AutoScan: WVWSR61J84W047451
01-038-997-016-R_WVWSR61J84W047451-20210205-1504.PLB
01-038-997-016-R_WVWSR61J84W047451-20210206-1450.PLB
03-1C0-907-379-L_WVWSR61J84W047451-20210205-1513.PLB
03-1C0-907-379-L_WVWSR61J84W047451-20210206-1501.PLB
15-1C0-909-605-F_WVWSR61J84W047451-20210205-1510.PLB
15-1C0-909-605-F_WVWSR61J84W047451-20210206-1508.PLB
16-1J0-907-487-A_WVWSR61J84W047451-20210206-1511.PLB
17-1J5-920-906-Q_WVWSR61J84W047451-20210206-1513.PLB
19-6N0-909-901_WVWSR61J84W047451-20210206-1516.PLB
46-1C0-959-799-C_WVWSR61J84W047451-20210205-1512.PLB
46-1C0-959-799-C_WVWSR61J84W047451-20210206-1520.PLB
56-3B7-035-180-G_WVWSR61J84W047451-20210206-1523.PLB
blockmap-OBD_WVWSR61J84W047451-20210206-1527.CSV
Saturday,06,February,2021,15:28:03:14741
VCDS Version: 20.12.0.1 (x64) HEX-NET2 CB: 0.4529.4
Data version: 20201125 DS322.1
VIN: WVWSR61J84W047451 License Plate:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
76
VIN: WVWSR61J84W047451 Mileage: 290550km-180539miles
Address 01: Engine Labels: 038-906-016-BEW.LBL
Part No SW: 038 997 016 R HW: 028 101 114 6
Component: R4 1,9L EDC G000SG 0282
Revision: 12345678 Serial number: VWZ7Z0C7769815
Coding: 0150031
Shop #: WSC 66565 257 00032
VCID: AD0CE2FE21022733684-5184
Address 03: ABS Brakes Labels: 1C0-907-37X-ABS.LBL
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001025
Shop #: WSC 01266 785 00200
VCID: B338F486C72671C33E0-5184
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Part No: 1C0 909 605 F
Component: 17 AIRBAG VW61 0108 0003
Coding: 12599
Shop #: WSC 01266
VCID: A70010D606FE0D63928-513C
Address 16: Steering wheel Labels: 1J0-907-487-A.LBL
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 01266
VCID: AF30F8F62E0E55235A8-5184
Address 17: Instruments Labels: 1J0-920-XX5-17.LBL
Part No: 1J5 920 906 Q
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 15232
Shop #: WSC 07437
VCID: BB28DCA6EA76B983E60-513C
Subsystem 1 - Part No: WVWSR61J84W0
WVWSR61J84W0
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01266
VCID: F0B23B8AF3B00ADB032-513C
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Part No: 1C0 959 799 C
Component: 8A Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 01266
VCID: B720C096D65E9DE3028-4B1E
Component: 8A Tõrsteuer.FS KLO 0202
Component: 8A Tõrsteuer.BF KLO 0202
Component: 8A Tõrsteuer.HL KLO 0202
Component: 8A Tõrsteuer.HR KLO 0202
Address 56: Radio Labels: 3B7-035-1XX-56.LBL
Part No: 3B7 035 180 G
Component: Radio PM6 0016
Coding: 04031
Shop #: WSC 01266
VCID: A41A07DA77C8E67BB7A-513C
End------(Elapsed Time: 37:31, VBatt start/end: 14.5V/14.3V, Deb=2)--------
;SW:038-997-016-R HW:028-101-114-6 --- Engine
;Component:R4 1,9L EDC G000SG 0282, Coding:0150031
;Friday,05,February,2021,15:04:55:14741
;VCDS Version: Release 20.12.0 (x64) Data version: 20201125 DS322.1
;VCID: AD0CE2FE21022733684-5184
1,0,Injection Quantity,
1,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM
Specification (Full Load): 2800...3200 RPM
;903 /min,RPM,
1,2,Injection Quantity,,Specification (Idle): 3.0...9.0 mg/Str.
;5.5 mg/str,Inj. Quantity,
1,3,Injection Duration,(specified),Specification (Idle): 3.0...9.0 °CF
;6.1°KW,Idle Stabilization,
1,4,Coolant,Temperature (G62),Range: -40.5...+135.0 °C
Specification (Warm): 80.0...110.0 °C
;12.6°C,Temperature,
2,0,Idle Speed,
2,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM
;903 /min,RPM,
2,2,Accel. Pedal Pos.,Sensor 1 (G79),Range: 0.0...100.0 %
Specification (Idle): 0.0 %
Specification (Full Load): 100.0 %
;0.0 %,Load,
2,3,Operation Status,,xxxxxxx1 = Climate Control ON
xxxx1xxx = Idle Switch closed
xxx1xxxx = Kick-Down (only Automatic Transmission)
x1xxxxxx = Idle Speed raised
; 0 01 0,Bin. Bits,
2,4,Coolant,Temperature (G62),Range: -40.5...+135.0 °C
3,0,Exhaust Gas Recirculation (EGR),
3,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM
;903 /min,RPM,
3,2,Exhaust Gas,Recirculat. (spec.),Specification (Idle): 150.0...280.0 mg/Str.
Specification (Full Load): 800.0...950.0 mg/Str.
;510.0 mg/str,Mass Air / Rev.,
3,3,Exhaust Gas,Recirculat. (actual),Specification (Idle): 130.0...300.0 mg/Str.
Specification (Full Load): 800.0...1100.0 mg/Str.
;480.0 mg/str,Mass Air / Rev.,
3,4,Exhaust Gas,Recirc. Duty Cycle,Specification (Idle): 10.0...90.0 %
Specification (Full Load): 90.0...100.0 %
;100.6 %,Duty Cycle,
4,0,Pump-Jet Valves,
4,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM
;903 /min,RPM,
4,2,Injection Start,(specified),Specification (Idle): 4.0 °v.OT ... 2.0 °n.OT
;9.9 °BTDC,Ign. Timing,
4,3,Injection Duration,(specified),Specification (Idle): 3.0...9.0 °CF
4,4,Torsion Value,,Specification: -3...+3 °CF
;1.5°KW,Idle Stabilization,
5,0,Start Conditions (last Engine Start),
5,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM
;903 /min,RPM,
5,2,Start Injection,Quantity,Specification: 7.0...19.0 mg/Str.
;21.7 mg/str,Inj. Quantity,
5,3,Start,Synchronisation,001 = Self-Synchronisation Camshaft active
002 = Self-Synchronisation Crankshaft active
004 = Engine running
008 = Engine Synchronisation validated
016 = Engine Synchronisation completed successfully
032 = Self-Synchronisation Camshaft Sensor successful
064 = Self-Synchronisation Crankshaft Sensor successful
128 = First valid Cog/Tooth detected
Interim Values are the Sum of the Individual Values
;48.0,(no units),
5,4,Coolant,Temperature (G62),Range: -40.5...+135.0 °C
6,0,Cruise Control System (CCS),
6,1,Vehicle Speed,(actual),
;0.0 km/h,Speed,
6,2,Cruise Control,Pedal Monitoring,xxxxxxx1 = Brake Light Switch operated
xxxxxx1x = Brake Pedal Switch operated
xxxxx1xx = Clutch Pedal Switch operated
xxxx1xxx = CCS enabled
xxx1xxxx = ACC enabled
xx1xxxxx = Main Switch
00xxxxxx = ACC/CCS Mode not active
10xxxxxx = Status override
01xxxxxx = ACC/GRA active
11xxxxxx = ACC blocked
;00101000,Bin. Bits,
6,3,Accel. Pedal Pos.,Sensor 1 (G79),Range: 0.0...100.0 %
;0.0 %,Load,
6,4,Cruise Control,Switch Monitoring,xxxxxxx1 = Stuck ON
xxxxxx1x = Pressed OFF
xxxxx1xx = Decelerate (-)
xxxx1xxx = Accelerate (+)
xxx1xxxx = Set (SET)
xx1xxxxx = Resume (RESET)
1xxxxxxx = Stuck ON (Hardware)
;00000011,Bin. Bits,
7,0,Temperatures,
7,1,Fuel Temperature,(G81),Specification (Cold): ca. Ambient Temperature
;9.9°C,Temperature,
7,2,Fuel Cooling,Status,Range: 0.0...100.0 %
Specification (OFF): 0.0 %
Specification (ON): 100.0 %
;0.0 %,Load,
7,3,Intake Air,Temperature (G72),Specification (Cold): ca. Ambient Temperature
;8.1°C,Temperature,
7,4,Coolant,Temperature (G62),Range: -40.5...+135.0 °C
8,0,Injection Quantity Limitation I (Torque Limitation),
8,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM
;903 /min,RPM,
8,2,Torque Request,(Driver),Specification (Idle): -5.0...0.0 Nm
;-2.0 Nm,Torque,
8,3,Torque Limitation,,Specification (Idle): 100.0...200.0 Nm
;174.0 Nm,Torque,
8,4,Smoke Limitation,,Specification (Idle): 100.0...200.0 Nm
;172.0 Nm,Torque,
9,0,Injection Quantity Limitation II (Torque Limitation),
9,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM
;903 /min,RPM,
9,2,Torque Request,(Cruise Control),
;-1280.0 Nm,Torque,
9,3,Transmission,Limitiation,
;410.0 Nm,Torque,
9,4,Torque Restriction,,
;172.0 Nm,Torque,
10,0,Charge Pressure Control,
10,1,Mass Air Flow,(actual),Specification (Idle): 130.0...300.0 mg/Str.
