Results 1 to 10 of 18
Thread: Logging Advanced Measuring values on 5F
    Verified VCDS User andyvee's Avatar
    May 2014
    Rossendale, Lancashire, UK
    Hi
    I wanted to log some advanced measuring values on 5F using the HEX-NET, but I have come across an issue.
    I can log fine using VCDS on my laptop, here is an extract of what I was logging
    Sunday,07,February,2016,17:32:52:04069VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 15.7.3.0 (x64)
    Data version: 20151216
    VIN: TMBKJ9NE0F0104172   License Plate:
                    Address 5F: Information Electr.  (5E0 035 020 C)
    17:32:46
      211   GPS Position-Length 2 17'26.4"W
      212   GPS Position-Width 53 42'4.6"N
      455   Status of tuner for digital radio (DAB)-Service_Label BBC Radio 2
      471   Status of tuner for digital radio (DAB)-Mute not activated
      472   Status of tuner for digital radio (DAB)-Audio_Quality 10
      473   Status of tuner for digital radio (DAB)-signal_quality 60
      579   DAB_FM_linking-fm_quality 96 %
      580   DAB_FM_linking-DAB_quality 100 %
      581   DAB_FM_linking-dab_mute_status No
    So I tried to replicate this using the iPad and the HEX-NET in AP mode
    The only problem is, the descriptions don't match, and neither do the ID numbers?
    How do I work out which are the same channels to log without trial and error on a large number of channels until I hit upon the right ones?
    Hi andyvee,
    Can you post an autoscan from both VCDS and VCDS-Mobile? This will let us look into why you may be seeing differences there. Also, a screenshot of the values you are trying to log that are different wouldn't hurt.
    --Shaun
  3. Likes Uwe liked this post
    May 2014
    Hi Shaun
    I have some of it, I'll get it posted. What I did find today though is that if I tether the iPad and HEX-NET to my phone and use the Cloud Functions, then I can get the same descriptions by going in to Cloud Functions - Basic Settings - Show Measuring Data
    But, I can't start to log as every time it says my HEX-NET has lost it's connection to the server ........
    Going round in circles here .......
    May 2014
    Ok, here goes
    VCDS Mobile Autoscan
    #hndoc:?docid=0000168D&xt=hnh:7283DC1B594675CCE147646A23D53910D7411C2FBE35F92792BE62728B15559DVCDS Mobile 0.4301.0.4
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 42 44 52 55 5F 6D
    	 A5
    Address 01: Engine  (CKFC2 J623)	Labels: 04L-907-309-V1.clb
    	Part No SW: 04L 906 021 DT	HW: 04L 907 309 D
    	Component: R4 2,0L EDC   H22 7545
    	Revision: 83H22---
    	Coding: 111D0032046501091000
    	Shop #: WSC 73430 031 00000
    	ASAM Dataset: EV_ECM20TDI01104L906021DT 002007
    	ROD: EV_ECM20TDI01104L906021DT_SK37.rod
    	VCID: 7AB761EB603BD16227C740ABF8-802F
    No fault codes found.
    Address 02: Auto Trans  (J743)	Labels: 0D-02.lbl
    	Part No SW: 0D9 300 041 P	HW: 02E 927 770 AQ
    	Component: DQ250-6F MQB  H53 4507
    	Revision: 03253104
    	ROD: EV_TCMDQ250021_AU37.rod
    	VCID: 250D6297B9058E9A3A759BAF29-8070
    Address 03: ABS Brakes  (J104)	Labels: 5Q0-907-379.clb
    	Part No SW: 5Q0 907 379 M	HW: 5Q0 907 379 H
    	Component: ESC           H31 0571
    	Revision: 00000000
    	Coding: 1C078A91242009700078060741C5243851249000608224F2F661F072C009
    	Shop #: WSC 73430 031 00063
    	ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
    	VCID: 46CFC51B6443658213BF045B5C-8013
    Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
    	Part No SW: 5Q0 959 435 A	HW: 5Q0 959 435
    	Revision: 00021000
    	Coding: 030C0C
    	Shop #: WSC 73430 790 00000
    	VCID: 3A37A1EB20BB1162674780AB38-806F
    Address 08: Auto HVAC  (J255)	Labels: 5G0-907-044.clb
