Page 8 of 8 FirstFirst ... 678
Results 71 to 80 of 80
Thread: Complicated MK5 Golf Steering Angle Sensor Fault
  1. #71
    Northern ireland
    Did you manage to get a chance to recode the SWCM? I'm quite interested to see what way this fairs out as I've had a few of these issues with different vehicles ALL with different successful repairs.
  2. Likes Jack@European_Parts liked this post
  3. #72
    Feb 2016
    Not yet mate. Hopefully I'll change and code the SWCM in the next two days. Either way, I'll be sure to update this thread with the resolution.
  5. #73
    Feb 2016
    Looks like it was the steering wheel control module. It's been fine and fault free for over a day (and many "testing" miles). The annoying thing is that it was the same module the previous specialist couldn't code in, so 70 lost there for no reason. Anyway, alls well that ends well. Thanks for the help everybody, especially Jack!
    It seems VW made some iffy SWCMs in 2007/2008 - a couple of other threads on the internet with Golfs of the same year with the same issue:
    http://forums.ross-tech.com/showthre...steering-fault
    http://www.vwaudiforum.co.uk/forum/s...-on!-2007-Golf
    Perhaps the Ross-tech wiki for 00778 can be updated with the info that steering wheel control module may be defective in 1K variant?
  6. Likes Uwe liked this post
  7. #74
    May 2016
    I'm going to bump this instead of creating a new thread since there is a lot of good information and i am having a similar issue with a 2009 GLI. I have several steering angle/abs faults, and there is a known issue with 2009s abs control module. is this linked to the steering column control module or separate? i am going to replace/run an adaptation on the abs control module first but curious on your thoughts. also it looks like in 2009 the steering control module was moved to the steering rack itself, so would that require replacing the whole rack? i'll post some of my log below. i omitted the other noise since i have a lot of other stuff going on.
    Tuesday,14,June,2016,18:25:34:03562
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: 3VWDA71K89M080050   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 62 72
    VIN: 3VWDA71K89M080050   Mileage: 118910km-73887miles
    0F-Digital Radio -- Status: Cannot be reached 1100
    Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0106
       Revision: 00H35001
       Coding: 113B600D492A00FA880B06E9921900413800
       VCID: 74E78B76D7B6C59E6A-8020
    16352 - Control Module - Electrical Error
                        Fault Status: 00101110
                        Reset counter: 123
                        Mileage: 118539 km
                        Count: 17474
                        Count: 32768
                        Count: 13056
                        Count: 96
                        Count: 48162
                        Count: 4203
                        Count: 5632
                        Reset counter: 79
                        Mileage: 118206 km
                        Count: 16387
                        Count: 32768
                        Count: 13056
                        Count: 8212
                        Count: 48896
                        Count: 4352
                        Fault Status: 01100101
                        Reset counter: 79
                        Mileage: 118206 km
                        Count: 16387
                        Count: 32768
                        Count: 13056
                        Count: 295
                        Count: 48896
                        Count: 4352
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 86
                        Mileage: 118206 km
                        Count: 16387
                        Count: 32768
                        Count: 13056
                        Count: 8193
                        Count: 48896
                        Count: 4352
    End-------------------------(Elapsed Time: 02:10)--------------------------
  8. #75
    Feb 2016
    Jamaica
    I've noticed something about the two autoscans that were posted. I don't see address #04 for the steering angle sensor. Is it a case where this model of the MK5 doesn't come with this version of sensor?
  9. #76
    Quote Originally Posted by NitrousOxide View Post
    It has an entry in the Installation List, but it's not directly accessible.
  10. #77
    Feb 2016
    Jamaica
    I have an issue where I was messing around with VCDS the day I got my cable then my steering angle sensor appeared to stop working.
    The symptoms that I experience is that anything related to the use of the steering angle sensor produces an error (such as ABS and ECS).
