Complicated MK5 Golf Steering Angle Sensor Fault
GTINR
C?ID=80919
Hello all. I'm having some issues with my car. I have tried to explain what happens below. I have also attached an autoscan.
When I'm driving the steering wheel, ESP and Tyre pressure lights come on intermittently. The steering wheel light usually turns off within a second. The ESP and Tyre Pressure lights turn off after a few hundred metres. They often return 3 or 4 times in one instance. After this, it may not come on for a day or so. Or it could return within hours.
In VCDS measuring blocks, when the light comes on the steering angle sensor freezes. It also say the steering angle sensor is not initialised. Now, it also says the sensor is defective (intermittent). But the sensor is a new one from VW.
I have had the steering angle sensor replaced with a new one, but the fault persists. I have followed the Ross-Tech website on reseting and recalibrating the sensor. But it hasn't worked. In fact, it will not let me run basic settings in group 060. It is almost as if the battery is dropping out or the sensor is losing power (but the battery is brand new and to the correct specification).
I bought the car in December, and the battery was on its last legs. The owner had the wrong sized tyres fitted to the front. I have changed these to the correct size.
Finally, when the mechanic was installing the new sensor, he noted that the slip ring centre line was not aligned with the one on the steering wheel, making it seem like the tracking was correct, but it wasn't. He's corrected that now and the steering is off centre slightly.
To go in a straight line, the steering wheel is at an angle of around 7.9 degrees (to the right). To centre it to 0.00, it is slightly to the left I am having a four wheel alignment tomorrow to track straight and true. Could this be the issue?
Below is my autoscan. The car is a 2007 MK5 GTI DSG.
On the scan, I have had the paddle faults for a while, but only just noticed the wiper and steering control faults. Not sure if that may be because of the recent work? Or could it indicate the clock spring is faulty? I have cleared the faults and they have not come back. The radio and CAN fault is because I installed a newer RCD510 Delphi.
Thanks for the help.
Thursday,25,February,2016,13:40:14:60835
VCDS Version: 15.7.3.0
Data version: 20151216
VIN: License Plate:
Mileage: 115430km-71724mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56
VIN: Mileage: 115430km-71724miles
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 J HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWZ7Z0G8026897
Coding: 040300031C070060
Shop #: WSC 01279 785 00200
VCID: 2D5559BCB4FC9D56EA-8078
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 043 Q HW: 02E 927 770 AE
Component: GSG DSG 070 1305
Revision: 04507000 Serial number: 00000701031215
VCID: 224FBA80FD22522E47-8076
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0004738
VCID: 73E18FC412588BA67C-8026
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
VCID: 70EB80C8634EB0BE81-8024
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006619795
Coding: E78F8F2700041500471400001400000000087F075C0001
Shop #: WSC 01287 785 00200
VCID: 6CD394B84F66545EBD-8038
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 240107 020 0501
Coding: 00038805
Shop #: WSC 01287
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 250107 020 0105
Coding: 00208933
Shop #: WSC 01287
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1004BM
Coding: 0013112
Shop #: WSC 01269 785 00200
VCID: 3D7569FC649C0DD65A-8068
Subsystem 1 - Serial number: 6332MSME157D606AJ
Subsystem 2 - Serial number: 6342MSME155C2139A
Subsystem 3 - Serial number: 6352QSME200C1E19G
Subsystem 4 - Serial number: 6362QSME1F783C31S
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0012102
VCID: 010DD50C58E4A9367E-8054
Component: E0221 002 0010
01749 - Switch for Tiptronic in Steering Wheel (E439); Down
01748 - Switch for Tiptronic in Steering Wheel (E438); Up
00888 - Wiper Switch for Intermittent Operation (E22)
Part No SW: 1K6 920 973 HW: 1K6 920 973
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0G8026897
Coding: 0007403
Shop #: WSC 44474 136 93303
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 140110F2000040
Coding: ED811F06000202002001
Shop #: WSC 10580 123 09991
VCID: 69DDEDAC40944176C6-803C
03272 - Control Module for Audio Interface
Fault Status: 01110100
Reset counter: 13
Mileage: 113774 km
Time: 21:14:19
Component: IMMO VDD 1610
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 005 0982
Coding: 0000566
VCID: 397D7DEC70B431F676-806C
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: WSC 00000 028 00001
VCID: 356571DC5CACD59692-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 819002085103087F2D0484057008DAC690B800
VCID: 0301DF0442F8BB266C-8056
Subsystem 2 - Part No: 1K0 951 178
Component: Neigungssensor 001 0101
Subsystem 3 - Part No: 1K0 951 178
Component: Innenraumueberw.001 0101
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Coding: 0000822
VCID: 3A7F62E075B23AEE7F-806E
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74E38CD817568C9E65-8020
Address 56: Radio (J503) Labels: None
Part No SW: 16D 035 190 HW: 16D 035 190
Component: RCD510USB 003 0003
Revision: -----001 Serial number: VWZ4Z3R8054291
Coding: 01000424000006
Shop #: WSC 00081 790 00119
VCID: 5DB5C97C44DC2DD63A-8008
Reset counter: 63
Mileage: 114800 km
Time: 10:41:34
End-------------------------(Elapsed Time: 01:49)--------------------------
Yep, being that far out of alignment may indeed be the source of those issues. The spec for successful calibration of the steering angle sensor is +/- 1.5° with the car tracking straight ahead. Indirect TPMS also depends on knowing the steering angle with a certain level of precision, since the rotational speeds are expected to be different when the car is not going straight.
