Results 1 to 10 of 14
Thread: Audi A4 B8 2010 01705 - Selection Switch for Mirror-Adjust (E48)
    Verified VCDS User Bill-A4B8's Avatar
    Mar 2016
    Hi everyone
    Just scanned first time my car and found this error. Any advise will be appreciated. I have retro the puddle lights on all doors and about to code them but on first scan on VCDS came up this error and non of the door modules are accessible '' no response from Controller''
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 J HW: 8K0 959 793 E
    Component: TSG FA H11 0306
    Revision: Serial number: 0000102421931
    Coding: 011002204001410001
    Shop #: WSC 06325 000 00000
    VCID: 479D3578F6096806FF-8012
    Reset counter: 217
    Mileage: 119679 km
    Date: 2016.02.27
    Time: 11:44:42
    Do you mean none of the OTHER door control modules are accessible? Because clearly 42 is.
    Mind posting a complete Auto-Scan please?
    Also, when did you retrofit the puddle lights, and did you do a scan prior?
    Mar 2016
    Hi Uwe
    yes non of the doors modules are accessible. I have done the doors few weeks ago and a lot of people just installed and worked straight. So I thought will work on mine as well but I think I am not that lucky.
    I never done any scan before as didn't had the cable which I bought 4 days ago. Here is the full scan
    VCDS Version: Release 15.7.4 (x64) Running on Windows 7 x64
    Data version: 20160216
    Tuesday,15,March,2016,20:55:22:42140
    Chassis Type: 8K (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 55 56 5F 62 72
    VIN: WAUZZZ8K3AA102067   Mileage: 119890km-74496miles
    Address 01: Engine (------CDHA)       Labels: 06H-907-115-CAB.clb
       Part No SW: 8K1 907 115 C    HW: 8K1 907 115
       Component: 1.8l R4/4V TF H11 0003
       Revision: A5H11---
       Coding: 0104000C18070120
       ASAM Dataset: EV_ECM18TFS8K1907115C A01004
       ROD: EV_ECM18TFS_AU48.rod
       VCID: 2E5360DC71B3D94EDC-807A
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 AK    HW: 8K0 907 379 AK
       Component: ESP8 front    H04 0070
       Coding: 010500
       VCID: 020BE46C9DAB8D2E68-8056
       Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
       Component: BCM2 1.1      H02 0326
       Coding: 031100
       VCID: 0109EB6098AD963671-8054
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
    00956 - Key 2
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 63
                        Mileage: 117665 km
                        Date: 2015.11.28
                        Time: 17:37:11
       Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
       Component: KLIMA 3 ZONEN H08 0171
       Revision: D0000000    Serial number: 01021220091344
       Coding: 64140000
       VCID: 76E388BCC163A18E54-8022
       Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
       Component: BCM1 1.0      H25 0380
       Revision: 09025001    Serial number: 00000000527842
       Coding: 260050914034AF010001000000001D0D001D030800010141000000
       VCID: 3A7B5C8CB5FB05EE70-806E
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 271109  H05 0070
       Coding: 00FD11
       Component: RLS  H04 0003
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
       Component: AirbagVW-AU10 H39 0560
       Serial number: 003EFD07ZZ0-
       Coding: 30363435363030303030554A3052384B3053
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 41892B60D02D563631-8014
       Serial number: 6334MSME4D450B77O
       Serial number: 6344MSME4D432370A
       Serial number: 6352QSME19454D34K
       Serial number: 6362QSME0A452000%
       Serial number: 63732SME5345342E$
       Serial number: 63832SME3A465400W
       Revision: --------    Serial number: 90315IL2000NS
       Coding: 000016
       VCID: 3D715790A4D532D655-8068
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 980 L    HW: 8K0 920 980 L
       Component: KOMBIINSTR.   H20 0255
       Revision: 00100000    Serial number: CIW22VTC9
       Coding: 2F04080002002600010000
       VCID: 3B755988BAC13CE66B-806E
       Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0105
       Revision: EB800053    Serial number: 5300E09B20020A
       Coding: 00C303
       VCID: 52AB142C0D4BDDAE98-8006
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H06 0170
                        Reset counter: 217
                        Mileage: 119679 km
                        Date: 2016.02.27
                        Time: 11:44:42
       Revision: 00002001    Serial number: 0124495386
       Coding: 011B0622003904400030013280000000
       Part No SW: 8K0 959 792 J    HW: 8K0 959 792 E
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000102382678
       VCID: 4683387CF103710E04-8012
       Revision: 00000003    Serial number: 10000000384828
       VCID: 346772B4979FF39EAA-8060
       Part No: 8K5 907 357
       Coding: 0000004
       Shop #: WSC 06324 000 00000
       VCID: 77FD85B80669D8864F-8022
       Part No SW: 4F0 035 056 B    HW: 4F0 035 056
       Component: Radio U STD   H45 0020
       Revision: AB001007    Serial number: 342LZ097734162
       Coding: 010003020100000001
       VCID: 1F4D8D180E1940C667-804A
       Part No SW: 8T2 035 666 E    HW: 8T2 035 666 E
       Component: H-BN-EU       H45 0047
       Revision: --------    Serial number: 475LZ097540025
       Coding: 01010100010681EC01000B1C000000030001
       Subsystem 1 - Part No: 8R0 060 884 J
       Component: EUR 2010  1005
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
       Component: E0380 Bedient  H08 0100
       Subsystem 4 - Part No: 8R0 906 961 A
       Component:   CD-Database  1293
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000102449751
       Coding: 010002204001210001
       VCID: 428B246CDD2B4D2E28-8016
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000102449754
    End-------------------------(Elapsed Time: 02:47)--------------------------
    Audi A4 2010 1.8T S Line Black
    Audi A4 2002 1.8T Sports
    Mar 2016
    for all doors same message
    I'm confused how this can be. Your Auto-Scan shows all four doors responding:
                        Reset counter: 217
                        Mileage: 119679 km
                        Date: 2016.02.27
                        Time: 11:44:42
    So the question is, what's different when you did the Auto-Scan and when you're trying to access the doors individually. I know this sounds silly, but do you have the ignition on when you're trying to access the doors individually?
    Mar 2016
    ok I done one scan with key in ignition and second one to be sure with running engine both scan same. but I tried to access the door when engine was running. not sure if that makes a difference?
  7. #7
    I don't think so, but please try with Key On, Engine Off.
    PS: Please see How to get Verified. I think you fall into category 2) in that post.
  8. #8
    Mar 2016
    I will try in the morning and also get the account verified.
    thanks for your help
  9. Likes Uwe liked this post
  10. #9
    Mar 2016
    done a third scan today and manage to access door module but I think need help with codes.
    (Uwe@filled verification form)
  11. Likes Uwe liked this post
  12. #10
    Verified...
    I would move this, but it's unclear to me whether it belongs in Car Repair (for the fault code with the mirror switch) or in Retrofits (for the puddle lights).