;485.0 mg/str,Mass Air / Rev.,
10,2,Atmospheric,Pressure,Specification: 900.0...1100.0 mbar
;979.2 mbar,Absolute Pres.,
10,3,Boost Pressure,(actual),Specification (Idle): 900.0...1150.0 mbar
Specification (Full Load): 1850.0...2400.0 mbar
;958.8 mbar,Absolute Pres.,
10,4,Accel. Pedal Pos.,Sensor 1 (G79),Specification (Idle): 0.0 %
;0.0 %,Load,
11,0,Charge Pressure Control,
11,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM
;903 /min,RPM,
11,2,Boost Pressure,(specified),Specification (Idle): 900.0...1150.0 mbar
Specification (Full Load): 1900.0...2200.0 mbar
;1050.6 mbar,Absolute Pres.,
11,3,Boost Pressure,(actual),Specification (Idle): 900.0...1150.0 mbar
11,4,Charge Pressure,Control Duty Cycle,
;80.5 %,Duty Cycle,
12,0,Glow Plugs,
12,1,Glow Status,,00000000 = Waiting for Coolant Temperature
00000001 = Waiting for ECO Start Request
00010000 = Pre-Glow
01010000 = No Pre-Glow
10110000 = Post-Glow
11000000 = No Post-Glow
11110000 = Interim Glow
00110000 = Readiness Glowing
01110000 = Glow Start
10110001 = Waiting for Post-Glow
11010000 = No Post-Glow
11110001 = Waiting for Interim Glow
11111111 = Glowing OFF
;10110000,Bin. Bits,
12,2,Pre-Glow Period,,
;2.42 s,Time,
12,3,Supply Voltage,(Terminal 30),Specification: 13.0...15.0 V
;14.59 V,Voltage,
12,4,Coolant,Temperature (G62),Range: -40.5...+135.0 °C
13,0,Idle Stabilization (Injection Quantity Deviation),
13,1,Injection Quantity,Deviation Cyl. 1,Specification (Idle): -2.8...+2.8 mg/Str.
;-0.16 mg/str,Inj. Quantity,
13,2,Injection Quantity,Deviation Cyl. 2,Specification (Idle): -2.8...+2.8 mg/Str.
;-0.49 mg/str,Inj. Quantity,
13,3,Injection Quantity,Deviation Cyl. 3,Specification (Idle): -2.8...+2.8 mg/Str.
;0.68 mg/str,Inj. Quantity,
13,4,Injection Quantity,Deviation Cyl. 4,Specification (Idle): -2.8...+2.8 mg/Str.
;0.00 mg/str,Inj. Quantity,
15,0,Fuel Consumption,
15,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM
;903 /min,RPM,
15,2,Engine Torque,,Specification (Idle): 25.0...60.0 Nm
;40.0 Nm,Torque,
15,3,Fuel Consumption,,
;0.60 l/h,Fuel Consump.,
15,4,Torque Request,(Driver),Specification (Idle): -5.0...0.0 Nm
;-2.0 Nm,Torque,
16,0,Auxiliary Heating,
16,1,Generator Load,,Specification: 5.0...95.0 %
;39.2 %,Load,
16,2,Auxiliary Heating,Shut-Off Conditions,See Label File
;11000000,Bin. Bits,
16,3,Heating Element,Activation,1x - Relay for Coolant Preheat. (High Output - J360) activated
x1 - Relay for Coolant Preheat. (Low Output - J359) activated
; 00,Bin. Bits,
16,4,Supply Voltage,(Terminal 30),Specification: 13.0...15.0 V
;14.52 V,Voltage,
17,0,Readiness Code (EOBD),
17,1,CARB,Mode 01 DATA A,See Label File
;00000000,Bin. Bits,
17,2,CARB,Mode 01 DATA B,See Label File
;00000111,Bin. Bits,
17,3,CARB,Mode 01 DATA C,See Label File
;11100000,Bin. Bits,
17,4,CARB,Mode 01 DATA D,See Label File
18,0,Piezo Unit Injector Status,
18,1,Injector Status,Cylinder 1,000 = No Faults detected
002 = Control while Starting
004 = Small Injection Quantity or Piezo Injector OFF
008 = Energy Limits/Maximum Current reached
016 = Begin of Injection Period (BIP)/Valve Closing Time implausible
032 = Piezo Capacity implausible
064 = Piezo Energy implausible
128 = Begin of Injection Period (BIP) not plausible > Electrical Fault
;0.0,(no units),
18,2,Injector Status,Cylinder 2,000 = No Faults detected
;0.0,(no units),
18,3,Injector Status,Cylinder 3,000 = No Faults detected
;0.0,(no units),
18,4,Injector Status,Cylinder 4,000 = No Faults detected
;0.0,(no units),
20,0,Injection Quantity Limitation (from ABS),
20,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM
;903 /min,RPM,
20,2,Engine Torque,,
;38.0 Nm,Torque,
20,3,ASR Limitation,,
;1270.0 Nm,Torque,
20,4,MSR Limitation,,
;-1280.0 Nm,Torque,
21,0,CAN-Databus Status (Powertrain),
21,1,Engine Electronics,,
21,2,Transmission,Electronics,
21,3,Brake Electronics,,
21,4,Brake Electronics,(ESP),
;00000100,Bin. Bits,
22,0,Shut-Off Status,
22,1,Shut-Off Status,Cruise Control,
;6.0,(no units),
22,2,Switch Monitoring,Cruise Control,000 = Neutral
001 = OFF (Switched)
002 = OFF (Tipped)
003 = SET (CCS ON)
004 = Tip Down
005 = Deceleration (-)
006 = RESUME/RESET
007 = Tip Up
008 = Acceleration (+)
;0.0,(no units),
22,3,Shut-Off Status,Charge Pressure,001 = Cold Start
002 = System Malfunction
004 = Control Deviation
016 = Diagnostic Interference
;0.0,(no units),
22,4,Shut-Off Status,Climate Control,001 = Launch Condition
002 = Shut-Off: Launch Condition
004 = Acceleration Condition
008 = Shut-Off: Acceleration Condition
016 = Shut-Off: Start Condition
032 = System Malfunction recognized
064 = Shut-Off: System Malfunction recognized
128 = Shut-Off: Idle Speed too Low
;16.0,(no units),
23,0,Injector Switch Time Deviation,
23,1,Switch Time Deviat.,Cylinder 1,Specification: -100.0...+100.0 ms
;-76.0,(no units),
23,2,Switch Time Deviat.,Cylinder 2,Specification: -100.0...+100.0 ms
;-55.0,(no units),
23,3,Switch Time Deviat.,Cylinder 3,Specification: -100.0...+100.0 ms
;-59.0,(no units),
23,4,Switch Time Deviat.,Cylinder 4,Specification: -100.0...+100.0 ms
;-66.0,(no units),
25,0,Start Control,
25,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM
;903 /min,RPM,
25,2,Status,Terminal 50,0 = Relay OFF
0 = Relay ON
; 0,Bin. Bits,
25,3,Engine Condition,,1 = Engine Standby
2 = Engine Start
4 = Engine Normal
;4.0,(no units),
25,4,Start Abort,Conditions,
;0.0,(no units),
26,0,Checksum,
26,1,Checksum,,
;E52F,Checksum,
27,0,Speed Limiter,
27,1,Cruise Control,Status,
;1.0,(no units),
27,2,Adaptive Cruise,Control Status,
27,3,Vehicle Speed,,
;0.0 km/h,Speed,
27,4,Vehicle Speed,Limit,
;255.0 km/h,Speed,
28,0,,
