Results 1 to 5 of 5
Thread: Auto Scan Testing: 2007 RS4
    Post Auto Scan Testing: 2007 RS4
    I bought a Hex Net device and finally got my car back from the dealer today to run a scan. Running Windows 7 with IE 9 (can't update IE, can try with Chrome next time). Wireless Infrastructure mode, connected to my iPhone. Autoscan hung on 0F. I tried to update and the update process crashed, I will try again tomorrow connecting to my home wifi as opposed to my phone.
    Chassis Type:8E
    Scan:
    	 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    	 69 75 76 77
    VIN: WUARU78E27N900712
    Address 01: Engine	Labels:079-910-560-BNS1.lbl
    	Part Number SW: 8E1-910-560-A	HW: 8E1907560
    	Component: 4.2L V8/4V FSI     0060
    	Revision: --H09---	Serial Number: XXXXXXXXXXXXXX
    	Coding: 01040009180F0160
    	Shop #: WSC 08307 444 91149
    	VCID: 240B7F93B5EBEFF4216A8FA-8071
    000547 - Angle Sensor 2 for Throttle (G188)
    	P0223 - 001 - Signal Too High - Intermittent
    000289 - Throttle Position Sensor (G69)
    	P0121 - 008 - Implausible Signal - Intermittent
    Address 03: ABS Brakes	Labels:8E0-910-517.lbl
    	Part Number SW: 8E0-910-517-G	HW: 8E0614517BD
    	Component: ESP8 quattro    H06  0150
    	Revision: 00000000	Serial Number: 00000000000000
    	Coding: 0004533
    	Shop #: WSC 06335 000 00000
    	VCID: 2B1994AFD835208CE0B0DCE-807E
    18265 - Load Signal
    	P1857 - 000 - Error Message from ECU - Intermittent
    Address 09: Cent. Elect.	Labels:8E0-907-279-8EC.lbl
    	Part Number SW: 8E0-907-279-N
    	Component: int. Lastmodul  USA 0907
    	Coding: 01023
    	VCID: 3D3DAAF73641AF3C4E64A26-4B3C
    No fault codes found.
    I downloaded the 14.5.2 App and was able to complete a scan
    Wednesday,21,May,2014,22:01:34:08204
    VCDS Version: 14.5.2.0
    Data version: 20140520
    VIN: WUARU78E27N900712   License Plate:
    Mileage: 71430km-44384mi   Repair Order:
              67 69 75 76 77
    VIN: WUARU78E27N900712   Mileage: 71430km-44384miles
    Address 01: Engine        Labels: 079-910-560-BNS1.lbl
       Part No SW: 8E1 910 560 A    HW: 8E1 907 560
       Revision: --H09---    Serial number: XXXXXXXXXXXXXX
       VCID: 24042BE3E7FBF31BFF-8071
                        Fault Status: 00100001
                        Mileage: 71332 km
                        RPM: 2043 /min
                        Load: 22.7 %
                        Speed: 27.0 km/h
                        Temperature: 96.0C
                        Temperature: 30.0C
                        Absolute Pres.: 1020.0 mbar
                        Voltage: 13.335 V
                        Mileage: 71340 km
                        RPM: 3370 /min
                        Load: 16.9 %
                        Speed: 53.0 km/h
                        Temperature: 96.0C
                        Temperature: 30.0C
                        Voltage: 12.192 V
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 G    HW: 8E0 614 517 BD
       Coding: 0004533
       VCID: 2B16C0DF8A253C633E-807E
                        Fault Status: 00101101
                        Fault Frequency: 12
                        Reset counter: 36
                        Hex Value: 0x0000
                        Hex Value: 0x4002
                        Hex Value: 0x0025
                        Hex Value: 0x0194
                        Hex Value: 0x0001
    18265 - Load Signal
                        Reset counter: 35
                        Hex Value: 0x3600
                        Hex Value: 0x6206
                        Hex Value: 0x0028
                        Hex Value: 0x01A5
                        Hex Value: 0x0001
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 N
       Coding: 01023
       Shop #: WSC 06335
       VCID: 3D32FE873551A2D390-4B3C
       Part No SW: 8E0 035 593 F    HW:
       Component: SDAR SIRIUS
       Revision:             Serial number: AUZ4Z7F2027350
