Results 1 to 10 of 10
Thread: A3, 2016, Comfort Turn Signal Coding - Fail – Security Code Required
    Mar 2016
    Question A3, 2016, Comfort Turn Signal Coding - Fail – Security Code Required
    ...as the title states. How do I make the change? Any ideas?
    Thanks,
    Chaz
    VCDS Version: 15.7.4.1
    Data version: 20160216
    VIN: WAUB8GFFXG1036768   License Plate:
    Mileage: 984km-611mi   Repair Order:
    Chassis Type: FF (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 52 55 5F 6C
    VIN: WAUB8GFFXG1036768   Mileage: 984km-611miles
    Address 01: Engine (J623-CNTC)       Labels: 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 0A1D00124426000F3000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
       ROD: EV_ECM20TFS0205G0906259D_AU37.rod
       VCID: 2F43E43376B49546D7-807A
       Part No SW: 0D9 300 013 B    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4902
       Revision: 06253104    Serial number: TFK01508191522
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021_AU37.rod
       VCID: 160D31D7E92E448EB4-8042
       Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
       Component: ESC           H42 0623
       Revision: 00000000    Serial number: 92275000008168
       Coding: 13FF6A9234230A72017E030681CB29C8562C5080C08194B6024100548208
       ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
       VCID: 79D71A6BF8708BF639-802C
       Revision: 00021000    Serial number: 0377566252
       Coding: 030C0C
       ROD: EV_KessyHellaMQBAB_AU37.rod
       VCID: 3A55C567BDF640EE70-806E
    Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
       Component: AC Automat    H13 0060
       Revision: 20027000    Serial number: 00000000718089
       Coding: 03000014010000000000000000001400
       VCID: 334BE8439A9CB1A6B3-8066
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
       Component: BCM MQBAB MNA H24 0175
       Serial number: 01061523901093
       Coding: 04151A46C04122F541C04004511007000800000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 7F23F473E654A5C607-802A
       Slave 1:
       Component: WWS371 150721  042 0585
       Serial number:         150808004518
       Coding: 0A47F7
       Slave 2:
       Serial number: 20560377
       Coding: 00006C
       Slave 3:
       Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
       Serial number: 25 06 2015  00000392
       Serial number: 00000000000063398600
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST000H6D1100000
       Coding: 101F00
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
       Revision: --------    Serial number: 39331524106920
       Coding: 0010150011
       ROD: EV_EPHVA18AU3700000_AU37.rod
       VCID: 43ABB883CA3C012623-8016
       Serial number: 003GCR03ALW
       Coding: 9DCCFCC0000000005000001AC24800000065
       VCID: 47B3AC93FE042D06FF-8012
       Seat belt tensioner; left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34230167A07091540713
       Coding: 333135
       Seat belt tensioner; right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34230168A07091540856
       Coding: 333135
       Seat occupant detection; front passenger side:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 694000000000001E3GNX
       Coding: 303333
       Subsystem 4 - Part No SW: -----------    HW: 480 002 608 15
       Serial number: 35700000000F7A48661T
       Subsystem 5 - Part No SW: -----------    HW: 480 002 608 15
       Serial number: 35800000000C6A48661Q
       Subsystem 6 - Part No SW: -----------    HW: 480 402 408 15
       Serial number: 3510002B71CF1D33E24B
       Subsystem 7 - Part No SW: -----------    HW: 480 402 808 15
       Serial number: 3520002B11C1EFA5F19L
       Subsystem 8 - Part No SW: -----------    HW: 480 400 705 15
       Serial number: 3550002C71A878726142
       Subsystem 9 - Part No SW: -----------    HW: 480 400 705 15
       Serial number: 3560002C51A87872322/
       Part No SW: 8V0 953 521 FH    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0110
       Revision: --------    Serial number: 27081508490861
       Coding: A018
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 052F669B8488FF164D-8050
       Part No SW: 8V0 920 960 M    HW: 8V0 920 960 M
       Component: KOMBI         H03 6420
       Coding: 0BE518192B80D7050200AA001800000000000000
       VCID: 45AFA69BC4083F160D-8010
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2223
       Revision: --------    Serial number: 29081510802622
       Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
       ROD: EV_GatewConti.rod
       VCID: 75CF165BD468EF965D-8020
       Serial number: 06 08 2015  B0015107
    Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
       Serial number: HA1-00014.07.15
       Coding: 0001
       ROD: EV_AllWheelContrHA1VW37X_AU21.rod
