Logging Advanced Measuring values on 5F
andyvee
Rossendale, Lancashire, UK
C?ID=159389
Hi
I wanted to log some advanced measuring values on 5F using the HEX-NET, but I have come across an issue.
I can log fine using VCDS on my laptop, here is an extract of what I was logging
Sunday,07,February,2016,17:32:52:04069VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: TMBKJ9NE0F0104172   License Plate:
                Address 5F: Information Electr.  (5E0 035 020 C)
17:32:46
  211   GPS Position-Length 2 17'26.4"W
  212   GPS Position-Width 53 42'4.6"N
  455   Status of tuner for digital radio (DAB)-Service_Label BBC Radio 2
  471   Status of tuner for digital radio (DAB)-Mute not activated
  472   Status of tuner for digital radio (DAB)-Audio_Quality 10
  473   Status of tuner for digital radio (DAB)-signal_quality 60
  579   DAB_FM_linking-fm_quality 96 %
  580   DAB_FM_linking-DAB_quality 100 %
  581   DAB_FM_linking-dab_mute_status No
So I tried to replicate this using the iPad and the HEX-NET in AP mode
The only problem is, the descriptions don't match, and neither do the ID numbers?
How do I work out which are the same channels to log without trial and error on a large number of channels until I hit upon the right ones?
Shaun
Hi andyvee,
Can you post an autoscan from both VCDS and VCDS-Mobile? This will let us look into why you may be seeing differences there. Also, a screenshot of the values you are trying to log that are different wouldn't hurt.
--Shaun
andyvee
C?ID=159389
Hi Shaun
I have some of it, I'll get it posted. What I did find today though is that if I tether the iPad and HEX-NET to my phone and use the Cloud Functions, then I can get the same descriptions by going in to Cloud Functions - Basic Settings - Show Measuring Data
But, I can't start to log as every time it says my HEX-NET has lost it's connection to the server ........
Going round in circles here .......
andyvee
C?ID=159389
Ok, here goes
VCDS Mobile Autoscan
#hndoc:?docid=0000168D&xt=hnh:7283DC1B594675CCE147646A23D53910D7411C2FBE35F92792BE62728B15559DVCDS Mobile 0.4301.0.4
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 42 44 52 55 5F 6D
	 A5
Address 01: Engine  (CKFC2 J623)	Labels: 04L-907-309-V1.clb
	Part No SW: 04L 906 021 DT	HW: 04L 907 309 D
	Component: R4 2,0L EDC   H22 7545
	Revision: 83H22---
	Coding: 111D0032046501091000
	Shop #: WSC 73430 031 00000
	ASAM Dataset: EV_ECM20TDI01104L906021DT 002007
	ROD: EV_ECM20TDI01104L906021DT_SK37.rod
	VCID: 7AB761EB603BD16227C740ABF8-802F
No fault codes found.
Address 02: Auto Trans  (J743)	Labels: 0D-02.lbl
	Part No SW: 0D9 300 041 P	HW: 02E 927 770 AQ
	Component: DQ250-6F MQB  H53 4507
	Revision: 03253104
	ROD: EV_TCMDQ250021_AU37.rod
	VCID: 250D6297B9058E9A3A759BAF29-8070
Address 03: ABS Brakes  (J104)	Labels: 5Q0-907-379.clb
	Part No SW: 5Q0 907 379 M	HW: 5Q0 907 379 H
	Component: ESC           H31 0571
	Revision: 00000000
	Coding: 1C078A91242009700078060741C5243851249000608224F2F661F072C009
	Shop #: WSC 73430 031 00063
	ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
	VCID: 46CFC51B6443658213BF045B5C-8013
Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
	Part No SW: 5Q0 959 435 A	HW: 5Q0 959 435
	Revision: 00021000
	Coding: 030C0C
	Shop #: WSC 73430 790 00000
	ROD: EV_KessyHellaMQBAB_AU37.rod
	VCID: 3A37A1EB20BB1162674780AB38-806F
Address 08: Auto HVAC  (J255)	Labels: 5G0-907-044.clb
	Part No SW: 5E0 907 044 N	HW: 5E0 907 044 N
	Component: Climatronic   H03 0907
	Revision: 00001K06
	Coding: 02110104000100011005000100101000
	ROD: EV_ACClimaBHBVW37X_SK37.rod
	VCID: 302383C3F6C7DB32D9E31253BE-8065
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
Address 09: Cent. Elect.  (J519)	Labels: 5Q0-937-08X-HV1.clb
	Part No SW: 5Q0 937 086 AA	HW: 5Q0 937 086 AA
