got a 2006 jetta 1,9 tdi ,customer want to increase idle rpm from actual 820-840 rpm to 900-920,tryed adaptation,it says security login needed,tryed 12233,it says "security code accepted",channel 06 says "error channel not available",i was looking thru all 255 channels,nothing available for idle rpm adjustement,i remember i did this before on 1,9 tdi with edc16(can't remember exactly what year,was a european touran),there is any way to adjust the idle in this car using VCDS ? auto-scan attached,thanks
Sunday,14,February,2016,10:56:22:35697
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: 3VWDT71K26M0xxxxx License Plate:
Mileage: 277290km-172300mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 47 52 56 62
65 72 7D
VIN: 3VWDT71K26M0xxxxx Mileage: 277290km-172300miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H02--- Serial number: VWZ7Z0F4484819
Coding: 0050078
VCID: 64CD5B7FA7D0CE1EF5-8030
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit - Intermittent
Fault Status: 00110000
Mileage: 263147 km
Time: 19:04:39
RPM: 1050 /min
Voltage: 12.01 V
Bin. Bits: 00001000
Temperature: 10.8°C
Bin. Bits: 10110000
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000607070375
VCID: 51A382ABC8624BB6AE-8004
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0021122
VCID: 73EF2823123E59A67C-8026
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
VCID: 70E5272F632862BE81-8024
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000453255
Coding: 14018E234004150007140000001400000028770B5C0000
VCID: 3777DC3346C6F58680-8062
Component: Wischer 220807 021 0501
Coding: 00038805
Shop #: WSC 00066
02092 - Enabling Heated Seat
Fault Status: 00101001
Reset counter: 106
Mileage: 255890 km
Voltage: 14.05 V
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F1040388
VCID: 2A51F5478574586E0F-807E
Reset counter: 39
Mileage: 276073 km
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D05LLRL
Coding: 0013889
VCID: 6CDD335F4F00865EBD-8038
Subsystem 2 - Serial number: 6332MSME110F1241$
Subsystem 3 - Serial number: 6342MSME117A104D9
Subsystem 4 - Serial number: 6351HSME0A5A1051%
Subsystem 5 - Serial number: 6361HSME0A630D38B
Subsystem 6 - Serial number: 63727SME0A5D0A187
Subsystem 7 - Serial number: 63827SME0A5F4E7CS
Part No SW: 1K0 953 549 AS HW: 1K0 953 549 AS
Component: J0527 035 0070
Coding: 0012021
VCID: 030F78E3429E69266C-8056
Component: E0221 002 0010
Part No SW: 1K0 920 973 D HW: 1K0 920 973 D
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4484819
Coding: 0023203
Shop #: WSC 03087 444 84487
VCID: 2E59F957B99C344ED3-807A
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001067151158
Coding: 3FFF0B620F001002
VCID: 2C5DF35F8F80465EFD-8078
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1293324T23NE03
Coding: 0000003
VCID: 3973DA0B70D2E3F676-806C
Component: IMMO 3HL 1610
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 C HW: 3C0 959 760 C
Component: Sitzverstellung 1001
Revision: 00004000 Serial number: 00000000000000
VCID: 2D5BFE5BB49A4F56EA-8078
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1125
Revision: 11006001 Serial number: 00000502068804
Coding: 0001463
VCID: 3C7DC31F7FE0D6DE6D-8068
Fault Status: 00100101
Reset counter: 81
Reset counter: 106
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Reset counter: 106
00100 - Drivers Interior Locking Button (E308)
Reset counter: 87
Mileage: 275064 km
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
VCID: 346DEB3F57B01E9EA5-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: KSG PQ35 RDK 051 0215
Revision: 00051000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0888F0488DC00
VCID: 74ED2B3F17305E9E65-8020
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000008468
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1125
Revision: 11006001 Serial number: 00000071968804
Coding: 0001462
VCID: 3D7BCE1B64FADFD65A-8068
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio DE2 145 0175
Revision: 00145000 Serial number: VWZ4Z7F2127580
Coding: 0010400
VCID: 244D1B7FE7508E1E35-8070
00003 - Control Module
014 - Defective
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12005001 Serial number: 00000000446234
Coding: 0001168
VCID: 3E79C91769FCC4CE43-806A
Component: RDK 0420
Coding: 0100101
Fault Status: 00110100
Reset counter: 100
Mileage: 276555 km
Time: 00:57:51
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12005001 Serial number: 00000000414207
Coding: 0001168
VCID: 3F87B4136EF6CDC648-806A
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
014 - Defective
End-------------------------(Elapsed Time: 02:21)--------------------------
