Results 1 to 2 of 2
Thread: RNS-510 Retrofit to Jetta Hybrid and Energy Flow display
    Hi there,
    I was wondering if anyone has ever attempted this before.
    I have succesfully installed my RNS-510 in my 2013 Jetta Hybrid Trendline, which did not come with the Energy Flow display. I've seen mention of the early Touareg Hybrid displaying energy flow on an RNS-510, so in theory it's possible.
    If anyone has any suggestions it would be most welcome :)
    Here's an autoscan.
    Monday,17,February,2014,14:17:17:09090
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    VIN: 3VW637AJ1DM280254   License Plate: HYBRID
    Chassis Type: AJ (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 51 52 56 61 62 72
              77 8C
    Address 01: Engine (J623-CNLA)       Labels: None
       Part No SW: 04E 906 023     HW: 04E 907 309 B
       Component: 1.4l TFSI hy  H01 5631
       Revision: V8H01---    Serial number: 00000000000000
       Coding: 00250012442401000000
       Shop #: WSC 95243 999 19308
       ASAM Dataset: EV_ECM14TFS01104E906023 002018
       ROD: EV_ECM14TFS01104E906023.rod
       VCID: DDBBDF0ECC128CF65F5-8088
    20575 - Inverter Cooling System
              P0A93 00 [096] - Inadequate Performance
                        Mileage: 3635 km
                        Date: 2010.14.14
                        Time: 18:46:58
    5604 - Park/Neutral Switch Input Circuit
              P0850 00 [032] - Open or Short to Plus
                        Mileage: 3635 km
                        Date: 2010.14.14
                        Time: 18:46:58
    10203 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [036] - -
                        Mileage: 4038 km
                        Date: 2010.14.21
                        Time: 08:05:34
    10593 - Cylinder 3
              P0303 00 [036] - Misfire Detected
                        Mileage: 4038 km
                        Date: 2010.14.21
                        Time: 08:05:39
    Address 02: Auto Trans        Labels: 0CW-927-769.clb
       Part No SW: 0CG 300 045 A    HW: 0AM 927 769 H
       Component: GSG DSG AG7     431 4002
       Revision: 00043014    Serial number: CU501212165946
       VCID: 27573DE696CE9626F59-8072
    005913 - Functionality limited due to Engine Control Module
                   P1719 - 000 -  - Intermittent
                        Reset counter: 9
                        Mileage: 4038 km
                        Date: 2010.14.21
                        Time: 08:05:02
       Part No SW: 1K0 907 379 AR    HW: 1K0 907 379 AR
       Component: ESP MK60EC1   H31 0135
       Revision: 00H31001
       Coding: A14B400C492A20FA850D02E9921D0440211800
       VCID: 8201CC721D2C130E027-80D7
       Part No SW: -----------    HW: -----------
       Component: Climatronic   0202
       Revision: --------
       Coding: 0010404002
       Shop #: WSC 00066 000 00118
       ASAM Dataset: EV_ACClimaBHBVW361Hybri 001001
       ROD: EV_ACClimaBHBVW361Hybri.rod
       VCID: EFE795C636BE0E66FD9-80BA
       Air Conditioning Compressor:
       Subsystem 1 - Part No SW: 5C0 820 803 F    HW: 5C0 820 803 F
       Component: J842 eKK  H03 0001
    10489856 - No Basic Setting
              B2010 00 [009] - -
                        Reset counter: 118
    9480753 - A/C Compressor
              U103B 00 [008] - No Communication
                        Reset counter: 189
                        Mileage: 4038 km
                        Date: 2010.14.18
                        Time: 18:46:16
    9477872 - AC Compressor First Run-In
              B109E F0 [009] - Not Performed
                        Reset counter: 118
    13646848 - A/C Compressor
              U103C 00 [008] - Implausible Signal
                        Reset counter: 182
                        Mileage: 3574 km
                        Date: 2010.14.14
                        Time: 15:44:27
       Part No SW: 5K0 937 084 J    HW: 5K0 937 084 J
       Component: BCM PQ35 B    021 1068
       Revision: BG021001
       Coding: 2D200A3A812F3EC400880881040000440100008640808D605C8026000043
       VCID: 3973EB9EB07A10D693D-806C
                        Fault Status: 00101010
                        Reset counter: 190
                        Mileage: 4038 km
                        Date: 2010.14.21
                        Time: 08:05:00
                        Voltage: 13.90 V
       Part No SW: 5C0 959 655 J    HW: 5C0 959 655 J
       Component: AirbagVW10    101 0911
       Serial number: 003KLD00571R
       Coding: 00004838
       Shop #: WSC 00066 790 00185
       ASAM Dataset: EV_AirbaVW10SMEVW360 001024
       ROD: EV_AirbaVW10SMEVW360_VW01.rod
       VCID: 3973EB9EB87A10D693D-806C
       Serial number: 6940000Y130000RHPU0R
       Coding: 303036
       Serial number: 3572MSME2C077375ZZZ-
