The first thing I'd do with that car is clear all those fault codes. Almost all of them are flagged "Intermittent" meaning the fault condition that set the code no did not exist (or could not be detected) at the time the scan was performed. Then see what comes back when and under what circumstances.im having the same issues after updating using the java client fyi i did just have my whole nav unit replaced due to many faults
using vcds windows client in network mode
Code:VCDS Version: Release 15.7.4 Running on Windows 8.1 x86 Data version: 20160216 www.Ross-Tech.com Saturday,19,March,2016,01:53:34:49139 Chassis Type: A3 (7N0) Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F 52 56 62 72 75 77 VIN: 1VWCV7A37FC009301 Mileage: 71510km-44434miles 01-Engine -- Status: Malfunction 1010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Sporadic communication error 1000 08-Auto HVAC -- Status: Sporadic communication error 1000 09-Cent. Elect. -- Status: Sporadic communication error 1000 15-Airbags -- Status: Sporadic communication error 1000 16-Steering wheel -- Status: Sporadic communication error 1000 17-Instruments -- Status: Sporadic communication error 1000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: Sporadic communication error 1000 2B-Steer. Col. Lock -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 36-Seat Mem. Drvr -- Status: Malfunction 0010 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Sporadic communication error 1000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: Sporadic communication error 1000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: Sporadic communication error 1000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Sporadic communication error 1000 72-Door, Rear Right -- Status: Sporadic communication error 1000 75-Telematics -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CVCA) Labels: None Part No SW: 04L 906 016 AF HW: 04L 907 309 K Component: R4 2,0L EDC H20 8417 Revision: 8AH20--- Coding: 011D0012032410089000 Shop #: WSC 41657 001 1048576 ASAM Dataset: EV_ECM20TDI01104L906016AF 001014 ROD: EV_ECM20TDI01104L906016AF.rod VCID: ED9289163C2E8D5625-80B8 1 Fault Found: 4113 - Camshaft Position Sensor (G40) P0341 00 [100] - Implausible Signal Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 71512 km Date: 2016.03.19 Time: 00:40:24 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-927-770.lbl Part No SW: 02E 300 061 T HW: 02E 927 770 AL Component: GSG DSG AG6 521 4509 Revision: 05652104 Serial number: 00001404052843 Coding: 0000020 Shop #: WSC 09003 957 00200 VCID: A502B1366C5E7516AD-80F0 5 Faults Found: 18258 - Powertrain Data Bus P1850 - 000 - Missing Message from ECU - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 39 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 28907 - No Communications with Cruise Control (Front) Distance Sensor U0235 - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 39 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 18270 - Powertrain Data Bus P1862 - 000 - Missing Message from Instrument Cluster - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 39 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 18275 - Powertrain Data Bus P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 39 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 01196 - Engine-Transmission Data Bus 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 39 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM Component: ESP MK60EC1 H46 0164 Revision: 00H46001 Coding: C54BC0F549220003A30E03E4921A0042A1100012 Shop #: WSC 09003 957 00200 VCID: FEB0BE5A694806CE8C-80AA 5 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 Freeze Frame: Count: 0 Count: 12 Count: 0 Count: 8208 Count: 45312 Count: 0 Count: 255 Count: 0 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 Freeze Frame: Count: 2 Count: 12 Count: 0 Count: 8194 Count: 45312 Count: 0 Count: 255 Count: 0 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 Freeze Frame: Count: 2 Count: 12 Count: 0 Count: 8226 Count: 45312 Count: 0 Count: 255 Count: 0 00457 - Control Module for Network (J519) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 Freeze Frame: Count: 2 Count: 12 Count: 0 Count: 8262 Count: 45312 Count: 0 Count: 255 Count: 0 02214 - Tire Pressure Warning 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Mileage: 71446 km Time Indication: 0 Date: 2016.03.01 Time: 09:42:24 Freeze Frame: Count: 0 Count: 32768 Count: 4608 Count: 16401 Count: 50494 Count: 255 Count: 257 Count: 0 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb Part No SW: 5K0 959 434 E HW: 5K0 959 434 Component: VWKESSYPQ35GP 092 