Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 48
Thread: Missing ROD and ASAM dataset update failing
  1. #31
    Mar 2015
    France
    I updated my HEX-NET this week (firmware + database ASAM), but since I did this operation, VCDS mobile is not able to read the fault codes, here is the result of autoscan :
    005475 - ROD - Unknown faultcode
    007157 - ROD - Unknown faultcode
    004986 - ROD - Unknown faultcode
    004987 - ROD - Unknown faultcode
    005418 - ROD - Unknown faultcode
    The hexnetconfig app tells me there is an available update, but makes an error while installing (code 2).
    The vids mobile interface tells me there is an internal error on the server...
    Help !!!
  2. #32
    Quote Originally Posted by William View Post
    Help !!!
    Please post an Auto-Scan so we can see what control module this is from.
  3. #33
    Mar 2015
    France
    The problem has been solved today : I managed to update the dataset !
    See you !
  4. Likes jyoung8607, Uwe liked this post
  5. #34
    Verified VCDS User andyvee's Avatar
    May 2014
    Rossendale, Lancashire, UK
    I'm still getting EV_ACCMRRBoschVW372_AU37.rod repeatedly downloading
  6. Likes Uwe liked this post
  7. #35
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by andyvee View Post
    Can you post a current Mobile Auto-Scan, as much as you can get without the ASAM data update? The last one I could find from you was about a month ago, and it didn't have a VIN. It's my understanding the VIN figures into the the ROD lookup process, so if that's missing, that may be important.
    Jason
  8. #36
    May 2014
    Saturday,12,March,2016,11:29:24:04069VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: TMBKJ9NE0F0104172   License Plate:
    Mileage: 40634km-25248mi   Repair Order:
    Chassis Type: NE (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 42 44 52 55 5F 6D
              A5
    VIN: TMBKJ9NE0F0104172   Mileage: 40634km-25248miles
    2B-Steer. Col. Lock -- Status: Malfunction 0010
    Address 01: Engine (J623-CKFC)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H22 7545
       Revision: 83H22---
       Coding: 111D0032046501091000
       Shop #: WSC 73430 031 00000
       ASAM Dataset: EV_ECM20TDI01104L906021DT 002007
       ROD: EV_ECM20TDI01104L906021DT_SK37.rod
       VCID: 7AB839CFFDD0BCEE30-802E
       Part No SW: 0D9 300 041 P    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4507
       Revision: 03253104    Serial number: TFK01409080569
       ROD: EV_TCMDQ250021_AU37.rod
       VCID: 25023AB324EEE3162D-8070
       Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
       Component: ESC           H31 0571
       Revision: 00000000    Serial number: 62724000001129
       Coding: 1C078A91242009700078060741C5243851249000608224F2F661F072C009
       Shop #: WSC 73430 031 00063
       ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
       VCID: 46C09D3FF9A8080E04-8012
       Revision: 00021000    Serial number: 0347141964
       Coding: 030C0C
       Shop #: WSC 73430 790 00000
       VCID: 3A38F9CFBD507CEE70-806E
       Part No SW: 5E0 907 044 N    HW: 5E0 907 044 N
       Component: Climatronic   H03 0907
       Revision: 00001K06
       Coding: 02110104000100011005000100101000
       ASAM Dataset: EV_ACClimaBHBVW37X 003017
       ROD: EV_ACClimaBHBVW37X_SK37.rod
       VCID: 302CDBE76B2CB6BECE-8064
              B10CD 00 [008] -  -
                        Reset counter: 220
                        Mileage: 40634 km
                        Date: 2016.03.11
                        Time: 15:03:17
       Part No SW: 5Q0 937 086 AA    HW: 5Q0 937 086 AA
       Component: BCM PQ37BOSCH 028 0106
       Revision: --------    Serial number: 86581310140746
       Coding: 0F511B76424722FB0FA44086B11C17280800000000000000000000000000
       Shop #: WSC 73430 790 12345
       ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 79BA26C3F8D6B7F639-802C
       Slave 1:
       Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 140911  041 0570
       Serial number:         140919232831
       Coding: 0E4DFD
