Results 1 to 10 of 11
Thread: Coding MY16 Amundsen / MIB2 - VW/Skoda
    Verified VCDS User BGB's Avatar
    Mar 2016
    Norway
    Coding MY16 Amundsen / MIB2 - VW/Skoda - 1123601 - predictive route data
    I've learned that there have been issues with coding in 5F on 2016 models where menues in unrelated controllers have disappeared. Read more here: http://forums.vwvortex.com/showthrea...MY16-MIB2-cars
    From VWVortex:
    Posting this to find out if a problem being experienced on Skodas is being found on other VAG cars with the same system and maybe a warning to those looking at coding to tread very carefully indeed as the usual protections of autoscans and adaption maps before and after will not protect you with this problem.
    This concerns the new 2016 Model Year cars 1-2 months old with the new MIB2 headunits (Amundsen and Columbus on Skoda, Discover and Discover Pro on VW)
    Coding certain items (we now believe in 5f) will cause unrelated menus to disappear from the head unit. Coding done on an item is successful so it is not the wrong thing being coded.
    The adaption maps being taken prior to any coding are not showing how the car actually is (judging by the menus functional on infotainment at the time) this mis-read map is being coded to the car when other items are coded resulting in corruptions in the controller.
    Adaptions are being made that result in corruption of the head units and loss of menus that do not appear in VCDS log files so it is impossible to re-trace steps as you actually have not made those steps.
    RossTech have not responded to queries about this from several people for over a month now so I would be very careful about using VCDS on a MY16 car with the high-end nav units until this is sorted.
    Now I have not coded anything in 5F on my 2016 Skoda Octavia but I got this fault code:
    Address A5: Frt Sens. Drv. Assist Labels: 5Q0-980-653.clb
    Control Module Part Number: 5Q0 980 653 G HW: 5Q0 980 653
    Component and/or Version: MQB_MFK H06 0060
    Software Coding: 0101010001030308000400000100000101
    Work Shop Code: WSC 73430 790 00000
    ASAM Dataset: EV_MFKBoschAU370 001001 (SK37)
    ROD: EV_MFKBoschAU370_AU37.rod
    VCID: 3C7755FFB70376DE62-8068
    B1630 02 [008] - Signal Failure
    Fault Frequency: 6
    Reset counter: 125
    Mileage: 512 km
    Date: 2016.03.05
    Time: 19:02:01
    It seems that it has something to do with 5F issue - is there any information on 2016 models and VCDS?
    Quote Originally Posted by BGB View Post
    That problem was fixed in version 15.7.3.
  3. Likes BGB, Jack@European_Parts liked this post
    Mar 2016
    Norway
    First of all, I do apologize, I should have searched, found a thread here: http://forums.ross-tech.com/showthre...ght=my16+skoda
    But, why do I keep getting the fault code posted?
  5. Likes Dana, Uwe liked this post
    United States
    I'm not an exert in this area (I still drive a 2012 Tiggy / Mk6) but if tweaks were not made and that fault is stored I suspect the system failed in some way and needs to be further diagnosed. Please post the complete Auto-Scan if you'd like someone here to research this.
  7. Likes BGB liked this post
  8. #5
    Mar 2016
    Norway
    Thank you Dana for your reply, I will post a complete scan as quickly as possible (At work for the moment).
