Missing ROD and ASAM dataset update failing
   #21
Piranha
Malta
C?ID=90948
Also, 1 usefull feature which is missing in vcds mobile is the feature in bcds pc where you can delete faults in all modules from the autoscan directly, could his be added?
D-Dub
US 2014 GTI Drivers Edition/DSG
C?ID=272151
"me too", also having this issue with missing 'rods' repeatedly downloading via mobile vcds.
Also, when i do an auto scan and says to download missing information, it doesn't save my auto-scan results and I lose the whole window while it tries to update.
I have to choose cancel/update later to save the autoscan results. Not very intuitive.
Some additional info;
cb: 0.4305
fw: 0.238
cfb: 0.10
bl: 0.27
ds: 10...039
Trying to update via vcds windows 15.7.4 > hexnet config 2.014 (usb direct to pc, not connected to car)
repeatedly downloads and applies the same updates every time
Updated rod data needed
Applying update...
Downloading DS update
Unpacking DS update
Update completed successfully
#hndoc:?docid=00001854&xt=hnh:DEF3C490FD91965114F96AD06DE81708826E2F6C900C4FC015F74A70004D1205
Wed,Mar,02,2016,22:24:37
VCDS Mobile 0.4305.0.4
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72
Address 01: Engine	Labels: 06J-907-115-CBF.clb
	Part No SW: 1K0 907 115 AT	HW: 1K0907115AK
	Component: 2.0l R4/4V TFSI      0020
	Revision: E3H26---	Serial Number:
	Coding: 040301081C070160
	VCID: 78B37BE35F515B4A96B32AB3CA-802D
008213 - Intake Manifold Flap Position Sensor (Bank 1)
	P2015 - 000 - Implausible Signal - Intermittent - MIL ON
005386 - Engine Off Timer Performance
	P150A - 000 - - - Intermittent
Address 02: Auto Trans	Labels: 02E-927-770.lbl
	Part No SW: 02E 300 058 P	HW: 02E927770AL
	Component: GSG DSG AG6     521  3513
	Revision: 05652104	Serial Number: 00001308290689
	VCID: 2711689FC26F04B2CF89B1C72F-8072
No fault codes found.
Address 03: ABS Brakes  (J104)	Labels: None
	Part No SW: 1K0 907 379 BL	HW: 1K0 907 379 BL
	Revision: 00H31001
	Coding: 114B600C49220003880E06ED92220041B70800
	VCID: 7DBD6AF77073FE62C5E563CF8D-8028
02214 - Tire Pressure Warning
Address 08: Auto HVAC  (J301)	Labels: 3C8-907-336.clb
	Part No SW: 7N0 907 426 BH	HW: 7N0 907 426 BH
	Component: AC Manuell    H20 0505
	Revision: 00001019
	Coding: 0010002002
	VCID: 7BB964EF6E67E852FBD14DD793-802E
Address 09: Cent. Elect.  (J519)	Labels: 1K0-937-08x-09.clb
	Part No SW: 1K0 937 086 T	HW: 1K0 937 086 T
	Component: BCM PQ35  M   111 0709
	Revision: AC111709
	Coding: 6F180A1A90272AC4008800C1750009E448ED2086435D8D20E48420240040
	VCID: 41C5D6074C0B5A82E18DCF1F81-8014
	Subsystem 1 - 	Part No SW: 5K1-955-119
	Component: Wischer 0409126  0512
	Coding: 009795
Address 15: Airbags  (J234)	Labels: 5K0-959-655.clb
	Part No SW: 5C0 959 655 M	HW: 5C0 959 655 M
	Component: AirbagVW10G   014 0726
	Coding: 00004737
	ROD: N/A
	VCID: 3C3BA7F32BE92F6AB25B96C3DE-8069
	No ASAM data for: "EV_AirbaVW10SMEVW360"
	Subsystem 1 - 	Part No SW: 5K0-959-339-B
	Component: BF-Gewichtss.006 0001
	Serial Number: ---0000R--000084LN00
	Subsystem 2 - 	Part No SW: 5K0-959-354
	Component: S.Sens.Fahr.VH02 ----
	Serial Number: 3572MSME5725017DZZZX
	Subsystem 3 - 	Part No SW: 5K0-959-354
	Component: S.Sens.Beif.VH02 ----
	Serial Number: 3582MSME3876757DZZZ7
	Subsystem 4 - 	Component: S.Sens.Fahr.H--- ----
	Serial Number: 3512QSME4E2F3605ZZZ/