28,1,,,
;0.304 V,Voltage,
28,2,,,
28,3,,,
; 0 01 0,Bin. Bits,
28,4,,,
;0.0 %,Load,
30,0,Lambda Sensor Air Values I,
30,1,,,
;100 ohms,Resistance,
30,2,,,
;0.000 V,Voltage,
30,3,,,
;0.7 %,Lambda,
30,4,,,
;1.0,(no units),
31,0,Lambda Sensor Air Values II,
31,1,,,
;0.0,(no units),
31,2,,,
;1.6 %,Duty Cycle,
31,3,,,
;4.964 V,Voltage,
31,4,,,
;0.000 V,Voltage,
32,0,Lambda Sensor Air Values III,
32,1,,,
;0.0,(no units),
32,2,,,
;8.1°C,Temperature,
32,3,,,
;989.4 mbar,Absolute Pres.,
32,4,,,
;0.000 V,Voltage,
33,0,Lambda Sensor Air Values IV,
33,1,,,
;903 /min,RPM,
33,2,,,
33,3,,,
33,4,,,
;64.00 g/s,Mass Flow,
34,0,Lambda Sensor Status,
34,1,,,
; 0,Bin. Bits,
34,2,,,
;11001001,Bin. Bits,
34,3,,,
;52.0,(no units),
34,4,,,
;0.0,(no units),
35,0,Lambda Sensor Faults I,
35,1,,,
35,2,,,
35,3,,,
35,4,,,
;00100000,Bin. Bits,
36,0,Lambda Sensor Faults II,
36,1,,,
36,2,,,
36,3,,,
36,4,,,
37,0,Lambda Sensor Faults III,
37,1,,,
37,2,,,
37,3,,,
37,4,,,
38,0,Lambda Sensor Faults IV,
38,1,,,
38,2,,,
38,3,,,
38,4,,,
39,0,,
39,1,,,
;903 /min,RPM,
39,2,,,
;5.8 mg/str,Inj. Quantity,
39,3,,,
39,4,,,
;00000010,Bin. Bits,
40,0,,
40,1,,,
;903 /min,RPM,
40,2,,,
40,3,,,
40,4,,,
;1.00,(no units),
41,0,,
41,1,,,
41,2,,,
;0.0 %,Duty Cycle,
41,3,,,
;0.0 %,Duty Cycle,
41,4,,,
;0.0 %,Duty Cycle,
42,0,,
42,1,,,
;-2.5 %,Lambda,
42,2,,,
42,3,,,
;95.9 %,Duty Cycle,
42,4,,,
;0.0 %,Duty Cycle,
43,0,,
43,1,,,
;80.1 %,Duty Cycle,
43,2,,,
;100.6 %,Lambda,
43,3,,,
;-2.5 %,Lambda,
43,4,,,
44,0,,
44,1,,,
;903 /min,RPM,
44,2,,,
;13.5°C,Temperature,
44,3,,,
;00000001,Bin. Bits,
44,4,,,
;100.6 %,Lambda,
50,0,,
50,1,,,
;903 /min,RPM,
50,2,,,
50,3,,,
50,4,,,
51,0,,
51,1,,,
;903 /min,RPM,
51,2,,,
;441 /min,RPM,
51,3,,,
;48.0,(no units),
51,4,,,
;01010000,Bin. Bits,
52,0,Cylinder Speed,
52,1,Cylinder 1,,
;0.0,(no units),
52,2,Cylinder 2,,
;0.0,(no units),
52,3,Cylinder 3,,
;0.0,(no units),
52,4,Cylinder 4,,
;0.0,(no units),
55,0,,
55,1,Control Module,Coding,General Malfunction Status
;0.0,(no units),
55,2,Control Module,Coding,
;0.0,(no units),
55,3,Malfunction Path,EEPROM,
55,4,Malfunction Path,Communication,
56,0,,
56,1,Malfunction Path,Voltage (MIN),
56,2,Malfunction Path,Voltage (MAX),
56,3,Malfunction Path,Shut-Off Status,
56,4,Reset Status,,
;0xFF00,Hex Value,
60,0,Engine Cooling I,
60,1,Engine Speed,(G28),
;903 /min,RPM,
60,2,Engine Torque,,
;36.0 Nm,Torque,
60,3,Coolant,Temperature (G62),Specification: 80.0...110.0 °C
;14.4°C,Temperature,
60,4,,,
;0.0 %,Load,
61,0,Engine Cooling II,
61,1,Coolant (Spec.),Engine Output,
;89.1°C,Temperature,
61,2,Coolant (Act.),Engine Output,
61,3,,,
;0.0 %,Load,
61,4,,,
62,0,Engine Cooling (Temperatures),
62,1,Coolant Temperat.,Engine Output,Specification: min. 75.0 °C
62,2,,,
62,3,Ambient,Temperature,Specification: -30.0...+50.0 °C
;0.0 %,Load,
62,4,Intake Air,Temperature,Specification: 5.0...80.0 °C
63,0,,
63,1,,,
;Data for,,
63,2,,,
;Group 063,,
63,3,,,
;Not,,
63,4,,,
;Available,,
65,0,,
65,1,,,
;0.0 %,Load,
65,2,,,
;16.2°C,Temperature,
65,3,,,
65,4,,,
66,0,,
66,1,,,
66,2,,,
66,3,,,
66,4,,,
74,0,,
74,1,Engine Speed,(G28),Specification (Idle): 860...940 RPM
;903 /min,RPM,
74,2,Temperature bef.,Turbo Charger,
;246.0°C,Temperature,
74,3,Lambda/Oxygen,Sensor Value,Range: 1.000...2.0000
Values above 1.38 often imply
Carbonization of the PPD/PD Unit Injector.
;1.00,(no units),
74,4,Injection Quantity,Offset,
;0.0 mg/str,Inj. Quantity,
80,0,Advanced Control Module Identification I,
80,1,,,
;BPG-810 26.04.04 12345678 1889 0262, ,
81,0,Advanced Control Module Identification II,
81,1,Vehicle Ident.,Number (VIN),
;WVWSR61J84W047451 VWZ7Z0C7769815 1234567,Vehicle Ident.,
82,0,Advanced Control Module Identification III,
82,1,,,
;0003225766565 <> 78 79 <> ,Vehicle Ident.,
86,0,,
86,1,,,
;11001100,Bin. Bits,
86,2,,,
;11111010,Bin. Bits,
86,3,,,
;11011111,Bin. Bits,
86,4,,,
87,0,,
87,1,,,
;11111111,Bin. Bits,
87,2,,,
;11111100,Bin. Bits,
87,3,,,
;01001111,Bin. Bits,
87,4,,,
89,0,,
89,1,,,
89,2,,,
89,3,,,
89,4,,,
90,0,,
90,1,,,
;903 /min,RPM,
90,2,,,
90,3,,,
90,4,,,
91,0,,
91,1,,,
;127.0,(no units),
91,2,,,
;-128.0,(no units),
91,3,,,
91,4,,,
;0.0,(no units),
93,0,,
93,1,,,
93,2,,,
;0.84,(no units),
93,3,,,
;52.8,(no units),
93,4,,,
;44.4,(no units),
125,0,CAN-Databus Communication (Powertrain),
125,1,Transmission,,Range: Transm. 1/Transm. 0
125,2,Brake Electronics,,(J104)
;ABS 1, ,
125,3,Instrument Cluster,(J285),Range: Instruments 1/Instruments 0
Specification: Instruments 1
;Instruments 1, ,
125,4,Airbag,(J234),Wertebereich: Airbag 1/Airbag 0
Specification: Airbag 1
;Airbag 1, ,
131,0,,
131,1,,,
;16.0,(no units),
131,2,,,
131,3,,,
131,4,,,
;18.0°C,Temperature,
133,0,,
133,1,,,
;882 /min,RPM,
133,2,,,
;475.0 mg/str,Mass Air / Rev.,
133,3,,,
133,4,,,
;0.0,(no units),
134,0,,
134,1,,,
;39.2 %,Load,
134,2,,,
;14.52 V,Voltage,
134,3,,,
134,4,,,
140,0,,
140,1,,,
140,2,,,
140,3,,,
140,4,,,
213,0,,
213,1,,,
;903 /min,RPM,
213,2,,,
;0.0 %,Load,
213,3,,,
;0.0 km/h,Speed,
213,4,,,
;0.0,(no units),
225,0,,
225,1,,,
;0.0,(no units),
225,2,,,
;0.0,(no units),
225,3,,,
;0.0,(no units),
225,4,,,
;0.0,(no units),
226,0,,
226,1,,,
;0.0,(no units),
226,2,,,
226,3,,,
;0.0,(no units),
226,4,,,
;0.0,(no units),
227,0,,
227,1,,,
;0.0,(no units),
227,2,,,
;0.0,(no units),
227,3,,,
;0.0,(no units),
227,4,,,
;0.0,(no units),
228,0,,
228,1,,,
;0.0,(no units),
228,2,,,
;0.0,(no units),
228,3,,,
228,4,,,
229,0,,
229,1,,,
229,2,,,
229,3,,,
;0.0,(no units),
229,4,,,
;0.0,(no units),
;Saturday,06,February,2021,14:50:44:14741
;903 /min,RPM,
;6.3 mg/str,Inj. Quantity,
;4.5°C,Temperature,
2,0,Idle Speed,
;882 /min,RPM,
;0.0 %,Load,
