hi guys I have this treg its wet but nothing making it to the ground. just wanted to know if that pipe is coming from the air cleaner, or where the oil is coming from.
thank you dana looks like you nailed it. at first you would think the oil is coming from the short hose connecting the two pipes. but the more i looked at it seems to be coming from all over the frame. i removed both front wheel well covers and found debris like leaves and needles and a lot of soil. i took some pics will try and load them. i would recommend if you have a treg to open the wheel wells asap you will need a vacuum to clean all the crap out. also the drian from the cowl had alot of soil and leavesP.S. Do you think the AC drain or water could be tracking down that hose/pipe collecting that sticky anti-corrosion goo and making it look wet? Sorta like the clear but sticky goo washing out door drain holes onto the rockers after 5+ years.
http://forums.ross-tech.com/showthread.php?1996-Level-Control-Bleeding-Charging
