Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: 2016 Audi A3 e-tron, 1.4 TFSI CUKB
    Jun 2014
    Newcastle, England
    For one day only, whilst my car was in service, I had a play with an e-tron. The service guy said people are quite polar about them ('marmite' - you either love them or you hate them) but something like this would probably suit my daily commute. Also, being a hybrid, is much better than the Nissan Leaf as there are no worries about running out of charge.
    It would be rude to have it all day without grabbing an Auto-Scan:
    Tuesday,23,February,2016,16:32:31:26758
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: WAUZZZ8V4GA0*****   License Plate: NA65***
    Mileage: 6052km-3760mi   Repair Order: e-tron
    Chassis Type: 8V (5QE)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 55 5F 75
              8C C6
    VIN: WAUZZZ8V4GA0*****   Mileage: 6052km-3760miles
    C6-Batt. Chrg. -- Status: OK 0000
    Address 01: Engine (J623-CUKB)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 023 AF    HW: 04E 907 309 F
       Component: R4 1.4l TFSI  H21 1725
       Revision: X3H21---
       Coding: 021D0012632401083000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM14TFS01104E906023AF 005005
       ROD: EV_ECM14TFS01104E906023AF.rod
       VCID: 64CDD7B86F33391EFA-8030
    5604 - Park/Neutral Switch Input Circuit
              P0850 00 [032] - Open or Short to Plus
    Address 02: Auto Trans (J743)       Labels: None
       Part No SW: 0DD 300 045 L    HW: 0DD 927 770 B
       Component: GSG DQ400E    H31 1110
       Revision: 00031033    Serial number: TFK01504290287
       Shop #: WSC 00099 780 00200
       ASAM Dataset: EV_TCMDQ400021 001001
       ROD: EV_TCMDQ400021.rod
       VCID: 30656BE86B4BD5BECE-8064
    17 Faults Found:
    32317 - Unknown Error Code
              U04B5 00 [002] - -
    10893 - Implausible Data Received from Battery Energy Control Module 2
              U0413 00 [002] - -
    60354 - ROD - Unknown Error Code
              - 00 [002]
    60355 - ROD - Unknown Error Code
              - 00 [002]
    60356 - ROD - Unknown Error Code
              - 00 [002]
    60357 - ROD - Unknown Error Code
              - 00 [002]
    60358 - ROD - Unknown Error Code
              - 00 [002]
    60359 - ROD - Unknown Error Code
              - 00 [002]
    60360 - ROD - Unknown Error Code
              - 00 [002]
    60361 - ROD - Unknown Error Code
              - 00 [002]
    60362 - ROD - Unknown Error Code
              - 00 [002]
    60363 - ROD - Unknown Error Code
              - 00 [002]
    60364 - ROD - Unknown Error Code
              - 00 [002]
    60365 - ROD - Unknown Error Code
              - 00 [002]
    60366 - ROD - Unknown Error Code
              - 00 [002]
    60367 - ROD - Unknown Error Code
              - 00 [002]
    60369 - ROD - Unknown Error Code
              - 00 [002]
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
       Part No SW: 5Q0 907 379 AK    HW: 5Q0 907 379 H
       Component: ESC           H31 0809
       Revision: 00000000    Serial number: 61805000001946
       Coding: 12F180A23823326E017C060241C32948011C4C80608294F402A100788608
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
       ROD: EV_Brake1UDSContiMK100OMG_AU37.rod
       VCID: 050BEA3C8449A0164D-8050
       Revision: 00021000    Serial number: 0373591152
       Coding: 030C0C
       ROD: EV_KessyHellaMQBAB_AU37.rod
       VCID: 3A7149C0BD371FEE70-806E
    Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
       Part No SW: 8V0 820 043 F    HW: 8V0 820 043 F
       Component: AC Automat    H05 0040
