Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 80
Thread: Complicated MK5 Golf Steering Angle Sensor Fault
  1. #21
    Tartu, Estonia
    I hardly think its bad g85. Otherwise it would say something like " steering angle - no signal". Fault code indicates a more like when you remove battery and car has to be driven for evaluation. I would rather check ABS wiring with load to see wire integrity. And check for SW updates too.
    The world is my oyster...
  2. Likes Uwe, Jack@European_Parts liked this post
  3. #22
    Feb 2016
    Not sure if Erwin do a day subscription, but I won't personally check the wires. I won't do the repair myself, as there are too many delicate bits. It's best left to a professional. The reason I have posted this is incase I could do something with VCDS, or check the fuses etc.
    I think it's exceedingly unlikely to be two faulty G85 sensors (with the new one being brand new from VW).
    As golfi_vend says, it appears to be some sort of battery issue. It appears to lose calibration every now and then. However, I put a brand new Varta battery in December (to the correct specs). I had a battery test done yesterday and it's fine.
    How do I check for SW updates, golfi_vend?
  4. #23
    Tartu, Estonia
    Call/visit dealer or authorized shop.
  5. Likes Jack@European_Parts liked this post
  6. #24
    Feb 2016
    VW can't tell me if there are any updates without plugging the car in.
    They did say that for £60 (can't remember if that includes VAT, £72 if it didn't) they'll definitely find out what's wrong. My guess is that it's going to take them a while. Crucially it includes a courtesy car. Seems very reasonable for a cast iron answer.
  7. #25
    What are you waiting for ?
    When you are done pulling your pud with the dealer ....get the WD in Erwin, and lets move forward with actual tests.
    There are no magic answers........only the ones you test + verify.
  8. #26
    Feb 2016
    You're a funny guy with a clear disdain for the Brits. Luckily I'm an easy going kinda guy and Brits are usually very reserved.
    I'm just going to get VW to find out what's wrong. I'll report back as to what the fault was.
  9. #27
    I was an abused child.........Nah I hate everyone equally.
    Your happiness is my only concern...... don't you know that?
    If I didn't like the British........ I'd not offer to help you find your way.
    I'd lead you into a black hole.
    On the other hand.......... if Hitler would of swarmed the UK first........ I think you would be driving on the right side of the road, and the country would probably not be suffering from gingivitis.
    "Give me WD or give me a Tone Generator"
    https://en.wikipedia.org/wiki/Catego...United_Kingdom
  10. #28
    Quote Originally Posted by GTINR View Post
    Don't take anything Jack says personally -- or as aimed at a particular race, religion, or nationality. That's just the way he is.
  11. #29
    Feb 2016
    Of course it's all just fun and you guys are trying to help me. But there's only so much I can do personally unfortunately.
    I was looking at some measuring blocks in Central Electric module, and terminal 31 reads a constant 0.10v, whereas the others hover around 13.5 to 14v. Is that normal?
    Also had a look under the bonnet and it looks like some of the black sheet covering the wires is discoloured in drops, like brake fluid has been dropped on it?
  12. #30
    Terminal 31 is... Ground.
  13. Likes Jack@European_Parts liked this post
