TPMS (Tire Pressure Meter System Direct) for VW Golf MKVII MQB
XaGiCo
Ponferrada of Spain
C?ID=243154
Hello Family!
TPMS (Tire Pressure Meter System) para VW Golf MKVII
http://youtu.be/5ZKPQuNMBEs
http://youtu.be/qYTv57KOT2Y
Codificación Completa:
Ingredientes Principales:
Unos 300€ de inversión!
- 5Q0 907 273 / 5Q0 907 273A -> Centralita TPMS
- 8E0 971 934 A -> Conector Centralita TPMS
- 5Q0 907 275 / 5Q0 907 275B -> 4 Válvulas TMPS
- Cable
- VAGCOM
- VCP (opcional)
Coming Soon BRICO!!!
Good Night/Day!
Regards
XaGiCo
XaGiCo
Ponferrada of Spain
C?ID=243154
PDF Brico TPMS Tire Pressure Meter System
- > LINK PDF BRIKO TPMS VISUALIZACIÓN DE PRESIONES EN LOS NEUMÁTICOS EN VW GOLF MKVII
Last Version: 03-08-2016
Size 16MB
Language Text: Spanish
Version 1.0
Ingredients and utensils:
Mount Images:
Basic Coding VAGCOM:
Advanced Coding VAG CAN PRO / VCP:
Personal Coding VAG CAN PRO / VCP:
https://vimeo.com/155693133
After six months of use everything works perfect!
He adjusted one last photo, TPMS with My last Retrofit Lane Assist with VZA & Light Assist!
Post Original!
Brico: TPMS Visulización de presiones en VW Golf VII en ClubVWGolf
http://www.clubvwgolf.com/foro/show...TPMS-Visulización-de-presiones-en-VW-Golf-VII
Enjoy it!
Regates :sect:
XaGiCo
ASR
C?ID=270252
Very nice!!!:thumbs:
Danilo78
Italy
C?ID=216246
Good morning
I have VCDS and VCP with license
I don't find zdc file passat_tirepressure_5q0907273A,B.zdc
How do you create personal XaGiCo zdc file?
Danilo78
Italy
C?ID=216246
I installed all parts.
Now I have these problems:
- My cluster out of reject coding when I try to activate bit "wheel speed error counter active";
- I don't find zdc file passat_tirepressure_5q0907273A,B.zdc
- how do I create personal zdc file for my GTD?
Someboby can help me please?
XaGiCo
Ponferrada of Spain
C?ID=243154
Danilo78
Italy
C?ID=216246
Thank you so much XaGiCo
About first vco configuration, by filemanager I don't find passat_tirepressure_5q0907273A,B.zdc
Do you know where I can find it?
ems:
What do yo think is the problem?
Thanks friend
XaGiCo
Ponferrada of Spain
C?ID=243154
ems:
Thanks friend
File Passat talking support VCP only solution!
Byte 3 Bit 7 and old label in PDF.
It has the wrong label, in more current versions they corrected it!
Look labels in last versión 17.1.0
Regards
Danilo78
Italy
C?ID=216246
Thank you very much!
Link for download of your upgraded pdf?
Regardas
Danilo78
Italy
C?ID=216246
I installed and programmed tpms unit.
No dtc now but on cluster display something not good.
Up pressure nomber not here, on discover pro are ok I believe...
poTEl65cj
pogJMQYDj
Somebody can help me please?
XaGiCo
Ponferrada of Spain
C?ID=243154
poTEl65cj
pogJMQYDj
Please One Auto-scan Full ( The most current)
Regards
Danilo78
Italy
C?ID=216246
This is my autoscan in this moment:
Tuesday,07,February,2017,21:41:02:05573
VCDS Version: 17.1.2.0
Data version: 20170131 DS267.1
VIN: WVWZZZAUZFW******   License Plate:
Mileage: 52061km-32349mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 3C 42 44 47 52 55
          5F 65 A5 A9 C0
VIN: WVWZZZAUZFW******   Mileage: 52061km-32349miles
Address 01: Engine (J623-CUNA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EQ    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 8360
   Revision: 81H22---
   Coding: 091D0032036405083000
   ASAM Dataset: EV_ECM20TDI01104L906021EQ 002011
   ROD: EV_ECM20TDI01104L906021ER.rod
   VCID: 78F42609C3C68E81DB-802C
   Part No SW: 0D9 300 041 Q    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4504
   Revision: 05853104    Serial number: TFK01504011518
   ROD: EV_TCMDQ250021.rod
   VCID: 2648387159F2C871B9-8072
   Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
   Component: ESC           H42 0711
   Revision: 00000000    Serial number: 60935000002968
   Coding: 01FA6BA13423096F077A0608C1C8A980D62C90E0608395F51862508A4289
   Shop #: WSC 12345 123 12345
   VCID: 499293CDE8ACC70974-801C
   Revision: 00021000    Serial number: 0365830359
   Coding: 030C0C
   VCID: 3A70FC01BD4A5C91ED-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020114202400011105000200101000
   VCID: 6AD00C418D6A2C115D-803E
   Air quality sensor:
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011510602060
   Coding: 00111E66C24122FB0BA44080B11C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 00044EE99B16C641E3-8054
   Component: WWS    150403  043 0551
   Serial number:         150410040138
   Component: RLHS  037 0059
   Serial number: S3Y15M04D20H00M25S18
   Coding: 1EA8DD
   Serial number: 000000000ZY150750Y1C
   Serial number: 00000000000062141643
   Sun Roof:
   Component: J245 PS73.403  H03 0004
   Serial number: 0000FST0008DFNN00000
   Coding: 181901
   Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0047
   Revision: --------    Serial number: 39431510500062
   Coding: 0031165051
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 428084E1D59A1451B5-8016
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 24031503273603
   Coding: 001C1700FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001015
   VCID: 3874E60983464E811B-806C
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H16 0115
   Serial number: 24031541350375
   ROD: EV_DRCONTITEMIC.rod
   VCID: 76E82831C9D2F8F1C9-8022