; 0 01 0,Bin. Bits,
;4.5°C,Temperature,
;882 /min,RPM,
;570.0 mg/str,Mass Air / Rev.,
;903 /min,RPM,
;11.8 °BTDC,Ign. Timing,
;903 /min,RPM,
;20.3 mg/str,Inj. Quantity,
;48.0,(no units),
;4.5°C,Temperature,
;0.0 km/h,Speed,
;0.0 %,Load,
7,0,Temperatures,
;5.4°C,Temperature,
;0.0 %,Load,
;6.3°C,Temperature,
;4.5°C,Temperature,
;882 /min,RPM,
;-2.0 Nm,Torque,
;174.0 Nm,Torque,
;178.0 Nm,Torque,
;924 /min,RPM,
;-1280.0 Nm,Torque,
;410.0 Nm,Torque,
;174.0 Nm,Torque,
;495.0 mg/str,Mass Air / Rev.,
;0.0 %,Load,
;903 /min,RPM,
;80.5 %,Duty Cycle,
12,0,Glow Plugs,
00010000 = Pre-Glow
;2.42 s,Time,
;14.59 V,Voltage,
;5.4°C,Temperature,
;-0.45 mg/str,Inj. Quantity,
;0.26 mg/str,Inj. Quantity,
;0.21 mg/str,Inj. Quantity,
;882 /min,RPM,
;46.0 Nm,Torque,
;0.80 l/h,Fuel Consump.,
;-2.0 Nm,Torque,
;43.5 %,Load,
; 00,Bin. Bits,
;14.59 V,Voltage,
;0.0,(no units),
;0.0,(no units),
;0.0,(no units),
;0.0,(no units),
;924 /min,RPM,
;40.0 Nm,Torque,
;1270.0 Nm,Torque,
;-1280.0 Nm,Torque,
;6.0,(no units),
002 = OFF (Tipped)
003 = SET (CCS ON)
004 = Tip Down
006 = RESUME/RESET
007 = Tip Up
;0.0,(no units),
;0.0,(no units),
;16.0,(no units),
;-83.0,(no units),
;-77.0,(no units),
;-69.0,(no units),
;-78.0,(no units),
25,0,Start Control,
;903 /min,RPM,
0 = Relay ON
; 0,Bin. Bits,
2 = Engine Start
4 = Engine Normal
;4.0,(no units),
;0.0,(no units),
26,0,Checksum,
26,1,Checksum,,
;E52F,Checksum,
27,0,Speed Limiter,
;1.0,(no units),
;0.0 km/h,Speed,
;255.0 km/h,Speed,
28,0,,
28,1,,,
;0.304 V,Voltage,
28,2,,,
28,3,,,
; 0 01 0,Bin. Bits,
28,4,,,
;0.0 %,Load,
30,1,,,
30,2,,,
;0.000 V,Voltage,
30,3,,,
;0.7 %,Lambda,
30,4,,,
;1.0,(no units),
31,1,,,
;0.0,(no units),
31,2,,,
;1.2 %,Duty Cycle,
31,3,,,
;4.964 V,Voltage,
31,4,,,
;0.000 V,Voltage,
32,1,,,
;0.0,(no units),
32,2,,,
;6.3°C,Temperature,
32,3,,,
32,4,,,
;0.000 V,Voltage,
33,1,,,
;882 /min,RPM,
33,2,,,
33,3,,,
;999.6 mbar,Absolute Pres.,
33,4,,,
;65.42 g/s,Mass Flow,
34,1,,,
; 0,Bin. Bits,
34,2,,,
34,3,,,
;52.0,(no units),
34,4,,,
;0.0,(no units),
35,1,,,
35,2,,,
35,3,,,
35,4,,,
36,1,,,
36,2,,,
36,3,,,
36,4,,,
37,1,,,
37,2,,,
37,3,,,
37,4,,,
38,1,,,
38,2,,,
38,3,,,
38,4,,,
39,0,,
39,1,,,
;903 /min,RPM,
39,2,,,
39,3,,,
39,4,,,
40,0,,
40,1,,,
;903 /min,RPM,
40,2,,,
;6.0 mg/str,Inj. Quantity,
40,3,,,
40,4,,,
;1.00,(no units),
41,0,,
41,1,,,
41,2,,,
;0.0 %,Duty Cycle,
41,3,,,
;0.0 %,Duty Cycle,
41,4,,,
;0.0 %,Duty Cycle,
42,0,,
42,1,,,
;-1.3 %,Lambda,
42,2,,,
42,3,,,
;95.9 %,Duty Cycle,
42,4,,,
;0.0 %,Duty Cycle,
43,0,,
43,1,,,
;78.5 %,Duty Cycle,
43,2,,,
;100.6 %,Lambda,
43,3,,,
;-2.5 %,Lambda,
43,4,,,
44,0,,
44,1,,,
;903 /min,RPM,
44,2,,,
;6.3°C,Temperature,
44,3,,,
44,4,,,
;100.6 %,Lambda,
50,0,,
50,1,,,
;903 /min,RPM,
50,2,,,
50,3,,,
50,4,,,
51,0,,
51,1,,,
;882 /min,RPM,
51,2,,,
;441 /min,RPM,
51,3,,,
;48.0,(no units),
51,4,,,
52,1,Cylinder 1,,
;0.0,(no units),
52,2,Cylinder 2,,
;0.0,(no units),
52,3,Cylinder 3,,
;0.0,(no units),
52,4,Cylinder 4,,
;0.0,(no units),
55,0,,
;0.0,(no units),
;0.0,(no units),
56,0,,
56,4,Reset Status,,
;0xFF00,Hex Value,
;903 /min,RPM,
;40.0 Nm,Torque,
;7.2°C,Temperature,
60,4,,,
;0.0 %,Load,
;7.2°C,Temperature,
61,3,,,
;0.0 %,Load,
61,4,,,
;7.2°C,Temperature,
62,2,,,
;6.3°C,Temperature,
;6.3°C,Temperature,
63,0,,
63,1,,,
;0.00 bar,Pressure,
63,2,,,
;0.0 Nm,Torque,
63,3,,,
63,4,,,
;16.0,(no units),
65,0,,
65,1,,,
;0.0 %,Load,
65,2,,,
;7.2°C,Temperature,
65,3,,,
65,4,,,
66,0,,
66,1,,,
66,2,,,
;6.3°C,Temperature,
66,3,,,
66,4,,,
74,0,,
;903 /min,RPM,
;1.00,(no units),
80,1,,,
82,1,,,
86,0,,
86,1,,,
86,2,,,
;11111000,Bin. Bits,
86,3,,,
;11011110,Bin. Bits,
86,4,,,
87,0,,
87,1,,,
87,2,,,
87,3,,,
87,4,,,
89,0,,
89,1,,,
89,2,,,
89,3,,,
89,4,,,
90,0,,
90,1,,,
;903 /min,RPM,
90,2,,,
90,3,,,
;550.0 mg/str,Mass Air / Rev.,
90,4,,,
91,0,,
91,1,,,
;127.0,(no units),
91,2,,,
;-128.0,(no units),
91,3,,,
91,4,,,
;4.0,(no units),
93,0,,
93,1,,,
93,2,,,
;0.81,(no units),
93,3,,,
;54.0,(no units),
93,4,,,
;44.4,(no units),
;ABS 1, ,
;Instruments 1, ,
;Airbag 1, ,
131,0,,
131,1,,,
;16.0,(no units),
131,2,,,
;5.2 mg/str,Inj. Quantity,
131,3,,,
131,4,,,
;9.0°C,Temperature,
133,0,,
133,1,,,
;903 /min,RPM,
133,2,,,
133,3,,,
133,4,,,
;0.0,(no units),
134,0,,
134,1,,,
;37.6 %,Load,
134,2,,,
;14.59 V,Voltage,
134,3,,,
134,4,,,
140,0,,
140,1,,,
140,2,,,
140,3,,,
140,4,,,
213,0,,
213,1,,,
;903 /min,RPM,
213,2,,,
;0.0 %,Load,
213,3,,,
;0.0 km/h,Speed,
213,4,,,
;0.0,(no units),
225,0,,
225,1,,,
;0.0,(no units),
225,2,,,
;0.0,(no units),
225,3,,,
;0.0,(no units),
225,4,,,
;0.0,(no units),
226,0,,
226,1,,,
;0.0,(no units),
226,2,,,
226,3,,,
;0.0,(no units),
226,4,,,
;0.0,(no units),
227,0,,
227,1,,,
;0.0,(no units),
227,2,,,
;0.0,(no units),
227,3,,,
;0.0,(no units),
227,4,,,
;0.0,(no units),
228,0,,
228,1,,,
;0.0,(no units),
228,2,,,
;0.0,(no units),
228,3,,,
228,4,,,
229,0,,
229,1,,,
229,2,,,
229,3,,,
;0.0,(no units),
229,4,,,
;0.0,(no units),
;SW:1C0-907-379-L HW: --- ABS Brakes
;Component:ABS FRONT MK60 0101, Coding:0001025
;Friday,05,February,2021,15:13:19:14741
;VCID: B338F486C72671C33E0-5184
1,0,Current Wheel Speed (Basic Setting: Brake Pump Bleeding),
1,1,Speed Sensor,Front Left (G47),Specification: 0.0...255.0 km/h
;0.0 km/h,Speed,
1,2,Speed Sensor,Front Right (G45),Specification: 0.0...255.0 km/h
;0.0 km/h,Speed,
1,3,Speed Sensor,Rear Left (G46),Specification: 0.0...255.0 km/h
;0.0 km/h,Speed,
1,4,Speed Sensor,Rear Right (G44),Specification: 0.0...255.0 km/h
;0.0 km/h,Speed,
2,0,Starting Wheel Speed,
2,1,Speed Sensor,Front Left (G47),Specification: 0.0...254.0 km/h (255.0 km/h = standing)
;255.0 km/h,Speed,
