Results 1 to 5 of 5
Thread: MY2013 Passat CC Byte 18 Original Coding
    Sep 2015
    I tried to code the rear foglamps to work following form advice on changing Byte 18. This did not work. I cannot get the original coding back to remove the bulb error light on the dash. I'm looking for a member that can put the original coding back on the Passat CC with factory LED tail lights. The closest I've gotten is 0F with still leaves me with two LED Module DRL faults and no rear turn signals. I would greatly appreciate any advice on how to return it to factory.
    Monday,08,February,2016,11:21:46:19968
    VCDS Version: 15.7.3.0 (x64)
    Data version: 20151216
    VIN: WVWBN7AN2DE559507   License Plate: CDA 27271
    Mileage: 25660km-15944mi   Repair Order:
    Chassis Type: AN (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 53 55 56
              62 65 72 77
    VIN: WVWBN7AN2DE559507   Mileage: 25660km-15944miles
    02-Auto Trans -- Status: Cannot be reached 1100
    Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
       Part No SW: 06J 906 027 FE    HW: 06J 907 309 B
       Component: MED17.5.2 TFSI 2 06 3952
       Revision: PAH04---    Serial number: VWZCZ000000000
       Coding: 0404010A1C070160
       Shop #: WSC 05314 000 00000
       VCID: 73E5E41712FB28A67C-8026
    049409 - No Communication with Transmission Control Module
                   U0101 - 000 -
                        Mileage: 25660 km
                        Date: 2016.02.08
                        Time: 11:03:45
                        Load: 0.0 %
                        Temperature: 47.0C
                        Temperature: 28.0C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 11.938 V
    Address 02: Auto Trans
       Part No SW: 3AA 614 109 AP    HW: 3AA 614 109 AP
       Component: J104   C2 450M V46D 0030
       Revision: --H07---    Serial number: 00000006725252
       Coding: 0004495
       Shop #: WSC 05311 000 00000
       VCID: 7BF5CC373AAB60E624-802E
                        Reset counter: 109
                        Mileage: 25660 km
                        Date: 2016.02.08
                        Time: 11:03:46
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 11.50 V
                        Bin. Bits: 00011111
                        Count: 217
                        Hex Value: 0x0000
       Part No SW: 3AA 907 044 AN    HW: 3AA 907 044 AN
       Component: Climatronic   H03 0303
       Revision: 00001K02
       Coding: 0010001048
       Shop #: WSC 00015 115 00000
       VCID: 7CF7CF2BF7A567DE2D-8028
    Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
       Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
       Component: BCM PQ47 H++  421 0465
       Revision: BD421001
       Coding: 0008000000000000008802819400A94C257D008840200D20C184402000C0
       VCID: 41897EDFD8C7CA363E-8014
       Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
       Component: WWS464 080213  010 0604
       Coding: 00B795
       Component: RLFS  024 0042
       Coding: 0228DD
                        Reset counter: 109
                        Mileage: 25660 km
                        Date: 2016.02.08
                        Time: 11:03:47
                            Term 15 On
                        Voltage: 11.50 V
    01516 - Terminal 30; Left
                        Fault Status: 00101011
                        Reset counter: 149
                        Mileage: 25660 km
                        Date: 2016.02.08
                        Time: 10:59:59
                            Term 15 Off
                        Voltage: 12.15 V
                        Fault Status: 00101010
                        Reset counter: 149
                        Mileage: 25660 km
                        Date: 2016.02.08
                        Time: 10:28:19
                            Term 15 On
                        Voltage: 11.60 V
    01800 - Light Switch (E1)
                        Reset counter: 149
                        Mileage: 25660 km
                        Date: 2016.02.08
                        Time: 10:29:20
                            Term 15 Off
                        Voltage: 12.10 V
    02391 - Terminal 30 Reference
                        Reset counter: 149
                        Mileage: 25660 km
                        Date: 2016.02.08
                        Time: 10:59:59
                            Term 15 Off
                        Voltage: 12.15 V
       Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
       Component: J234__713 VW10 HI   2118
       Revision: 25018000    Serial number: 003LDP30JE2E
       Coding: 0012595
       VCID: 4E9355E3D999254EB3-801A
       Subsystem 1 - Part No: 3C8 959 339 A
       Component: BF-Gewichtsens. 003 0001
       Subsystem 2 - Serial number: 0000000000CNEA
       Subsystem 3 - Serial number: 0022.01.130000300000660015†63
       Subsystem 4 - Serial number: 660015†6332MTS635470373 †63
       Subsystem 5 - Serial number: 70373 †6342MTS626370353 †63
       Subsystem 6 - Serial number: 70353 †6351HTS6TPFSQBKR †63
       Subsystem 7 - Serial number: SQBKR †6361HTS6KQM7PBKJ †63
       Subsystem 8 - Serial number: 7PBKJ †63727TS6GHDBPBKJ †63
       Subsystem 9 - Serial number: BPBKJ †63827TS6J0J2RBKR
       Subsystem 10 - Serial number: 2RBKR
    Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
       Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
       Revision: FF010041    Serial number: 20130213300755
       Coding: 098A270000
