Results 1 to 10 of 20
Thread: long code for abs golf mk vii gti
    Mar 2016
    UAE
    Dear All i need a long coding for abs module
    VCDS Version: Release 15.7.4 (x64) Running on Windows 8.1 x64
    Data version: 20160216
    euro
    Saturday,19,March,2016,20:02:31:05701
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
    VIN: 3VW4T7AUXFM004160   Mileage: 11786km-7323miles
    03-ABS Brakes -- Status: Not registered 0011
    Address 01: Engine (J623-CNTA)       Labels: 06K-907-425-V1.clb
       Component: 2.0l R4 TFSI  H13 0004
       Revision: --H13---
       Coding: 091D00124424000F0000
       Shop #: WSC 00066 790 00202
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
       ROD: EV_ECM20TFS0205G0906259A_VW37.rod
       VCID: 2C571AF2471D725EF2-8078
    17178 - Databus
              U1123 00 [047] - Received Error Message
                        Mileage: 9813 km
                        Date: 2016.01.25
                        Time: 17:05:41
       Part No SW: 0D9 300 040 S    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H52 4310
       Revision: 05852204    Serial number: TFK01403011556
       Shop #: WSC 00066 790 07031
       ROD: EV_TCMDQ250021_AU37.rod
       VCID: 275DE5DE5EFB51061F-8072
              P1734 00 [002] - -
       Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
       Component: ESC           H31 0371
       Revision: 00000000    Serial number: 51744000001209
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
       ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
       VCID: 44875252CF8D9A1E1A-8010
    12 Faults Found:
    0038 - Front Left Wheel Speed Sensor
              C101A 29 [008] - Signal Implausible
                        Reset counter: 82
                        Mileage: 11161 km
                        Date: 2016.03.17
                        Time: 17:20:11
    0054 - Front Right Wheel Speed Sensor
              C101B 29 [008] - Signal Implausible
                        Reset counter: 82
                        Mileage: 11161 km
                        Date: 2016.03.17
                        Time: 17:20:10
    0070 - Rear Left Wheel Speed Sensor
              C101C 29 [008] - Signal Implausible
                        Reset counter: 82
                        Mileage: 11161 km
                        Date: 2016.03.17
                        Time: 17:20:11
    0086 - Rear Right Wheel Speed Sensor
              C101D 29 [008] - Signal Implausible
                        Reset counter: 82
                        Mileage: 11161 km
                        Date: 2016.03.17
                        Time: 17:20:11
    0195 - Control module not coded
              U1013 00 [137] - -
                        Reset counter: 27
                        Date: 2016.01.25
                        Time: 17:05:49
    0212 - Longitudinal Acceleration Sensor
              C1017 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 27
                        Date: 2016.01.25
                        Time: 17:05:49
    0270 - Lateral Acceleration Sensor
              C1079 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 27
                        Date: 2016.01.25
                        Time: 17:05:49
    0279 - Brake Pressure Sensor 1
              C107A 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 27
                        Date: 2016.01.25
                        Time: 17:05:49
    0295 - Steering angle sensor
                        Reset counter: 27
                        Date: 2016.01.25
                        Time: 17:05:49
    4161 - Coding invalid
              U10DA 00 [009] - -
                        Reset counter: 48
                        Mileage: 9856 km
                        Date: 2016.01.25
                        Time: 20:50:35
    8290 - Coding Not Possible
              U10BC 00 [137] - -
                        Reset counter: 27
                        Mileage: 9813 km
                        Date: 2016.01.25
                        Time: 17:05:54
    8306 - Databus
              U1122 00 [137] - Implausible Message
                        Reset counter: 27
                        Mileage: 9813 km
                        Date: 2016.01.25
                        Time: 17:05:54
    Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
       Part No SW: 5G0 907 426 N    HW: 5G0 907 426 N
       Component: AC Manuell    H01 0705
       Revision: 00001K06
       Coding: 00020004200100000000000000000000
       ROD: EV_ACManueBHBVW37X_SE37.rod
       VCID: 3663389A8951388E94-8062
       Part No SW: 5Q0 937 087 K    HW: 5Q0 937 087 K
       Component: BCM PQ37BOSCH 026 0097
       Revision: --------    Serial number: 86580704141031
       Coding: 000018464041804969E44000001407201000000000000000000000000000
       ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 4385514ECA839D2623-8016
       Slave 1:
       Component: WWS    140224  043 0581
       Serial number:         140422135735
    329480 - Heated Passenger Seat
              B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
                        Fault Frequency: 17
                        Reset counter: 88
                        Mileage: 9856 km
                        Date: 2016.01.25
                        Time: 18:22:40
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM004CLF
       VCID: 51A96B0600FF7FB6A1-8004
       Seat occupant detection; front passenger side:
       Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
       Component: BF-Gewichtss.  005 0016
       Serial number: IBH0000J140000MXMZ0A
       Coding: 30325A
       Subsystem 2 - Part No SW: -----------    HW: 480 002 901 14
       Serial number: 3570000000087028BE0M
       Subsystem 3 - Part No SW: -----------    HW: 480 003 101 14
       Serial number: 35800000000B503D9E0S
       Subsystem 4 - Part No SW: -----------    HW: 480 400 302 14
       Serial number: 3510002AB12AB1B5D0FF
       Subsystem 5 - Part No SW: -----------    HW: 480 400 302 14
       Serial number: 3520002B313013F1A1EW