  9. Likes Dana liked this post
  10. #6
    Mar 2016
    Norway
    Here is the complete scan, of course the fault code posted above did not appear for some reason:
    VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64
    Data version: 20160216
    Monday,14,March,2016,23:08:33:26833
    Chassis Type: NE (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 2B 36 42 44 52 55
              5F 69 6D A5
    VIN: TMBLD9NE6G0158055   Mileage: 632km-392miles
    Address 01: Engine (J623-CJSB)       Labels: 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 H    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0003
       Revision: --H13---
       Coding: 349D001A2476010B1000
       Shop #: WSC 73430 031 00000
       ASAM Dataset: EV_ECM18TFS0208V0906264H 001005
       ROD: EV_ECM18TFS0208V0906264H_AU37.rod
       VCID: 4189240BD0E11B3631-8014
       Part No SW: 0D9 300 012 F    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4904
       Revision: 06253104    Serial number: TFK01511201275
       Shop #: WSC 73430 031 00063
       ROD: EV_TCMDQ250021_AU37.rod
       VCID: 1939AC6B18F163F699-804C
       Revision: 00000000    Serial number: 63365000000381
       Coding: 1C076A913425A9740077070541C82938562C9500E08294FC16415070E009
       ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
       VCID: 7AFB93E7FDB788EE30-802E
       Revision: 00021000    Serial number: 0387876734
       Coding: 030C0C
       Shop #: WSC 73430 790 00000
       VCID: 3A7B53E7BD3748EE70-806E
       Part No SW: 5E0 907 044 AA    HW: 5E0 907 044 AA
       Component: Climatronic   H04 1002
       Revision: 00001K07
       Coding: 02010004004101011005004100101000
       ROD: EV_ACClimaBHBVW37X_SK37.rod
       VCID: 64C7CD9F6F336E1EFA-8030
       Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
       Revision: --------    Serial number: 86580812151430
       Coding: 0C031B76C24722FB4FE44004001C17280C00000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 0305EE038A7DC92663-8056
       Slave 1:
       Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 151115  041 0570
       Serial number:         151124190742
       Coding: 065DDD
       Slave 2:
       Component: RLHS  037 0059
       Serial number: S4Y15M12D12H12M20S32
       Coding: 00885D
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
       Revision: --------    Serial number: 39391534302056
       Coding: 0071151151
       Shop #: WSC 73430 790 00063
       ROD: EV_EPHVA18AU3700000_SK37.rod
       VCID: 43852E03CAFD092623-8016
    Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
       Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
       Component: ACC Bosch MQB H05 0400
       Serial number: 26111503211971
       Coding: 000C1E00FE0339
       ASAM Dataset: EV_ACCMRRBoschVW372 001016
       ROD: EV_ACCMRRBoschVW372_AU37.rod
       Part No SW: 3Q0 959 655 AQ    HW: 3Q0 959 655 AQ
       Component: Airbag VW20   013 0200
       Revision: --------    Serial number: 003SNPNGKT1$
       Coding: 98FCC000000000005C5400CC000800000065
       ROD: EV_AirbaVW20TS6VW48X_SK37.rod
       VCID: 0D11C83BDC398F5605-8058
       Seat belt tensioner; left:
       Serial number: 34169593B11121550576
       Coding: 333135
       Seat belt tensioner; right:
       Serial number: 34169592B10121590481
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 454 000 312 15
       Serial number: 3576U00000009B89B71L
       Subsystem 4 - Part No SW: -----------    HW: 454 000 212 15
       Serial number: 3586U0000008199DA71O
       Subsystem 5 - Part No SW: -----------    HW: 454 802 611 15
       Serial number: 3516R4C884A09000000B
       Subsystem 6 - Part No SW: -----------    HW: 454 802 511 15
       Serial number: 3526RBF56F808000000P
       Subsystem 7 - Part No SW: -----------    HW: 454 801 410 15
       Serial number: 3556VD53BD108000000I
       Part No SW: 5Q0 953 507 JB    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0120
       Revision: --------    Serial number: 01121504401142
       Coding: 6410
       ASAM Dataset: EV_SMLSKLOMQB 020001
       ROD: EV_SMLSKLOMQB_SK37.rod
       VCID: 7F0D62F3E695ADC607-802A
       Part No SW: 5E0 920 758 B    HW: 5E0 920 758 B
       Component: KOMBI         324 6422
       Coding: 07A50819ED840008018C6A031000000000000000
       Shop #: WSC 73430 031 12345
       VCID: 2B5566A3426DE166FB-807E
    Address 18: Aux. Heat (J364)       Labels: 5Q0-963-272.clb
       Part No SW: 5Q0 963 272 F    HW: 5Q0 963 272 F
       Component: STH-MQB       007 0072
       Coding: 9309
       ROD: EV_AuxilParkiHeateWOS_AU37.rod
       VCID: 39794CEBB83143F679-806C
       Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
       Component: R149 T91-LIN  003 0301
       Serial number: 00000000000001279532
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1243
       Revision: --------    Serial number: 0004208070
       Coding: 030100347F085900EB00225E1E0F00010001050000000000000000000000
       Shop #: WSC 73430 790 12345
       ROD: EV_GatewLear.rod
       VCID: 79F98CEBF8B183F639-802C
       Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
       Component: E221__MFL-PR6  H02 0150
       Serial number: 000000000D2684251115
       Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
       Component: J367-BDMConti  H02 1011
       Serial number: 74185704001512120263