1202 Revision: 00092000 Serial number: 0332322625 Coding: 130C0C Shop #: WSC 09003 957 00200 ASAM Dataset: EV_KESSYPQ35G A02717 ROD: EV_KESSYPQ35G.rod VCID: B73E6B7E0EF2F7860F-80E2 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb Part No SW: 561 907 044 AP HW: 561 907 044 AP Component: Climatronic H03 0707 Revision: 00001K01 Coding: 0010019012 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_ACClimaBHBVW411 A01001 ROD: EV_ACClimaBHBVW411_VW41.rod VCID: E582F136E4DEB5166D-80B0 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE Component: BCM PQ35 H+ 122 0174 Revision: BL122001 Coding: EF200E3B982B08D4098802013600854800F1A01E45A005B064806000BC70 Shop #: WSC 09003 957 00200 VCID: F8BCA8424B6C38FEC6-80AC Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 290514 05 54 0403 Coding: 02300A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 5K0-959-655.clb Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB Component: AirbagVW10 500 0975 Serial number: 003LZD018ST9 Coding: 00004D32 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_AirbaVW10SMEVW360 001030 ROD: EV_AirbaVW10SMEVW360_SE36.rod VCID: F2A89A6A251052AEF8-80A6 Seat occupied recognition: Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B Component: BF-Gewichtss. H10 0046 Serial number: 6940000Y1400016MTW0J Coding: 303047 Crash sensor for side airbag; driver side: Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354 Component: S.Sens.Fahr.V H02 ---- Serial number: 3572MSME6E6B6A44ZZZB Crash sensor for side airbag; front passenger side: Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354 Component: S.Sens.Beif.V H02 ---- Serial number: 3582MSME312C6A44ZZZ- Crash sensor for side airbag; rear; driver side: Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A Component: S.Sens.Fahr.H H02 ---- Serial number: 3516KSME7B12782EZZZ+ Crash sensor for side airbag; rear; passenger side: Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A Component: S.Sens.Beif.H H02 ---- Serial number: 3526KSME050D572DZZZZ Crash sensor for front airbag; driver side: Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A Component: F.Sens.Fahr H02 ---- Serial number: 3556LSME0703372EZZZU Crash sensor for front airbag; front passenger side: Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A Component: F.Sens.Beif H02 ---- Serial number: 3566LSME1D6B352EZZZ7 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb Part No SW: 1K5 953 521 BR HW: 5K0 953 569 AH Component: LENKS.MODUL 016 0140 Revision: FF010042 Serial number: 20140530200383 Coding: 000A140000 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_SMLSNGVOLWSXS A01004 ROD: EV_SMLSNGVOLWS.rod VCID: FEB0BE5A614806CE8C-80AA Multi Function Steering Wheel Control Module: Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB Component: E221__MFL-YVJ H07 0022 Coding: E20000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 561 920 970 G HW: 561 920 970 G Component: KOMBI H04 0813 Serial number: 00000000000000 Coding: 231C01 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723 ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod VCID: 9E709EDA8108A6CEEC-80CA No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM Component: J533 Gateway H55 1653 Revision: H55 Serial number: 28061403000506 Coding: 461000 Shop #: WSC 09003 957 00200 VCID: 804CC0A213BC703EFE-80D4 13 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Time Indication: 0 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 00457 - Control Module for Network (J519) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Time Indication: 0 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Time Indication: 0 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 228 Time Indication: 0 ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H04 0813 Serial number: Coding: 000007 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710 ROD: EV_Immo_UDS_VDD_RM09_SE25.rod VCID: EA98820A0DC09A6E40-80BE No fault code found. ------------------------------------------------------------------------------- Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb Part No SW: 5K0 905 861 C HW: 5K0 905 861 C Component: ELV-PQ35 H21 0240 Revision: 00000000 Serial number: 14000125876005 Coding: 4900000000000000 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_ELVMarquMPVW36X A01001 ROD: EV_ELVMarquMPVW36X.rod VCID: B02C5062EB9C20BE4E-80E4 No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 Cannot be reached ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 561 959 760 B HW: 561 959 760 B Component: MEM-FS H04 0182 Revision: AA000000 Serial number: 00000105342645 Coding: 00581B0000000000000021010100202020202120202020 