       Slave 2:
       Component: RLHS  037 0059
       Serial number: S4Y14M10D13H14M19S10
       Coding: 00885D
       Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY141272BD5
       Serial number: 00000000000060534409
       Subsystem 5 - Part No SW: 5E9 959 591     HW: 7P0 959 591 B
       Component: J245 PS24.011  H01 0008
       Serial number:     WOO3215520Z
       Coding: 991900
       Subsystem 6 - Part No SW: 5E9 959 591 A    HW: 7P0 959 591 C
       Component: J394 PS24.011  H01 0008
       Serial number:     WOO32246742
       Coding: 991900
    131586 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 220
                        Mileage: 40634 km
                        Date: 2016.03.11
                        Time: 15:14:58
       Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0047
       Revision: --------    Serial number: 39431426502437
       Coding: 0131161051
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_EPHVA2CAU3700000 003019
       ROD: EV_EPHVA2CAU3700000_SK37.rod
       VCID: 42C8812FD580342E28-8016
    Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 26091403210306
       Coding: 00081600FE0739
       ASAM Dataset: EV_ACCMRRBoschVW372 001015
       ROD: EV_ACCMRRBoschVW372_AU37.rod
       VCID: 383CE3C7835C6EFE86-806C
       Part No SW: 3Q0 959 655 AA    HW: 3Q0 959 655 AA
       Component: Airbag VW20   012 0200
       Revision: --------    Serial number: 003NYPLJ7PWH
       Coding: 98FCC000000000005C5400CC008800000065
       ROD: EV_AirbaVW20TS6VW48X_SK37.rod
       VCID: 7DB232D3ECFE8BD615-8028
       Seat belt tensioner; left:
       Component: BeltPretRevFL  H35 0341
       Serial number: 34169595B01101441286
       Coding: 333135
       Seat belt tensioner; right:
       Component: BeltPretRevFR  H35 0341
       Serial number: 34169594B01101440818
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 454 002 609 14
       Serial number: 3576U0000006A741411%
       Subsystem 4 - Part No SW: -----------    HW: 454 002 709 14
       Serial number: 3586U0000000B070211V
       Subsystem 5 - Part No SW: -----------    HW: 454 802 709 14
       Serial number: 3516R4C40B204000000-
       Subsystem 6 - Part No SW: -----------    HW: 454 802 909 14
       Serial number: 3526RB940DC04000000A
       Subsystem 7 - Part No SW: -----------    HW: 454 800 109 14
       Serial number: 3556VC8E29804000000L
       Part No SW: 5Q0 953 507 EJ    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 17081404400903
       Coding: 6C10
       ROD: EV_SMLSKLOMQB_SK37.rod
       VCID: 0248412F9500F42E68-8056
       Part No SW: 5E0 920 911     HW: 5E0 920 911
       Component: KOMBI         304 4270
       Coding: 27A50A186D94A60001887A031000000000000000
       Shop #: WSC 00123 123 12345
       VCID: 608C6BA77B4C463E1E-8034
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1188
       Revision: --------    Serial number: 0002531914
       Coding: 030100340F087300EF00025E1C0F00010001050000000000000000000000
       ASAM Dataset: EV_GatewLear 011016
       ROD: EV_GatewLear.rod
       Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
       Component: E221__MFL-PR6  H05 0130
       Serial number: 000000000C1182020914
       Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
       Component: J367-BDMHella  H03 8043
       Serial number: 5298644603
       Revision: 00000000    Serial number: 14000267752001
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_AU37.rod
       VCID: 3424D7F79F348A9EAA-8060
              U1400 00 [008] - -
                        Reset counter: 220
                        Mileage: 40634 km
                        Date: 2016.03.11
                        Time: 15:14:56
    Address 36: Seat Mem. Drvr (J810)       Labels: None
       Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
       Component: Sitzmemory    H06 0009
       Serial number: Y0006NHK10076
       Coding: 001400000000010001A081808080000000008181000000D4
       ASAM Dataset: EV_SeatMemorDriveSide 001015
       ROD: EV_SeatMemorDriveSide_SK37.rod
       VCID: 3B36FCCBB26A45E66B-806E
       Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
       Component: TSG FS        009 0014
       Serial number: 0000121334006
       Coding: 001D0820DE01048000001100
       ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
       VCID: 44C48737CF943A1E1A-8010
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
       Serial number: 00000000000004020570
       Coding: 1D0200
       Component: EPS_MQB_ZFLS  122 1043
       Coding: 9302
       ROD: EV_SteerAssisMQB.rod
       VCID: 41CA8E23D0862F3631-8014
       Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
       Component: TSG BFS       009 0014
       Serial number: 0000121631170
       Coding: 001D0020DE01048000001100
       ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
       VCID: 43C6842BCA9A3D2623-8016
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
       Serial number: 00000000000003981447
       Coding: 050200
       Coding: 03CE02003F010000
       ROD: EV_HeadlRegulVWAFS_SE26.rod
       VCID: 40CC8B27DB8C263E3E-8014
       Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H06 0009
       Coding: 3E0000
       Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H06 0009
       Coding: 3E0000
    Address 5F: Information Electr. (J794)       Labels: 5E0-035-MIB-HGH1.clb
       Part No SW: 5E0 035 020 C    HW: 5E0 035 020 C
       Component: MU-H-ND-EU    H43 0390
       Serial number: A313I0EB012483
       Coding: 03730201000000001111120200A800002F0003F601000100F6
       Shop #: WSC 47024 001 1048576
       ASAM Dataset: EV_MUHig6C3HBAS 001041
       ROD: EV_MUHig6C3HBAS_SK37.rod
       VCID: 177E007BEE824186AF-8042
       Media Player Position 1:
       Subsystem 1 - Part No SW: 5E0 919 606     HW: 5E0 919 606
       Component: ABT_High  H60 0030
       Serial number: SKZ8Z9PT6007AK
       Engine Control Module 2:
       Subsystem 2 - Part No SW: V03 959 800 MF    HW: -----------
       Component: ECE 2016  --- 0134
    1539 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 180
                        Mileage: 40634 km
                        Date: 2016.03.11
                        Time: 15:15:06
    1564 - Microphone 1
              B129B 13 [008] - Open Circuit
                        Reset counter: 220
                        Mileage: 40634 km
                        Date: 2016.03.04
                        Time: 10:13:30
    7184 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 220
                        Mileage: 40634 km
                        Date: 2016.03.04
                        Time: 10:13:31
    Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
       Part No SW: 5E0 959 107 A    HW: 5E0 959 107
       Component: HDSG-Modul    H01 0746
       Revision: 42001001    Serial number: 277400848
       Coding: 1233074002
       ASAM Dataset: EV_HDSGSk462 301136
       ROD: EV_HDSGSk462_SK37.rod
       VCID: 2A18C98F4DF0CC6E00-807E
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
       Component: MQB_MFK       H06 0052
       Serial number: 10000141271
       Coding: 0101010001030303000400000100010100
       ROD: EV_MFKBoschAU370_AU37.rod
    End-------------------------(Elapsed Time: 02:40)--------------------------
    Address 08: DTCs cleared
    Address 09: DTCs cleared
    Address 2B: DTCs cleared
    Address 5F: DTCs cleared
    Don't worry about all the DTC's, I know why they are there
  9. #37
    Cincinnati, OH
    Fair enough, but can you give that another shot from VCDS Mobile -- the web-based version, instead of Desktop? I'd like to see if Mobile is getting or missing your VIN, and what RODs it flags as missing in a scan separately from what the download process keeps trying to grab.
    Jason
  10. #38
    May 2014
    No probs, I'll do another mobile scan tomorrow. The ones I have saved seem to have the VIN.
    #hndoc:?docid=00001902&xt=hnh:3FA2038B0FC3473944E1603A55C2D52643DBE9C32765830AAA4A590FB7F2C6C0VCDS Mobile 0.4305.0.4
    	 A5
    Address 01: Engine  (CKFC2 J623)	Labels: None
    	Revision: 83H22---
    	VCID: 7AB761EB603BD16227C740ABE4-802F
    No fault codes found.
