New VCDS tool, Some Faults, Trouble shooting time.
RobbieR
Canada
C?ID=268344
Hi Folks,
So after many hours of researching diagnostic tools, I pulled the trigger on a VCDS tool and could use some help trouble shooting my 2011 Audi A3.
Some pre info for you pro's, I have looked at the following already wrt the DPF code and the P2101 code.
For the P2101 code, I removed and cleaned the throttle body valve and re-installed about three weeks ago, things where going well, then the code showed up
again. I have cycled the valve using the output test routine in VCDS and it cycles.
The DPF code, I followed the manuals recommendation to drive the Pi$$ out of my car, which was fun :) no just kidding! but i did take it out for a nice little rip!
as recommended by so many DPF post's and the DPF is still lit up. Last night, we tried the Emergency DPF regeneration using the VCDS, but i think it didn't happen? Not sure
how to verify this? watching the MB temperatures they where healthy looking at Block 241 and 099 ( sorry, forgot to take note). yes, I know there a log button, still getting familiar VCDS ;)
Something new that has not showed up yet in the form of a code is, I noticed just shortly after shutting the car off, a squeal come from under the car. using the test routine Exhaust pressure control valve(J883) to cycle the valve, it squeals. but no code. I guess this needs servicing?
Thanks in advanced for your thoughts and recommendations.
btw, car is in stock form.
Please see below scan.
MB Code 241.1 69ml 241.2 50.1g 241.3 45.9g my apologies if the 241.X is the wrong order.
Thursday,28,January,2016,13:33:06:37433
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WAUAJCFM4BA107222   License Plate:
Mileage: 101560km-63106mi   Repair Order:
Chassis Type: FM (8P0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WAUAJCFM4BA107222   Mileage: 101560km-63106miles
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 906 019 CT    HW: 03L 906 019 CT
   Component: R4 2,0L EDC G000AG  7971
   Revision: 12H14---    Serial number: AUX7Z0K0FND0A1
   Coding: 0350078
   Shop #: WSC 93250 999 04781
   VCID: 7F0D69E32E6F45C608-802A
008449 - Throttle Valve Actuator Control System
               P2101 - 000 - Malfunction - Intermittent - MIL ON
                    Fault Status: 10100000
                    Fault Frequency: 10
                    Mileage: 100670 km
                    Date: 2016.01.16
                    Time: 08:44:54
                    RPM: 966 /min
                    Voltage: 13.60 V
                    Lambda: 99.4 %
                    Bin. Bits: 00000000
009315 - Diesel Particle Filter
               P2463 - 000 - Excessive Soot Accumulation - MIL ON
                    Fault Status: 11100000
                    Mileage: 100961 km
                    Date: 2016.01.16
                    Time: 17:52:59
                    RPM: 1357 /min
                    Speed: 57.0 km/h
                    Pressure: 18 mbar
                    Hex Value: 0xFF02
                    Temperature: 180.0°C
                    (no units): 122.4
                    Mileage: 730 km
Readiness: 1 2 0 0 1
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2705
   Revision: 05351112    Serial number: 00001012160043
   Shop #: WSC 06314 000 00000
   VCID: 173DA143261F9D86A0-8042
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 1150400F49220001880D02E6921B0042390800
   Shop #: WSC 38655 001 1048576
   VCID: 76E38CC7C155048E5B-8022
   Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
   Component: KlimavollautomatH09 0170
   Revision: 000800      Serial number: 8P0820043BN
   VCID: 79F987FB304B6BF636-802C
01273 - Fresh Air Blower (V2)
                    Fault Status: 00100011
                    Reset counter: 11
                    Mileage: 99775 km
                    Date: 2016.01.03
                    Time: 08:19:13
                    Temperature: -19.5°C
                    (no units): 133.0
                    (no units): 248.0
                    Fault Status: 00101110