       VCID: 6BD5FC7782CBF066B4-803E
       Component: E221__MFL-TK6  H07 0022
       Coding: E20000
    0516 - Databus
                        Reset counter: 109
                        Mileage: 25660 km
                        Date: 2016.02.08
                        Time: 11:03:47
    Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
       Part No SW: 3C8 920 971 B    HW: 3C8 920 971 B
       Component: KOMBI         H05 0705
       Coding: 240F00
       Shop #: WSC 05314 115 00000
       VCID: 2C573F6B4745375EFD-8078
    12648704 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 109
                        Mileage: 25660 km
                        Date: 2016.02.08
                        Time: 11:03:47
       Part No SW: 7N0 907 530 AJ    HW: 7N0 907 530 AJ
       Component: J533  Gateway H51 1634
       Revision:   H51       Serial number: 150213F2000373
       Coding: 469006
       VCID: 78FFD33BCB9D4BFE49-802C
                        Reset counter: 109
                        Mileage: 25660 km
                        Date: 2016.02.08
                        Time: 11:03:46
       Part No SW: 3C8 919 965     HW: 3C8 919 965
       Revision: 00001000    Serial number: 1614128R3D6203
       VCID: 75E1DA0F1C8F369652-8020
       Part No SW: 3AA 959 433 C    HW: 3AA 959 433 C
       Component:    IMMO         042 0404
       VCID: 3979163F701792F676-806C
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
       Component: SG EXT.PLAYER H19 0550
       Revision: A1001003    Serial number: 7664331387
       Coding: 010100
       VCID: 2A5B397345B1296E0F-807E
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0555
       Revision: 12110009    Serial number: 0006553890
       Coding: 0004B7
       Shop #: WSC 05311 115 00000
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 6DD1F26FBCDFFE56AA-8038
       Slave Driver:
       Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0501
       Serial number: 00000003365030
       Coding: 010490
       Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.302 1202
       Revision: 1BH04737    Serial number: 00130420064301
       Coding: 0000258
       VCID: 3F8D78276E33BCC648-806A
    Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
       Component:    KSG PQ47 ELV 042 0638
       Coding: 1B910F8001862E521204141FF08A0F0E105800
    Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AJ
       Component: EZE_2         H51 1634
       Coding: 00000008
       VCID: 6FEDE867BED30C4698-803A
       Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
       Component: Analoguhr  005 0004
       Part No SW: 3C8 959 702     HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0555
       Revision: 14110009    Serial number: 0006551697
       Coding: 0004B6
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 6ED3F563B1D9054E93-803A
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0501
       Serial number: 00000003332147
       Coding: 010490
       Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
       Component: J540 EPB4  VW-86594 0010
       Revision:   H19       Serial number: 00000000780311
       Coding: 0022156
       VCID: 36631D0341097D8E9B-8062
                        Reset counter: 109
                        Mileage: 25660 km
                        Date: 2016.02.08
                        Time: 11:03:46
                        Voltage: 11.70 V
                        Count: 73
                        Hex Value: 0x1270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
       Part No SW: 6R0 907 357 B    HW: 6R0 907 357 A
       Component: LWR-ECU       005 0030
       Coding: 070A000101000000
       ASAM Dataset: EV_HeadlRegulVWLWRCC 002004
       ROD: EV_HeadlRegulVWLWRCC.rod
       VCID: 3979163FB81792F676-806C
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
       Component: Radio Prem-8  H05 0008
       Revision: -----09S    Serial number: VWZ4Z7N1106296
       Coding: 0100040004000F
       VCID: 64C7974B6715BF1EF5-8030
                000 -  -
                        Reset counter: 217
                        Mileage: 21490 km
                        Date: 2015.10.26
                        Time: 16:45:03
       Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
       Component: RDKBERU30     H09 0010
       Serial number: 10000000197388
       ASAM Dataset: EV_RDKBERU30 003012
       ROD: EV_RDKBERU30_VW36.rod
       VCID: 35611A0F940F769692-8060
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Component: TELEFON       H15 3200
       Revision: 1B001001    Serial number: 00007664175400
       Coding: 0A10040000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA.rod
       VCID: 3A7B0933BD1199EE7F-806E
    End-------------------------(Elapsed Time: 03:14)--------------------------
    16.4905 S, 151.7375 W
    - Using a Factory Tool to perform the SVM (Actual vs. Specified test plan) and an online connection to Volkswagen's servers will insure you that 'byte-18' has returned to the factory setting.
    Official Factory Repair Information
    Hope this helps,
    drpeter
    Sep 2015
    Thsnks :)
    I appreciate your quick reply. I've spoken with VW about getting it in. Thank you for giving me helpful info so quickly
    Quote Originally Posted by DrPeter View Post
    Hope this helps,
    drpeter
    Dec 2015
    Quote Originally Posted by afeyeguy View Post
    Did you ever get the byte coding? Same car, same prob!
    Aug 2015
    Same here, did you ever get the correct coding for byte 18 by any chance.
