Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: long code for abs golf mk vii gti
    Mar 2016
    UAE
    I would try this:
    01FA6BA1342009700078020681C32980D62C9000408194B400430050C009
    NEtech i tried this code it accepted but it wont let me do the adaption for steering angle sensor ? any thoughs on this so now i have 2 warning lights remaining the traction and steering
    thanks guys
  2. #12
    Mar 2016
    UAE
    those are the faults i get now once i am going to do the calibration for steering angle sensor it just keeps says running not stopped or anything that seems strange to me
    Thursday,31,March,2016,18:26:31:05701
    VCDS Version: Release 15.7.4 (x64) Running on Windows 8.1 x64
    euro
    Address 03: ABS Brakes Labels: 5Q0-907-379-ESP-V1.clb
    Control Module Part Number: 5Q0 907 379 K HW: 5Q0 907 379 F
    Component and/or Version: ESC H31 0371
    Software Coding: 01FA6BA1342009700078020681C32980D62C9000408194B400 430050C009
    Work Shop Code: WSC 01383 790 50316
    ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001 (VW37)
    ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
    VCID: 44875252CF8D9A1E1A-8010
    0295 - Steering angle sensor
    Reset counter: 78
    Date: 2016.03.31
    Time: 18:05:22
    8277 - Databus
    U1122 00 [009] - Implausible Message
    Reset counter: 78
    Date: 2016.03.31
    Time: 18:05:22
    Reset counter: 78
    Mileage: 13884 km
    Date: 2016.03.31
    Time: 18:05:31
  3. #13
    Quote Originally Posted by euro1 View Post
    thanks guys
    euro1: I doubt that there is anyone more knowledgeable than NEtech when it comes to there's matters (certainly not me), but the problem may be the security code that you are using to access the steering angle sensor. My understanding is that there is a different SA for different bunches of adaptation channels in the ABS. Here's a list of the SAs that I'm aware-of for you to try
    25004
    11966
    15081
    18573
    20103
    24435
    25004
    28183
    31857
    37202
    40168
    44595
    10505
    But remember that if the SA code is not accepted, you might need to wait a while (with the ignition switched-on) before you will be allowed to re-enter another SA
  5. #14
    How does the Autoscan look like, do you still have several U112x DTC ?
    If so I would search for that.
  6. Likes Jack@European_Parts liked this post
  7. #15
    Jul 2014
    Poland
    Did your car accepted my code??? I just want to know for my knowledge.
  8. Likes Jack@European_Parts liked this post
  9. #16
    Mar 2016
    UAE
    no i will post a full autoscan again
    automech i havent tried your code
    thanks guys
  10. #17
    Mar 2016
    UAE
    scan
    this is my latest scan pls have a look
    Tuesday,12,April,2016,17:26:52:05701
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    Dealer/Shop Name: euro
    VIN: 3VW4T7AUXFM004160   License Plate: HA
    Mileage: 15542km-9657mi   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
    VIN: 3VW4T7AUXFM004160   Mileage: 15542km-9657miles
    Address 01: Engine (J623-CNTA)       Labels: 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0004
       Revision: --H13---
       Coding: 091D00124424000F0000
       Shop #: WSC 00066 790 00202
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
       ROD: EV_ECM20TFS0205G0906259A_VW37.rod
       VCID: 2C571AF2471D725EF2-8078
    17178 - Databus
              U1123 00 [047] - Received Error Message
                        Mileage: 12645 km
                        Date: 2016.03.22
                        Time: 19:04:17
       Part No SW: 0D9 300 040 S    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H52 4310
       Revision: 05852204    Serial number: TFK01403011556
       Shop #: WSC 00066 790 07031
       ROD: EV_TCMDQ250021_AU37.rod
       VCID: 275DE5DE5EFB51061F-8072
              P1734 00 [002] - -
       Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
       Component: ESC           H31 0371
       Revision: 00000000    Serial number: 51744000001209
       Coding: 01FA6BA1342009700078020681C32980D62C9000408194B400430050C009
       Shop #: WSC 01383 790 50316
                        Reset counter: 78
                        Date: 2016.03.31
                        Time: 18:05:22
    8277 - Databus
                        Reset counter: 78
                        Date: 2016.03.31
                        Time: 18:05:22
                        Reset counter: 78
                        Mileage: 13884 km
                        Date: 2016.03.31
                        Time: 18:05:31
    Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
       Part No SW: 5G0 907 426 N    HW: 5G0 907 426 N
       Component: AC Manuell    H01 0705
       Revision: 00001K06
       Coding: 00020004200100000000000000000000
       ROD: EV_ACManueBHBVW37X_SE37.rod
       VCID: 3663389A8951388E94-8062
       Part No SW: 5Q0 937 087 K    HW: 5Q0 937 087 K
       Component: BCM PQ37BOSCH 026 0097
       Revision: --------    Serial number: 86580704141031
       Coding: 000018464041804969E44000001407201000000000000000000000000000
       ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 4385514ECA839D2623-8016
       Slave 1:
       Component: WWS    140224  043 0581
       Serial number:         140422135735