       VCID: 2C14C3C38D2B3B5B37-51A8
    Address 11: Engine II        Labels: 079-910-560-BNS2.lbl
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
       Component:    Airbag 9.41  H12 3840
       Revision: 91H12384    Serial number: 0036N001XUU/
       Coding: 0432607
       VCID: 3C34F3837F4BABDBA7-8069
       Subsystem 1 - Part No: 8E0 910 339 B
       Component: BF-Gewichtsens. 002 0070
       Subsystem 2 - Serial number: 3BVDF
       Subsystem 3 - Serial number: 0001.01.000000200000000000†63
       Subsystem 4 - Serial number: 000000†6332DRB4032DC891V†63
       Subsystem 5 - Serial number: DC891V†6342DRB4035107B1C†63
       Subsystem 6 - Serial number: 107B1C†6352ARB4014663CFT†63
       Subsystem 7 - Serial number: 663CFT†6362ARB401423629A†63
       Subsystem 8 - Serial number: 23629A†63729RB40149B10DM†63
       Subsystem 9 - Serial number: 9B10DM†63829RB40149B5F1U
       Subsystem 10 - Serial number: 9B5F1U
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 981 S    HW: 8E0 920 981 S
       Component: KOMBI+WFS 4     H14 0040
       Revision: 0040        Serial number: 00000000000000
       Coding: 0023261
       VCID: 3D32FE876551A2D390-5184
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0305
       Coding: 00002
       VCID: 71AA12B73A8916B344-4B3C
       Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
       Component: AFS 1           H01 0010
       Coding: 0000019
       VCID: 281C3FD39BD3177BD3-807D
       Subsystem 1 - Part No: 8E0 941 329
       Component: AFS-Modul links H03 0020
       Subsystem 2 - Part No: 8E0 941 329
       Component: AFS-Modul rechtsH03 0020
    Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
       Part No SW: 8E0 035 192 J    HW: 8E0 035 192 J
       Component: RNS-E US3       H72 0110
       Revision:      03S    Serial number: AUZBZ7F2446940
       Coding: 0309637
       Shop #: WSC 08353 444 57634
       VCID: 2B16C0DF88253C633E-51A8
                        Reset counter: 71
                        Date: 2005.08.26
                        Time: 00:00:30
                        Voltage: 11.90 V
                        Mileage: 655350 km
                        Count: 65535
                        Clock: 255:255
                        Reset counter: 31
                        Date: 2011.06.12
                        Time: 12:00:13
                        Mileage: 655350 km
                        Count: 2105
                        Clock: 21:36
    Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
       Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
       Component: Reifendruck 3   H04 0130
       Coding: 0062523
       VCID: 2A18C5DB87DF256BC5-5184
       Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
       Component: FSE_255x BT     H21 0290
       Revision: 00000001    Serial number: 00000000456536
       Coding: 0011877
    End-------------------------(Elapsed Time: 07:18)--------------------------
    - Chris
  2. Likes Uwe liked this post
  3. #2
    What happens when you go to 0F directly in VCDS-Mobile?
    I updated the Hex Net successfully when connected to my home wifi and then directly accessed 0F and received this message:
    The message would then disappear and the fields on the page were blank.
    - Chris
    Please do the following in VCDS-Mobile: [Options] -> Put 001f in the Debug Level field, click [Submit]. Then [Done, Go Back], [Select], [0F - Digital Radio]. I would expect it to fail in the manner above. Exit the module. Go to [View Saved Files]. There should be a new file at the bottom of the list named 'debuglog.edl'. Synch it to the Cloud and post the docid here.
    Note: Shaun is out today (his sister is getting married this weekend) and won't be able to look at it and work whatever is causing this until next week.
    File is uploaded and docid is: 000003E4
  7. Likes Uwe liked this post
