Results 1 to 6 of 6
Thread: Widows 10 and HEX NET Config
    Verified VCDS User Gizmo's Avatar
    Mar 2014
    S.E.Kent UK
    My netbook is dying fast and due to ongoing VCDS-Mobile issues I have bought a cheap Windows 10 tablet purely to run VCDS on.
    However despite using the links on the HEX-NET downloads page to install Java (Version 8 Update 73) and then the HEX-NET Config (both V2.007 and I also tried the older V1.963)
    When I try to open HEX-NETConfig I get the following error:
    According to the Java site, Java has installed correctly??
    I have tried downloading with Internet Explorer and Firefox with the same results (I deleted Java and HEX-NETConfig fully between trying with each browser)
    Has anyone else had issues with Windows 10? (I am usually a Mac user)
    HEX-NET
    2016 Škoda Superb L&K (190CR)
    Pre-booked a VW ID.3 1st Edition
  2. Likes Uwe liked this post
  3. #2
    Verified VCDS User andyvee's Avatar
    Rossendale, Lancashire, UK
    Nope, but I manually installed both the 64 and 32 bit java versions
    Edit - after checking I only installed the 64 bit version
  4. Likes Uwe liked this post
  5. #3
    It's not clear to me.. Have you got this sorted?
  6. #4
    Mar 2014
    S.E.Kent UK
    No, everything I tried came back with the same error above so thought I would ask if there was a known conflict with Windows 10.
    HEX-NET
    Lansdale, PA
    Have you tried running it via command prompt?
    Access your command prompt (search CMD)
    enter the following
    Java -jar C:\Users\Martin\Downloads\HexNetConfigV2.007.jar
  8. Likes Uwe, Gizmo, DrPeter liked this post
  9. #6
    Mar 2014
    S.E.Kent UK
    No I hadn’t, but that has worked thanks
    HEX-NET
  10. Likes Uwe liked this post
