Results 1 to 10 of 16
Thread: Eurovan 2000
    Apr 2015
    Eurovan 2000
    VCDS Version: Release 15.7.4 Running on Windows XP x86
    Data version: 20160216
    Friday,25,March,2016,17:20:21:26691
    Chassis Type: 7D - VW Transporter/Multivan (1996 > 2004)
    Scan: 01 02 03 08 15 17 18 19 22 25 35 37 56
       Mileage: 208530km-129574miles
    Address 01: Engine        Labels: 021-906-259-AES.lbl
       Part No: 021 906 259 P
       Component: MOTRONIC M5.9    AT V03
       Coding: 00001
       VCID: 224B9B9FAEA7B22E48-4AE8
    11 Faults Found:
    18021 - MIL Control Circuit
                P1613 - 35-10 - Open or Short to Plus - Intermittent
    00577 - Knock Sensor Regulation Cylinder 1
                08-10 - Control Limit Surpassed - Intermittent
    00579 - Knock Sensor Regulation Cylinder 3
    00524 - Knock Sensor 1 (G61)
    00581 - Knock Sensor Regulation Cylinder 5
                P0300 - 35-00 -
    16685 - Cylinder 1
                P0301 - 35-00 - Misfire Detected
    16690 - Cylinder 6
                P0306 - 35-00 - Misfire Detected
                P0300 - 35-00 -
    16685 - Cylinder 1
    16690 - Cylinder 6
    Address 02: Auto Trans        Labels: 01P-927-733.lbl
       Part No: 01P 927 733 BC
       Component: AG4 Getriebe 01P    4478
       Coding: 00000
       VCID: 75E190C34FA975965D-095E
    Address 03: ABS Brakes        Labels: 8E0-614-111-EDS.lbl
       Part No: 7D0 614 111 B
       Component: ABS/EDS 5.3         D00
       Shop #: BB 24258
       VCID: 1B35A67B89CD83E68B-5124
    Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
       Part No: 1J0 909 603 AJ
       Component: AIRBAG VW3 -        V04
       Coding: 16714
       Shop #: WSC 02743
       VCID: 71E9A4D33BC159B681-4B00
                32-10 - Resistance Too High - Intermittent
    00589 - Airbag Igniter 1; Passenger Side (N131)
    00532 - Supply Voltage B+
    Address 17: Instruments        Labels: 7D0-920-xxx-17.lbl
       Part No: 7D0 920 901 E
       Component: T4-KOMBIINSTR. VDO V01
       Coding: 03261
       VCID: 25418083BF8945162D-5140
    End-------------------------(Elapsed Time: 03:19)--------------------------
    Here goes, I have two vw's at the moment with drive-ability issues. My ATQ passat snapped it's TB three weeks ago and I just got it back on the road with a used engine and the CEL came on during my road test. This post is about my wife's 2000 Eurovan which has been running like a champ until last Tuesday. My car was down and we were ride sharing when the CEL came on.
    Less than two years ago (last Spring) I had to pass CT emissions and used the vag-com to troubleshoot all the SAIP and vacuum issues to get it through which it did after replacing the SAIP, the EGR valve, the issue ended up being the kombi valve itself which no amount of cleaning could get to move the plunger. I also replaced all the spark plugs at that time. All was good until last fall (4 months ago) when it developed a heater core leak, so I put in a new heater core and afterwards the airbag indicator came on, I double checked both airbags and they were attached so I closed it up and drove it. Fast forward four months to last Tuesday and we're driving on a secondary road and I felt the engine shudder followed briefly by a CEL, but it went away. About 30secs later we're at a stop light and the engine begins shuddering again and the CEL comes on steady. I turned around and headed home, basically limped the mile distance home because attempting to accelerate would cause the light to blink and it wasn't a violent shaking, just an uncomfortable shuddering like it was out of sync.
    Hooked up my vag-com and it wasn't reading, getting "questionable" and "short to ground". I had lent this vag-com to a friend from work in the last two years so that he could "fix" his heavily modified A4. I suspect now, something happened it to then, since he said "it worked and then it didn't".