       Revision: 20010000    Serial number: 00000000684704
       Coding: 0310001000000000000000000000100001000000
       ASAM Dataset: EV_AirCondiFrontRDWAU37X 001015
       ROD: EV_AirCondiFrontRDWAU37X.rod
       VCID: 356B5AFC9429F0969D-8060
       Subsystem 1 - Part No SW: 12E 963 231 F    HW: 12E 963 231 F
       Component: J848 HV-PTC  H09 0206
       Serial number: LM151993003807000181
       Subsystem 3 - Part No SW: 12E 820 803 E    HW: 12E 820 803 E
       Component: J842 eKK  H02 0005
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 084 AQ    HW: 5Q0 937 084 AL
       Component: BCM MQBAB M   H24 0175
       Serial number: 01061519600494
       Coding: 07151C42C25106FD038C5004B31407A80800000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 0717E034BE45B2063F-8052
       Slave 1:
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 150701  042 0580
       Serial number:         150704185228
       Coding: 0A47F7
       Slave 2:
       Serial number: 24078775
       Coding: 00006C
       Slave 3:
       Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
       Serial number: 04 05 2015  00001346
       Serial number: 000000000ZY151672XRZ
       Serial number: 00000000000063127378
       Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST000FKK9S00000
       Coding: 901E00
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0054
       Revision: --------    Serial number: 39231519400576
       Coding: 0000040011
       ASAM Dataset: EV_EPHVA14AU3700000 002024
       ROD: EV_EPHVA14AU3700000_AU37.rod
       VCID: 3C7D4FD8B70321DE62-8068
       Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
       Component: AirbagVW20    010 0870
       Serial number: 003MFR011R6G
       Coding: 98CCC0000C2000009C5400CA00C800000065
       VCID: 50A50B680B8BB5BEAE-8004
       Subsystem 1 - Part No SW: -----------    HW: 480 001 207 15
       Serial number: 35700000000568C4F41R
       Subsystem 2 - Part No SW: -----------    HW: 480 001 207 15
       Serial number: 35800000000969C4F41X
       Subsystem 3 - Part No SW: -----------    HW: 480 401 407 15
       Serial number: 3510002BD1C52F439268
       Subsystem 4 - Part No SW: -----------    HW: 480 401 407 15
       Serial number: 3520002A91B7E8F1F3AU
       Subsystem 5 - Part No SW: -----------    HW: 480 402 306 15
       Serial number: 3550002BD1C52F344324
       Pedestrian protection crash sensor; driver side:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 906 15
       Serial number: 2280002BD1B65D534044
       Pedestrian protection crash sensor; front passenger side:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 906 15
       Serial number: 2290002B31B65D548297
       Subsystem 8 - Part No SW: -----------    HW: 480 002 805 15
       Serial number: I0M00000000AC8016494
       Subsystem 9 - Part No SW: -----------    HW: 480 002 805 15
       Serial number: I0N0000000078901649%
       Part No SW: 8V0 953 521 FB    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0110
       Revision: --------    Serial number: 15071504220491
       Coding: A418
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 7F0778D4E695FAC607-802A
       Part No SW: 8V0 920 972 E    HW: 8V0 920 972 E
       Component: KOMBI         H03 6421
       Coding: 27240C182B8026000103E8101200000000000000
       VCID: 40853B28DBEB453E3E-8014
    9456128 - Engine Control Module (ECM) not authorized
              B104A 00 [008] -  -
                        Fault Frequency: 14
                        Mileage: 43 km
                        Date: 2015.11.04
                        Time: 07:53:56
    Address 19: CAN Gateway (J533)       Labels: Redir Fail!