    	Part No SW: 5E0 907 044 N	HW: 5E0 907 044 N
    	Component: Climatronic   H03 0907
    	Revision: 00001K06
    	Coding: 02110104000100011005000100101000
    	ASAM Dataset: EV_ACClimaBHBVW37X 003017
    	ROD: EV_ACClimaBHBVW37X_SK37.rod
    	VCID: 302383C3F6C7DB32D9E31253BE-8065
    	Subsystem 1 -
    	Subsystem 2 -
    	Subsystem 3 -
    Address 09: Cent. Elect.  (J519)	Labels: 5Q0-937-08X-HV1.clb
    	Part No SW: 5Q0 937 086 AA	HW: 5Q0 937 086 AA
    	Component: BCM PQ37BOSCH 028 0106
    	Revision: --------
    	Coding: 0F511B76424722FB0FA44086B11C17280800000000000000000000000000
    	Shop #: WSC 73430 790 12345
    	ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
    	ROD: EV_BCMBOSCH_AU37.rod
    	VCID: 79B57EE7653DDA7A2EBD37BFE5-802C
    	Subsystem 1 - 	Part No SW: 5E2-955-119
    	Component: ]Ý
    	Subsystem 2 -
    	Subsystem 3 -
    	Subsystem 4 -
    	Subsystem 5 - 	Component: ™
    	Subsystem 6 - 	Component: ™
    	Subsystem 7 -
    Address 10: Park/Steer Assist  (J791)	Labels: 5Q0-919-298.clb
    	Part No SW: 5Q0 919 298 F	HW: 5Q0 919 298
    	Component: PARKHILFE PLA H12 0047
    	Revision: --------
    	Coding: 0131161051
    	Shop #: WSC 73430 790 00063
    	ASAM Dataset: EV_EPHVA2CAU3700000 003019
    	ROD: EV_EPHVA2CAU3700000_SK37.rod
    	VCID: 42C7D90B486B59A23F97D80B90-8017
    Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
    	Part No SW: 5Q0 907 572 D	HW: 5Q0 907 572 D
    	Component: ACC Bosch MQB H05 0304
    	Coding: 00081600FE0739
    	ASAM Dataset: EV_ACCMRRBoschVW372 001015
    	ROD: N/A
    	VCID: 3833BBE31EB7037291336AB316-806D
    	No ASAM data for: "EV_ACCMRRBoschVW372"
    Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
    	Part No SW: 3Q0 959 655 AA	HW: 3Q0 959 655 AA
    	Component: Airbag VW20   012 0200
    	Revision: --------
    	Coding: 98FCC000000000005C5400CC008800000065
    	ROD: EV_AirbaVW20TS6VW48X_SK37.rod
    	VCID: 7DBD6AF77115E65A02E563CF91-8028
    	Subsystem 1 - 	Part No SW: 5G0-980-945-B
    	Component: 315
    	Subsystem 2 - 	Component: 315
    	Subsystem 3 - 	Component: ---
    	Subsystem 4 - 	Component: ---
    	Subsystem 5 - 	Component: ---
    	Subsystem 6 - 	Component: ---
    Address 16: Steering wheel  (J527)	Labels: 5Q-16.lbl
    	Part No SW: 5Q0 953 507 EJ	HW: 5Q0 953 549 C
    	Revision: --------
    	Coding: 6C10
    	ROD: EV_SMLSKLOMQB_SK37.rod
    	VCID: 8247990B88EB19A2FF17980B50-80D7
    Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
    	Part No SW: 5E0 920 911	HW: 5E0 920 911
    	Component: KOMBI         304 4270
    	Coding: 27A50A186D94A60001887A031000000000000000
    	Shop #: WSC 00123 123 12345
    	VCID: E083B38366A7ABB289C3A293AE-80B5
    Address 19: CAN Gateway  (J533)	Labels: None
    	Part No SW: 5Q0 907 530 T	HW: 5Q0 907 530 F
    	Component: GW MQB High   128 1188
    	Revision: --------
    	Coding: 030100340F087300EF00025E1C0F00010001050000000000000000000000
    	ASAM Dataset: EV_GatewLear 011016
    	ROD: EV_GatewLear.rod
    	Subsystem 1 -
    	Subsystem 2 -
    	Subsystem 3 -
    Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
    	Part No SW: 5Q0 905 861 A	HW: 5Q0 905 861 A
    	Revision: 00000000
    	Coding: 5D00000000000000
    	ROD: EV_ELVMarquMQB_AU37.rod
    	VCID: 342B8FD302DFE712BD0B3E636A-8061
    Address 36: Seat Mem. Drvr  (J810)	Labels: None
    	Part No SW: 5Q0 959 760 A	HW: 5Q0 959 760 A
    	Component: Sitzmemory    H06 0009
    	Coding: 001400000000010001A081808080000000008181000000D4
    	ASAM Dataset: EV_SeatMemorDriveSide 001015
    	ROD: EV_SeatMemorDriveSide_SK37.rod
    	VCID: 3B39A4EF2F81286A7C518DD7CF-806E
    Address 42: Door Elect, Driver  (J386)	Labels: 5QX-959-X93-42.clb
    	Part No SW: 5Q4 959 593 B	HW: 5Q4 959 593 B
