Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Forum Exclusive: TEST version 16.3.0
    Exclusively for R-T forum members, a preview of what what we expect to release as a public Beta version soon -- TEST version 16.3.0.
    This includes:
    • An all-new UDS data set, which should support newer models, including some so-called 2017 models (a MY designation that I personally think is rather premature).
    • New "VAG Speak" locations for measuring values on UDS modules. These replace the formerly arbitrary location numbers for data items, which were subject to change with new data sets.
    • New HEX+CAN firmware that should make these old work-horse interfaces compatible with MLB2 platform cars.
    The above are a few highlights and is not intended to be a comprehensive list of changes from 15.7.x.
    IMPORTANT NOTE: Due to architectural constraints in some of our older interfaces, once you update the firmware in one, it will no longer be compatible with older versions of VCDS on cars that use CAN bus for diagnostics. You will have to use version 16.3 or newer from that point on and won't be able to revert to the previous release version, so don't download this and update your interface firmware unless you're willing to take some risk with a brand-new version that isn't even full public "Beta" yet.
    We would appreciate it if you folks did not spread the following link (or the the software itself) around. All support for this TEST version will be right here, in this forum, and nowhere else. Not via e-mail, not over the phone.
    If you don't have a really late model car that either doesn't work with your HEX+CAN interface, or that's missing ROD files, there's no compelling reason to download and install this.
    By downloading and installing this software, you acknowledge that you've read everything I posted above.
    If you have questions about the software itself, please post them right here in this thread.
    Please post Auto-Scans from this software in the Reference Scans section of the forum.
    Last edited by Uwe; 04-01-2016 at 09:18 AM. Reason: Removed link to download since public Beta is now available
    Mar 2016
    Norway
    I'm aware it is still a Test but do you recommend cars with MIB2 to use this version? As MIB2 headunits isn't fully supported on latest VCDS 15.7, I assume this is a step forward or what?
    What do you mean "Fully Supported"?
    MIB2 works fine since 15.7.3.
    Mar 2016
    Norway
    I meant no long coding support for some modules like 5F. Are we getting those anytime soon?
    There's no difference between this Test version and 15.7.4 in that respect, the coding data is exactly the same.
    There should be some new data when it's officially released as a Beta. Whether it will cover your particular head unit, I don't know right now. There are so bloody many variations of these....
  6. Likes Drive, andyvee liked this post
    Verified VCDS User andyvee's Avatar
    Rossendale, Lancashire, UK
    I'm up for it
  8. Likes Uwe liked this post
    Forgot to ask, any impact on on HEX-NET if I use this?
  10. #8
    Nope, no impact on the HEX-NET. As you know, HEX-NET updates are separate from VCDS and since the HEX-NET worked with the MLB2 cars to begin with, the HEX-NET does not require any firmware here.
  11. #9
    Mar 2016
    Norway
    The channel data is no longer properly sorted in Adaptations with this version. Possibly a bug.
  12. #10
    Quote Originally Posted by Drive View Post
    Would you mind elaborating?