	Subsystem 5 - 	Component: S.Sens.Beif.H--- ----
	Serial Number: 3522QSME46363A7EZZZ2
	Subsystem 6 - 	Component: F.Sens.Fahr  --- ----
	Serial Number: 35527SME3C07792FZZZV
	Subsystem 7 - 	Component: F.Sens.Beif  --- ----
	Serial Number: 35627SME0830792FZZZL
Address 16: Steering wheel  (J527)	Labels: 5K-16.lbl
	Part No SW: 5K0 953 507 AH	HW: 5K0 953 549 B
	Component: Lenks.Modul   008 0090
	Revision: --------
	Coding: 189A140000
	ROD: N/A
	VCID: 76AF75DB5545B53A849F149BD0-8023
	No ASAM data for: "EV_SMLSNGKUDS"
Address 17: Instruments  (J285)	Labels: 5K0-920-xxx-17.clb
	Part No SW: 5K6 920 973 C	HW: 5K6 920 973 C
	Coding: 270D01
	ROD: N/A
	VCID: 3731B8DF12CF0C325F2961871F-8062
	No ASAM data for: "EV_Kombi_UDS_VDD_RM09"
Address 19: CAN Gateway  (J533)	Labels: 7N0-907-530-V2.clb
	Part No SW: 7N0 907 530 AF	HW: 7N0 907 530 AF
	Component: J533  Gateway H52 1634
	Revision:   H52
	Coding: 350002
	VCID: 74AB4FD34339BF2ABA8BFE6336-8021
Address 25: Immobilizer  (J334)	Labels: 5K0-920-xxx-25.clb
	Part No SW: 5K0 953 234	HW: 5K0 953 234
	ROD: N/A
	VCID: EA97D1AB91FDE1DA902710EB34-80BF
	No ASAM data for: "EV_Immo_UDS_VDD_RM09"
Address 2E: Media Player 3  (J650)	Labels: 5N0-035-342.lbl
	Part No SW: 5N0 035 342 G	HW: 5N0 035 342 G
	Revision: A1001003
	Coding: 020100
	VCID: 2B1994AFDE87A0D22BB1DD17E3-807E
Address 37: Navigation  (J794)	Labels: 1K0-035-27x-37.clb
	Part No SW: 1K0 035 274 H	HW: 1K0 035 274 H
	Component: RNS315-NAR    H70 0407
	Coding: 04000401040005000000100A
	ROD: EV_RNS315NARV2UDS.rod
	VCID: 29156EA7D47BAAC2D99DC7FFC9-807C
Address 42: Door Elect, Driver	Labels: 1K0-959-701-MIN3.lbl
	Part No SW: 5K0 959 701 H	HW: 5K0959701H
	Component: Tuer-SG         009  2105
	Coding: 0001204
	VCID: 3731B8DF12CF94325F2961871F-8062
Address 44: Steering Assist	Labels: 1Kx-909-14x-44.clb
	Part No SW: 1K0 909 144 R
	Component: EPS_ZFLS Kl. 74      3501
	Revision: 00H22000
	VCID: 3935BEE724DB8242A93D77BF39-806C
Address 46: Failed to respond
Address 52: Door Elect, Pass.	Labels: 1K0-959-702-MIN3.lbl
	Part No SW: 5K0 959 702 H	HW: 5K0959702H
	Coding: 0001204
	VCID: 3833BBE31FD19B4A56336AB30A-806D
Address 55: Xenon Range	Labels: 5M0-907-357-V2.lbl
	Part No SW: 5M0 907 357 C	HW: 7L6941329B
	Component: AFS-Steuergeraet     0148
	Revision: 00H04000	Serial Number:
	Coding: 1446940
	VCID: 342B8FD303B97F2A7A0B3E6376-8061
	Subsystem 1 - 	Part No SW: 7L6-941-329-B	Labels: 3D0-941-329.clb
	Component: AFS-Lst.-Modul l     0004
	Coding: 0000022
	Subsystem 2 - 	Part No SW: 7L6-941-329-B	Labels: 3D0-941-329.clb
	Component: AFS-Lst.-Modul r     0004
	Coding: 0000022
Address 62: Door, Rear Left	Labels: 1K0-959-703-GEN3.lbl
	Part No SW: 5K0 959 703 D	HW: 5K0959703D
	Component: Tuer-SG         007  2101
	Coding: 0001168
	Shop #: WSC 01357 011 1012552
	VCID: 352DB2D708C366224D154B6F65-8060
Address 72: Door, Rear Right	Labels: 1K0-959-704-GEN3.lbl
	Part No SW: 5K0 959 704 D	HW: 5K0959704D
	Coding: 0001168
	VCID: 362FB5DB15C56D3A441F549B10-8063
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
A few people have been running into a similar looping concern, myself included. Ross-Tech have been working on it quite a bit. It seems like it may have been a perfect storm of several small issues combined. But, I am now getting very promising results from the latest alpha test version. Stay tuned on this one just a little while longer.