2,2,Speed Sensor,Front Right (G45),Specification: 0.0...254.0 km/h (255.0 km/h = standing)
;255.0 km/h,Speed,
2,3,Speed Sensor,Rear Left (G46),Specification: 0.0...254.0 km/h (255.0 km/h = standing)
;255.0 km/h,Speed,
2,4,Speed Sensor,Rear Right (G44),Specification: 0.0...254.0 km/h (255.0 km/h = standing)
;255.0 km/h,Speed,
3,0,Switches and Warning Lights,
3,1,Brake Light,Switch (F),Specification: not oper./operated
;Not Oper., ,
3,2,Brake System,Warning Light,Specification: on/off
;OFF, ,
3,3,ABS,Warning Light,Specification: on/off
;OFF, ,
3,4,,,
;N/A,,
11,0,,
11,1,,,
;0,Count,
11,2,,,
;0,Count,
11,3,,,
;0,Count,
11,4,,,
;N/A,,
12,0,,
12,1,,,
;0,Count,
12,2,,,
;0,Count,
12,3,,,
;0,Count,
12,4,,,
;N/A,,
13,0,,
13,1,,,
;0,Count,
13,2,,,
;0,Count,
13,3,,,
;0,Count,
13,4,,,
;N/A,,
14,0,,
14,1,,,
;0,Count,
14,2,,,
;0,Count,
14,3,,,
;0,Count,
14,4,,,
;N/A,,
80,1,,,
;CTA-000 17.04.04 00000001 0101 1886,,
125,1,Engine,,
;Engine 1, ,
125,2,,,
125,3,,,
125,4,Transmission,,
225,0,,
225,1,,,
;Engine 1, ,
225,2,,,
225,3,,,
225,4,,,
;Saturday,06,February,2021,15:01:25:14741
;0.0 km/h,Speed,
;0.0 km/h,Speed,
;0.0 km/h,Speed,
;0.0 km/h,Speed,
;255.0 km/h,Speed,
;255.0 km/h,Speed,
;255.0 km/h,Speed,
;255.0 km/h,Speed,
;Not Oper., ,
;OFF, ,
;OFF, ,
3,4,,,
;N/A,,
11,0,,
11,1,,,
;0,Count,
11,2,,,
;0,Count,
11,3,,,
;0,Count,
11,4,,,
;N/A,,
12,0,,
12,1,,,
;0,Count,
12,2,,,
;0,Count,
12,3,,,
;0,Count,
12,4,,,
;N/A,,
13,0,,
13,1,,,
;0,Count,
13,2,,,
;0,Count,
13,3,,,
;0,Count,
13,4,,,
;N/A,,
14,0,,
14,1,,,
;0,Count,
14,2,,,
;0,Count,
14,3,,,
;0,Count,
14,4,,,
;N/A,,
80,1,,,
125,1,Engine,,
;Engine 1, ,
125,2,,,
125,3,,,
225,0,,
225,1,,,
;Engine 1, ,
225,2,,,
225,3,,,
225,4,,,
;SW:1C0-909-605-F HW: --- Airbags
;Component:17 AIRBAG VW61 0108 0003, Coding:12599
;Friday,05,February,2021,15:10:21:14741
;VCID: A70010D606FE0D63928-513C
1,0,Ignitiers I (Front Airbags Stage 1 && Front Belt Tensioners),
1,1,Airbag (Stage 1),Driver Side,Specification: Correct
Display Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
;Correct, ,
1,2,Airbag (Stage 1),Passenger Side,Specification: Correct
;Correct, ,
1,3,Belt Tensioner,Front Driver Side,Specification: Correct
;Correct, ,
1,4,Belt Tensioner,Front Pass. Side,Specification: Correct
;Correct, ,
2,0,Ignitiers II (Rear Belt Tensioners),
2,1,Belt Tensioner,Rear Driver Side,Specification: Correct
;Not Installed, ,
2,2,Belt Tensioner,Rear Pass. Side,Specification: Correct
;Not Installed, ,
2,3,,,
;N/A,,
2,4,,,
;N/A,,
3,0,Voltage && Seat. Occupation && Belt Inquiry I (Front),
3,1,Voltage Supply,,Specification: Correct
;Correct, ,
3,2,Occupied Seat,Sensor Pass. Side,Display Range: child/child seat/light adult/heavy adult/occupied/not occupied/not installed
;Not Installed, ,
3,3,Belt Inquiry,Front Driver Side,Specification: Not Installed/Belt Yes/Belt No
Display Range: Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed/Belt Yes/Belt No
;Belt: No, ,
3,4,Belt Inquiry,Front Pass. Side,Specification: Not Installed/Belt Yes/Belt No
;Belt: No, ,
4,0,Belt Inquiry II (Rear),
4,1,Belt Inquiry,Rear Driver Side,Specification: Not Installed/Belt Yes/Belt No
;Not Installed, ,
4,2,Belt Inquiry,Rear Pass. Side,Specification: Not Installed/Belt Yes/Belt No
;Not Installed, ,
4,3,,,
;N/A,,
4,4,,,
;N/A,,
5,0,Igniters III (Side Airbags),
5,1,Side Airbag,Front Driver Side,Specification: Correct
;Correct, ,
5,2,Side Airbag,Front Pass. Side,Specification: Correct
;Correct, ,
5,3,Side Airbag,Rear Driver Side,Specification: Correct
;Not Installed, ,
5,4,Side Airbag,Rear Pass. Side,Specification: Correct
;Not Installed, ,
6,0,Seat Occupation (Rear),
6,1,Seat Occupation,Rear Driver Side,Display Range: Not Installed
;Not Installed, ,
6,2,Seat Occupation,Rear Pass. Side,Display Range: Not Installed
;Not Installed, ,
6,3,,,
;N/A,,
6,4,,,
;N/A,,
7,0,Igniters IV (Head Airbags),
7,1,Head-Level Airbag,Driver Side,Specification: Correct
;Correct, ,
7,2,Head-Level Airbag,Passenger Side,Specification: Correct
;Correct, ,
7,3,,,
;N/A,,
7,4,,,
;N/A,,
8,0,Crash Sensor I (Version),
8,1,Driver Side,Front,
;1,Count,
8,2,Passenger Side,Front,
;1,Count,
8,3,Driver Side,Rear,
;8,Count,
8,4,Passenger Side,Rear,
;8,Count,
9,0,Crash Sensor I (Identification),
9,1,Driver Side,Front,
;01, ,
9,2,Passenger Side,Front,
;01, ,
9,3,Driver Side,Rear,
;08, ,
9,4,Passenger Side,Rear,
;08, ,
10,0,Key Switch,
10,1,Passenger,Airbag Status,Display Range: ON/OFF
;Not Installed, ,
10,2,Key Switch,Logic Contact 1,Display Range: too small/to Ground/to B+/on/off/not installed
;Not Installed, ,
10,3,Key Switch,Logic Contact 2,Display Range: too small/to Ground/to B+/on/off/not installed
;Not Installed, ,
10,4,,,
;N/A,,
11,0,,
11,1,,,
;Not Installed, ,
11,2,,,
;Not Installed, ,
11,3,,,
;Not Installed, ,
11,4,,,
;N/A,,
45,0,,
45,1,,,
;Data for,,
45,2,,,
;Group 045,,
45,3,,,
;Not,,
45,4,,,
;Available,,
;Saturday,06,February,2021,15:08:57:14741
;Correct, ,
;Correct, ,
;Correct, ,
;Correct, ,
;Not Installed, ,
;Not Installed, ,
2,3,,,
;N/A,,
2,4,,,
;N/A,,
;Correct, ,
;Not Installed, ,
;Belt: No, ,
;Belt: No, ,
;Not Installed, ,
;Not Installed, ,
4,3,,,
;N/A,,
4,4,,,
;N/A,,
;Correct, ,
;Correct, ,
;Not Installed, ,
;Not Installed, ,
;Not Installed, ,
;Not Installed, ,
6,3,,,
;N/A,,
6,4,,,
;N/A,,
;Correct, ,
;Correct, ,
7,3,,,
;N/A,,
7,4,,,
;N/A,,
;1,Count,
;1,Count,
;8,Count,
;8,Count,
;01, ,
;01, ,
;08, ,
;08, ,
10,0,Key Switch,
;Not Installed, ,
;Not Installed, ,
;Not Installed, ,
10,4,,,
;N/A,,
11,0,,
11,1,,,
;Not Installed, ,
11,2,,,
;Not Installed, ,
11,3,,,
;Not Installed, ,
11,4,,,
;N/A,,
;SW:1J0-907-487-A HW: --- Steering wheel
;Component:Lenkradelektronik 0005, Coding:00118
