Results 1 to 4 of 4
Thread: Volkswagen Scirocco (13) - 2010 - Cruise Control Retrofit
    Verified VCDS User Abbott Automotive's Avatar
    Feb 2016
    Mansfield, Nottinghamshire, UK
    I was just wondering if anyone could help me identity the correct module that I will need to retrofit cruise control on my (2010 Volkswagen Scirocco)
    I've already purchased the cruise control stalks (part number: 5K0 953 502 M), but I am being told different part numbers by different people for the correct module that I will need to carry out this retrofit.
    I have also been told that because I already have a highline module installed (exiting module part number: 5K0 953 569 D) that I "might" not need to change the module, could this be a possibility?
    I thought it may be good to add this little bit of information too, as I think it’s relevant to the post ... It's the model with the MFSW
    Please note: This is my first post of the Forum so please go easy on me if I've missed anything
    I have also copied a full auto scan below
    Thank you, in advance
    Thursday,03,December,2015,19:33:37:48548
    VCDS Version: 15.7.2.0 (x64)
    Data version: 20151124
    VIN: WVWZZZ13ZAV436850   License Plate:
    Mileage: 90520km-56246mi   Repair Order:
    Chassis Type: 13 (1K0)
    Scan: 01 03 08 09 14 15 16 17 19 25 2E 42 44 46 52 56
    VIN: WVWZZZ13ZAV436850   Mileage: 90520km-56246miles
    Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 KD    HW: 03L 906 022 G
       Component: R4 2,0L EDC 0000SG  6166
       Revision: 13H03---    Serial number:
       Coding: 0001072
       Shop #: WSC 00020 790 00000
       VCID: 71E99DD16814BEB694-8024
       Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
       Revision: 00H30001
       Coding: 763B40F5492500006E1302E992190082300000
       Shop #: WSC 00020 790 12345
       VCID: 78FFA0F5CB6EEFFE53-802C
       Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
       Revision: 00003001
       Coding: 0000000002
       Shop #: WSC 00020 999 00000
       VCID: 7DF1B1E1EC4CCAD600-8028
    9475349 - Position Sensor for Right Temperature Flap Motor
              B1095 15 [008] - Open or Short to Plus
                        Reset counter: 13
                        Mileage: 90245 km
                        Date: 2015.11.28
                        Time: 13:37:03
       Part No SW: 5K0 937 086 C    HW: 5K0 937 086 C
       Component: BCM PQ35 M    011 0028
       Revision: BC011001
       Coding: 4E100A38F027E100408800843400812E43513B88536D81605C8000000000
       VCID: 346754C59786CB9EBF-8060
       Subsystem 1 - Part No: 1K8 955 119 E  Labels: 1KX-955-119.CLB
       Component: Wischer 17120  22  0614
       Coding: 009795
       Component: RLS 160210 05  54  0403
       Coding: 0730ED
       Subsystem 4 - Part No: 1K8 951 605
       Component: LIN BACKUP HO  H09 9002
                        Fault Status: 00101010
                        Reset counter: 248
                        Mileage: 88566 km
                        Date: 2010.04.06
                        Time: 16:55:53
                        Voltage: 14.00 V
    Address 14: Susp. Elect. (J250)       Labels: None
       Revision: 00000000    Serial number: 08021004490002
       Coding: 000180
       Shop #: WSC 47951 001 1048576
       VCID: 275DB3895650B0060A-8072
       Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
       Component: 0H AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 003D1D023NCR
       Coding: 0012360
       VCID: 6FED9BA97E20A84682-803A
       Subsystem 1 - Serial number: 6332MSME4E7242419
       Subsystem 2 - Serial number: 6342MSME4E7300718
       Subsystem 3 - Serial number: 6352QSME4F4E0122J
       Subsystem 4 - Serial number: 6362QSME324C1C36L
       Part No SW: 5K0 953 521 T    HW: 5K0 953 569 D
       Component: LENKS.MODUL   009 0122
       Revision: FF010035    Serial number: 20100211200732
       Coding: 1082040000
       ASAM Dataset: EV_SMLSNGVOLWS A01002
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 3D7171E1ACCC0AD640-8068
       Coding: 820000
       Part No SW: 1K8 920 971 C    HW: 1K8 920 971 C
       Component: KOMBI         H05 0305
       Coding: 170B00
       Shop #: WSC 00020 999 12345
       VCID: 336557D99A88CCA6A6-8066
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H16 0233
       Revision:   H16       Serial number: 4520K102160B97
       Coding: E9881F06000212004001
       VCID: 69D9F5B140C44676DC-803C
       Component: IMMO          H05 0305
       VCID: 6ADB8ABD8DC24D6ED5-803E
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Component: SG EXT.PLAYER H13 0090
       Revision: A1001003    Serial number: 7667802323
       VCID: 2643BE8D515AA90E31-8072
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
       Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
       Component: Tuer-SG         009 2124
       Coding: 0016949
       VCID: 397965F170E436F66C-806C
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 178    3001
       Revision: 00H17000
       VCID: 31695DD1A894FEB6D4-8064
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
       Coding: 0016948
       VCID: 3A7B7AFD75E23DEE65-806E
    Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 3C8 035 195     HW: 3C8 035 195
       Component: Radio RCD510  040 0166
       Revision: 00000001    Serial number: VWZ1Z3K6360226
       Coding: 0100040004
       VCID: 65C1F9816CDC6216F8-8030
    End-------------------------(Elapsed Time: 02:05)--------------------------
  2. Likes Uwe liked this post
  3. #2
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    searched for informations and found this:
    Address 16: Steering wheel (J527) HW: 5K0 953 569 D >> without CCS
    Part number 5K0 953 569 L >> PR 8T1/2 >> assisted CCS
    otherwise 5K0 054 691 E >> retofit kit for CCS
    -Wolfgang
    Drive more talk less
  4. Likes Uwe liked this post
  5. #3
    Feb 2016
    Thank you for your reply
    I am being told the modules that will work are ... 5K0 953 569 E, H, T (and 'AL' which is apparently the old H)
    I believe this information is based on the chart below
  6. #4
    Feb 2016
    Here's just a quick update for anyone else is looking for this informatiom (the above info on my last post is correct)
    My current non CCS module is 5K0 953 569 D, this has to be changed to 5K0 953 569 E, H or T (the 'AL' being the old 'H' is also fine)
    Thank you to them who took time to take a look at my post
  7. Likes AIB Wolfgang, Uwe liked this post
