Hi All,
I used to own a 2010 Audi A5 and had a Hex-USB+CAN interface fully registered with Ross-Tech. It was great so thankyou for everything with that
I now have a new 2016 Audi Q7 (4M) and understand from the website that the HEX-USB+CAN interface does not support this new model (4M). However on the Ross-Tech site you state:
"We do not know if or when we will be able to make the HEX-USB+CAN interface compatible with those models (and other future ones using the MLB 2 platform) so if support for those models is important to you, we recommend purchasing a HEX-NET instead."
Does this imply the HEX-NET interface does work with the 4M Q7? I want to enable Needle Sweep (simple example) and have been told this coding is required (and yes, this is specifically for the 2016 Q7 4M model):
The following code is to be applied:
select STG 17 (switchboard)
STG coding -> function 10
byte 1
Enable Bit 0
Is the HEX-NET fully registered interface capable of doing this? (and even other settings?)
Many thanks in advance
Andy
byte 1
Enable Bit 0
Andy
