - Pressure too Low
419584 - TPMS Warning; Rear Left Tire
C1059 00 [032] - Flat
Address 08: Auto HVAC (E87) Labels: None
Part No SW: 8W0 820 043 G HW: 8W0 820 043 G
Component: Klima Zone 3 H32 0050
Coding: 2618401C5544410D02000100800000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 37456B848ECD95868F-8062
Slave 1:
Subsystem 2 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000000650535
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 8W0 907 063 AG HW: 8W0 907 063 G
Component: BCM1 MLBevo H12 0228
Coding: 07501943C13900CD010D511858BF80F911031100000000000000000020001C810A450222025605
Shop #: WSC 06342 790 00001
ASAM Dataset: EV_BCM1BOSCHAU736 015005
ROD: N/A
VCID: 0037C0589B83123E7E-8054
Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A
Component: WWS491 150928 043 0813
Serial number: 894353?0401527100420
Coding: 5BC7F7
Component: G397_RLFS H06 0004
Serial number: 60936876
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 P HW: 4M0 941 531 P
Component: E1 - LDS H05 0007
Serial number: 20 07 2015 00054268
Subsystem 8 - Part No SW: 8W0 947 135 G HW: 8W0 947 135
Component: J528-Dachele H13 0080
Serial number: Q00019385
Subsystem 19 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H15 0010
Serial number: 2615000100796001
No ASAM data for: "EV_BCM1BOSCHAU736" ()
Address 15: Airbags (J234) Labels: None
Part No SW: 8W0 959 655 HW: 8W0 959 655
Component: Airbag10.44 H52 0084
Serial number: 003M6000JEN1
Coding: AECCF0C00C800000585400F3C04C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: N/A
VCID: 063BD640B9A73C0E44-8052
Subsystem 1 - Part No SW: ----------- HW: 442 062 910 15
Serial number: 3577Y00BD1A87822D4DJ
Subsystem 2 - Part No SW: ----------- HW: 442 062 910 15
Serial number: 3587Y009B1A87824141.
Subsystem 3 - Part No SW: ----------- HW: 442 0B1 010 15
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700C31D5E5B472FT
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 010 15
Serial number: 3527700A91D72E55A2AQ
Subsystem 5 - Part No SW: ----------- HW: 442 0C0 211 15
Component: FrontSensor_D 1C5 014A
Serial number: 3557500A51D92276112+
Subsystem 6 - Part No SW: ----------- HW: 442 0C0 211 15
Component: FrontSensor_P 1C5 014A
Serial number: 3567500A51D92270C37B
Subsystem 7 - Part No SW: ----------- HW: 442 0C0 311 15
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500C11D690F4B3EK
Subsystem 8 - Part No SW: ----------- HW: 442 430 211 15
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00BB1A537E2F28V
Subsystem 9 - Part No SW: ----------- HW: 442 430 211 15
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00BB1A537E3023D
No ASAM data for: "EV_AirbaAU10BPAAU736" ()
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4M0 907 129 HD HW: 4M0 907 129 HD
Component: Lenks.Modul H11 0008
ROD: EV_SMLSKLOAU736_AU49.rod
VCID: 79C1ADBCF85943F639-802C
Address 17: Instruments (J285) Labels: None
Part No SW: 8W5 920 790 B HW: 8W5 920 790 B
Component: FBenRDW H11 0267
Coding: 04A469D0288000080B23E9601000600000000000
ASAM Dataset: EV_DashBoardAU736 001020
ROD: N/A
VCID: 41B1055CD009DB3631-8014
No ASAM data for: "EV_DashBoardAU736" ()
Address 18: Aux. Heat (J364) Labels: None
Part No SW: 4M0 265 105 E HW: 4M0 265 105 E
Component: HSG H09 0060
Coding: 0D0F01
ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
ROD: EV_AuxilParkHeateEBEAU736_AU49.rod
VCID: 2961BDFC4879337609-807C
169986 - Fuel Level too Low
P1250 00 [008] - -
Reset counter: 117
Mileage: 7019 km
Date: 2016.03.28
Time: 21:55:49
Part No SW: 8W5 907 468 HW: 8W5 907 468
Component: Gateway H10 1078
Revision: 3Q030034 Serial number: 3483Q007515B12
Coding: 0301000100000F407F00000000590012C8100007100000000175070F00000000
ASAM Dataset: EV_CGateCONTIAU491 002040
ROD: EV_CGateCONTIAU491.rod
Subsystem 4 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20151103064301 RD076
Subsystem 5 - Part No SW: 8S0 915 181 HW: 8S0 915 181
Component: J367-BDMHella H10 9052
Serial number: 4075668303
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 15000096402006