    	Component: TSG FS        009 0014
    	Coding: 001D0820DE01048000001100
    	ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
    	VCID: 44CBDF13527F57920DABEE23BA-8011
    Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
    	Part No SW: 5Q0 909 144 P	HW: 5Q0 909 144 P
    	Component: EPS_MQB_ZFLS  122 1043
    	Coding: 9302
    	ROD: EV_SteerAssisMQB.rod
    	VCID: 41C5D6074D6D42BA268DCF1F9D-8014
    Address 52: Door Elect, Pass.  (J387)	Labels: 5QX-959-X92-52.clb
    	Part No SW: 5Q4 959 592 B	HW: 5Q4 959 592 B
    	Component: TSG BFS       009 0014
    	Coding: 001D0020DE01048000001100
    	ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
    	VCID: 43C9DC0F577150AA34A1E537A7-8016
    Address 55: Xenon Range  (J745)	Labels: 7P6-907-357.clb
    	Part No SW: 7P6 907 357 D	HW: 7P6 907 357 A
    	Revision: --------
    	Coding: 03CE02003F010000
    	ROD: EV_HeadlRegulVWAFS_SE26.rod
    	VCID: 40C3D30346674BB22983C2138E-8015
    	Subsystem 1 - 	Part No SW: 1T0-941-329-B
    	Component: >
    Address 5F: Information Electr.  (J794)	Labels: None
    	Part No SW: 5E0 035 020 C	HW: 5E0 035 020 C
    	Component: MU-H-ND-EU    H43 0390
    	Coding: 03730201000000001111120200A800002F0003F601000100FE
    	ASAM Dataset: EV_MUHig6C3HBAS 001041
    	ROD: EV_MUHig6C3HBAS_SK37.rod
    	VCID: 1771585F73692C0AB8E90107E3-8042
    	Subsystem 1 - 	Part No SW: 5E0-919-606
    	Component: ABT_High
    	Subsystem 2 -
    Address 6D: Trunk Elect.  (----)	Labels: 7N0-959-107.clb
    	Part No SW: 5E0 959 107 A	HW: 5E0 959 107
    	Component: HDSG-Modul    H01 0746
    	Revision: 42001001
    	Coding: 1233074002
    	ASAM Dataset: EV_HDSGSk462 301136
    	ROD: EV_HDSGSk462_SK37.rod
    	VCID: 2A1791ABD01BA1E217A7D0EBE8-807F
    Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 5Q0-980-653.clb
    	Part No SW: 5Q0 980 653 F	HW: 5Q0 980 653
    	Component: MQB_MFK       H06 0052
    	Coding: 0101010001030303000400000100010100
    	ROD: EV_MFKBoschAU370_AU37.rod
    VCDS Autoscan
    Monday,08,February,2016,18:40:42:04069VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    Mileage: 39812km-24738mi   Repair Order:
    Chassis Type: NE (5Q0)
              A5
    VIN: TMBKJ9NE0F0104172   Mileage: 39812km-24738miles
    Address 01: Engine (J623-CKFC)       Labels: 04L-907-309-V1.clb
       Revision: 83H22---
       VCID: 7AB839CFFDD0BCEE3F-802E
       Revision: 03253104    Serial number: TFK01409080569
       VCID: 25023AB324EEE31622-8070
              P1734 00 [002] - -
       Revision: 00000000    Serial number: 62724000001129
       VCID: 46C09D3FF9A8080E0B-8012
       Revision: 00021000    Serial number: 0347141964
       Coding: 030C0C
       VCID: 3A38F9CFBD507CEE7F-806E
       Revision: 00001K06
       VCID: 302CDBE76B2CB6BEC1-8064
       Revision: --------    Serial number: 86581310140746
       VCID: 79BA26C3F8D6B7F636-802C
       Slave 1:
       Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 140911  041 0570
       Serial number:         140919232831
       Coding: 065DDD
       Slave 2:
       Component: RLHS  037 0059
       Serial number: S4Y14M10D13H14M19S10
       Coding: 00885D
       Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY141272BD5
       Serial number: 00000000000060534409
       Subsystem 5 - Part No SW: 5E9 959 591     HW: 7P0 959 591 B
       Component: J245 PS24.011  H01 0008
       Serial number:     WOO3215520Z
       Coding: 991900
       Subsystem 6 - Part No SW: 5E9 959 591 A    HW: 7P0 959 591 C
       Component: J394 PS24.011  H01 0008
       Serial number:     WOO32246742
       Coding: 991900
       Revision: --------    Serial number: 39431426502437
       Coding: 0131161051
       VCID: 42C8812FD580342E27-8016
       Serial number: 26091403210306