       Serial number: HA1-00007.11.15
       Coding: 0001
       VCID: 4A9B0327EDD7D86EE0-801E
       Revision: 00000000    Serial number: 15000254787001
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_AU37.rod
       VCID: 34677DDF9F53BE9EAA-8060
    Address 36: Seat Mem. Drvr (J810)       Labels: None
       Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
       Component: Sitzmemory    H06 0009
       Serial number: Y0006OKA14066
       Coding: 001000000000010001A081808080000000008181000000D4
       ASAM Dataset: EV_SeatMemorDriveSide 001015
       ROD: EV_SeatMemorDriveSide_SK37.rod
       VCID: 3B7556E3B20D71E66B-806E
       Component: TSG FS        010 0031
       Serial number: 0000178756556
       Coding: 00110920DE00048000001100
       ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
       VCID: 479D3A13FEC52506FF-8012
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
       Serial number: 00000000000008291766
       Coding: 010200
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 9103
       ROD: EV_SteerAssisMQB.rod
       VCID: 44872D1FCFF30E1E1A-8010
       Component: TSG BFS       010 0031
       Serial number: 0000178905610
       Coding: 00110120DE00048000001100
       ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
       VCID: 46833717F9CF3C0E04-8012
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
       Serial number: 00000000000008277538
       Coding: 190200
       Coding: 03EA00003F010000
       ROD: EV_HeadlRegulVWAFS_SE26.rod
       VCID: 408F210FDBEB123E3E-8014
       Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H06 0009
       Coding: 3E0000
       Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H06 0009
       Coding: 3E0000
    Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-HGH2.clb
       Part No SW: 3V0 035 020 B    HW: 3V0 035 020
       Component: MU-H-ND-EU    H50 0318
       Serial number: A676K0FB005175
       Coding: 037342010000000011111202008800002F0002F401208100BE
       ROD: EV_MUHig4CGen2HBAS_SK37.rod
       VCID: 2541909B2489D7162D-8070
       Media Player Position 1:
       Radio Tuner - Digital:
       Subsystem 2 - Part No SW: 5E0 919 606     HW: 5E0 919 606
       Component: ABT_High  H61 0031
       Serial number: SKZ8Z9RW800SU7
       Engine Control Module 2:
       Subsystem 3 - Part No SW: -----------    HW: -----------
       Component: -------------  --- ----
       Seat Adjustment Driver Side:
       Subsystem 4 - Part No SW: V03 959 801 JK    HW: -----------
       Component: ECE 2016  --- 0134
       Air Conditioning Compressor:
       Diesel Pump Control Unit:
       Door Electronics Driver Side:
       Subsystem 7 - Part No SW: -----------    HW: -----------
       Brake Assistance:
       Subsystem 8 - Part No SW: -----------    HW: -----------
       Interior Monitoring:
       Subsystem 9 - Part No SW: -----------    HW: -----------
       Sound System:
       Door Electronics Rear Left:
       Subsystem 12 - Part No SW: -----------    HW: -----------
       Subsystem 13 - Part No SW: -----------    HW: -----------
       Subsystem 14 - Part No SW: V03 959 800 EG    HW: -----------
       Component: Gracenote2  --- 1012
    Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
       Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
       Component: Anhaenger     H21 0203
       Revision: 8C001003    Serial number: 0388656291
       Coding: 0100000202000000
       ROD: EV_TrailFunctGener2Hella_AU37.rod
       VCID: 3E735FF7A11F64CE4C-806A
    Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
       Part No SW: 5E0 959 107 A    HW: 5E0 959 107
       Component: HDSG-Modul    H01 0746
       Revision: 42001001    Serial number: 317501780
       Coding: 1233074003
       ASAM Dataset: EV_HDSGSk462 301136
       ROD: EV_HDSGSk462_SK37.rod
       VCID: 2A5B63A74D97F86E00-807E
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
       Component: MQB_MFK       H06 0060
       Serial number: 10000466941
    End-------------------------(Elapsed Time: 05:54)--------------------------
    Really hope some experts can come with some input.
  11. Likes Uwe liked this post
  12. #7
    Mar 2016
    Norway
    Anyone want to take a look please? Pretty please...
  13. #8
    This DTC has been in different Autoscans.
    It could be an DTC for information (Fault Priority: 6).
    So if 1123601 (B1630) is shown, like the above Autoscan, please observe when it comes up.
    I could be it becomes, active when the Camera in your window is covered by dirt or snow/ice.
  14. Likes BGB, Jack@European_Parts liked this post
  15. #9
    Mar 2016
    Norway
    Thank you very much for your reply.
    This may be, I do have lane assist, city safety and acc and I do know that when we have had much snow and dirt during the winter the sensors and camera in the front window may get covered up. I even at one point got a warning while driving saying "low visibility" in a snow storm.
    The main issue here is that nothing is related to the problem with MIB2 and Amundsen during VCDS pre 15.7.3 release.
  16. #10
    Mar 2016
    Norway
    After 16 days at the dealership they concluded that the fault code most likely comes from when the sensor is dirty / covered and the message "low visibility acc" appears. As for the long 16 days wait they sorted out a couple of other things as well.
