TPMS 3AA907273H into Passat B6
berndh
C?ID=66436
I've installed direct TPMS module 3AA 907 273 H into my Passat B6 with the following hardware:
B7/B8 TPMS module:
Address 65: Tire Pressure
Control Module Part Number: 3AA 907 273 H
Component and/or Version: RDKBERU30 H04 0012
B7 BCM:
Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
Part No SW: 3AA 937 087 J HW: 3AA 937 087 J
Component: BCM PQ47 H++ 421 0465
Coding: 000800000000000000980088200009FE67F56888417D8760648820240040
B7 CCM:
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Part No SW: 3AA 959 433 B HW: 3AA 959 433 B
Component: KSG PQ47 ELV 043 0645
Coding: 18910A0051034E763602951570084FCE705900
CC Tacho:
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 880 R HW: 3C8 920 880 R
Coding: 161F01
B7 Gateway:
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN
Component: J533 Gateway H56 1642
Revision: H56 Serial number: 101013F1001943
Coding: 462006
But I get an error on the Tacho:
10486016 - Control module
B2001 00 [009] - Incorrect software version
Reset counter: 142
Any help appreciated.
I've disabled the ABS indirect TPMS by changing the coding back to 0000283.
Is the tacho not supporting this version of the TPMS ECU?? Or am I forgetting something???
Thanks for all the help
Spacewalker
Poland
C?ID=159607
273 H working only with Component Protection. As far as I know 273 F is the latest working good for 5Q0 hardware
diskoboy
C?ID=50403
There is no component protection on any 3AA modules
What is the hardware / software version of your tacho?
Spacewalker
Poland
C?ID=159607
It is component protection .
Already tested brand new H module so I know what I am talking about
Early RDK module 3AA SW with 3AA Hw
latest F and H use 5Q0 Hw
H - working only with latest cluster (I guess is SW100x) due to component protection supporting
F - working with older cluster.
To run H you must have compatible parts (GW, cluster) and match it together online. Even if you have right parts in older car , you still need Enable it online.
However - H can be downgrade to F and fully use w/o any Activation
berndh
C?ID=66436
How can I downgrade the H module to F Version? I do have odis but not the F version SW.
My Tacho is hw03 and software 0703. It would be possible to upgrade my tacho to swx002, but does the H version then work? Or do I need to match these online?
I know for instance that just upgrading the tacho to the x002 would work standalone, but not sure about adding a component protected module to it?
berndh
C?ID=66436
Nu tacho is hw 03 and software 0703. However I can upgrade this tacho to x002 if this would work with the H module.
Spacewalker
Poland
C?ID=159607
Higher SW will only support devices with Component Protection,
Are you able to match those device toogether ?
Most people think if controler is with Component protection, they need only cluster with this
but component protection is a security check which need to be match too
berndh
C?ID=66436
And how to downgrade the H to F? Is that someting I can do using ODIS ?? I don't see an eeprom on the pcb of the module. So the sw is stored in the MC95xxxx controller I guess.
Would the F version work with my 3AA 907 275F sensors?
berndh
C?ID=66436
Btw, I did not get any error on the RDK module 65 though. I would have expected that the module would not work with in the car it would have thrown an error. But I could not long-code the module either. The only error I got was the incorrect SW version in the Tacho. Therefor I would expect upgrading the Tacho SW, it would be able to communicate with the TPMS H version.
Spacewalker
Poland
C?ID=159607
As far as I know all cluster SW with X*** are not official.
When you look into ETKA for RDK module 273H is relisted since 05.2015 -> current
Cluster SW you talking X002 -is out 6.2014 as I remember , so cluster was a year before RDK module.
perhaps is supporting some Component protection , but even ..... this must be activate and match online
golfi_vend
Tartu, Estonia
C?ID=195131
...However I can upgrade this tacho to x002 if this would work with the H module.
You probably need SW1000+.
I hardly think you have official ODIS, so this discussion doesn't belong here what and why to flash. Otherwise you would know ;)
Spacewalker
Poland
C?ID=159607
I hardly think he dont , otherwise he will have access to official files.
rado20vt
C?ID=24542
Not entirely true.
