Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Which gateway to choose
    Dec 2015
    When auto scanning my 16 golf r i get the message unable to find gateway, which gateway should i choose manually I don't see golf mk7 ,other golf? special golf?
    Thx
    Administrator Andy's Avatar
    Sector 7G
    Got the ignition turned on? That message is not normal.
    Dec 2015
    yes ignition is on
    Jun 2014
    Newcastle, England
    Are you able to select an individual module? Such as ECU-01 or even the CAN Gateway-19?
  5. Likes Uwe, Dana liked this post
    United States
    I see you noted a 2012 JSW in addition to the 2016 R. If the R won't communicate at all please try the JSW since that vehicle is also CAN.
    Dec 2015
    jetta works i did some coding already trying to get R to work with VCDS uploading ASAM updates; hopefully that will do it
    thx
    Dec 2015
    BTW what is ASAM ?
  9. #8
    Dec 2015
    No luck on R
    In self test unable to ping network
    once i get to cloud functions i get server error or i get to coding (7) but there are no disruptions for codes like i see in jetta
    thx
  10. #9
    Lansdale, PA
    What happens when you click [select] [Can Gateway] ? Does it display information?
  11. Likes Dana liked this post
  12. #10
    Jun 2014
    Newcastle, England
    Quote Originally Posted by bonoman68 View Post
    BTW what is ASAM ?
    See how ASAM is highlighted in green? Hover your mouse cursor over it and the description appears as a ToolTip.
  13. Likes Dana, Uwe liked this post