                        Fault Frequency: 44
                        Reset counter: 148
                        Mileage: 12645 km
                        Date: 2016.03.22
                        Time: 19:13:56
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM004CLF
       VCID: 51A96B0600FF7FB6A1-8004
       Seat occupant detection; front passenger side:
       Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
       Component: BF-Gewichtss.  005 0016
       Serial number: IBH0000J140000MXMZ0A
       Coding: 30325A
       Subsystem 2 - Part No SW: -----------    HW: 480 002 901 14
       Serial number: 3570000000087028BE0M
       Subsystem 3 - Part No SW: -----------    HW: 480 003 101 14
       Serial number: 35800000000B503D9E0S
       Subsystem 4 - Part No SW: -----------    HW: 480 400 302 14
       Serial number: 3510002AB12AB1B5D0FF
       Subsystem 5 - Part No SW: -----------    HW: 480 400 302 14
       Serial number: 3520002B313013F1A1EW
       Subsystem 6 - Part No SW: -----------    HW: 480 402 002 14
       Serial number: 3550002C7107DB44218%
       Subsystem 7 - Part No SW: -----------    HW: 480 402 002 14
       Serial number: 3560002C7107DB42D213
       Part No SW: 5Q0 953 507 DB    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 21031404220259
       Coding: 0410
       ROD: EV_SMLSKLOMQB_SE37.rod
       VCID: 79F9F3A6F8CF17F639-802C
       Part No SW: 5G6 920 970 C    HW: 5G6 920 970 C
       Component: KOMBI         316 2210
       Coding: 0BBD090A2180CF0502086A00000000
       VCID: 306F0E826B3516BECE-8064
       Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2163
       Revision: --------    Serial number: 17021410000843
       Coding: 0101000820085900EF000028180F00000001000000000000000000000000
       Shop #: WSC 00066 790 07026
       ASAM Dataset: EV_GatewConti 010015
       ROD: EV_GatewConti.rod
       VCID: 3E7320BAA161F0CE4C-806A
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q
       Component: E221__MFL-DC1  H06 0101
       Serial number: 29140000273350094134
       Coding: 29FFFF
       Serial number: 220414060502AY
       Coding: 003E03200000040000000000
       ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
       VCID: 408F5E42DB95863E3E-8014
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
       Serial number: 00000000000001873215
       Coding: 011000
              B1487 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 142
                        Mileage: 13993 km
                        Date: 2016.04.02
                        Time: 11:47:11
       Coding: 0002
       ROD: EV_SteerAssisMQB.rod
       VCID: 35613F96945733969D-8060
    15873 - Steering angle sensor
                        Reset counter: 78
                        Mileage: 13884 km
                        Date: 2016.03.31
                        Time: 18:13:43
       Serial number: 090414060502SV
       ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
       VCID: 3F8D5DBEA66BF9C647-806A
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
       Serial number: 00000000000001850857
       Coding: 191000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     013 0645
       Serial number: V7B02303141921
       Coding: 02730000FF00000021220001001800001F0203040100010002
       ROD: EV_MUStd4CPASE_SK37.rod
       VCID: 64C7B2D26F4DFA1EFA-8030
       Media Player Position 1:
       Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
       Component: ABT_Std_Plus  H60 0030
       Serial number: VWZ8Z9PS50020B
              B11CF 53 [009] - Deactivated
                        Reset counter: 58
                        Mileage: 12645 km
                        Date: 2016.03.22
                        Time: 19:04:43
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Part No SW: 5QE 035 285     HW: 5QE 035 285
       Component: OCULowMQBUS   006 0528
       ROD: EV_OCULowMQB.rod
       VCID: 020B944A9519542E68-8056
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 108
                        Mileage: 1048574 km
                        Time: 00:00:00
       Component: SAS-GEN 2     H06 0013
       Serial number: 140207200004
       VCID: 6BD5D9EE8293B566BB-803E
    End-------------------------(Elapsed Time: 03:15)--------------------------
    -3VW4T7AUXFM004160-15542km-9657mi.txt
    Displaying Log--3VW4T7AUXFM004160-15542km-9657mi.txt.
  11. #18
    United States
    I believe the current coding
    is correct. I would reset the TPMS, take that car for a short test drive, turn the steering lock to lock at a standstill and clear codes to see which return. The G85 calibration would be completed in Address 44 (instead of 03 or 16 like other cars).
  12. #19
    OK, I've been following this thread with more than a modicum of interest, but the multiple suggestions is making progress difficult to follow! So using my handy-dandy "code string to Byte list converter" this is the current state-of-play- I think:
    If my converter is working properly, it appears that the only live suggestion is from NEtech
  13. Likes XaGiCo liked this post
  14. #20
    Mar 2016
    UAE
    guys finally the long code worked i would like to thank everyone in here for the great support,the only thing i had to do it was to reset the tpms and then all went good
    thanks
  15. Likes Uwe, Fredrick Awuor liked this post
