Welcome home - Fog light - Octavia 2011
killep2
C?ID=214777
Hello guys.
I tried a lot of coding but never success to do it on the best side.
I am looking how to configure welcome home / Leaving home on my Octavia. A5FL.
Somehow I success to configure the parking light to be on for few second after I am locking the car but that's all.
Can some one help me code this ?
Thanks !
Wednesday,21,May,2014,19:41:40:40508
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
Dealer/Shop Name: Big-Byte
VIN: TMBBK61Z7B8022701   License Plate:
Gateway Installation List:  7N0 907 530
Wednesday,21,May,2014,19:45:17:40508
Chassis Type: 1Z (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
Address 01: Engine (CDA)       Labels: 06J-907-115-CDA.clb
   Part No SW: 3T0 907 115 G    HW: 1Z0 907 115 F
   Component: 1.8l R4/4V TFSI     0030
   Revision: AAH18---    Serial number:
   Coding: 0203000C24070060
   Shop #: WSC 64888 768 16448
   VCID: 356136445CDF4AB6781-8060
001089 - EVAP Emission Control Sys
               P0441 - 000 - Incorrect Flow - Intermittent
                    Mileage: 65327 km
                    Date: 2001.14.20
                    Time: 02:01:32
                    RPM: 835 /min
                    Load: 23.5 %
                    Temperature: 98.0°C
                    Temperature: 54.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.462 V
001674 - ECM Power Relay Load Circuit: (J271)
               P068A - 000 - De-Energized Performance Too Early - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 96.0°C
                    Temperature: 60.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 9.144 V
Address 02: Auto Trans        Labels: 0AM-300-04x.lbl
   Part No SW: 0AM 300 050 E    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2673
   Revision: 00043014    Serial number: CU501307285442
   Shop #: WSC 00029 730 29360
   VCID: 2B55103C8A9B0C461E5-807E
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 113B401C092400FC881202E4901A0041350800
   Shop #: WSC 73430 790 00000
   VCID: 76E3F148C15901AEB1B-8023
   Part No SW: 3T0 907 044 AR    HW: 3T0 907 044 AR
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000002
   Shop #: WSC 73430 790 00999
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 820B1D981591AD0E0D3-80D7
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 40180AB8802100C0000A00800000810042E131EE505D89205C0448800040
   VCID: 387F3F708BCDB7DE637-806D
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 18101  26  0601
   Coding: 00DFB7
01134 - Alarm Horn (H12)
                    Reset counter: 195
                    Mileage: 65570 km
                    Date: 2001.14.24
                    Time: 22:11:23
                    Voltage: 11.95 V
                        Term 50 Off
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC212XEE
   Coding: 0020790
   VCID: 3D712E6464EF92F6B01-8068
   Subsystem 1 - Serial number: 6332MSME583233702
   Subsystem 2 - Serial number: 6342MSME583233679
   Subsystem 3 - Serial number: 6351HSME24654321.
   Subsystem 4 - Serial number: 6361HSME24635D078
   Part No SW: 5K0 953 521 AR    HW: 5K0 953 569 A
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101008301625
   Coding: 1882000000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7CF7E360F7755BFEC7F-8029
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 800000
   Part No SW: 1Z0 920 843 K    HW: 1Z0 920 843 K
   Component: KOMBI         H20 0420
   Coding: 110901
   Shop #: WSC 73430 031 12345
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 408F5790DB1DFF1EDB7-8015
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 161010F2002537
   Coding: ED807F0600020200001302
   VCID: EDD15E24F40F4276C01-80B8
   Component: IMMO          H20 0420
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EADB55380DE1554EA53-80BF
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Coding: 0004342
   VCID: 76E3F148015901AEB1B-8023
   Part No: 1K0 909 144 J
   Revision: 00H17000
   VCID: 31690254A8B76696249-8064
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0004342
   VCID: 489F4FB03B2DC75E137-801D
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 161 F    HW: 1Z0 035 161 F
   Component: SWING         009 0065
   Revision: 0I001001    Serial number: SKZ1Z2K8411072
   Coding: 050004000004
   VCID: 3169025468B76696249-8064
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 326B0D58ADB15D8E5D3-8067
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 3365085C52AB5486565-8066
killep2
C?ID=214777
Thank you!
The issue can be considered as resolved :)