       Part No SW: 5QE 907 530 D    HW: 5QE 907 530 A
       Component: GW MQB EV     312 3225
       Revision: --------    Serial number: 27061510804213
       Coding: 0201001726F200005B001208580000000001010100010000000000000000
       ASAM Dataset: EV_GatewEVConti 013020
       ROD: EV_GatewEVConti.rod
       VCID: 47972034FEC57206FF-8012
       Subsystem 1 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 06 07 2015  E0024140
       Subsystem 2 - Part No SW: 5QE 915 181     HW: 5QE 915 181
       Serial number: 1713827103
    Address 23: Brake Booster (J539)       Labels: None
       Part No SW: 5QE 909 059 D    HW: 5QE 909 059 B
       Component: EBKV          H14 0182
       Serial number:   085430010238
       Coding: 03720100331902030002050500
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
       ROD: EV_BrakeBoostBoschMQBOMG_AU37.rod
       VCID: 4FA7081416B5AA46B7-801A
       Subsystem 2 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0152
       Serial number: 05802861070715001814
    239616 - Implausible Data Received from Engine Control Module
              U0401 00 [032] - -
       Revision: 00000000    Serial number: 15000174836008
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_AU37.rod
       VCID: 346D67F89F53E99EAA-8060
       Serial number: 280615BFR15176
       Coding: 001C9E204001040000001002
       Shop #: WSC 06385 790 00021
       ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
       VCID: 438F3424CAFD5E2623-8016
       Component: EPS_MQB_ZFLS  125 1061
       Coding: C102
       ROD: EV_SteerAssisMQB.rod
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 5G0 907 080 D    HW: 5G0 907 080 D
       Component: VW370P3815010 H06 4492
       Revision: 00H06000
       Coding: C0020000000000000000
       ASAM Dataset: EV_DMCM09550115G0907080D 001018
       ROD: EV_DMCM09550115G0907080D.rod
       VCID: 28558388539B9D7E16-807C
       Serial number: 020715BG11620A
       Coding: 001C96204001040000001002
       ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
       VCID: 42813120D5E7572E28-8016
       Coding: 011E00002B230200
       ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
       VCID: 3F8738D4A6153AC647-806A
       Coding: E00100
       Coding: E00100
       Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
       Component: LeiMo links  H01 7050
       Coding: E00100
       Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
       Component: LeiMo rechts  H01 7050
       Coding: E00100
       Part No SW: 8V0 035 036 E    HW: 8V0 035 036 B
       Component: MU-H-LND-EU   H45 0397
       Serial number: A300G0F7551897
       Coding: 01739301FF00000021111101000A02102F00010701000100DE
       ASAM Dataset: EV_MUHig4CHBAS 001040
       ROD: EV_MUHig4CHBAS_AU37.rod
       Engine Control Module 2:
       Subsystem 1 - Part No SW: V03 959 800 Q    HW: -----------
       Component: ECE 2015/2016  --- 0122
       Seat Adjustment Driver Side:
       Component: DU High  H49 0014
       Serial number: AUZ8Z9FY203P4V
       Sound System:
       Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
       Component: ControlUnit_H  H81 0816
       Serial number: C1000015051500020054
       Door Electronics Rear Left:
       Component: Gracenote  --- 1010
    Address 75: Telematics (J949)       Labels: None
       Part No SW: 5QE 035 284 A    HW: 5QE 035 284 A
       Component: OCULowMQBEU   008 0561
       Coding: 017393011080BA0100F800000000
       ROD: EV_OCULowMQB.rod
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 5Q0 915 182 C    HW: 5Q0 915 182 C
       Component: BECM          H05 0652
       Serial number: T4030045
       Coding: 00000000
       ASAM Dataset: EV_BECM09620115Q0915182 006036
       ROD: EV_BECM06020115C6915182_AU37.rod
       VCID: 336F64E49A5DEEA6B3-8066
       Subsystem 2 - Part No SW: 5Q0 915 250 D    HW: 5Q0 915 250 D
       Component: BJB  H27 0240
       Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D1  H14 0472
       Serial number: V013C1550730200
       Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D2  H14 0472
       Serial number: V013C1550730190
       Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D3  H14 0472
       Serial number: V013C1550730189
       Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D4  H14 0472
       Serial number: V013C1550531081
       Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D5  H14 0472
       Serial number: V013C1550730336
       Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D6  H14 0472
       Serial number: V013C1550730334
       Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D7  H14 0472
       Serial number: V013C1550730340
       Subsystem 10 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D8  H14 0472
       Serial number: V013C1550730335
    Address C6: Batt. Chrg. (J1050)       Labels: None
       Part No SW: 5QE 915 682 AA    HW: 5QE 915 682 AA
       Component: OBC KOSTAL    H61 3017
       Revision: --------    Serial number: 0107150FP00148
       Coding: 115068203000
       ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
       ROD: EV_OBCSinglPhaseKLOVW3709_AU37.rod
       VCID: 0C1DDF18A723D15E12-8058
    End-------------------------(Elapsed Time: 05:08)--------------------------
  2. Likes jyoung8607, Andy, Uwe, NEtech, Eric liked this post
  3. #2
    Hmm -- I'm wondering just how real those almost perfectly sequentially numbered fault codes in the tranny are...