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR0DSP8I
   VCID: 7F06CD15E6E8B9B99A-802A
   Belt Pretensioner left:
   Serial number: 34169667B19041510022
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169668B17041570842
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 204 15
   Serial number: 35767000000007B8B31Q
   Subsystem 4 - Part No SW: -----------    HW: 480 001 304 15
   Serial number: 35867000000AAB70141U
   Subsystem 5 - Part No SW: -----------    HW: 480 400 904 15
   Serial number: 3516502AD1A87850B26H
   Subsystem 6 - Part No SW: -----------    HW: 480 400 904 15
   Serial number: 3526502AB1A878517117
   Subsystem 7 - Part No SW: -----------    HW: 480 400 904 15
   Serial number: 3556502C9194131463A3
   Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 15041504400949
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 7BFE3905F2F0A599B6-802E
   Part No SW: 5G1 920 757     HW: 5G1 920 757
   Component: KOMBI         301 4310
   Coding: 07AD09987E9C000804887E0F5400000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   VCID: 6BDE09458290351926-803E
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0003390353
   Coding: 030100040F087300FF00027E9D0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72E01421A5BAE4D1E5-8026
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150000730720045153
   Coding: 2DFFFF
   Serial number: 2520616303
   Revision: 00000000    Serial number: 15000091730001
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 346CD2399F2EAAE137-8060
Address 3C: Lane Change (J1086)       Labels: None
   Part No SW: 5Q0 907 686 A    HW: 5Q0 907 686 A
   Component: HRE_Master    H11 0066
   Serial number: 0364164866
   Coding: 02011103
   ASAM Dataset: EV_HREntryHella 001024
   ROD: EV_HREntryHella.rod
   VCID: 3B7EF905B2706599F6-806E
   Serial number: 230315BCM00796
   Coding: 003F1220D000048000001000
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
   Serial number: 00000000000005805248
   Coding: 110000
   Coding: 9303
   ROD: EV_SteerAssisMQB_VW31.rod
   VCID: 3776E5358E5841F912-8062
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0070
   Serial number: VWZ8Z1FC402M79+
   Coding: 120000008AAA8A0000
   ASAM Dataset: EV_AMPMst11CALPI 001007
   ROD: EV_AMPMst11CALPI.rod
   VCID: 63CE61656A407D599E-8036
   Serial number: 020415BD205411
   Coding: 003F1020DE00048000801000
   VCID: 41828BEDD09C0F49AC-8014
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
   Serial number: 00000000000005921294
   Coding: 090000
   Coding: 029203104F010200
   VCID: 40848EE9DB960641A3-8014
   Subsystem 1 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0002
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0002
   Coding: 900000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 021 C    HW: 5G0 035 021 B
   Component: MU-H-TND-EU   H44 0376
   Serial number: A330D0F7520223
   Coding: 027300010000000011111202000800101F0202F4010001009F
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 1A301C811D8A7C910D-804E
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU301E7E
   Subsystem 2 - Part No SW: V03 959 800 KF    HW: -----------
   Component: ECE 2017  --- 0157
   Component: Gracenote  --- 1010
   Serial number: 30000000019474
   ROD: EV_RDKBERU30_006.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 10000341309
   Coding: 0101020001020303020400010100000100
   ROD: EV_MFKBoschAU370.rod
   Part No SW: 5G0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0014
   Serial number: 150311200428
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 5G0 907 160     HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0006
   Serial number: 150324201384
   ROD: EV_ActuaForExterNoiseUDS_VW12.rod
End-------------------------(Elapsed Time: 06:04)--------------------------
Danilo78
Italy
C?ID=216246
Solved....
System was ok....
On cluster display real pressure ok after drive little meters with car
pndPyHoyj
darkchina811
ITALY
C?ID=333184
I have today successfully completed this retrofit.
somehow VCP did not let me upload the XML file to the tire module, it kept saying "communication error". I used ODIS-E and the upload was done.
Rollux
New Zealand
C?ID=380572
Interested in this retrofit but have a couple of questions;
1. Do you only need the one receiver unit? Some things I have seen say you need one receiver for each wheel arch.
2. If only 1 receiver, how does the car know which wheel is which?
Regards
Dan
Ewan MacNee
C?ID=88042
one receiver and 4 transmitters, one in each wheel. I guess it uses the distance to work out which sensor is which.
darkchina811
ITALY
C?ID=333184
it cannot be based on distance, because the car doesn't know where the receiver is. mine is close to the exhaust but what if I installed in the engine bay?
I honestly have no idea how it knows which wheel is which :D
Ronaldo
Brazil
C?ID=357813
The valves have sensors that detect what direction the wheel is rotating so the receiver can determine which side of the car the signals are coming from. The strength of the signal determines If It comes from front or rear sensors.
Mari
C?ID=150535
Left & right maybe... front or back I don't believe because the receiver doesn't know where it is placed in the car (front or back)...