I have official ODIS supplied and registered through VAG for programming firmware and checking DTCs on VAG parts we supply but I dont have access to official files nor do I know what software would be compatible with other components
golfi_vend
Tartu, Estonia
C?ID=195131
TPMS 3AA 907 273 H fully working with no faults codes:
Also extra menu available. Cluster SW1008
Monday,01,May,2017,17:20:39:57784
VCDS Version: 17.4.1.1 (x64)  HEX-V2 CB: 0.4336.4
Data version: 20170413 DS270.4
VIN: WVWZZZ3CZCE   License Plate:
Mileage: 41140km-25563mi   Repair Order:
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 18 19 22 25 2E 36 37 3C 42
          44 46 47 4F 52 53 55 56 61 62 65 69 6C 72 77 A5
VIN: WVWZZZ3CZCE   Mileage: 41140km-25563miles
Address 01: Engine (0-32-BWS )       Labels: None
   Part No SW: 03H 906 023 L    HW: 03H 907 309 A
   Component: 3,6 FSI EU5   H04 2758
   Revision: MFH04---    Serial number: 00000000000000
   Coding: 001D0012246600000000
   Shop #: WSC 00017 780 00200
   ASAM Dataset: EV_ECM36FSI01103H906023L 002011
   ROD: EV_ECM36FSI_002_VW46.rod
   VCID: 2B000D0F638B2BDFC62-807E
Readiness: 1110 0101
   Part No SW: 02E 300 014 C    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3108
   Revision: 05551213    Serial number: 00001203072091
   Shop #: WSC 01760 780 00200
   VCID: 127EB0EBE8619A17E54-8046
   Part No SW: 3AA 614 109 AH    HW: 3AA 614 109 AD
   Component: J104   C2 450M V545 0023
   Revision: --H07---    Serial number: 00000004785076
   Coding: 0115108
   Shop #: WSC 05311 000 08193
   VCID: 73B0D56FF7BB331F4E2-8026
   Part No SW: 3AA 907 044 E    HW: 3AA 907 044 E
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 0018004808
   Shop #: WSC 17301 666 28888
   VCID: 323E106B44A17A17854-8066
   Revision: BD421001
   Coding: 0008000000000000008C0288B40010EC2375000865202D20E480662400C9
   Shop #: WSC 00015 115 00054
   VCID: 41DC4FA7F187D18F0CE-8014
   Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
   Component: WWS464 120711  23 0604
   Serial number: 120711
   Coding: 00B795
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0024
   Serial number: Y11M09D27h09m48s26S1
   Coding: 0280DD
Address 10: Park/Steer Assist (J446)       Labels: 3AE-919-475.clb
   Part No SW: 3AE 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0018
   Revision: --------    Serial number: 28231227910709
   Coding: 318103
   Shop #: WSC 51101 142 80368
   ASAM Dataset: EV_EPHVA18VW47X0000 001006
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 3FD8495F87F3A77F7AA-806A
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000516390
   Coding: 0010000
   Shop #: WSC 02224 127 174003
   VCID: 382A2243AE5D9047BB0-806C
Address 14: Susp. Elect. (J250)       Labels: 3C0-907-376.clb
   Revision: 00000000    Serial number: 27091103970001
   Coding: 030180
   Shop #: WSC 05314 000 00000
   VCID: 2708F13F7FE30FBF22A-8072
   Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
   Component: J234__708 VW10 HI   1918
   Revision: 22014000    Serial number: 003JZPLKYF33
   Coding: 0012344
   VCID: 4BC06D8FCFCB0BDFE62-801E
   Subsystem 1 - Serial number: 6332MTS626122461
   Subsystem 2 - Serial number: 6342MTS627872451
   Subsystem 3 - Serial number: 6351HTS6LA1IDAKJ
   Subsystem 4 - Serial number: 6361HTS6SBJHDAKR
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20110926101433
   Coding: 299AA70001
   Shop #: WSC 00015 115 08193
   VCID: 71BCDF678127010FBCE-8024
   Coding: E30000
   Part No SW: 3C8 920 881     HW: 3C8 920 881
   Component: KOMBI         H03 1008
   Coding: 140F000000
   Shop #: WSC 17226 001 1048576
   VCID: 6A8EC80BACF1F2D7FD4-803E
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 5K0 963 272 B
   Component: Standheizer     022 3907
   Revision: 00022000    Serial number: 09020188000000
   Coding: 0031132
   VCID: 2F38191F5B1357FFEAA-807A
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 11061600F10011
   Coding: 469006
   Shop #: WSC 45632 456 32456
   VCID: 7BA0FD4FD3EB7B5F162-802E
   Part No SW: 0BS 907 554 C    HW: 0BS 907 554 C
   Component: Haldex 4Motion      4016
   Coding: 0000005
   VCID: 46D65CBBD4A9F6B739C-8012
   Part No SW: 3AA 959 799 A    HW: 3AA 959 799 A
   Component:    IMMO         083 0402
   Revision: 00083000    Serial number: VWZCZ000000000
   Revision: A1001003    Serial number: 7660948599
   VCID: 290CF70769F739CF34E-807C
03138 - Input AUX IN
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 69
                    Mileage: 41143 km
                    Date: 2017.05.01
                    Time: 17:18:22