Jason
   #26
D-Dub
C?ID=272151
This updated fixed the update percentage, but it is still continuously downloading the (apparently) same rod updates over and over again.
Tried with both via mobile vcds and the java updater/usb.
   #27
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Hmm, that sucks. :( My alpha test HEX-NET is loop-free at this point, although we were still looking into some outstanding redirect questions. I have a release HEX-NET I haven't upgraded and tried this on yet. I'll see what it does later tonight.
Jason
   #29
andyvee
Rossendale, Lancashire, UK
C?ID=159389
Same here - with the Java utility, updated Rod data needed every time still EV_ACCMRRBoschVW372_A something or other from what I can see, as well as it keep wanting to apply the DS update again
   #30
abishoff
C?ID=248712
im having the same issues after updating using the java client fyi i did just have my whole nav unit replaced due to many faults
using vcds windows client in network mode
VCDS Version: Release 15.7.4 Running on Windows 8.1 x86
Data version: 20160216
Saturday,19,March,2016,01:53:34:49139
Chassis Type: A3 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 75 77
VIN: 1VWCV7A37FC009301   Mileage: 71510km-44434miles
05-Acc/Start Auth. -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: Sporadic communication error 1000
15-Airbags -- Status: Sporadic communication error 1000
16-Steering wheel -- Status: Sporadic communication error 1000
17-Instruments -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CVCA)       Labels: None
   Part No SW: 04L 906 016 AF    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 8417
   Revision: 8AH20---
   Coding: 011D0012032410089000
   Shop #: WSC 41657 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906016AF 001014
   ROD: EV_ECM20TDI01104L906016AF.rod
   VCID: ED9289163C2E8D5625-80B8
4113 - Camshaft Position Sensor (G40)
          P0341 00 [100] - Implausible Signal
                    Mileage: 71512 km
                    Date: 2016.03.19
                    Time: 00:40:24
   Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4509
   Revision: 05652104    Serial number: 00001404052843
   Shop #: WSC 09003 957 00200
   VCID: A502B1366C5E7516AD-80F0
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU - Intermittent
                    Reset counter: 39
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -  - Intermittent
                    Reset counter: 39
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
                    Reset counter: 39
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
                    Reset counter: 39
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
01196 - Engine-Transmission Data Bus
                    Reset counter: 39
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: C54BC0F549220003A30E03E4921A0042A1100012
   VCID: FEB0BE5A694806CE8C-80AA
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Count: 12
                    Count: 8208
                    Count: 45312
                    Count: 255
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Count: 2
                    Count: 12
                    Count: 8194
                    Count: 45312
                    Count: 255
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Count: 2
                    Count: 12
                    Count: 8226
                    Count: 45312
                    Count: 255
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Count: 2
                    Count: 12
                    Count: 8262
                    Count: 45312
                    Count: 255
                    Reset counter: 228
                    Mileage: 71446 km
                    Date: 2016.03.01
                    Time: 09:42:24
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 50494
                    Count: 255
                    Count: 257
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Revision: 00092000    Serial number: 0332322625
   Coding: 130C0C
   ROD: EV_KESSYPQ35G.rod
   VCID: B73E6B7E0EF2F7860F-80E2
   Part No SW: 561 907 044 AP    HW: 561 907 044 AP
   Component: Climatronic   H03 0707
   Revision: 00001K01
   Coding: 0010019012
   ROD: EV_ACClimaBHBVW411_VW41.rod
   VCID: E582F136E4DEB5166D-80B0
   Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
   Component: BCM PQ35 H+   122 0174
   Revision: BL122001
   Coding: EF200E3B982B08D4098802013600854800F1A01E45A005B064806000BC70
   VCID: F8BCA8424B6C38FEC6-80AC
   Component: RLS 290514 05  54  0403
   Coding: 02300A
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD018ST9
   Coding: 00004D32