    If you still had this car, we'd as you to make a debug file of that....
    That was about aggressive mode, FS#924.
    They are also in all Golf GTE.
  5. Likes Uwe liked this post
  6. #4
    New User
    Aug 2016
    Canada
    Has anyone documented the specific A3 e-tron, that is non ICE, modules? I'm looking for a way of setting the charging parameters for the battery. The US and EU versions have very different settings
    Oct 2016
    I bought a 2016 A3 E-tron and in less than a month the MIL came on. Doubled checked the gas cap several times but doesn't go off until I'm driving to the dealer. Anyways, I have the HEX-USB and upgraded to the latest and greatest firmware and VCDS. Plugged it into the car. LED on HEX-USB turns green. But VCDS doesn't pick up anything in Auto-Scan, individual modules scan, and not even the ODB II. I figured OBD II would at least work but nothing. It's like the car isn't responding. Did I miss a step?
    Quote Originally Posted by cbdrake View Post
    Did you turn your ignition on?
    Stoke on Trent, England
    Just for reference on CUKB:
    Manufacturer: Audi, Mounting Time: 05/14-08/16, Model: Audi A3/S3 Etron Sportback, Engine Code: CUKB, 110Kw, 150PS, 1.4 Ltr, 4 Cyls, Turbocharged Stratified Injection (TSI), Hybrid
    Manufacturer: Audi, Mounting Time: 05/14-08/16, Model: Audi A3/S3 Etron Quattro, Engine Code: CUKB, 110Kw, 150PS, 1.4 Ltr, 4 Cyls, Turbocharged Stratified Injection (TSI), Hybrid
    Manufacturer: Audi, Mounting Time: 05/14-08/16, Model: Audi A3/S3 Etron Limousine, Engine Code: CUKB, 110Kw, 150PS, 1.4 Ltr, 4 Cyls, Turbocharged Stratified Injection (TSI), Hybrid
    Manufacturer: Audi, Mounting Time: 05/14-08/16, Model: Audi A3/S3 Etron, Engine Code: CUKB, 110Kw, 150PS, 1.4 Ltr, 4 Cyls, Turbocharged Stratified Injection (TSI), Hybrid
    Manufacturer: VW, Mounting Time: 05/14-, Model: Hybrid, Engine Code: CUKB, 110Kw, 150PS, 1.4 Ltr, 4 Cyls, Turbocharged Stratified Injection (TSI), Hybrid
    Manufacturer: VW, Mounting Time: 05/14-, Model: Golf, Engine Code: CUKB, 110Kw, 150PS, 1.4 Ltr, 4 Cyls, GTE, Turbocharged Stratified Injection (TSI), Hybrid
    As taken from my new VAG Engine & Transmission Codes app.
    New User Keith
  10. #8
    Oct 2016
    It's a push button ignition, not a physical key. Yes. I tried all 3 states: off, started ignition but engine not running, and engine running.
  11. #9
    Oct 2016
    It's a push button ignition, not a physical key. But Yes. I tried all 3 states: off, started ignition but engine not running, and engine running.
    I have the HEX-USB that does not support CAN. Is that the problem? I noticed on a support page that the interface is HEX-CAN.
  12. #10
    Yeah, that would do it. Apologies that I didn't dig into our records enough to notice that. A 2016 A3 simply isn't going to "talk" via K-Lines.
    You can upgrade here -- where you are in category 3:
    http://store.ross-tech.com/shop/cat/IntUp.html