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 B    HW: 3C8 959 760 B
   Component: Sitzmemory    H02 1001
   Revision: 00H02000
   Coding: 000039
   VCID: 34321673BE357427978-8060
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 F    HW: 1T0 035 680 H
   Component: RNS-MID       H61 4020
   Revision: AB001001    Serial number: VWZ6Z7L7258061
   Coding: 04050002010000A0200F
   VCID: 313C1F674127410FFCE-8064
   Part No SW: 3AA 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0030
   Revision: 00H02000    Serial number: 6PZ 010 316-06
   Coding: 0000174
   Shop #: WSC 00046 000 00000
   VCID: 3A2E384B905182574D4-806E
   Subsystem 1 - Part No: 3AA 907 568 D
   Component: J770  SWA Slave H02 0030
   Subsystem 2 - Serial number: 6PZ 010 316-26
   Subsystem 3 - Serial number: 5F04.08.1100H020003C330639˙
   Subsystem 4 - Serial number: 330639˙
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0535
   Revision: 12110009    Serial number: 0003520120
   Coding: 0011FF
   Shop #: WSC 05311 115 08193
   VCID: 6D84C3179D1FE5EF986-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000002320213
   Coding: 010098
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.300 1002
   Revision: 1AH03734    Serial number: 00112640219501
   Coding: 0000258
   Shop #: WSC 01507 666 61265
   VCID: 3C223E539A65BC675F8-8068
Address 46: Central Conv.        Labels: 3C0-959-799-46.clb
   Component: 09 KESSY PQ47   083 0346
   Coding: 01900A0001C60E76360494157200CFCE7058011324379C
   Shop #: WSC 01730 666 04577
   Subsystem 4 - Part No: 3AA 962 243
   Component: GEB.F.Heckoef       0719
Address 47: Sound System (R184)       Labels: 5K0-035-456.clb
   Part No SW: 3AA 035 466     HW: 3AA 035 466
   Component: KonzernAmp12K H03 6904
   Revision: --------    Serial number: A1108A00010558
   ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
   ROD: EV_AudioVerst12KanalSTT1.rod
   Component: EZE_2         H56 1682
   Coding: 00000009
   VCID: 6FB8D91F979317FFAAA-803A
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0003
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0535
   Revision: 14110009    Serial number: 0003525533
   Coding: 0011FE
   VCID: 6E86C41B90191EF7A1C-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000002320294
   Coding: 010098
Address 53: Parking Brake        Labels: User\3AA-907-801.lbl
   Part No SW: 3AA 907 801 H    HW: 3AA 907 801 G
   Revision:   H19       Serial number: 00000000288415
   Coding: 0022157
   Shop #: WSC 17301 666 17767
   VCID: 36362C7BA4496637A9C-8062
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H04 0111
   Coding: 073A00104F000200
   VCID: 3728217FAFC39F3FB2A-8062
   Subsystem 1 - Part No SW: 1T0 941 329 A    HW: 1T0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 390000
   Subsystem 2 - Part No SW: 1T0 941 329 A    HW: 1T0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 390000
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Component: Batt.regelung H56 1682
   Coding: 03260172
   VCID: 71BCDF6781A7010FBCE-8024
   Subsystem 1 - Part No SW: 3AA 915 181     HW: 3AA 915 181
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370442594
   Part No SW: 3AA 907 273 H    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0012
   Serial number: 40000000032852
   ROD: EV_RDKBERU30_006_VW36.rod
   VCID: 392C274799D7894F44E-806C
Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
   Revision: 3A001001    Serial number: 00008030245160
   Coding: 0100000100000000
   VCID: 303A1A634A2D4807F30-8064
   Part No SW: 3C8 907 441     HW: 3C8 907 441
   Revision: 00H11000    Serial number: 525PA8-J285690
   Coding: 0030008
   VCID: 6788B13FB363CFBFE2A-8032
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0982
   Revision: --------    Serial number: 35502105190036
   Coding: 020000010100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 2412E6330E55E4A7078-8070
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3AA-980-654.clb
   Part No SW: 3AA 980 654 D    HW: 3AA 980 654 A
   Component: MFK_Gen1      H08 0300
   Serial number: 0156503661
   Coding: 01010200010202110200040001010000
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
End----------(Elapsed Time: 02:21, VBatt start/end: 11.3V/11.3V)-----------
Bwant
C?ID=130834
So the 'H' version is a direct replacement for the 'F' version or is there a problem with component protection?
golfi_vend
Tartu, Estonia
C?ID=195131
No CP related fault so far. You'll need high sw cluster for the "H" to work.
Bwant
C?ID=130834
I believe I'm on sw1007 at the moment. Is this high enough Golfi?
Bwant
C?ID=130834
Thanks. I'll buy one and try it.