   ROD: EV_AirbaVW10SMEVW360_SE36.rod
   VCID: F2A89A6A251052AEF8-80A6
   Serial number: 6940000Y1400016MTW0J
   Coding: 303047
   Serial number: 3572MSME6E6B6A44ZZZB
   Serial number: 3582MSME312C6A44ZZZ-
   Serial number: 3516KSME7B12782EZZZ+
   Serial number: 3526KSME050D572DZZZZ
   Serial number: 3556LSME0703372EZZZU
   Serial number: 3566LSME1D6B352EZZZ7
   Part No SW: 1K5 953 521 BR    HW: 5K0 953 569 AH
   Revision: FF010042    Serial number: 20140530200383
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: FEB0BE5A614806CE8C-80AA
   Component: E221__MFL-YVJ  H07 0022
   Coding: E20000
   Part No SW: 561 920 970 G    HW: 561 920 970 G
   Component: KOMBI         H04 0813
   Coding: 231C01
   VCID: 9E709EDA8108A6CEEC-80CA
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 28061403000506
   Coding: 461000
   VCID: 804CC0A213BC703EFE-80D4
13 Faults Found:
                    Fault Status: 00110100
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Reset counter: 228
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 228
   Component: IMMO          H04 0813
   Coding: 000007
   VCID: EA98820A0DC09A6E40-80BE
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Revision: 00000000    Serial number: 14000125876005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: B02C5062EB9C20BE4E-80E4
   Part No SW: 561 959 760 B    HW: 561 959 760 B
   Component: MEM-FS        H04 0182
   Revision: AA000000    Serial number: 00000105342645
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: A208AA2ABD70822EC8-80F6
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3C0 035 684 P    HW: 3C0 035 684 P
   Component: RNS-MID       H27 5382
   Revision: AB001001    Serial number: VWZ6Z7R7224015
   Coding: 04090042010000A6000B
   Shop #: WSC 23052 002 1048576
   VCID: B02C5062E39C20BE4E-80E4
   Subsystem 1 - Part No: 7L6 919 859
   Component: NAR V8  8112
                    Reset counter: 228
                    Mileage: 71464 km
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0525
   Revision: 12110009    Serial number: 0008552180
   Coding: 0405FD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 9C7494D29714B4DE02-80C8
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630140613191023
   Coding: 800000
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 215    3501
   Revision: 00H22000
   VCID: B93A6D46F0E6E1F6F9-80EC
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Voltage: 12.50 V
                        DU
                    Temperature: 31.0°C
                    RPM: 1498 /min
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Voltage: 12.50 V
                        DU
                    Temperature: 31.0°C
                    RPM: 1498 /min
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K 6815
   Revision: --------    Serial number: EAA098A0144697
   VCID: A600B63AD9587E0EA4-80F2
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
   Component: EZE_2         H55 1653
   Coding: 01030108
   VCID: EFAE931E3E227F4617-80BA
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0005
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0525
   Revision: 14110009    Serial number: 0008587165
   Coding: 0405FC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 9D7299D68C0EBDD6F5-80C8
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B
   Component: J389__TSG_HR  006 5470
   Serial number: 14102631140627144210
   Coding: 800000
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
                    Reset counter: 228
                    Mileage: 71464 km
Address 75: Telematics (J949)       Labels: None
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0102
   Serial number: 000003554140523
   Coding: 02140102C2423A007F1606000000
   ROD: EV_OCULow.rod
   VCID: D3E63FEEBA4A3BA613-8086
0041 - Databus
                    Reset counter: 228
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 188
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:47:39
Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007666170901
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: AE104E1AF1A8364E5C-80FA
End-------------------------(Elapsed Time: 02:31)--------------------------
   #31
William
France
C?ID=238135
I updated my HEX-NET this week (firmware + database ASAM), but since I did this operation, VCDS mobile is not able to read the fault codes, here is the result of autoscan :
005475 - ROD - Unknown faultcode
007157 - ROD - Unknown faultcode
004986 - ROD - Unknown faultcode
004987 - ROD - Unknown faultcode
005418 - ROD - Unknown faultcode
The hexnetconfig app tells me there is an available update, but makes an error while installing (code 2).