       ROD: EV_ACCMRRBoschVW372_AU37.rod
       VCID: 383CE3C7835C6EFE89-806C
       Revision: --------    Serial number: 003NYPLJ7PWH
       VCID: 7DB232D3ECFE8BD61A-8028
       Seat belt tensioner; left:
       Component: BeltPretRevFL  H35 0341
       Serial number: 34169595B01101441286
       Coding: 333135
       Seat belt tensioner; right:
       Component: BeltPretRevFR  H35 0341
       Serial number: 34169594B01101440818
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 454 002 609 14
       Serial number: 3576U0000006A741411%
       Subsystem 4 - Part No SW: -----------    HW: 454 002 709 14
       Serial number: 3586U0000000B070211V
       Subsystem 5 - Part No SW: -----------    HW: 454 802 709 14
       Serial number: 3516R4C40B204000000-
       Subsystem 6 - Part No SW: -----------    HW: 454 802 909 14
       Serial number: 3526RB940DC04000000A
       Subsystem 7 - Part No SW: -----------    HW: 454 800 109 14
       Serial number: 3556VC8E29804000000L
       Revision: --------    Serial number: 17081404400903
       Coding: 6C10
       VCID: 0248412F9500F42E67-8056
       VCID: 608C6BA77B4C463E11-8034
       Revision: --------    Serial number: 0002531914
       Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
       Component: E221__MFL-PR6  H05 0130
       Serial number: 000000000C1182020914
       Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
       Component: J367-BDMHella  H03 8043
       Serial number: 5298644603
       Revision: 00000000    Serial number: 14000267752001
       VCID: 3424D7F79F348A9EA5-8060
       Serial number: Y0006NHK10076
       VCID: 3B36FCCBB26A45E664-806E
       Serial number: 0000121334006
       VCID: 44C48737CF943A1E15-8010
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
       Serial number: 00000000000004020570
       Coding: 1D0200
       Coding: 9302
       VCID: 41CA8E23D0862F363E-8014
       Serial number: 0000121631170
       VCID: 43C6842BCA9A3D262C-8016
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
       Serial number: 00000000000003981447
       Coding: 050200
       VCID: 40CC8B27DB8C263E31-8014
       Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H06 0009
       Coding: 3E0000
       Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H06 0009
       Coding: 3E0000
    Address 5F: Information Electr. (J794)       Labels: 5E0-035-MIB-HGH1.clb
       Serial number: A313I0EB012483
       VCID: 177E007BEE824186A0-8042
       Media Player Position 1:
       Subsystem 1 - Part No SW: 5E0 919 606     HW: 5E0 919 606
       Component: ABT_High  H60 0030
       Serial number: SKZ8Z9PT6007AK
       Engine Control Module 2:
       Subsystem 2 - Part No SW: V03 959 800 MF    HW: -----------
       Component: ECE 2016  --- 0134
       Revision: 42001001    Serial number: 277400848
       Coding: 1233074002
       VCID: 2A18C98F4DF0CC6E0F-807E
       Serial number: 10000141271
    End-------------------------(Elapsed Time: 02:35)--------------------------
    May 2014
    Screenshots from VCDS
    May 2014
    Screenshots from VCDS Mobile Advanced Measuring Values
    May 2014
    Screenshots from VCDS Cloud
  9. Likes Eric, Uwe liked this post
  10. #8
    May 2014
    So you can see the VCDS cloud ones match up, but I can't run any logging!
    The VCDS-Mobile ones are unidentifiable, and the values they return are not formatted in any way either?
    Just noticed the VCDS Mobile Autoscan is not interrogating sub modules correctly and also has a ROD data missing.
  11. #9
    May 2014
    Any further news guys?
    I want to be able to log Group 473 with the HEX-NET in AP mode.
  12. #10
    May 2014
    I still want to log Group 473 (Desktop app) via the web app?
