Results 1 to 4 of 4
Thread: Audi A3 8L 1.8T poor driveability, hesitation
    Lithuania
    The problem is that sometimes car starts to hesitate and won't accept accelerator pressed. Looks like one or two cylinders stops working.
    Owner said that some time ago MAF was replaced with genuine Bosch.
    I drove myself car today and it runs great. I was unable to reproduce that problems. Owner says that this problem occurs especially in rainy days when humidity is high. Fuel consumption is normal, idle is steady.
    I erased all the errors and these did not come back.
    Can be faulty wiring ? Insulation ?
    VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64
    Data version: 20160216
    Sunday,20,March,2016,19:13:57:48017
    Chassis Type: 8L - Audi A3/S3 (1997 > 2003)
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
       Mileage: 197890km-122963miles
    Address 01: Engine        Labels: 06A-906-018-AGU.lbl
       Part No: 06A 906 018 AQ
       Component: 1.8L R4/5VT MOTR HS D03
       Coding: 04000
       Shop #: WSC 06435
       VCID: 71E902383B128BB681-4B04
                P1602 - 35-10 - Voltage too Low - Intermittent
    00561 - Mixture Adaptation
                14-10 - Adaptation Limit (Add) Exceeded - Intermittent
    17978 - Engine Start Blocked by Immobilizer
                P1570 - 35-10 -  - Intermittent
    16514 - Oxygen (Lambda) Sensor B1 S1
                P0130 - 35-10 - Malfunction in Circuit - Intermittent
    Readiness: N/A
    Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
       Part No: 1J0 907 379 H
       Component: ABS/EDS 20 IE CAN  0001
       Coding: 13504
       Shop #: WSC 06435
       VCID: 3663F12412FCEC8E94-4B04
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
                35-10 -  -  - Intermittent
    Address 08: Auto HVAC        Labels: 8L0-820-043-2D.lbl
       Part No: 8L0 820 043 D
       Component: A3 KLIMAVOLLAUTOMAT_D75
       Coding: 03140
       Shop #: WSC 06435
       VCID: 29592A58D342B37609-25A0
    00785 - Temp Sensor in Instrument Panel (G56)
                30-00 - Open or Short to Plus
    01272 - Positioning Motor for Central Flap (V70)
                41-10 - Blocked or No Voltage - Intermittent
    00792 - A/C Pressure Switch (F129)
    Address 15: Airbags        Labels: 8L0-959-655-AI7.lbl
       Part No: 8L0 959 655 F
       Component: Airbag 7 Audi      0505
       Coding: 00104
       Shop #: WSC 06435
       VCID: 418992F84B325B3631-5140
    Address 17: Instruments        Labels: 8L0-919-xxx-17.lbl
       Part No: 8L0 919 880 E
       Component: AB-KOMBIINSTR. VDO D07
       Coding: 04042
       VCID: 3C77E30C2CD036DE62-5122
       Subsystem 1 - Part No: IMMO
       Component: IDENTNR: AUZ7Z0W0472282
       IMMO-IDENTNR: AUZ7Z0W0472282
    00771 - Fuel Level Sensor (G)
    Address 35: Centr. Locks        Labels: 8D0-862-257.lbl
       Part No: 8L0 862 257 G
       Component: ZV-Pumpe, DWA, Funk D06
       Coding: 13130
       Shop #: WSC 06313
       VCID: 3979FA1823E203F679-4F06
    01370 - Alarm triggered by Interior Monitoring
                35-00 -  -
    01368 - Alarm triggered by Luggage Compartment Switch
                35-00 -  -
    01366 - Opened Due to Crash Signal
                35-00 -  -
    00956 - Key 2
                09-00 - Adaptation Limit Surpassed
    Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
       Part No: 8L0 951 173
       Component: Innenraumueberw.    D04
       Coding: 00001
       Shop #: WSC 06435
       VCID: 6ED319442A2C944E9C-4B1C
    01377 - Ultra Sonic Sensor for Alarm System; Left (G170)
                27-00 - Implausible Signal
    01380 - Alarm triggered by Anti-Theft Sensor; Rear Left
                35-00 -  -
    01383 - Alarm triggered by Anti-Theft Sensor; Front Right
                35-00 -  -
    End-------------------------(Elapsed Time: 03:40)--------------------------
    OXS oxygen sensor heater circuits are faulty with sporadic short, and will if not already, damage the ecu if not fused or replaced immediately!
  3. Likes Sheepwolf liked this post
    Lithuania
    Will check that aswell. As I imagine wires near sensor might be damaged/kinked and driving on wet surface brings water on sensor what causes shorts and impact ECU work.
    Thanks Jack.
    I think the fact it went dead POTS on the TV it would be a good idea to unplug them immediately because it doesn't take long to smoke up an ecu.
    If you find you need a set of sensors with an ecu, we have you covered so please let us know.