       Subsystem 6 - Part No SW: -----------    HW: 480 402 002 14
       Serial number: 3550002C7107DB44218%
       Subsystem 7 - Part No SW: -----------    HW: 480 402 002 14
       Serial number: 3560002C7107DB42D213
              B13BC F2 [137] - No function
                        Mileage: 9856 km
                        Date: 2016.01.25
                        Time: 21:07:53
       Part No SW: 5Q0 953 507 DB    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 21031404220259
       Coding: 0410
       ROD: EV_SMLSKLOMQB_SE37.rod
       VCID: 79F9F3A6F8CF17F639-802C
       Part No SW: 5G6 920 970 C    HW: 5G6 920 970 C
       Component: KOMBI         316 2210
       Coding: 0BBD090A2180CF0502086A00000000
       VCID: 306F0E826B3516BECE-8064
    16776973 - Databus
                        Reset counter: 27
                        Mileage: 9813 km
                        Date: 2016.01.25
                        Time: 17:05:48
       Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2163
       Revision: --------    Serial number: 17021410000843
       Coding: 0101000820085900EF000028180F00000001000000000000000000000000
       Shop #: WSC 00066 790 07026
       ASAM Dataset: EV_GatewConti 010015
       ROD: EV_GatewConti.rod
       VCID: 3E7320BAA161F0CE4C-806A
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q
       Component: E221__MFL-DC1  H06 0101
       Serial number: 29140000273350094134
       Coding: 29FFFF
    66304 - Databus
              U1124 00 [009] - Additional Installations Detected
                        Reset counter: 48
                        Mileage: 9813 km
                        Date: 2016.01.25
                        Time: 17:05:49
       Serial number: 220414060502AY
       Coding: 003E03200000040000000000
       VCID: 408F5E42DB95863E3E-8014
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
       Serial number: 00000000000001873215
       Coding: 011000
       Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
       Component: EPS_MQB_ZFLS  503 5043
       Coding: 8102
       ROD: EV_SteerAssisMQB.rod
       VCID: 35613F96945733969D-8060
    19204 - Databus
                        Reset counter: 88
                        Mileage: 9813 km
                        Date: 2016.01.25
                        Time: 17:05:47
       Serial number: 090414060502SV
       VCID: 3F8D5DBEA66BF9C647-806A
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
       Serial number: 00000000000001850857
       Coding: 191000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     013 0645
       Serial number: V7B02303141921
       Coding: 02730000FF00000021220001001800001F0203040100010002
       ROD: EV_MUStd4CPASE_SK37.rod
       VCID: 64C7B2D26F4DFA1EFA-8030
       Media Player Position 1:
       Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
       Component: ABT_Std_Plus  H60 0030
       Serial number: VWZ8Z9PS50020B
              B11CF 53 [009] - Deactivated
                        Reset counter: 27
                        Mileage: 9813 km
                        Date: 2016.01.25
                        Time: 17:05:25
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Part No SW: 5QE 035 285     HW: 5QE 035 285
       Component: OCULowMQBUS   006 0528
       Coding: 02730002C2821A017F1E06000000
       ROD: EV_OCULowMQB.rod
       VCID: 020B944A9519542E68-8056
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 0
       Part No SW: 5G0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0013
       Serial number: 140207200004
       VCID: 6BD5D9EE8293B566BB-803E
    End-------------------------(Elapsed Time: 03:16)--------------------------
    May 2014
    Quote Originally Posted by euro1 View Post
    Coding: 00000000000000000000000000000000000000000000000000 0000000000
    Euro1. hello. Here's some information from my database. It's from an Autobahn (NAR)
    ;SW:5Q0-907-379-K HW:5Q0-907-379-F --- ABS Brakes
    ;Component: ESC H31 0371
    ;EV_Brake1UDSContiMK100ESP
    Coding:01FA6BA13420096C007C020881C52980D62C9000408 194B400430050C009
    Hope that it is of use
    Would you mind telling us how it got to be all zeros?
    Considering the complexity of the coding in the previous generation of ABS modules (MK60EC1), I doubt this one will be any easier.
    Mar 2016
    UAE
    Thanks Mate i will try with that code today although i have tried already with some us specs codes before with no luck.
    i have bought the car like this with an abs problem the original module in the car didnt have any communication it was completely dead i can say so i swap it with a good one now but i need to coded obviously
    thanks
    Jul 2014
    I'll try to calc the coding for you but it will take some time since this ABS is really complicated to code and I don't have much info for US models.
  6. #6
    Jul 2014
    01fa6ba1342009700378060681c32980d62c90c0608294b402030030c002
    01fa6ba1342009700378060681c32980d62c90c0608294b402030050c002
    01fa6ba1342009700378060681c32980d62c90c0608294b400430050c002
    Last edited by Uwe; 03-20-2016 at 11:11 PM. Reason: CODE tags (to eliminate spurious blank space that forum software inserts in long strings otherwise
  7. Likes Uwe liked this post
    I would try this:
    01FA6BA1342009700078020681C32980D62C9000408194B400430050C009
  9. Likes Uwe liked this post
  10. #8
    Mar 2016
    UAE
    Thanks guys i will try all the codes and i will let u know
  11. #9
    May 2014
    Not sure what it means, but here's a comparison of all the suggestions thus far. Can someone explain the significance of the differences - please?
  12. Likes Uwe, XaGiCo liked this post
  13. #10
    Jul 2014
    Many of this bytes are still not fully described, nor by me or RT or anyone, that's why you need to try couple of options. I can tell that the last byte corresponds to modes which the "ESP OFF" button on centre console works. I still miss precise data on bytes 02,04,06,17,18,24-28, (work in still process), so you need to look at the people scans with similar car to match some bytes.
  14. Likes Uwe, DV52 liked this post