Coding: 8800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 32535A9065AF70AEB8-8066
Part No SW: 8W0 959 593 A HW: 8W0 959 593
Component: TSG FS 005 0039
Serial number: 0000174404807
Coding: 001D8B214000000000001080
ROD: EV_DCU2DriveSideMAXHCONT.rod
VCID: 48A71878F333EA7EF6-801C
Address 44: Steering Assist (J500) Labels: None
Part No SW: 8W0 909 144 D HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0405
Coding: 09000080008000
ASAM Dataset: EV_EPSZFAU49X 002015
ROD: EV_EPSZFAU49X.rod
VCID: 3E4B7EA0A1F7A4CE4C-806A
Part No SW: 8W0 959 592 A HW: 8W0 959 592
Component: TSG BFS 005 0039
Serial number: 0000174219280
ROD: EV_DCU2PasseSideMAXHCONT.rod
VCID: 47A51B44FE2DE506FF-8012
Part No SW: 8W0 035 036 A HW: 8W0 035 036 A
Component: MU-P-LN-EU 050 0333
Serial number: A667K0F7504783
Coding: 01940201FF00000053110001000A00102F002365017001009E
ASAM Dataset: EV_MUHig4CGen2HBAS 001115
ROD: N/A
VCID: 3151559C60A94BB6C1-8064
Subsystem 2 - Part No SW: ----------- HW: -----------
Component: ------------- --- ----
Subsystem 3 - Part No SW: ----------- HW: -----------
Subsystem 4 - Part No SW: V03 959 801 FA HW: -----------
Component: ECE 2016 --- 0134
Subsystem 7 - Part No SW: 8W0 919 605 HW: 8W0 919 605
Component: AU49x_DU_HIGH H40 0008
Serial number: AUZ8Z9FBJ00CVP
Subsystem 8 - Part No SW: ----------- HW: -----------
Subsystem 9 - Part No SW: ----------- HW: -----------
Subsystem 12 - Part No SW: ----------- HW: -----------
Subsystem 13 - Part No SW: 8W0 919 614 P HW: 8W0 919 614 P
Component: ControlUnit_H H22 0139
Serial number: C1000004101500050174
Subsystem 14 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1011
No ASAM data for: "EV_MUHig4CGen2HBAS" ()
7223 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 96
Mileage: 3913 km
Date: 2016.02.10
Time: 18:14:13
Address 69: Trailer (J345) Labels: None
Part No SW: 4M0 907 383 D HW: 4M0 907 383 B
Component: Anhaenger H20 0211
Revision: 9A001003 Serial number: 0385464223
Coding: 0110000202000000
ROD: EV_TrailFunctGener2Hella_AU37.rod
VCID: 335D5F949AB579A6B3-8066
Address 6C: Back-up Cam. (J772) Labels: None
Part No SW: 4M0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0130
Coding: 0294020103002005000040
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 004008
ROD: EV_CamSysRVRVCPANAMLBEv_AU49.rod
VCID: 72D39A90A52F30AE78-8026
Address 6D: Trunk Elect. (J605) Labels: None
Part No SW: 4M0 959 107 HW: 4M0 959 107
Component: HDSG-Modul H12 0143
Revision: -------- Serial number: 30319394900000
Coding: 05D0
ASAM Dataset: EV_DeckLidCONTIAU736 001010
ROD: EV_DeckLidCONTIAU736_AU49.rod
VCID: 70D79098AB2302BE8E-8024
Address 81: Gear Shift (J587) Labels: None
Part No SW: 8W1 713 041 D HW: 4M1 713 041 D
Component: GSM-LL H07 0068
Revision: 0L0D5012 Serial number: 20151017002122
ASAM Dataset: EV_GSMWaehlZFAU736 001013
ROD: N/A
VCID: 345F5C889FBB7E9EAA-8060
No ASAM data for: "EV_GSMWaehlZFAU736" ()
Address 82: Heads Up Display (J898) Labels: None
Part No SW: 8W5 919 617 HW: 8W5 919 617
Component: HeadUpDisplay H15 1524
Coding: 2B00C0
ASAM Dataset: EV_HudNSEIKAU736 001012
ROD: EV_HudNSEIKAU736.rod
VCID: 0539D14C84A137164D-8050
Address A5: Frt Sens. Drv. Assist (R242) Labels: None
Part No SW: 8W0 907 217 A HW: 8W0 907 217
Component: BVS H13 0030
Coding: 0404090200000401022023A1A50000FC10F0C020C280
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
ROD: N/A
VCID: 3A4372B0BDDF88EE70-806E
No ASAM data for: "EV_BVSMLBevKOSTAAU736" ()
1123671 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 85
Mileage: 2442 km
Date: 2016.01.11
Time: 18:02:43
1123600 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 112
Mileage: 5859 km
Date: 2016.03.14
Time: 08:19:35
1123601 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 113
Mileage: 3300 km
Date: 2016.01.27
Time: 13:09:01
Address AC: Reductant Control (J880) Labels: None
Part No SW: 4M0 907 355 HW: 4M0 907 355
Component: SCR-Stg-G3H10 0003
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736.rod
VCID: 6EEB8EE0B117144E9C-803A
End-------------------------(Elapsed Time: 06:38)--------------------------