PS: Please register your system so we can make you a Verified user here.
GTINR
C?ID=80919
Thanks for the reply, Uwe. I will let you know how I get on tomorrow. Fingers crossed it is this. I have spent a fair bit trying to get it fixed.
I provided my serial number in the new user form, is this not enough to get verified? I'll fill out the forms for full registration of my system later on tonight when I'm with my cable and VCDS comp.
No, if you are not in our records, a serial number is not sufficient. It looks like you fall into category 2) here.
GTINR
C?ID=80919
Thanks, I'll register it now.
The four wheel alignment was done today, but the steering wheel is still not in the centre. It's exactly the same as before. The fault persists.
What's odd is that 0.00 degrees on the steering angle sensor is slightly to the left. Is that normal?
I am going to have the steering set to the middle (again!) in the middle of next week.
I haven't gotten one of these cars aligned, but it used to be that part of a proper alignment included centering the steering wheel. ;)
GTINR
C?ID=80919
I know, that's the main reason I was there. Now he wants more money to adjust the track rod ends.
He corrected the toe on the left front as it was out, but didn't lock the steering wheel in place whilst he was doing it. Surely the basics are to lock it in place.
Do you know why 0.00 on the sensor is slightly to the left? Is that something that is recalibrated? When holding the steering exactly centre, the reading is 1.97 degrees. So it will still be out of the tolerance when the car is travelling straight and true?
GTINR
C?ID=80919
Scratch that, I've reset it again and it's at 0 degrees at the centre now. Hopefully it's just a steering alignment now.
Moving this to Car Repair Support since you're verified now.
GTINR
C?ID=80919
Well I said it was complicated, and it's living up to it.
Had a four wheel alignment done and it's tracking straight and true now. 0 degrees is straight ahead. But the fault still happens.
The steering light goes on and off constantly as you turn the wheel. The ESP and tyre pressure lights stay illuminated. Then all of them will just go off for 15 minutes. And then return again.
Running out of ideas as to what it could be?
GTINR
C?ID=80919
Hi. Below is the autoscan. I've done the basic settings a few times today. Even though the steering is now within the 1.5 degree tolerance, group 060 still doesn't activate when I press 'on/off' for the basic setting (just says error in red). However, as soon as I type Group 060, it shows adjustment status as OK and the steering limit stop needs to be done. So I guess the basic setting is working?
I've recoded the ABS and the CAN gateway, but it's made no difference :banghead:
Really sorry but I don't know how to shorten the autoscan.
Sunday,28,February,2016,21:01:20:60835
VIN:   License Plate:
Mileage: 115600km-71830mi   Repair Order:
VIN:  Mileage: 115600km-71830miles
   Revision: 00H11001
   Coding: 0004738
            000 -  -  - Intermittent
   Coding: 00038805
   Shop #: WSC 01287
   Coding: 00208933
   Shop #: WSC 01287
   Coding: 0013112
   Coding: 0012102
   Coding: 0007403
   Coding: 0000566
   Coding: 0000822
   Coding: 0000003
                    Reset counter: 93
                    Mileage: 115481 km
                    Time: 15:03:47
End-------------------------(Elapsed Time: 01:50)--------------------------
GTINR
C?ID=80919
I've already replaced the G85 with a new one. The VW specialist who did it initially suspected the steering control module and the link below describes my exact problem in an almost identical car. On page 2, the original poster notes that it was rectified with a new steering control module.
Are there any output tests I can do on the steering wheel module?
http://www.vwaudiforum.co.uk/forum/...-reset-but-the-lights-are-still-on!-2007-Golf
Time to stop guessing and RTFB while doing actual tests.
See post #13 link to RTFB
Pay to play.........
GTINR
C?ID=80919
I don't have access to Erwin. I'm not a business, just an enthusiast with a problem on my car.
Pay to play the enthusiast rates ........Print to PDF.....
GTINR
C?ID=80919
What are you talking about pay to play?! Fair enough saying I should check the wiring, but it's already been checked when the angle sensor was changed. The wiring to the steering control module and G85 are fine (in terms of no breakages, don't know if he used a multimeter on them).
If you don't know what the fault is then that's fine. I'm only looking for some guidance with it.
I don't take for granted the help on offer in the forum and I really appreciate it. But it's not realistic to ask an individual to buy an Erwin subscription
I have had my fill of the UK's arrogance today. NUT or BUT?
Oh I know.......trust me I know....
"memo bis punitor delicatum"
HTF do you know if wiring is good, if you don't have a repair manual.......?
Ever consider maybe the new sensor was damaged when installed, installed wrong or bad out of the box?
Is a 3 day Erwin sub gonna break the bank in Yiddish British Jewie Gooey Pounds?