	Component: BCM PQ37BOSCH 028 0106
	Revision: --------
	Coding: 0F511B76424722FB0FA44086B11C17280800000000000000000000000000
	Shop #: WSC 73430 790 12345
	ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
	ROD: EV_BCMBOSCH_AU37.rod
	VCID: 79B57EE7653DDA7A2EBD37BFE5-802C
	Subsystem 1 - 	Part No SW: 5E2-955-119
	Component: ]Ý
	Subsystem 2 -
	Subsystem 3 -
	Subsystem 4 -
	Subsystem 5 - 	Component: ™
	Subsystem 6 - 	Component: ™
	Subsystem 7 -
Address 10: Park/Steer Assist  (J791)	Labels: 5Q0-919-298.clb
	Part No SW: 5Q0 919 298 F	HW: 5Q0 919 298
	Component: PARKHILFE PLA H12 0047
	Revision: --------
	Coding: 0131161051
	Shop #: WSC 73430 790 00063
	ASAM Dataset: EV_EPHVA2CAU3700000 003019
	ROD: EV_EPHVA2CAU3700000_SK37.rod
	VCID: 42C7D90B486B59A23F97D80B90-8017
Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
	Part No SW: 5Q0 907 572 D	HW: 5Q0 907 572 D
	Component: ACC Bosch MQB H05 0304
	Coding: 00081600FE0739
	ROD: N/A
	VCID: 3833BBE31EB7037291336AB316-806D
	No ASAM data for: "EV_ACCMRRBoschVW372"
Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
	Part No SW: 3Q0 959 655 AA	HW: 3Q0 959 655 AA
	Component: Airbag VW20   012 0200
	Revision: --------
	Coding: 98FCC000000000005C5400CC008800000065
	ROD: EV_AirbaVW20TS6VW48X_SK37.rod
	VCID: 7DBD6AF77115E65A02E563CF91-8028
	Subsystem 1 - 	Part No SW: 5G0-980-945-B
	Component: 315
	Subsystem 2 - 	Component: 315
	Subsystem 3 - 	Component: ---
	Subsystem 4 - 	Component: ---
	Subsystem 5 - 	Component: ---
	Subsystem 6 - 	Component: ---
Address 16: Steering wheel  (J527)	Labels: 5Q-16.lbl
	Part No SW: 5Q0 953 507 EJ	HW: 5Q0 953 549 C
	Revision: --------
	Coding: 6C10
	ROD: EV_SMLSKLOMQB_SK37.rod
	VCID: 8247990B88EB19A2FF17980B50-80D7
Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
	Part No SW: 5E0 920 911	HW: 5E0 920 911
	Component: KOMBI         304 4270
	Coding: 27A50A186D94A60001887A031000000000000000
	Shop #: WSC 00123 123 12345
	VCID: E083B38366A7ABB289C3A293AE-80B5
Address 19: CAN Gateway  (J533)	Labels: None
	Part No SW: 5Q0 907 530 T	HW: 5Q0 907 530 F
	Component: GW MQB High   128 1188
	Revision: --------
	Coding: 030100340F087300EF00025E1C0F00010001050000000000000000000000
	ASAM Dataset: EV_GatewLear 011016
	ROD: EV_GatewLear.rod
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
	Part No SW: 5Q0 905 861 A	HW: 5Q0 905 861 A
	Revision: 00000000
	Coding: 5D00000000000000
	ROD: EV_ELVMarquMQB_AU37.rod
	VCID: 342B8FD302DFE712BD0B3E636A-8061
Address 36: Seat Mem. Drvr  (J810)	Labels: None
	Part No SW: 5Q0 959 760 A	HW: 5Q0 959 760 A
	Component: Sitzmemory    H06 0009
	Coding: 001400000000010001A081808080000000008181000000D4
	ASAM Dataset: EV_SeatMemorDriveSide 001015
	ROD: EV_SeatMemorDriveSide_SK37.rod
	VCID: 3B39A4EF2F81286A7C518DD7CF-806E
Address 42: Door Elect, Driver  (J386)	Labels: 5QX-959-X93-42.clb
	Part No SW: 5Q4 959 593 B	HW: 5Q4 959 593 B
	Component: TSG FS        009 0014
	Coding: 001D0820DE01048000001100
	ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
	VCID: 44CBDF13527F57920DABEE23BA-8011
Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
	Part No SW: 5Q0 909 144 P	HW: 5Q0 909 144 P
	Coding: 9302
	ROD: EV_SteerAssisMQB.rod
	VCID: 41C5D6074D6D42BA268DCF1F9D-8014
Address 52: Door Elect, Pass.  (J387)	Labels: 5QX-959-X92-52.clb
	Part No SW: 5Q4 959 592 B	HW: 5Q4 959 592 B
	Component: TSG BFS       009 0014
	Coding: 001D0020DE01048000001100
	ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
	VCID: 43C9DC0F577150AA34A1E537A7-8016
Address 55: Xenon Range  (J745)	Labels: 7P6-907-357.clb
	Part No SW: 7P6 907 357 D	HW: 7P6 907 357 A
	Revision: --------
	Coding: 03CE02003F010000
	ROD: EV_HeadlRegulVWAFS_SE26.rod
	VCID: 40C3D30346674BB22983C2138E-8015
	Subsystem 1 - 	Part No SW: 1T0-941-329-B
