Results 1 to 10 of 15
Thread: Adaptation Channel map - optimization
    Mar 2014
    Slovenia
    Is there a way in VCDS to get adaptation channel maps of all modules in the car with just one command/action?
    Currently we have to manually trigger (through ad. channel map command) mapping of every module separately, which can be really time consuming with some newer cars, because some ad. channel maps could take nearly half an hour.
    It would be great if you could just start ad. channel mapping of all channels and come back an hour later to find it has been done.
    Just a suggestion, if this has not been yet implemented.
    If you really want maps of ALL the modules, temporarily rename the Labels sub-folder so VCDS can't find it, set the Debug Level to 2 on the Options screen, and then run an Auto-Scan.
    Be sure to use a battery charger, and beware: This may take considerably longer than an hour on some newer cars at present.
  3. Likes icardiag, mtl liked this post
    Mar 2014
    Europe
    This is great, it saves a lot of time sitting in the car and going through modules one by one and wait a dozen of minutes between each module
    You're going to post those scans and maps in the Reference Section of the forum, right?
    Verified VCDS User andyvee's Avatar
    Rossendale, Lancashire, UK
    Will this work on MQB cars Uwe?
    I take it you can't specify security logins per module doing it this way?
    I can't think of any reason why it wouldn't work on an MQB.
    No, you cannot specify security access codes.
    Mar 2014
    Europe
    I used to send complete scans especially with new models to RT by email, but as I never ever received a simple "thanks" or "whatever" response, I stopped sending the scans in :-(
  9. #8
    Jun 2015
    Italy
    You can consider creating a new option like a "Full Controller Channel Map " and rename the existing at "Single Controller Channel Map" ?? and then in LOGS directory if it's possible to add a sub-directory for every single scan ?? for to avoid confusion for those who scans many cars !!!
  10. Likes mtl liked this post
  11. #9
    Mar 2014
    Slovenia
    I haven't yet posted the scans in that part of the forum (since the cars are not mine), but I do send data of ALL new, unrecognized modules to you guys .
    Quote Originally Posted by Ciamardo View Post
    That would be just perfect.
  12. Likes Uwe liked this post
  13. #10
    Mar 2014
    Slovenia
    I did a few tests.
    It worked on older platform (Superb 2, though you get plb and pla files which are not so ''user friendly'') but not on a MQB car - the new Touran .
    Did I miss something?