                    Reset counter: 10
                    Mileage: 99775 km
                    Time: 15:22:48
Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
   Part No SW: 8P0 907 063 K    HW: 8P0 907 063 K
   Component: BCM PQ35  M   107 0615
   Revision: 00107 AF
   Coding: 6E000A0FA01336E4287041E10000054D400A60AA104DC128E40200800040
   VCID: 3C775EEFBFF99EDE6D-8068
   Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H11 0050
   Coding: 00DD13
   Subsystem 2 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
Address 15: Airbags (J234)       Labels: 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
   Component: Airbag AU1042 H07 0200
   Revision: --------    Serial number: 003FC001CU4Y
   Coding: 30314239304130303033554A304C38503053
   ROD: EV_Airba10AURB4.rod
   VCID: 50AF1A5F0B710ABEA1-8004
   Serial number: 357
   Serial number: 3582DRB40000D3C52AE3
   Serial number: 35128RB400005FFBFBBF
   Serial number: 35228RB400005F967A4W
   Serial number: 35547RB40000603538CH
   Serial number: 35647RB40000603538EK
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0010042
   VCID: 46833C073135D40E0B-8012
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
   Part No SW: 8P0 920 932 GX    HW: 8P0 920 932 GX
   Component: KOMBIINSTR. VDO H01 0091
   Revision: D0H01004    Serial number: 2253M004000238
   Coding: 0256378
   Shop #: WSC 17627 002 1048576
   VCID: 102FDA5F03F14ABEE1-8044
   Part No SW: 8P0 907 530 B    HW: 1K0 907 951
   Component: J533  Gateway H42 0311
   Revision:   H42       Serial number: 160111F1003234
   Coding: 352102
   VCID: 326B70D76DBD58AEB7-8066
   Revision: D0H01004    Serial number: AUX7Z0K0FND0A1
   Shop #: WSC 41863 001 1048576
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
   Component: Tuer-SG         H04 0101
   Coding: 0001205
   VCID: 4999373B202B3B76E6-801C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 232    3201
   Revision: 00H20000
   VCID: 346776CF57A9569EA5-8060
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158086746648
   VCID: 36634CC741D5448E9B-8062
   Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
   Coding: 0001205
   VCID: 4A9B0837252D306EEF-801E
Address 56: Radio        Labels: None
   Part No SW: 8P0 035 186 AC    HW: 8P0 035 186 AC
   Component: R Concert2+     H02 0293
   Revision: 00H02000    Serial number: AUZ1Z3K1267481
   Coding: 0110112
   VCID: 73E5B5D3122711A67C-8026
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0001168
   Shop #: WSC 06314 000 1012544
   VCID: 428B20171D1DE82E27-8016
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0001168
   VCID: 438525130207E1262C-8016
End-------------------------(Elapsed Time: 01:59)--------------------------
RobbieR
Canada
C?ID=268344
Hi Uwe,
Thanks for the quick response, I did give it a try. When you say "to much soot", I guess if the soot levels are above 45g which mine are indicating 50.1, then an emergence DPF regeneration won't preform correct?
Cheers,
Rob
Yep, that's a good possibility.
"Manual Remediation" with OVEN CLEANER and garden hose tail pipe enema.......collect the sludge and dispose of properly on drain back buckets.
RobbieR
Canada
C?ID=268344
Hi Folks,
The Ross Tech scan tool was helpful in recovering my DPF situation.
I would like to update that the exhaust gas flapper valve was telling me it wasn't happy with some squeaks and screams, so i removed it and with much effort was able to return it to it easy rotating self again.
I have some questions for the pro's here.
I read a very long post on the TDI club forum by TurboAbA and found my issue to be very similar to what was described in this thread. There was a very good question asked in his thread that was going to be asked here on the VCDS forum about being able to restore the Ash value to its prior value if the DPF was left on the car, I was wondering if someone may recall if it was answered and if so how does one go about accomplishing this ?
https://forums.tdiclub.com/showthread.php?t=395726
If your interested in the state of the exhaust valve video here -->