	Component: >
Address 5F: Information Electr.  (J794)	Labels: None
	Part No SW: 5E0 035 020 C	HW: 5E0 035 020 C
	Component: MU-H-ND-EU    H43 0390
	Coding: 03730201000000001111120200A800002F0003F601000100FE
	ASAM Dataset: EV_MUHig6C3HBAS 001041
	ROD: EV_MUHig6C3HBAS_SK37.rod
	VCID: 1771585F73692C0AB8E90107E3-8042
	Subsystem 1 - 	Part No SW: 5E0-919-606
	Component: ABT_High
	Subsystem 2 -
Address 6D: Trunk Elect.  (----)	Labels: 7N0-959-107.clb
	Part No SW: 5E0 959 107 A	HW: 5E0 959 107
	Component: HDSG-Modul    H01 0746
	Revision: 42001001
	Coding: 1233074002
	ASAM Dataset: EV_HDSGSk462 301136
	ROD: EV_HDSGSk462_SK37.rod
	VCID: 2A1791ABD01BA1E217A7D0EBE8-807F
Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 5Q0-980-653.clb
	Part No SW: 5Q0 980 653 F	HW: 5Q0 980 653
	Component: MQB_MFK       H06 0052
	Coding: 0101010001030303000400000100010100
	ROD: EV_MFKBoschAU370_AU37.rod
VCDS Autoscan
Monday,08,February,2016,18:40:42:04069VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Mileage: 39812km-24738mi   Repair Order:
Chassis Type: NE (5Q0)
          A5
VIN: TMBKJ9NE0F0104172   Mileage: 39812km-24738miles
Address 01: Engine (J623-CKFC)       Labels: 04L-907-309-V1.clb
   Revision: 83H22---
   VCID: 7AB839CFFDD0BCEE3F-802E
   Revision: 03253104    Serial number: TFK01409080569
   VCID: 25023AB324EEE31622-8070
          P1734 00 [002] - -
   Revision: 00000000    Serial number: 62724000001129
   VCID: 46C09D3FF9A8080E0B-8012
   Revision: 00021000    Serial number: 0347141964
   Coding: 030C0C
   VCID: 3A38F9CFBD507CEE7F-806E
   Revision: 00001K06
   VCID: 302CDBE76B2CB6BEC1-8064
   Revision: --------    Serial number: 86581310140746
   VCID: 79BA26C3F8D6B7F636-802C
   Slave 1:
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 140911  041 0570
   Serial number:         140919232831
   Coding: 065DDD
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S4Y14M10D13H14M19S10
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY141272BD5
   Serial number: 00000000000060534409
   Subsystem 5 - Part No SW: 5E9 959 591     HW: 7P0 959 591 B
   Component: J245 PS24.011  H01 0008
   Serial number:     WOO3215520Z
   Coding: 991900
   Subsystem 6 - Part No SW: 5E9 959 591 A    HW: 7P0 959 591 C
   Component: J394 PS24.011  H01 0008
   Serial number:     WOO32246742
   Coding: 991900
   Revision: --------    Serial number: 39431426502437
   Coding: 0131161051
   VCID: 42C8812FD580342E27-8016
   Serial number: 26091403210306
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 383CE3C7835C6EFE89-806C
   Revision: --------    Serial number: 003NYPLJ7PWH
   VCID: 7DB232D3ECFE8BD61A-8028
   Seat belt tensioner; left:
   Component: BeltPretRevFL  H35 0341
   Serial number: 34169595B01101441286
   Coding: 333135
   Seat belt tensioner; right:
   Component: BeltPretRevFR  H35 0341
   Serial number: 34169594B01101440818
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 454 002 609 14
   Serial number: 3576U0000006A741411%
   Subsystem 4 - Part No SW: -----------    HW: 454 002 709 14
   Serial number: 3586U0000000B070211V
   Subsystem 5 - Part No SW: -----------    HW: 454 802 709 14
   Serial number: 3516R4C40B204000000-
   Subsystem 6 - Part No SW: -----------    HW: 454 802 909 14
   Serial number: 3526RB940DC04000000A
   Subsystem 7 - Part No SW: -----------    HW: 454 800 109 14
   Serial number: 3556VC8E29804000000L
   Revision: --------    Serial number: 17081404400903
   Coding: 6C10
   VCID: 0248412F9500F42E67-8056
   VCID: 608C6BA77B4C463E11-8034
   Revision: --------    Serial number: 0002531914
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H05 0130
   Serial number: 000000000C1182020914
   Serial number: 5298644603
   Revision: 00000000    Serial number: 14000267752001