The vids mobile interface tells me there is an internal error on the server...
Help !!!
   #32
Help !!!
Please post an Auto-Scan so we can see what control module this is from.
William
France
C?ID=238135
The problem has been solved today : I managed to update the dataset !
See you !
   #34
andyvee
C?ID=159389
I'm still getting EV_ACCMRRBoschVW372_AU37.rod repeatedly downloading
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Can you post a current Mobile Auto-Scan, as much as you can get without the ASAM data update? The last one I could find from you was about a month ago, and it didn't have a VIN. It's my understanding the VIN figures into the the ROD lookup process, so if that's missing, that may be important.
Jason
   #36
andyvee
C?ID=159389
Saturday,12,March,2016,11:29:24:04069VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.4.1 (x64)
VIN: TMBKJ9NE0F0104172   License Plate:
Mileage: 40634km-25248mi   Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 42 44 52 55 5F 6D
          A5
VIN: TMBKJ9NE0F0104172   Mileage: 40634km-25248miles
Address 01: Engine (J623-CKFC)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 7545
   Revision: 83H22---
   Coding: 111D0032046501091000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002007
   ROD: EV_ECM20TDI01104L906021DT_SK37.rod
   VCID: 7AB839CFFDD0BCEE30-802E
   Part No SW: 0D9 300 041 P    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4507
   Revision: 03253104    Serial number: TFK01409080569
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 25023AB324EEE3162D-8070
   Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
   Component: ESC           H31 0571
   Revision: 00000000    Serial number: 62724000001129
   Coding: 1C078A91242009700078060741C5243851249000608224F2F661F072C009
   Shop #: WSC 73430 031 00063
   ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
   VCID: 46C09D3FF9A8080E04-8012
   Revision: 00021000    Serial number: 0347141964
   Coding: 030C0C
   Shop #: WSC 73430 790 00000
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A38F9CFBD507CEE70-806E
   Part No SW: 5E0 907 044 N    HW: 5E0 907 044 N
   Component: Climatronic   H03 0907
   Revision: 00001K06
   Coding: 02110104000100011005000100101000
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 302CDBE76B2CB6BECE-8064
          B10CD 00 [008] -  -
                    Reset counter: 220
                    Mileage: 40634 km
                    Date: 2016.03.11
                    Time: 15:03:17
   Part No SW: 5Q0 937 086 AA    HW: 5Q0 937 086 AA
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86581310140746
   Coding: 0F511B76424722FB0FA44086B11C17280800000000000000000000000000
   Shop #: WSC 73430 790 12345
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 79BA26C3F8D6B7F639-802C
   Slave 1:
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 140911  041 0570
   Serial number:         140919232831
   Coding: 0E4DFD
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S4Y14M10D13H14M19S10
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY141272BD5
   Serial number: 00000000000060534409
   Subsystem 5 - Part No SW: 5E9 959 591     HW: 7P0 959 591 B
   Component: J245 PS24.011  H01 0008
   Serial number:     WOO3215520Z
   Coding: 991900
   Subsystem 6 - Part No SW: 5E9 959 591 A    HW: 7P0 959 591 C
   Component: J394 PS24.011  H01 0008
   Serial number:     WOO32246742
   Coding: 991900
131586 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 220
                    Mileage: 40634 km
                    Date: 2016.03.11
                    Time: 15:14:58
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0047
   Revision: --------    Serial number: 39431426502437
   Coding: 0131161051
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_SK37.rod
   VCID: 42C8812FD580342E28-8016
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 26091403210306
   Coding: 00081600FE0739
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 383CE3C7835C6EFE86-806C
   Part No SW: 3Q0 959 655 AA    HW: 3Q0 959 655 AA
   Component: Airbag VW20   012 0200
   Revision: --------    Serial number: 003NYPLJ7PWH
   Coding: 98FCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X_SK37.rod
   VCID: 7DB232D3ECFE8BD615-8028
   Seat belt tensioner; left:
   Component: BeltPretRevFL  H35 0341
   Serial number: 34169595B01101441286
   Coding: 333135
   Seat belt tensioner; right:
   Component: BeltPretRevFR  H35 0341
   Serial number: 34169594B01101440818
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 454 002 609 14
   Serial number: 3576U0000006A741411%