;Saturday,06,February,2021,15:11:33:14741
;VCID: AF30F8F62E0E55235A8-5184
1,0,Buttons right,
1,1,Button,"softer",Specification: operated/not operated
;Not Oper., ,
1,2,Button,"louder",Specification: operated/not operated
;Not Oper., ,
1,3,Button,"down",Specification: operated/not operated
;Not Oper., ,
1,4,Button,"up",Specification: operated/not operated
;Not Oper., ,
2,0,Buttons left,
2,1,Button,"RES (+)",Specification: operated/not operated
;Not Oper., ,
2,2,Button,"SET (-)",Specification: operated/not operated
;Not Oper., ,
2,3,Button,"Cancel"/"Mode",Specification: operated/not operated
;Not Oper., ,
2,4,Button,"Telephone",Specification: operated/not operated
;Not Oper., ,
3,0,Supply Voltage,
3,1,,,
;Not Oper., ,
3,2,Supply Voltage,,
;14.14 V,Voltage,
3,3,,,
;N/A,,
3,4,,,
;N/A,,
80,1,,,
;TAS-001 22.02.04 00006905 0001 0317,,
125,0,CAN-Databus Communication (Comfort),
125,1,Instrument Cluster,,
;Instruments 1, ,
125,2,CAN-Databus,Comfort (Status),
;2-Wire, ,
125,3,,,
;N/A,,
125,4,,,
;N/A,,
;SW:1J5-920-906-Q HW: --- Instruments
;Component:KOMBI+WEGFAHRSP VDO V03, Coding:15232
;Saturday,06,February,2021,15:13:21:14741
;VCID: BB28DCA6EA76B983E60-513C
1,0,General,
1,1,Vehicle Speed,,
;0.0 km/h,Speed,
1,2,Engine Speed,,
;880 /min,RPM,
1,3,Oil Pressure,Switch 2,Range: Oil Pr. 2 <min / Oil Pr. 2 OK
;Oil Pr. 2 OK, ,
1,4,Time,,
;04:10,Clock,
2,0,General,
2,1,Odometer,,
;290550 km,Mileage,
2,2,Fuel Level,,
;21.0 l,Tank Cont.,
2,3,Fuel Sender,Resistance,
;143 ohms,Resistance,
2,4,Ambient,Temperature,
3,0,General,
3,1,Coolant,Temperature,
;58.0°C,Temperature,
3,2,Oil Level,,Range: Ok/n.Ok
3,3,Oil,Temperature,
3,4,,,
;N/A,,
22,0,Immobilizer I,
22,1,Engine Start,permitted,Specification: 1 = Yes
Range: 0 = No / 1 = Yes
; 1, ,
22,2,Engine (ECU),responds,Specification: 1 = Yes
; 1, ,
22,3,Key Status,,Specification: 1 = Key OK
Range: 0 = Key not OK / 1 = Key OK
; 1, ,
22,4,Number of,adapted Keys,Specification: 1...4
; 2, ,
23,0,Immobilizer II,
23,1,Variable Code,authorized,Specification: 1 = Yes
; 1, ,
23,2,Key Status,(Transponder),Range: 0 = Not Locked / 1 = Locked
; 1, ,
23,3,Fixed Code,authorized,Specification: 1 = Yes
; 1, ,
23,4,Immobilizer,Status,Specification: 6 (Immobilizer adapted)
; 6, ,
24,0,Immobilizer III (Lock-Time),
24,1,Lock-Time,Instrument Cluster,
;0.0,(no units),
24,2,Lock-Time,Engine (ECU),
;0.0,(no units),
24,3,Lock-Time,Emergency Unlock,
;0.0,(no units),
24,4,Lock-Time,Transponder,
;0.0,(no units),
25,0,Immobilizer IV,
25,1,Immobilizer,Communication,0 = No Communication
1 = Communication via CAN-Databus
2 = Communication via W-Line
; 1, ,
25,2,,,
;N/A,,
25,3,,,
;N/A,,
25,4,,,
;N/A,,
50,0,General,
50,1,Odometer,,
;290550 km,Mileage,
50,2,Engine Speed,,
;880 /min,RPM,
50,3,Oil Temperature,,
50,4,Coolant,Temperature,
125,1,Engine,,Specification: Engine 1
Range: Engine 0/Engine 1
;Engine 1, ,
125,2,Transmission,,Range: Transm. 0/Transm. 1
125,3,Brake Electronics,(J104),Specification: ABS 1
Range: ABS 0/ABS 1
;ABS 1, ,
125,4,,,
;N/A,,
126,0,CAN-Databus Communication (Powertrain),
126,1,Steering Angle,Sensor (G85),Specification: Steer. ang. 1
Range: Steer. ang. 0/Steer. ang. 1
126,2,Airbags,(J234),Specification: Airbag 1
Range: Airbag 0/Airbag 1
;Airbag 1, ,
126,3,,,
126,4,,,
129,0,,
129,1,,,
129,2,,,
;N/A,,
129,3,,,
;N/A,,
129,4,,,
;N/A,,
130,0,CAN-Databus Communication (Comfort),
130,1,CAN-Comfort,Status,Specification: 2-Wire
Range: 2-Wire/1-Wire
;2-Wire, ,
130,2,Comfort System,(J393),Specification: Central 1
Range: Central 1/Central 0
;Central 1, ,
130,3,Door Electronics,Driver (J386),Specification: Dr. Door 1
Range: Dr. Door 1/Dr. Door 0
;Dr. Door 1, ,
130,4,Door Electronics,Passenger (J387),Specification: Pas. Door 1
Range: Pas. Door 1/Pas. Door 0
;Pas. Door 1, ,
131,0,CAN-Databus Communication (Comfort),
131,1,Door Electronics,Rear Left (J388),Specification: RL Door 1
Range: RL Door 1/RL Door 0
;RL Door 1, ,
131,2,Door Electronics,Rear Right (J389),Specification: RR Door 1
Range: RR Door 1/RR Door 0
;RR Door 1, ,
131,3,,,
131,4,,,
132,0,,
132,1,,,
132,2,,,
;St. Wheel 1, ,
132,3,,,
132,4,,,
135,0,,
135,1,,,
135,2,,,
135,3,,,
135,4,,,
;N/A,,
136,0,,
136,1,,,
136,2,,,
;N/A,,
136,3,,,
;N/A,,
136,4,,,
;N/A,,
140,0,CAN-Databus Communication (Infotainment),
140,1,CAN-Infotainment,Status,Specification: 2-Wire
;2-Wire, ,
140,2,Radio,,Range: Radio 1/Radio 0
;Radio 1, ,
140,3,,,
140,4,,,
142,0,,
142,1,,,
142,2,,,
142,3,,,
;N/A,,
142,4,,,
;N/A,,
143,0,,
143,1,,,
143,2,,,
;St. Wheel 1, ,
143,3,,,
;N/A,,
143,4,,,
;N/A,,
201,0,,
201,1,Distance Impulse,Number,
;3528,Count,
201,2,,,
;N/A,,
201,3,,,
;N/A,,
201,4,,,
;N/A,,
;SW:6N0-909-901 HW: --- CAN Gateway
;Component:Gateway K<->CAN 0001, Coding:00006
;Saturday,06,February,2021,15:16:16:14741
;VCID: F0B23B8AF3B00ADB032-513C
125,0,CAN-Databus Powertrain (Communication),
125,1,Engine Electronics,,Range: Engine 1/Engine 0
;Engine 1, ,
125,2,Transmission,Electronics,Range: Transm. 1/Transm. 0
Specification: Transm. 1
125,3,Brake Electronics,(J104),Range: ABS 1/ABS 0
;ABS 1, ,
125,4,Instrument Cluster,(J285),Range: Instruments 1/Instruments 0
;N/A,,
126,0,CAN-Databus Powertrain (Communication),
126,1,Steering Angle,Sensor (G85),Range: Steer. ang. 1/Steer. ang. 0
126,2,Airbag System,(J234),Range: Airbag 1/Airbag 0
;Airbag 1, ,
126,3,Steering Aid,(J500),Range: Steering 1/Steering 0
Specification: Steering 1
126,4,,,
129,0,,
129,1,,,
129,2,,,
;N/A,,
129,3,,,
;N/A,,
129,4,,,
;N/A,,
130,0,CAN-Databus Comfort (Communication),
130,1,CAN-Comfort,Status,Range: 2-Wire/1-Wire
;2-Wire, ,
130,2,Comfort System,(J393),Range: Central 1/Central 0