       VCID: 4AB595A7ED16D06EE0-801E
       Revision: 00000000    Serial number: 15000188545010
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_AU37.rod
       VCID: 3449EB5F9F92B69EAA-8060
       Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
       Serial number: 110715BGA19147
       Coding: 00101B204000048000000002
       ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
       VCID: 41A7B28BD020133631-8014
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 0102
       ROD: EV_SteerAssisMQB.rod
       VCID: 44A9BB9FCF32061E1A-8010
       Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
       Serial number: 180715BGH19574
       Coding: 001013204000048000000002
       ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
       VCID: 40A1B78FDB2A1A3E3E-8014
    Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
       Coding: 012A000101000000
       ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
       Part No SW: 8V0 035 844 C    HW: 8V0 035 844
       Component: MU-S-S-US     013 0660
       Serial number: A7A02408150931
       Coding: 01730100FF0A000011220001001A00002F0001440100010002
       ASAM Dataset: EV_MUStd6C3PASE 002020
       ROD: EV_MUStd6C3PASE_AU37.rod
       VCID: 3957DA6BB8F04BF679-806C
       Seat Adjustment Driver Side:
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0014
       Serial number: AUZ8Z9FY30CLC5
       Sound System:
       Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
       Serial number: C1000019061500040051
    Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
       Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
       Component: MQB RVC Mid   H07 0140
       Coding: 027300010201000300
       ASAM Dataset: EV_2CamSysRearPASE 006016
       ROD: EV_CamSysRearPANAAU914.rod
       VCID: 3041E74F6B8A8ABECE-8064
    End-------------------------(Elapsed Time: 03:28)--------------------------
    Below is a link showing VCDS screen shots during the process.
    Verified VCDS User DJAlix's Avatar
    Apr 2015
    London, United Kingdom
    Should be 31347.
    VAG Car Coding
    Adaptation | Coding | Diagnostic | Retrofit - London, United Kingdom
    Authorised VW Group Services Provider and Independent Repairer
    @vagcarcoding
  3. Likes Uwe liked this post
    Mar 2016
    DJAlix
    Thanks for the reply, I'll check again, however, don't remember seeing a field to enter a security code. As I'm new to VCDS is there a "global" security code entry location or would it be a pop up entry box?
    After I clicked the OK on security, it just failed with a condition of, "security code required - failed", no request for a code entry.
    Regards
  5. Likes Uwe liked this post
  6. #4
    Tartu, Estonia
    Check under the button where you press Coding and Adaption.
    The world is my oyster...
  7. Likes Uwe liked this post
  8. #5
    Apr 2015
    Not a problem
    There is no "global" security access field as each control module can have it's own individual (some times multiple) code. To enter a code do the following:
    - Enter the needed control module
    - Select the "Security Access - 16 Button"
    - In the new box that pops up enter your code and select Do It!
    - Proceed to Adaptations or Coding
    The security code you entered will be valid until you exit / disconnect from the control module. If you need to go back in to the module to continuing modification just repeat the above process.
    Something to note, 9 times out of 10 if the code in question is known to Ross-Tech it will be shown within a "tooltip bubble" on mousing over the security access code enter box.
    VAG Car Coding
    @vagcarcoding
  9. Likes DV52, Uwe, Chaz, Dana liked this post
  10. #6
    Mar 2016
    DJAlix,
    I followed your instructions and it worked as described, the change was accepted. Thank you!
    Regards,
    Chaz
  11. Likes Uwe, Dana, DJAlix liked this post
  12. #7
    Apr 2015
    Quote Originally Posted by Chaz View Post
    DJAlix,
    Regards,
    Chaz
    More than Welcome
    When you have some time check out this A3 8V VCDS PDF I am working on
    VAG Car Coding
    @vagcarcoding
  13. Likes Uwe liked this post
  14. #8
    Mar 2016
    DJAlix,
    Nice professional document you're cobbling together there, nicer than a lot of “manufacturers” documents Ive see. More importantly it should contain a valuable quantity of information as it progresses.
    Keep up the good work!
    Chaz
  15. Likes DJAlix liked this post
  16. #9
    Verified VCDS User andyvee's Avatar
    Rossendale, Lancashire, UK
    Have a look at the link in my sig - some of the Octavia III tweaks will apply to the A3 as well
  17. Likes Uwe, DJAlix liked this post
  18. #10
    Apr 2015
    DJAlix,
    Chaz
    Thanks Chaz! Is a major update coming very soon
    VAG Car Coding
    @vagcarcoding