   VCID: 3424D7F79F348A9EA5-8060
   Serial number: Y0006NHK10076
   VCID: 3B36FCCBB26A45E664-806E
   Serial number: 0000121334006
   VCID: 44C48737CF943A1E15-8010
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000004020570
   Coding: 1D0200
   Coding: 9302
   VCID: 41CA8E23D0862F363E-8014
   Serial number: 0000121631170
   VCID: 43C6842BCA9A3D262C-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000003981447
   Coding: 050200
   VCID: 40CC8B27DB8C263E31-8014
   Coding: 3E0000
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels: 5E0-035-MIB-HGH1.clb
   Serial number: A313I0EB012483
   VCID: 177E007BEE824186A0-8042
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5E0 919 606     HW: 5E0 919 606
   Component: ABT_High  H60 0030
   Serial number: SKZ8Z9PT6007AK
   Engine Control Module 2:
   Subsystem 2 - Part No SW: V03 959 800 MF    HW: -----------
   Component: ECE 2016  --- 0134
   Revision: 42001001    Serial number: 277400848
   Coding: 1233074002
   VCID: 2A18C98F4DF0CC6E0F-807E
   Serial number: 10000141271
End-------------------------(Elapsed Time: 02:35)--------------------------
andyvee
C?ID=159389
Screenshots from VCDS
andyvee
C?ID=159389
Screenshots from VCDS Mobile Advanced Measuring Values
andyvee
C?ID=159389
So you can see the VCDS cloud ones match up, but I can't run any logging!
The VCDS-Mobile ones are unidentifiable, and the values they return are not formatted in any way either?
Just noticed the VCDS Mobile Autoscan is not interrogating sub modules correctly and also has a ROD data missing.
andyvee
C?ID=159389
Any further news guys?
I want to be able to log Group 473 with the HEX-NET in AP mode.
andyvee
C?ID=159389
I still want to log Group 473 (Desktop app) via the web app?
Andy, there are no "Groups" in UDS modules. The location numbers for measuring values had been arbitrarily assigned. This is changing in the future; the locations will have what I will call "VAG Speak" names that will be the same from one ROD data file build to the next and (eventually) between VCDS and VCDS-Mobile.
Trade Member
C?ID=271231
Am I missing something here Uwe as a new user of VCDS?
VCDS and VCDS - Mobile?
Trade Member
C?ID=271231
It's entirely possible you are missing something. :)
VCDS-Mobile (requires a HEX-NET interface).
UDS Vs non-UDS.
OK I'm not concerned about mobile devices to use VCDS as my laptop has a much larger clearer readable screen to view any data ;) but as long as I am up to date just having purchased the VCDS, I would hope my software etc is the latest spec and ROSS TECH would keep me informed if I require updates etc? I'll also assume that my VCDS will have UDS having just bought it yes?
Yes, and yes.
andyvee
C?ID=159389
OK - understood. Doesn't help me though as I can't find the same measuring value between desktop and mobile :(
I'm pretty confident it's in there somewhere. Narrow it down by name?
andyvee
C?ID=159389
Tried that, nothing matches - and the values output are a little on the strange side as per my previous screenshots, values such as 1600389120%
473 (arbitrary value) on the Desktop is Status of Tuner for Digital Radio (DAB) - signal_quality
There are a number of Status of Tuner for Digital Radio (DAB) on the Web app in AP mode so no VCDS cloud connection(with no further description) - arbitrary numbers as below, I can't find one that gives a similar value that varies between 0-100 - pretty sure I have gone through them all now
6787-6789
6792-6797
6799-6809
6811-6821
I'll have another look tomorrow
Edit: With a VCDS cloud connection 473 is listed and works, the same as the desktop app. I can't maintain a stable VCDS cloud connection using my mobile as a hotspot though, in fact some times it won't even connect.