   Subsystem 4 - Part No SW: -----------    HW: 454 002 709 14
   Serial number: 3586U0000000B070211V
   Subsystem 5 - Part No SW: -----------    HW: 454 802 709 14
   Serial number: 3516R4C40B204000000-
   Subsystem 6 - Part No SW: -----------    HW: 454 802 909 14
   Serial number: 3526RB940DC04000000A
   Subsystem 7 - Part No SW: -----------    HW: 454 800 109 14
   Serial number: 3556VC8E29804000000L
   Part No SW: 5Q0 953 507 EJ    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 17081404400903
   Coding: 6C10
   ROD: EV_SMLSKLOMQB_SK37.rod
   VCID: 0248412F9500F42E68-8056
   Part No SW: 5E0 920 911     HW: 5E0 920 911
   Component: KOMBI         304 4270
   Coding: 27A50A186D94A60001887A031000000000000000
   Shop #: WSC 00123 123 12345
   VCID: 608C6BA77B4C463E1E-8034
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002531914
   Coding: 030100340F087300EF00025E1C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear.rod
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H05 0130
   Serial number: 000000000C1182020914
   Serial number: 5298644603
   Revision: 00000000    Serial number: 14000267752001
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3424D7F79F348A9EAA-8060
          U1400 00 [008] - -
                    Reset counter: 220
                    Mileage: 40634 km
                    Date: 2016.03.11
                    Time: 15:14:56
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006NHK10076
   Coding: 001400000000010001A081808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_SK37.rod
   VCID: 3B36FCCBB26A45E66B-806E
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000121334006
   Coding: 001D0820DE01048000001100
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 44C48737CF943A1E1A-8010
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000004020570
   Coding: 1D0200
   Coding: 9302
   ROD: EV_SteerAssisMQB.rod
   VCID: 41CA8E23D0862F3631-8014
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000121631170
   Coding: 001D0020DE01048000001100
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 43C6842BCA9A3D2623-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000003981447
   Coding: 050200
   Coding: 03CE02003F010000
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 40CC8B27DB8C263E3E-8014
   Coding: 3E0000
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels: 5E0-035-MIB-HGH1.clb
   Part No SW: 5E0 035 020 C    HW: 5E0 035 020 C
   Component: MU-H-ND-EU    H43 0390
   Serial number: A313I0EB012483
   Coding: 03730201000000001111120200A800002F0003F601000100F6
   Shop #: WSC 47024 001 1048576
   ASAM Dataset: EV_MUHig6C3HBAS 001041
   ROD: EV_MUHig6C3HBAS_SK37.rod
   VCID: 177E007BEE824186AF-8042
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5E0 919 606     HW: 5E0 919 606
   Component: ABT_High  H60 0030
   Serial number: SKZ8Z9PT6007AK
   Engine Control Module 2:
   Subsystem 2 - Part No SW: V03 959 800 MF    HW: -----------
   Component: ECE 2016  --- 0134
1539 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 180
                    Mileage: 40634 km
                    Date: 2016.03.11
                    Time: 15:15:06
1564 - Microphone 1
          B129B 13 [008] - Open Circuit
                    Reset counter: 220
                    Mileage: 40634 km
                    Date: 2016.03.04
                    Time: 10:13:30
7184 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 220
                    Mileage: 40634 km
                    Date: 2016.03.04
                    Time: 10:13:31
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 5E0 959 107 A    HW: 5E0 959 107
   Component: HDSG-Modul    H01 0746
   Revision: 42001001    Serial number: 277400848
   Coding: 1233074002
   ASAM Dataset: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462_SK37.rod
   VCID: 2A18C98F4DF0CC6E00-807E
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 10000141271
   Coding: 0101010001030303000400000100010100
   ROD: EV_MFKBoschAU370_AU37.rod
End-------------------------(Elapsed Time: 02:40)--------------------------
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 2B: DTCs cleared
Address 5F: DTCs cleared
Don't worry about all the DTC's, I know why they are there :)
   #37
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Fair enough, but can you give that another shot from VCDS Mobile -- the web-based version, instead of Desktop? I'd like to see if Mobile is getting or missing your VIN, and what RODs it flags as missing in a scan separately from what the download process keeps trying to grab.