    The symptoms I see is that the Address #04 is intermittently reachable, then it "disappears" and can't be contacted. This cycle repeats. When I go into the steering #16 module and look at the values for the steering angle sensor, it starts out showing legitimate vales, then it gets erratic. No hardware changes were made to the vehicle. I messed around with VCDS (the first day I got it). Even restoring all the stock values from the INITIAL auto-scan and clearing the error codes does not resolve the issue.
    How can I tell if my car came with a steering angle sensor in address #04, or the other type that I'm reading so much about (for my MK5 Golf)?
    I'm creating a new thread with a valid Auto scan so as not to clutter this one.
  11. #78
    May 2016
    i finally got around to replacing the abs control module and should have my car back together this weekend. we'll see if that affected anything.
  12. #79
    Sep 2015
    Old thread, but this was very helpful. 1K-based Seat Leon was having same symptoms, main problem being "00778 - Steering Angle Sensor (G85) 014 - Defective - Intermittent". Steering assist warning light was mainly on, sometimes off for a short period and then back on. Others had been trying to repair this already, G85 sensor had been changed, and then changed again, but no help from that. They also changed slip ring.
    First auto-scan when I saw the car:
    Sunday,12,January,2020,16:49:31:26429
    VIN: VSSZZZ1PZ7R079xxx   License Plate:
    Mileage: 234550km-145742mi   Repair Order:
    Chassis Type: 1P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: VSSZZZ1PZ7R079xxx   Mileage: 234550km-145742miles
    62-Door, Rear Left -- Status: Sporadic communication error 1000
       Part No SW: 1P0 907 115 C    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: SEZ7Z0G3738970
       Coding: 0303000318070160
       Shop #: WSC 00191 264 15243
       VCID: 2B03FA6ECF03438F4C5-807E
       Revision: 00H11001
       Coding: 0006792
       Shop #: WSC 06441 785 00200
       VCID: 73B3220E57B35B4FC45-8026
       Part No: 1P0 907 044
       Component: ClimatronicPQ35 010 0502
       VCID: 698F4066057F919F7E9-803C
       Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
       Component: Bordnetz-SG     H52 2002
       Revision: 00H52000    Serial number: 00000004664032
       Coding: A98E0F2F00041000431D00000000000000017F075C4000
       VCID: 6C8139720A8D84B705F-8038
       Subsystem 1 - Part No: 1P0 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 300107 022  0601
       Coding: 00056208
       Shop #: WSC 06441
    01064 - Terminal 58d; Interior Dimming
                        Fault Status: 00101010
                        Reset counter: 91
                        Mileage: 234519 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 14.10 V
       Part No SW: 3C0 909 605 L    HW: 3C0 909 605 L
       Component: R3 AIRBAG VW8   029 2522
       Revision: 11029000    Serial number: 003B0P1XDPL3
       Coding: 0021043
       VCID: 2F3BEE7EFB1B3FAF60D-807A
       Subsystem 1 - Serial number: 6332MSME15290A13
       Subsystem 2 - Serial number: 6342MSME1636177C
       Subsystem 3 - Serial number: 6351HTS62ADG6PB7
       Subsystem 4 - Serial number: 6361HTS6LNF01AK6
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Component: J0527           636 0070
       Coding: 0002042
       VCID: 015F78C61D0F79DFC69-8054
       Component: E0221           005 0060
       Part No: 1P0 920 825 C
       Component: KOMBIINSTRUMENT VO3 0422
       Coding: 0002101
       Shop #: WSC 00011 888 96745
       VCID: 2E05F37AFC1136A76BB-807A
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H12 0170
       Revision:   H12       Serial number: 33001071190F96
       Coding: 3D3F034007000202
                        Reset counter: 72
                        Mileage: 233573 km
                        Time: 16:12:38
       Component: IMMO            VO3 0422
       Part No SW: 1T0 959 701 G    HW: 1K0 959 793 M
       Component: J386  TUER-SG FT    1129
       Revision: 31008001    Serial number: 00000029769207
       Coding: 0000176