    With no vag-com, I took the pass airbag out to check it's connection, I checked the connections under the trans hump and checked voltage at #4 & #7 per the aftermarket radio airbag warning light document, the voltage is 10.5v but I have yet to get a 1k resistor to verify it. I do have an aftermarket radio, but I installed it eight years ago. When I got my passat back together I tested the vag-com on it and got the same error-so yesterday I upgraded to the HEX+CAN unit.
    Above is the first scan from the EV.
    At the moment I have the radio out, the climtronic unit is detached as well (access to pass airbag).
    I'm walking (literally) out to Good Friday services, I certainly don't expect any responses tonight, but I'll check later and again tomorrow and will hang on anything that's offered. Thanks...
  2. Likes Uwe liked this post
  3. #2
    Looks like a bad coil pack ............beware of the China ones
    We have them if needed in real Beru.......
    Apr 2015
    I think you're right! I pulled the spark plug cable off #6 while it was running and got nothing; checked #2 the same way and got something through me to ground. Traced and cleaned all the airbag connections. Thinking these were actually residual from when I had the dash apart for the heater core repair. Cleared all the codes and ran the engine for about 2 minutes and the CEL came back and the codes were only three(3) cyl#1, cyl#6, and random misfires.
    I have a place in the next town that I usually buy from for convenience. They have a Hueco on sale for $146.
    If you can get Beru I would...........buy the coil only and save money not buying the power stage because it is removable to be reusable.
    Hueco is now China.........
    Apr 2015
    I appreciate that you're a supporter of this site and the only respondent to my OP. I will probably pick up the Hueco locally unless I can find a used oem coil pack for significantly less. I found a Beru from GAP and it's $198, a little steep for me. The chinese stuff is love/hate right, love the price/hate the risk of premature failure. The van is 15 yrs old, I don't need a CP to last another 15 yrs, yet I've read that the chinese cp's are the ones that get replaced annually too.
    The 2000 eurovan is a 12v vr6, do you know if all the 12v vr6 coil packs are interchangeable? When I called junk yards on Friday I asked for a eurovan CP, maybe if I ask for a Golf CP they'll have them.
    VR6 coil packs with switch are not in most cases interchangeable.
    Wanna try something and save some coins?
    Take the coil out and separate it from power stage ........further remove the metal bridge.
    Wash and clean coil with alcohol and dry with compressed air.
    Bake in oven at 175 degrees F on cookie sheet and aluminum foil for 30 minutes then cool for 1 hour ambient.
    After cooled take RTV silicone........... and coat the entire secondary side by connectors where cracks are and suspect leaks in back.
    Let dry over night to cure.
    Reassemble the coil and under cover where the 8MM nuts are for the power stage coat further with RTV ........let dry then install the unit go drive it.
    Clean the wire end booty's and further Rub RTV on all the wire ends of the coil area externally and let them dry before assembly or plugging in.
    Use a good contact cleaner and fine brush to clean the high tension connectors on the wires internally and coil outputs.
  9. Likes Uwe liked this post
  10. #8
    Apr 2015
    Interesting, I've read about the JB Weld fix for VR6 Coil Packs that were arcíng externally through cracks in the plastic shell. I figured my CP had failed internally in that, the coil that is shared between #1 & #6 is not firing. I'll try your suggestion tonight. I prefer repairing to replacing anyhow.
  11. #9
    Worth a shot I think........
    When getting down ghetto style ...........I have even sawed the units to segregate them internally, with a RTV cushion; and further grab good used coils and reinstall them in the housing if dead.
    This is a waste spark system and dumb.........The power stage is required for the ECU though......specific tolerances for the switch.
    You can take individual high tension early round coils, and make a six hole bracket to wire them direct to the power stage.
    It is a hell of an enhancement, and the early round stuff is rugged which never fail.
    Same can be done with early square block coils too.
    I do this on race cars, and even DFI coils that are just too small.
    You would be surprised what you can do with one mans garbage.........to crank up the dwell.
  12. #10
    Apr 2015
    no change--put it all together this morning and same three codes: cyl#1, cyl#6, and random
  13. Likes Uwe, NZDubNurd liked this post
