Results 1 to 6 of 6
Thread: Passat ABS code required
    Feb 2016
    Hi, was changing the rear pads on a 2010 passat & after finishing the ABS/ESP light was on. Turns out the ABS code has got wiped some how. Is there anybody here that can help or do i need to contact Ross Tech directly to get the correct ABS coding?
    Many thanks.
    here is a scan of the error
    VCDS Version: Release 15.7.3 (x64) Running on Windows 7 x64
    Data version: 20151216
    Wednesday,17,February,2016,11:12:22:23326
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72 77
    VIN: WVWZZZ3CZAE182228   Mileage: 141200km-87737miles
    Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 QF    HW: 03L 907 309
       Component: R4 2,0L EDC G000SG  6211
       Revision: 13H08---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 84224 036 682055
       VCID: 79FDB2B830824CF636-802C
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
       Component: J104    C4 440 V2   0015
       Revision: --026---    Serial number: 00000705860542
       Coding: 0000000
       Shop #: WSC 05311 000 00000
       VCID: 62CFF5D4BD14AF2E07-8036
                        Reset counter: 202
                        Mileage: 141208 km
                        Date: 2010.07.10
                        Time: 11:07:56
                        Hex Value: 0x0000
                        Voltage: 11.75 V
                        Bin. Bits: 00011111
                        Count: 149
                        Hex Value: 0x0000
       Part No SW: 3C8 907 336 AG    HW: 3C8 907 336 AG
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000002
       Shop #: WSC 05311 115 00000
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 72EF8594A5F43FAE77-8026
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
       Part No SW: 3C8 937 049 F    HW: 3C8 937 049 F
       Revision: 00H54000    Serial number: 00000003983731
       Coding: 01888F0700041A00470A00000F000000000C5D435C000120000000000000
       Shop #: WSC 05124 000 00000
       VCID: 3463438C5760719EA5-8060
       Subsystem 1 - Part No: 3C2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 310510 022  0612
       Coding: 00046997
       Shop #: WSC 05124
       Part No SW: 5N0 959 655 N    HW: 5N0 959 655 N
       Component: J234__006 VW10 HI   1916
       Revision: 21014000    Serial number: 003GHPBWLEAK
       Coding: 0012342
       VCID: 489B077C3BE8E57EF9-801C
       Subsystem 1 - Serial number: 6332MTS612081450
       Subsystem 2 - Serial number: 6342MTS624301470
       Subsystem 3 - Serial number: 6351HTS6V4S3A9KJ
       Subsystem 4 - Serial number: 6361HTS64684A9KJ
    Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
       Part No SW: 3C9 953 501 BN    HW: 5K0 953 569 AB
       Component: LENKS.MODUL   009 0135
       Revision: FF010036    Serial number: 20100622200502
       Coding: 1182270002
       VCID: 76E7B984C99C238E5B-8022
       Coding: E20000
    Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
       Part No SW: 3C0 920 972 J    HW: 3C0 920 972 J
       Component: KOMBI         H03 0305
       Coding: 461F00
       Shop #: WSC 05314 115 00000
       VCID: 2D5556E87C4A2056EA-8078
    Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
       Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
       Component: J533  Gateway   H13 0172
       Revision:   H13       Serial number: 3620P106150174
       Coding: F9807F06400602002003
       Shop #: WSC 05314 000 00000
       VCID: 2F694CE0BE465246D8-807A
       Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
       Component:    IMMO         043 0383
       VCID: 7AFFADB4358447EE3F-802E
       Subsystem 1 - Part No: 3C0 905 861 H
       Component:    ELV          028 0380
       3C0905861H     ELV          028 0380
    02861 - Electronic Steering Column Lock Check Sum Error
                        Reset counter: 225
                        Mileage: 139713 km
                        Date: 2010.07.01
                        Time: 10:48:45
    Address 37: Navigation
       Part No SW: 3C0 959 701     HW: 3C0 959 793
       Component: TUER-SG FT    002 0306
       Revision: 13101005    Serial number: 0001032396
       Coding: 0002B5
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide.rod
       VCID: 65C5EEC8643AD816E2-8030
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0401
       Serial number: 00000001528851
       Coding: 000290
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 196    3001
       Revision: 00H17000
       VCID: 316D4A98A87244B6CE-8064
       Component:    KSG PQ46 ELV 043 0612
       Coding: 0191020051030E763004941570085FCE107C01
       Subsystem 1 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HORN H11 9004
       Part No SW: 3C0 959 702     HW: 3C0 959 792
       Component: TUER-SG BT    002 0306
       Revision: 15101005    Serial number: 0001044571
       Coding: 0002B4
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide.rod
       VCID: 66C7E9C4993CD30EEB-8032
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0401
       Serial number: 00000001535261
       Coding: 000290
       Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
       Component: J540 EPB3  VW-15417 0007
       Revision:   011       Serial number: 00000000320570
       Coding: 0000057
       VCID: 2C535BEC8F50295EFD-8078
    Address 56: Radio
    Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
       Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
       Component: Telefon       H08 6900
       Revision: 00008000    Serial number: 00000A07896433
       Coding: 012120
       VCID: 2A5F5DF445A4376E0F-807E
    End-------------------------(Elapsed Time: 02:28)--------------------------
    You did a scan before you started the work, right?
    If so, that scan was auto-saved to your Scans sub-folder....
    Coding: 0002341 This one matched the part #and ecu part #
    Coding: 0003370
    Coding: 0000298
    0002346
    0010533
    0000293
    Feb 2016
    I will look in the scan sub folder out of interest. I managed to get the code (0003365) from a customer who has a friend who works for VW so its sorted now. As a precaution we will take a note of the ABS number before doing any brake related work in case this happens again. Hopefully just a friday afternoon gremlin!
    Ewan
  5. Likes Jack@European_Parts, Sebastian liked this post
    Magdeburg, Germany
    Proper coding for this car is indeed is 0003365.
  7. Likes Uwe liked this post
    HQ
    Quote Originally Posted by Ewan MacNee View Post
    As a precaution we will t̶a̶k̶e̶ ̶a̶ ̶n̶o̶t̶e̶ ̶o̶f̶ ̶t̶h̶e̶ ̶A̶B̶S̶ ̶n̶u̶m̶b̶e̶r̶ run a full Auto-Scan before doing any b̶r̶a̶k̶e̶ ̶r̶e̶l̶a̶t̶e̶d̶ work on VW/Audi vehicles, in case this happens again.
    Fixed that for you.
    And now to recycle a joke:
    Jef
  9. Likes Uwe, NZDubNurd, Jack@European_Parts liked this post
