Sunday,12,January,2020,16:49:31:26429
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
VIN: VSSZZZ1PZ7R079xxx License Plate:
Mileage: 234550km-145742mi Repair Order:
Chassis Type: 1P (1K0)
VIN: VSSZZZ1PZ7R079xxx Mileage: 234550km-145742miles
62-Door, Rear Left -- Status: Sporadic communication error 1000
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1P0 907 115 C HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: SEZ7Z0G3738970
Coding: 0303000318070160
Shop #: WSC 00191 264 15243
VCID: 2B03FA6ECF03438F4C5-807E
Revision: 00H11001
Coding: 0006792
Shop #: WSC 06441 785 00200
VCID: 73B3220E57B35B4FC45-8026
Part No: 1P0 907 044
Component: ClimatronicPQ35 010 0502
VCID: 698F4066057F919F7E9-803C
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004664032
Coding: A98E0F2F00041000431D00000000000000017F075C4000
VCID: 6C8139720A8D84B705F-8038
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 300107 022 0601
Coding: 00056208
Shop #: WSC 06441
01064 - Terminal 58d; Interior Dimming
Fault Status: 00101010
Reset counter: 91
Mileage: 234519 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 14.10 V
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R3 AIRBAG VW8 029 2522
Revision: 11029000 Serial number: 003B0P1XDPL3
Coding: 0021043
VCID: 2F3BEE7EFB1B3FAF60D-807A
Subsystem 1 - Serial number: 6332MSME15290A13
Subsystem 2 - Serial number: 6342MSME1636177C
Subsystem 3 - Serial number: 6351HTS62ADG6PB7
Subsystem 4 - Serial number: 6361HTS6LNF01AK6
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0002042
VCID: 015F78C61D0F79DFC69-8054
Component: E0221 005 0060
01426 - Controls in Steering Wheel (E221)
Part No: 1P0 920 825 C
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002101
Shop #: WSC 00011 888 96745
VCID: 2E05F37AFC1136A76BB-807A
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 33001071190F96
Coding: 3D3F034007000202
Reset counter: 72
Mileage: 233573 km
Time: 16:12:38
Component: IMMO VO3 0422
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1129
Revision: 31008001 Serial number: 00000029769207
Coding: 0000176
VCID: 3B23CA2E3F63D30FDC5-806E
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.154 H07 1806
VCID: 3431E112123D1C771DF-8060
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Coding: 808000005283CC7F0006050560084F01207C80
Shop #: WSC 42500 205 63575
VCID: 035372CE07136BCFD45-8056
00893 - Switch for Trunk Handle (E234)
Fault Status: 00100111
Reset counter: 88
Mileage: 234395 km
Time: 10:48:05
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1129
Revision: 31008001 Serial number: 00000517778110
Coding: 0000176
VCID: 3C21C9323A6DD437D5F-8068
Part No: 1P1 035 186 B
Component: Radio BVX 0006
Coding: 0040424
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1108
Revision: 11006001 Serial number: 00000001125975
Coding: 0000144
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1108
Revision: 11006001 Serial number: 00000001016649
Coding: 0000144
End----------(Elapsed Time: 01:48, VBatt start/end: 12.3V/13.5V)-----------