       VCID: 3B23CA2E3F63D30FDC5-806E
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.154 H07 1806
       VCID: 3431E112123D1C771DF-8060
       Component:    KSG PQ35 G2  020 0203
       Coding: 808000005283CC7F0006050560084F01207C80
       Shop #: WSC 42500 205 63575
       VCID: 035372CE07136BCFD45-8056
    00893 - Switch for Trunk Handle (E234)
                        Fault Status: 00100111
                        Reset counter: 88
                        Mileage: 234395 km
                        Time: 10:48:05
       Part No SW: 1T0 959 702 G    HW: 1K0 959 792 M
       Component: J387  TUER-SG BT    1129
       Revision: 31008001    Serial number: 00000517778110
       Coding: 0000176
       VCID: 3C21C9323A6DD437D5F-8068
       Part No: 1P1 035 186 B
       Component: Radio BVX           0006
       Coding: 0040424
       Part No SW: 1K0 959 703 N    HW: 1K0 959 795 H
       Component: J388   TUER-SG HL   1108
       Revision: 11006001    Serial number: 00000001125975
       Coding: 0000144
       Part No SW: 1K0 959 704 N    HW: 1K0 959 794 H
       Component: J389   TUER-SG HR   1108
       Revision: 11006001    Serial number: 00000001016649
       Coding: 0000144
    End----------(Elapsed Time: 01:48, VBatt start/end: 12.3V/13.5V)-----------
    Lucky me, I found this thread and since the parts were quite similar, I thought that changing the steering wheel control module would be worth trying. And yes, it did help. Below is the auto-scan with new parts. Unfortunately I forgot to take the final scan when everything was working after some basic setting, but just imagine this without any fault codes:
    Friday,17,January,2020,18:01:51:26429
    Mileage: 234690km-145829mi   Repair Order:
    VIN: VSSZZZ1PZ7R079xxx   Mileage: 234690km-145829miles
    001089 - EVAP Emission Control Sys
                   P0441 - 002 - Incorrect Flow - Intermittent
                        Mileage: 234647 km
                        Time: 15:12:41
                        RPM: 834 /min
                        Load: 14.9 %
                        Temperature: 75.0∞C
                        Temperature: 18.0∞C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.224 V
       Revision: 00H11001
       Coding: 0006792
       Coding: 00056208
       Shop #: WSC 06441
                        Fault Frequency: 36
                        Reset counter: 91
                        Mileage: 234519 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 14.10 V
                        Reset counter: 91
                        Mileage: 234639 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.25 V
       Coding: 0021043
       Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
       Component: J0527           752 0101
       Coding: 0002042
       Shop #: WSC 06402 785 00200
       VCID: 78A915224ED53817F17-802C
    00888 - Wiper Switch for Intermittent Operation (E22)
    00895 - Cruise Control Switch (E45)
       Coding: 0002101
                        Reset counter: 72
                        Mileage: 233573 km
                        Time: 16:12:38
                        Reset counter: 91
                        Mileage: 234639 km
                        Time: 14:40:50
       Coding: 0000176
                        Reset counter: 88
                        Mileage: 234395 km
                        Time: 10:48:05
                        Reset counter: 91
                        Mileage: 234639 km
                        Time: 14:40:50
       Coding: 0000176
       Coding: 0040424
       Coding: 0000144
       Coding: 0000144
    End----------(Elapsed Time: 01:45, VBatt start/end: 12.5V/12.4V)-----------
    As proposed already in this thread, wiki page for fault code 00778 could mention that in some of these 1K-based cars, G85 being defective might well be actually J527 defective, if new G85 doesn't cure the problem.
  13. Likes Jack@European_Parts liked this post
  14. #80
    Feb 2016
    Jamaica
    I'm happy in my case, inflating the tyres to the same pressure, and doing the basic setting, before a long test-drive resolved my issue.
  15. Likes Uwe liked this post
