Hi everyone,
Just got my KII USB this morning,didnt waste any time using it
I have a auto scan and faults that Id like help diagnosing.
I crossed over from GM 1.5 yrs ago, so Im new to VAG diagnosis/common issues that codes point out.
Im wondering about the misfires on p0301 cyl 1 & p0303 cyl 3 as they didnt appear until I removed throttle body completely/unplugged and performed hard reset(2 hr unplug batt)
and also p0507 started after clean/remove/hard reset
also is engine coding correct? 07550
p0455 comes and goes,p0411 comes and goes
I have APR stage 2 fully loaded ecu ,test pipe V2.01 ,stock-93-100-valet ( I run 93 99%)
3"turbo back full exhaust
R8 coil packs
bkr7e plugs
Forge tip
new 710N
IE timing manual belt tensioner
Graf water pump
new green top coolant sensor/thermostat with G13 fluid
and a LOT more!!
Ive spent serious $$$ reviving this lovely machine, I refuse to quit now
Thanks for any help
R8 coil packs
bkr7e plugs
Forge tip
new 710N
Graf water pump
and a LOT more!!
Thanks for any help
Wednesday,03,February,2016,11:17:52:41155
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
Address 01: Engine Labels: 06A-906-032-AWP.lbl
Control Module Part Number: 06A 906 032 HF
Component and/or Version: 1.8L R4/5VT G 0005
Software Coding: 07550
Work Shop Code: WSC 78903
Additional Info: 3VWSE69M22M020296 VWZ7Z0A3838287
VCID: 69D7B07813D92176C6-515A
P0300 - 35-10 - - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
16687 - Cylinder 3
P0303 - 35-10 - Misfire Detected - Intermittent
16891 - Idle Control System RPM
P0507 - 35-10 - Higher than Expected. - Intermittent
16795 - Secondary Air Injection System
P0411 - 35-00 - Incorrect Flow Detected
Readiness: 0000 1101
Wednesday,03,February,2016,11:23:44:41155
Address 02: Auto Trans Labels: 09A-927-750.LBL
Control Module Part Number: 09A 927 750 T
Component and/or Version: AG5 Getriebe 09A 0162
Software Coding:
Work Shop Code:
VCID: 3C79392C2CCB64DE6D-515A
01166 - Engine Torque Signal
16-10 - Signal Outside Specifications - Intermittent
01236 - Shift Selector Locking Solenoid (N110)
31-10 - Open or Short to Ground - Intermittent
01045 - Tiptronic Switch (F189)
Wednesday,03,February,2016,15:18:20:41155
Component and/or Version: 1.8L R4/5VT G01 0005
16839 - EVAP System
P0455 - 35-00 - Large Leak Detected
16685 - Cylinder 1
16687 - Cylinder 3