;Central 1, ,
130,3,Door Electronics,Driver (J386),Range: Dr. Door 1/Dr. Door 0
;Dr. Door 1, ,
130,4,Door Electronics,Passenger (J387),Range: Pas. Door 1/Pas. Door 0
;Pas. Door 1, ,
131,0,CAN-Databus Comfort (Communication),
131,1,Door Electronics,Rear Left (J388),Range: RL Door 1/RL Door 0
;RL Door 1, ,
131,2,Door Electronics,Rear Right (J389),Range: RR Door 1/RR Door 0
;RR Door 1, ,
131,3,Seat Memory,Driver (J521),Range: Memory 1/Memory 0
Specification: Memory 1
131,4,Central Electronics,(J519),Range: E.Load.Crtl 1/E.Load.Crtl 0
Specification: E.Load.Crtl 1
132,0,CAN-Databus Comfort (Communication),
132,1,,,
132,2,Steering Wheel,Electronics (J527),Range: St. Wheel 1/St. Wheel 0
Specification: St. Wheel 1
;St. Wheel 1, ,
132,3,Heating/Air,Condition (J255),Range: A/C 1/A/C 0
Specification: A/C 1
132,4,Tire Pressure,Monitoring (J502),Range: Tire 1/Tire 0
Specification: Tire 1
135,0,CAN-Databus Comfort (Communication),
135,1,,,
135,2,Display Control,Front,
135,3,Display Control,Rear,
135,4,,,
;N/A,,
136,0,CAN-Databus Comfort (Communication),
136,1,,,
136,2,Central,Locking,
;N/A,,
136,3,,,
;N/A,,
136,4,,,
;N/A,,
140,0,CAN-Databus Infotainment (Communication),
140,1,CAN-Infotainment,Status,Range: 2-Wire/1-Wire
;2-Wire, ,
140,2,Analog Radio,,Range: Radio 1/Radio 0
Specification: Radio 1
;Radio 1, ,
140,3,Navigation,,Range: Navigation 1/Navigation 0
Specification: Navigation 1
140,4,,,
142,0,CAN-BUS Status (1 = OK / 0 = not OK),
142,1,Display Control,Front,
142,2,,,
142,3,,,
;N/A,,
142,4,,,
;N/A,,
143,0,CAN-BUS Status (1 = OK / 0 = not OK),
143,1,Digital Sound,Processor,
143,2,,,
;St. Wheel 1, ,
143,3,,,
;N/A,,
143,4,,,
;N/A,,
225,0,CAN-Databus Powertrain (Timeout),
225,1,Engine Electronics,,
;Engine 0, ,
225,2,Transmission,Electronics,
225,3,Brake Electronics,(J104),
;ABS 0, ,
225,4,Instrument Cluster,(J285),
;N/A,,
226,0,CAN-Databus Powertrain (Timeout),
226,1,Steering Angle,Sensor (G85),
226,2,Airbag System,(J234),
;Airbag 0, ,
226,3,Steering Aid,(J500),
226,4,,,
229,0,,
229,1,,,
229,2,,,
;N/A,,
229,3,,,
;N/A,,
229,4,,,
;N/A,,
;SW:1C0-959-799-C HW: --- Central Conv.
;Component:8A Komfortgerát HLO 0003, Coding:00259
;Friday,05,February,2021,15:12:12:14741
;VCID: B720C096D65E9DE3028-4B1E
1,0,Driver's door,
1,1,Electric window,hall signal,E40 (Specification: auto. open/auto. close/man. open/man. close/close not operated/implausible)
;Not Oper., ,
1,2,Electric window,thermal protection,Specification: yes/no
;No, ,
1,3,Child safety,switch,E39 (Specification: yes/no/not installed)
;OFF, ,
1,4,,,
;N/A,,
2,0,Driver's door (driver's switch for electric windows),
2,1,Passenger side,electric window,E81 (Specification: autom. open/autom. close/man. open/man. close/not operated/implausible)
;Not Oper., ,
2,2,Rear left,electric window,E53 (Specification: autom. open/autom. close/man. open/man. close/not operated/implausible)
;Not Oper., ,
2,3,Rear right,electric window,E55 (Specification: autom. open/autom. close/man. open/man. close/not operated/implausible)
;Not Oper., ,
2,4,,,
;N/A,,
3,0,Driver's door,
3,1,Mirror adjustment,switch driver,E43 (Specification: Pos X+/Pos X-/Pos Y+/Pos Y-/not operated)
;Not Oper., ,
3,2,Mirror selection,switch driver,E48 (Specification: left/right/fold/not operated)
;Right, ,
3,3,Mirror folding,switch,E263 (Specification: released/engaged/not installed)
3,4,Mirror heating,,E231 (Specification: on/off/not installed)
;OFF, ,
4,0,Passenger's door (electric window),
4,1,Switch passenger,(E107),Specification: autom. open/autom. close/man. open/man. close/not operated/implausible
;Not Oper., ,
4,2,Thermal protection,passenger,Specification: yes/no
;No, ,
4,3,Working speed,control switch,F261 (Specification: released/engaged/not installed)
4,4,,,
;N/A,,
5,0,Rear door's (electric windows),
5,1,Switch rear left,(E52),Specification: autom. open/autom. close/man. open/man. close/not operated/implausible
;Not Oper., ,
5,2,Thermal protection,rear left,Specification: yes/no
;No, ,
5,3,Switch rear right,(E54),Specification: autom. open/autom. close/man. open/man. close/not operated/implausible
;Not Oper., ,
5,4,Thermal protection,rear right,Specification: yes/no
;No, ,
6,0,,
6,1,Supply Voltage,(terminal 30),
;14.30 V,Voltage,
6,2,Ignition,,Specification: Terminal 15 on/Terminal 15 off
;Term 15 On, ,
6,3,S-Terminal,,Specification: operated/not operated
;Activated, ,
6,4,Speed signal,,Steps: 2 km/h
;0.0 km/h,Speed,
7,0,,
7,1,Central locking,key switch driver,Specification: open/closed/not operated/implausible
;Not Oper., ,
7,2,Central locking,key switch pass.,Specification: open/closed/not operated/implausible
;Not Oper., ,
7,3,Interior locking,driver switch,E150 (Specification: lock/unlock/not operated/implausible)
;Not Oper., ,
7,4,Interior locking,passenger switch,E198 - USA only (Specification: lock/unlock/not operated/implausible)
;Not Oper., ,
8,0,,
8,1,Hood contact,switch (F120),Specification: operated/not operated/not installed
;Closed, ,
8,2,Rear lid/tailgate,key switch,E165 (Specification: open/closed/not operated/implausible)
;Not Oper., ,
8,3,Rear lid/tailgate,contact switch,F124 (Specification: open/closed)
;Closed, ,
8,4,Central locking,thermal protection,Specification: yes/no
;No, ,
9,0,Central locking feedback,
9,1,Driver's side,,Specification: safe/not safe/locked/unlocked
;Implausible, ,
9,2,Passenger's side,,Specification: safe/not safe/locked/unlocked
;Implausible, ,
9,3,Rear left,,Specification: safe/not safe/locked/unlocked
;Implausible, ,
9,4,Rear right,,Specification: safe/not safe/locked/unlocked
;Implausible, ,