       Serial number: 3582MSME5E087375ZZZ0
       Serial number: 3516KSME5E310A22ZZZQ
       Serial number: 3526KSME7A307F21ZZZZ
       Serial number: 3556LSME290E3821ZZZX
       Crash sensor for front airbag; passenger side:
       Serial number: 3566LSME5F493721ZZZ+
       Part No SW: 1K5 953 507 T    HW: 5K0 953 549 B
       Component: Lenks.Modul   008 0090
       Revision: --------    Serial number:  90440MAH000X0
       Coding: 088A140000
       ROD: EV_SMLSNGKUDS.rod
       VCID: 42818C72D5AC530EC27-8017
       Component: E221__MFL-TAS  H31 0037
       Serial number: 0002361 FLE 20130105
       Coding: 820000
       Part No SW: 5C6 920 870 D    HW: 5C6 920 870 D
       Component: KOMBI         H08 0710
       Coding: 381E00
       ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
       VCID: 2C5DC2CA4728B57E18B-8079
       Part No SW: 7N0 907 530 AG    HW: 7N0 907 530 AG
       Component: J533  Gateway H53 1634
       Revision:   H53       Serial number: 27021303281599
       Coding: 351002
       VCID: 75EB27AEDCE2B4B6B75-8020
       Component: IMMO          H08 0710
       ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
       VCID: EAD184D20D5CEB4EAA7-80BF
    Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 3C0 035 684 K    HW: 3C0 035 684 F
       Component: RNS-MID       H61 4366
       Revision: AB001001    Serial number: VWZ6Z7L7294108
       Coding: 00010400000000900006
       VCID: 2B5FC1D64A26B246111-807E
       Subsystem 1 - Part No: 7L6 919 859
       Component: NAR V6  7963
    02633 - Antenna for Satellite Tuner
                        Fault Frequency: 19
                        Reset counter: 151
                        Mileage: 4032 km
                        Fault Frequency: 7
                        Reset counter: 151
                        Mileage: 4032 km
       Revision: 13110009    Serial number: 0006355144
       Coding: 0004B5
       Shop #: WSC 01383 790 50316
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: DBBFD116D20682C6211-808E
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  008 1508
       Serial number: 00000007588598
       Coding: 000490
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 69     3305
       Revision: 00H22000
       VCID: 3777EDA6466E06A6659-8062
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 5C0 907 080 E    HW: 5C0 907 080 C
       Component: VW361H0108000 H02 0535
       Revision: 00H02000    Serial number: 00000000000000
       Coding: 40020000000000000000
       ASAM Dataset: EV_DMCM04510115C0907080E 001021
       ROD: EV_DMCM04510115C0907080D.rod
       VCID: 254B37EE24C28436C75-8070
       Revision: 15110009    Serial number: 0006352806
       Coding: 0004B4
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: DCBDD20AD70885FE28B-8089
       Slave Passenger:
       Component: J389__TSG-HR  008 1508
       Serial number: 00000007607232
       Coding: 000490
    Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
                        Fault Frequency: 19
                        Reset counter: 151
                        Mileage: 4032 km
                        Fault Frequency: 7
                        Reset counter: 151
                        Mileage: 4032 km
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AG
       Component: Batt.regelung H53 1634
       Coding: 16660164
       VCID: F1E393BE288A1896EBD-80A4
       Subsystem 1 - Part No SW: 1S0 915 181 A    HW: 1S0 915 181 A
       Component: J367-BDM  H08 0181
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Revision: 1B001001    Serial number: 00007665015491
       Coding: 0A00000000010100
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA.rod
       VCID: 3A71F492BD7C1BCE9A7-806F
    9458195 - Control Module for Cellular Telephone
              B1052 13 [009] - Open Circuit
                        Reset counter: 150
                        Mileage: 4038 km
                        Date: 2010.14.18
                        Time: 18:54:24
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 5C6 915 182 B    HW: 5C6 915 182 B
       Component: BECM          H09 0601
       Serial number: 288 SYEQA02B31
       ASAM Dataset: EV_BECM06020115C6915182 005021
       ROD: EV_BECM06020115C6915182.rod
       VCID: 2A51C4D24DDCAB4EEA7-807F
    Last edited by Uwe; 03-05-2014 at 07:59 AM. Reason: Wrapped CODE tags around Auto-Scan
    United States
    The newer 7P VW Touareg uses the RNS-850 and that infotainment system is similar to the fiber optic (4G) A6/A7 Audi models.
    I don't know if this menu is possible but are you sure the Hybrid comparison vehicle had one of the older 7L6 Touareg specific RNS-510 units installed? If you happen to have a scan from the example vehicle please post it or a link to it.
  3. Likes Sebastian liked this post