Jason
   #38
andyvee
C?ID=159389
No probs, I'll do another mobile scan tomorrow. The ones I have saved seem to have the VIN.
#hndoc:?docid=00001902&xt=hnh:3FA2038B0FC3473944E1603A55C2D52643DBE9C32765830AAA4A590FB7F2C6C0VCDS Mobile 0.4305.0.4
	 A5
Address 01: Engine  (CKFC2 J623)	Labels: None
	Revision: 83H22---
	VCID: 7AB761EB603BD16227C740ABE4-802F
Address 02: Auto Trans  (J743)	Labels: 0D-02.lbl
	Revision: 03253104
	VCID: 250D6297B9058E9A3A759BAF35-8070
	Revision: 00000000
	VCID: 46CFC51B6443658213BF045B40-8013
	Revision: 00021000
	Coding: 030C0C
	VCID: 3A37A1EB20BB1162674780AB24-806F
	Revision: 00001K06
	VCID: 302383C3F6C7DB32D9E31253A2-8065
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
Address 09: Cent. Elect.  (J519)	Labels: None
	Revision: --------
	VCID: 79B57EE7653DDA7A2EBD37BFF9-802C
	Subsystem 1 - 	Part No SW: 5E2-955-119	Labels: 5Qx-955-119-V1.clb
	Component: Mý
	Subsystem 2 -
	Subsystem 3 -
	Subsystem 4 -
	Subsystem 5 - 	Component: ™
	Subsystem 6 - 	Component: ™
	Subsystem 7 -
	Revision: --------
	Coding: 0131161051
	VCID: 42C7D90B486B59A23F97D80B8C-8017
	ROD: N/A
	VCID: 3833BBE31EB7037291336AB30A-806D
	No ASAM data for: "EV_ACCMRRBoschVW372"
	Revision: --------
	VCID: 7DBD6AF77115E65A02E563CF8D-8028
	Subsystem 1 - 	Part No SW: 5G0-980-945-B
	Component: 315
	Subsystem 2 - 	Component: 315
	Subsystem 3 - 	Component: ---
	Subsystem 4 - 	Component: ---
	Subsystem 5 - 	Component: ---
	Subsystem 6 - 	Component: ---
Address 16: Steering wheel  (J527)	Labels: 5Q-16.lbl
	Revision: --------
	Coding: 6C10
	VCID: 8247990B88EB19A2FF17980B4C-80D7
	VCID: E083B38366A7ABB289C3A293B2-80B5
	Revision: --------
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
	Revision: 00000000
	VCID: 342B8FD302DFE712BD0B3E6376-8061
	VCID: 3B39A4EF2F81286A7C518DD7D3-806E
Address 42: Door Elect, Driver  (J386)	Labels: None
	VCID: 44CBDF13527F57920DABEE23A6-8011
	Coding: 9302
	VCID: 41C5D6074D6D42BA268DCF1F81-8014
Address 52: Door Elect, Pass.  (J387)	Labels: None
	VCID: 43C9DC0F577150AA34A1E537BB-8016
Address 55: Xenon Range  (J745)	Labels: 7P6-907-357.clb
	Revision: --------
	VCID: 40C3D30346674BB22983C21392-8015
	Subsystem 1 - 	Part No SW: 1T0-941-329-B	Labels: 3D0-941-329.clb
	Component: >
Address 5F: Information Electr.  (J794)	Labels: None
	VCID: 1771585F73692C0AB8E90107FF-8042
	Subsystem 1 - 	Part No SW: 5E0-919-606
	Component: ABT_High
	Subsystem 2 -
	Revision: 42001001
	Coding: 1233074002
	VCID: 2A1791ABD01BA1E217A7D0EBF4-807F
   #39
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Yeah, I'd definitely like to see a fresh one when you have it. That one was taken with CB 4305 (you can see at the top) and most all the fixes came in with CB 4309.
Jason
   #40
andyvee
C?ID=159389
Yep, I haven't done a mobile scan for a while as my wireless LAN doesn't stretch to the car, and I can't get VCDS Cloud to work reliably over 4G tethering in the UK, everything seems to time out and lose connection.
