2 Issues with Coding -- Rear Fog and TPMS (7K6)
JGMK6
C?ID=214099
Hey guys,
1) Rear-Fog
I recently installed a chrome non-auto euro switch in my 2012 Golf with halogens. I ran both trigger wires and now have parking lights activated and rear-fog (only when low-beams switched on).
I got the parking lights working perfect with the green light illuminated. I got the rear-fog working and icon in the dash when the switch is in the low-beam position.
I have yet to receive my euro-halogen rear-fog taillight so the left reverse light turns on when the rear-fog is activated. I have done the following:
* trigger wire from switch pin #3 to black cecm pin# 19
* trigger wire from switch pin #7 to black cecm pin# 17
* moved wire from black cecm pin #28 to brown cecm pin #47
* moved wire from brown cecm pin #47 to black cecm pin #28
* changed 09 Cent. Elec. Byte 18 to 02
So basically my problem is, the low-beams turn on when I pull the switch out two clicks for the rear-fog while in the parking light position (=> <=).
I also tried using 00 for byte 18 and the same problem persists. If I use 03 for byte 18 (default) then the rear-fog does not work at all. I also tried leaving the wire from brown cecm pin #47 taped up, however that left me with a bulb out error.
Could it be because I don't actually have a rear-fog light, I suspect it's coding since the rear-fog (reverse light) works when the switch is turned to the low-beam position.
2) TPMS 7K6
**May 21/2014 Figured it out...
Changed
ABS Brakes 03--
Byte 16 bit 2 to "Tire Pressure Monitoring (TPMS/PR-7K6) installed
Instruments 17--
Byte 02 bit 2 to "Tire Presure Monitoring (TPMS) active/installed
No codes, light turns on when ignition is on.
Just the rear fog now.. Would coding the cluster to Germany help any?
Attached is my latest scan from this morning
Thanks,
Justin
Wednesday,21,May,2014,09:05:38:30418
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVWCA7AJ3CW050256 License Plate:
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 BB HW: 07K 906 055
Component: 2,5l R5/4V G01 8758
Revision: T4H04--- Serial number:
Coding: 0000071
VCID: 6FC33ACF7EEBDE6672D-803A
Readiness: 0110 0001
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 114B400C492700FA880D02E9921F0041350000
VCID: 7BDB1E9FFA93B2C6CE5-802E
Address 08: Auto HVAC (J301) Labels: 7N0-907-426.clb
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000004002
ROD: EV_ACManueBHBVW36X_SE36.rod
VCID: 8021E9731B75511E1B7-80D5
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 G HW: 1K0 937 084 G
Component: BCM PQ35 B 110 0651
Revision: 00110 AC
Coding: 6F180A3A80272AC4008800C1500005C448010286524D8D60648020200040
VCID: 3245F3BB6D59B38E5D3-8067
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 02071 26 0512
Coding: 009795
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA0A0FQ
Coding: 00003132
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3FA3AA8FA60B6EE6A2D-806A
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME10323161ZZZA
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME111A3261ZZZJ
Serial number: 3512QSME70031E26ZZZO
Serial number: 3522QSME74201F31ZZZP
Component: F.Sens.Fahr --- ----
Serial number: 35527SME77717127ZZZF
Crash sensor for front airbag; passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME0B5F7127ZZZP
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440KG10009H
Coding: 108A140000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 72C533BBA5D9F38E9D3-8027
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Serial number: 40000000000000391769
Coding: E20000
Part No SW: 5K0 920 872 HW: 5K0 920 872
Component: KOMBI H03 0607
Coding: 370F01
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: ECF9ADC307FDA57ED7F-80B9
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 020711F1003585
Coding: 350002
VCID: 354FC8A79C37A4B6781-8060
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223RDV5G06
VCID: FEDD978BA98127EE69B-80AB
Component: IMMO H03 0607
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EAF5ABDB0D09BB4EA53-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660381737
VCID: 297714D7408FF056EC9-807C
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 H HW: 5K0 959 701 H
Component: Tuer-SG 009 2105
Coding: 0001204
VCID: 3753C2AF463B56A66AD-8062
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 3449F5A3574DBDBE4FF-8061
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Component: Tuer-SG 009 2119
Coding: 0001204
VCID: 3245F3BBAD59B38E5D3-8067
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7L1125321
Coding: 21000400040005
VCID: 63EB46FF62236A06E65-8036
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 354FC8A75C37A4B6781-8060
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001168
VCID: 364DCFAB4131AFAE71B-8063
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007660366836
Coding: 0A00000000010100
ASAM Dataset: EV_UHVNA A01015
ROD: EV_UHVNA.rod
VCID: 354FC8A79437A4B6781-8060
End ---------------------------------------------------------------------
Dana
Western PA, USA
The RF low beam/DRL and LR reverse/rear fog lamp BCM outputs will switch positions when Byte 18 is modified but I haven't heard of both low beams activating in conjunction with one of these retrofits. I would check measuring blocks 049, 050 and 051 to see if the switching is correct.
This rear fog lamp with (non LED) factory/incandescent tail light thread may be helpful as well:
http://forums.vwvortex.com/showthread.php?5979639-Working-Non-LED-Rear-Fog-Light