10,0,Rotary latch switches,
10,1,Driver's side,,Specification: 1 = dr. open / 2 = dr. closed
;Door Open, ,
10,2,Passenger's side,,Specification: 1 = dr. open / 2 = dr. closed
;Door Closed, ,
10,3,Rear left,,Specification: 1 = dr. open / 2 = dr. closed
;Door Closed, ,
10,4,Rear right,,Specification: 1 = dr. open / 2 = dr. closed
;Door Closed, ,
11,0,,
11,1,Immobilizer,key recognition,Specification: yes/no/not installed
;Yes, ,
11,2,Automatic,lock/unlock switch,Specification: operated/not oper./implausible
;Not Oper., ,
11,3,Sliding/tilting,sunroof released,Specification: yes/no
;Yes, ,
11,4,Status,CAN-Databus,Specification: 2-wire
;2-Wire, ,
12,0,CAN-Databus communication,
12,1,Door contr. module,Driver side,
;Dr. Door 1, ,
12,2,Door contr. module,Passenger side,
;Pas. Door 1, ,
12,3,Door contr. module,rear left,
;RL Door 1, ,
12,4,Door contr. module,rear right,
;RR Door 1, ,
13,0,,
13,1,Rear lid button,rear lid handle,E188/E234 (Specification: not operated/remote switch/lid lever/implausible)
;Not Oper., ,
13,2,Rear,first detent,Specification: open/closed/not installed
;Closed, ,
13,3,Instrument,illumination,Specification: 0...100 %
;0.0 %,Load,
13,4,,,
;N/A,,
14,0,,
14,1,Permanent code,known,Specification: OK/n.OK
;no Value, ,
14,2,Code within,effective range,Specification: OK/n.OK
;no Value, ,
14,3,Algorithm,,Specification: OK/n.OK
;no Value, ,
14,4,Key number,,Specification: 0...4 (0 = not operated)
;0,Count,
15,0,,
15,1,Remote control,button,Specification: open/closed/RLR/panic (RLR = rear lid release)
; 0 0 0 0,Bin. Bits,
15,2,Interior monitor,sensor (G273),Specification: yes/no/not installed
;Not Installed, ,
15,3,Interior monitoring,switch-off (E267),Specification: on/off/not installed
;Not Installed, ,
15,4,,,
;N/A,,
16,0,Alarm Sources,
16,1,1st Alarm Source,,1 = Door Contact Switch Driver Door
2 = Door Contact Switch Passenger Door
4 = Door Contact Switch Rear Left Door
8 = Door Contact Switch Rear Right Door
16 = Door Contact Switch Rear Lid/Tailgate
17 = Immobilizer
18 = Anti Theft System Power Supply
32 = Engine Hood Contact Switch
64 = Ignition (Terminal 15)
128 = Interior Monitoring
255 = No Alarm Source recognized
;64,Count,
16,2,2nd Alarm Source,,1 = Door Contact Switch Driver Door
17 = Immobilizer
;4,Count,
16,3,3rd Alarm Source,,1 = Door Contact Switch Driver Door
17 = Immobilizer
;1,Count,
16,4,4th Alarm Source,,1 = Door Contact Switch Driver Door
17 = Immobilizer
;4,Count,
80,1,Identification,,
;HLO-KSG 18.03.04 2.9 5.2 0001 0001,Identification,
;Saturday,06,February,2021,15:20:59:14741
1,0,Driver's door,
;Not Oper., ,
;No, ,
;OFF, ,
1,4,,,
;N/A,,
;Not Oper., ,
;Not Oper., ,
;Not Oper., ,
2,4,,,
;N/A,,
3,0,Driver's door,
;Not Oper., ,
;Right, ,
;OFF, ,
;Not Oper., ,
;No, ,
4,4,,,
;N/A,,
;Not Oper., ,
;No, ,
;Not Oper., ,
;No, ,
6,0,,
;14.08 V,Voltage,
;Term 15 On, ,
;Activated, ,
;0.0 km/h,Speed,
7,0,,
;Not Oper., ,
;Not Oper., ,
;Not Oper., ,
;Not Oper., ,
8,0,,
;Closed, ,
;Not Oper., ,
;Closed, ,
;No, ,
;Implausible, ,
;Implausible, ,
;Implausible, ,
;Implausible, ,
;Door Closed, ,
;Door Closed, ,
;Door Closed, ,
;Door Closed, ,
11,0,,
;Yes, ,
;Not Oper., ,
;Yes, ,
;2-Wire, ,
;Dr. Door 1, ,
;Pas. Door 1, ,
;RL Door 1, ,
;RR Door 1, ,
13,0,,
;Not Oper., ,
;Closed, ,
;0.0 %,Load,
13,4,,,
;N/A,,
14,0,,
;no Value, ,
;no Value, ,
;no Value, ,
;0,Count,
15,0,,
;Not Installed, ,
;Not Installed, ,
15,4,,,
;N/A,,
16,0,Alarm Sources,
17 = Immobilizer
;64,Count,
17 = Immobilizer
;4,Count,
17 = Immobilizer
;1,Count,
17 = Immobilizer
;4,Count,
;SW:3B7-035-180-G HW: --- Radio
;Component: Radio PM6 0016, Coding:04031
;Saturday,06,February,2021,15:23:18:14741
;VCID: A41A07DA77C8E67BB7A-513C
1,0,General,
1,1,Supply Voltage,(Terminal 30),Specification: 5...18 V
;Data for,,
1,2,Amplifier,Output,only if Amplifier installed
;Group 001,,
1,3,Telephone-Mute,,
;Not,,
1,4,Telephone-Mute,Status,Range: ON/OFF
;Available,,
2,0,Speaker/Line-Out (Front),
2,1,Location/Type,,
;Line-Out F/Lft, ,
2,2,Status,,
2,3,Location/Type,,
;Line-Out F/Rt, ,
2,4,Status,,
3,0,Speaker/Line-Out (Rear),
3,1,Location/Type,,
;Line-Out R/Lft, ,
3,2,Status,,
3,3,Location/Type,,
;Line-Out R/Rt, ,
3,4,Status,,
4,0,Remote Feed Antenna,
4,1,Antenna,Type,
;Active, ,
4,2,Component,,
;Antenna, ,
4,3,Antenna,Status,
;OK, ,
4,4,,,
;N/A,,
5,0,IF-Output,
5,1,Component,,
;Ant.Sw.Outp, ,
5,2,IF-Output,Status,
;Open Circuit, ,
5,3,,,
;N/A,,
5,4,,,
;N/A,,
6,0,,
6,1,,,
6,2,,,
6,3,,,
6,4,,,
;N/A,,
7,0,Communication Status CD-Changer (R41),
7,1,Component,,
;CD Connect., ,
7,2,CD-Changer,Status,
;Not OK, ,
7,3,,,
;N/A,,
7,4,,,
;N/A,,
8,0,Signal Strength,
8,1,Signal Strength,,
;SignalStrength, ,
8,2,Signal Strength,Tuner,
;60.0,(no units),
8,3,,,
;N/A,,
8,4,,,
;N/A,,
;PM6-001 26.03.04 00190016 ,Identification,
81,1,Serial Number,,
; VWZ5Z7D3054120 ,Serial Number,
138,0,,
138,1,,,
;Data for,,
138,2,,,
;Group 138,,
138,3,,,
;Not,,
138,4,,,
;Available,,
;33-OBD2
;Saturday,06,February,2021,15:27:41:14741
;VCID: D5FC6A1E6C024FF3F04-5184
04,Calculated load value,20.0 %
05,Engine coolant temperature,65 °C
0B,Intake Manifold Absolute Pressure,99 kPa abs
0C,Engine RPM,904 /min
0D,Vehicle speed,0 km/h
0F,Intake air temperature,28 °C
10,Mass Air Flow,14.47 g/s
11,Throttle position sensor,95.3 %
1C,OBD Requirements Met,OBD (EPA)
1D,Location of O2 sensors,B1S1
21,Distance travelled with MIL on,0 km
24,Bank 1 Sensor 1 Status,0.453 Lambda,2.190 V
Mode 9 : Calibration Identification
Type 02 - VIN : WVWSR61J84W047451 (Address 10)
Type 04 - Calibration ID : 038997016R 0282 (Address 10)
Type 06 - Calibration Verification Number : 370A88FD (Address 10)