Shop #: WSC 09003 957 00200 VCID: A208AA2ABD70822EC8-80F6 1 Fault Found: 00457 - Control Module for Network (J519) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels: 1T0-035-680.clb Part No SW: 3C0 035 684 P HW: 3C0 035 684 P Component: RNS-MID H27 5382 Revision: AB001001 Serial number: VWZ6Z7R7224015 Coding: 04090042010000A6000B Shop #: WSC 23052 002 1048576 VCID: B02C5062E39C20BE4E-80E4 Subsystem 1 - Part No: 7L6 919 859 Component: NAR V8 8112 1 Fault Found: 02635 - Tuner Not Enabled/Activated 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 5 Reset counter: 228 Mileage: 71464 km Time Indication: 0 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb Part No SW: 561 959 701 A HW: 3C0 959 793 C Component: TUER-SG FT 002 0525 Revision: 12110009 Serial number: 0008552180 Coding: 0405FD Shop #: WSC 09003 957 00200 ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001 ROD: EV_TSGFPQ25BRFVW46X.rod VCID: 9C7494D29714B4DE02-80C8 Slave Driver: Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Component: J388__TSG_HL 006 5470 Serial number: 14102630140613191023 Coding: 800000 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K0 909 144 R Component: EPS_ZFLS Kl. 215 3501 Revision: 00H22000 Shop #: WSC 01357 011 00200 VCID: B93A6D46F0E6E1F6F9-80EC 2 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 Freeze Frame: Voltage: 12.50 V DU Temperature: 31.0°C RPM: 1498 /min Speed: 0.0 km/h Speed: 0.0 km/h Count: 0 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 228 Mileage: 71466 km Time Indication: 0 Date: 2016.03.08 Time: 17:45:11 Freeze Frame: Voltage: 12.50 V DU Temperature: 31.0°C RPM: 1498 /min Speed: 0.0 km/h Speed: 0.0 km/h Count: 0 ------------------------------------------------------------------------------- Address 47: Sound System (R12) Labels: 5K0-035-456.clb Part No SW: 5C6 035 456 A HW: 5C6 035 456 A Component: KonzernAmp10K 6815 Revision: -------- Serial number: EAA098A0144697 ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001 ROD: EV_AudioVerst10KanalSTT3.rod VCID: A600B63AD9587E0EA4-80F2 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb Part No SW: 7N0 907 532 HW: 7N0 907 530 AM Component: EZE_2 H55 1653 Revision: H55 Serial number: 28061403000506 Coding: 01030108 Shop #: WSC 09003 957 00200 VCID: EFAE931E3E227F4617-80BA Subsystem 1 - Part No SW: 561 959 591 A HW: 561 959 591 A Component: J245 P05 9BA3 H08 0005 Coding: 181100 Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B Component: Analoguhr 008 0005 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb Part No SW: 561 959 702 A HW: 3C0 959 792 C Component: TUER-SG BT 002 0525 Revision: 14110009 Serial number: 0008587165 Coding: 0405FC Shop #: WSC 09003 957 00200 ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001 ROD: EV_TSGBPQ25BRFVW46X.rod VCID: 9D7299D68C0EBDD6F5-80C8 Slave Passenger: Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Component: J389__TSG_HR 006 5470 Serial number: 14102631140627144210 Coding: 800000 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels: 1T0-035-680.clb Part No SW: 3C0 035 684 P HW: 3C0 035 684 P Component: RNS-MID H27 5382 Revision: AB001001 Serial number: VWZ6Z7R7224015 Coding: 04090042010000A6000B Shop #: WSC 23052 002 1048576 VCID: B02C5062E39C20BE4E-80E4 Subsystem 1 - Part No: 7L6 919 859 Component: NAR V8 8112 1 Fault Found: 02635 - Tuner Not Enabled/Activated 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 5 Reset counter: 228 Mileage: 71464 km Time Indication: 0 ------------------------------------------------------------------------------- Address 75: Telematics (J949) Labels: None Part No SW: 561 035 285 HW: 561 035 285 Component: OCULowUSA 014 0102 Serial number: 000003554140523 Coding: 02140102C2423A007F1606000000 Shop #: WSC 131071 1023 2097151 ASAM Dataset: EV_OCULow 001010 ROD: EV_OCULow.rod VCID: D3E63FEEBA4A3BA613-8086 2 Faults Found: 0041 - Databus U1123 00 [008] - Received Error Message Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 228 2103041 - Control Module B1788 F0 [009] - Start Prohibition Deactivated Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 8 Fault Frequency: 1 Reset counter: 188 Mileage: 71466 km Date: 2016.03.08 Time: 17:47:39 ------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels: 5N0-035-729.clb Part No SW: 5N0 035 729 A HW: 5N0 035 729 A Component: TELEFON H05 0592 Revision: 1B001001 Serial number: 00007666170901 Coding: 0A10030080010110 Shop #: WSC 23052 002 1048576 ASAM Dataset: EV_UHVUMI 001007 ROD: EV_UHVUMI.rod VCID: AE104E1AF1A8364E5C-80FA No fault code found. End-------------------------(Elapsed Time: 02:31)--------------------------