    Address 02: Auto Trans  (J743)	Labels: 0D-02.lbl
    	Revision: 03253104
    	VCID: 250D6297B9058E9A3A759BAF35-8070
    Address 03: ABS Brakes  (J104)	Labels: None
    	Revision: 00000000
    	VCID: 46CFC51B6443658213BF045B40-8013
    	Revision: 00021000
    	Coding: 030C0C
    	VCID: 3A37A1EB20BB1162674780AB24-806F
    	Revision: 00001K06
    	VCID: 302383C3F6C7DB32D9E31253A2-8065
    	Subsystem 1 -
    	Subsystem 2 -
    	Subsystem 3 -
    Address 09: Cent. Elect.  (J519)	Labels: None
    	Revision: --------
    	VCID: 79B57EE7653DDA7A2EBD37BFF9-802C
    	Subsystem 1 - 	Part No SW: 5E2-955-119	Labels: 5Qx-955-119-V1.clb
    	Component: Mý
    	Subsystem 2 -
    	Subsystem 3 -
    	Subsystem 4 -
    	Subsystem 5 - 	Component: ™
    	Subsystem 6 - 	Component: ™
    	Subsystem 7 -
    	Revision: --------
    	Coding: 0131161051
    	VCID: 42C7D90B486B59A23F97D80B8C-8017
    	ROD: N/A
    	VCID: 3833BBE31EB7037291336AB30A-806D
    	No ASAM data for: "EV_ACCMRRBoschVW372"
    	Revision: --------
    	VCID: 7DBD6AF77115E65A02E563CF8D-8028
    	Subsystem 1 - 	Part No SW: 5G0-980-945-B
    	Component: 315
    	Subsystem 2 - 	Component: 315
    	Subsystem 3 - 	Component: ---
    	Subsystem 4 - 	Component: ---
    	Subsystem 5 - 	Component: ---
    	Subsystem 6 - 	Component: ---
    Address 16: Steering wheel  (J527)	Labels: 5Q-16.lbl
    	Revision: --------
    	Coding: 6C10
    	VCID: 8247990B88EB19A2FF17980B4C-80D7
    	VCID: E083B38366A7ABB289C3A293B2-80B5
    	Revision: --------
    	Subsystem 1 -
    	Subsystem 2 -
    	Subsystem 3 -
    	Revision: 00000000
    	VCID: 342B8FD302DFE712BD0B3E6376-8061
    	VCID: 3B39A4EF2F81286A7C518DD7D3-806E
    Address 42: Door Elect, Driver  (J386)	Labels: None
    	VCID: 44CBDF13527F57920DABEE23A6-8011
    	Coding: 9302
    	VCID: 41C5D6074D6D42BA268DCF1F81-8014
    Address 52: Door Elect, Pass.  (J387)	Labels: None
    	VCID: 43C9DC0F577150AA34A1E537BB-8016
    Address 55: Xenon Range  (J745)	Labels: 7P6-907-357.clb
    	Revision: --------
    	VCID: 40C3D30346674BB22983C21392-8015
    	Subsystem 1 - 	Part No SW: 1T0-941-329-B	Labels: 3D0-941-329.clb
    	Component: >
    Address 5F: Information Electr.  (J794)	Labels: None
    	VCID: 1771585F73692C0AB8E90107FF-8042
    	Subsystem 1 - 	Part No SW: 5E0-919-606
    	Component: ABT_High
    	Subsystem 2 -
    	Revision: 42001001
    	Coding: 1233074002
    	VCID: 2A1791ABD01BA1E217A7D0EBF4-807F
  11. #39
    Cincinnati, OH
    Yeah, I'd definitely like to see a fresh one when you have it. That one was taken with CB 4305 (you can see at the top) and most all the fixes came in with CB 4309.
    Jason
  12. #40
    May 2014
    Yep, I haven't done a mobile scan for a while as my wireless LAN doesn't stretch to the car, and I can't get VCDS Cloud to work reliably over 4G tethering in the UK, everything seems to time out and lose connection.
