Hi, I'm new. I did a cluster swap and amazingly it went mostly ok besides my ABS coding going to 0's. I had the old ABS coding and it was accepted. The only remaining issues are an immobilizer fault that wont clear despite all my keys working and what appears to be normally solved by basic settings for ESP.
When following the linked 1K instructions from the wiki I get module not available for the G200 and other sensors. Over 24 hours the steering angle sensor appears to now be happy. The yellow steering wheel light went out. Pressing the brake hard made the yellow ABS light blink and disappear. So I think the brake pressure sensor happy. However, the G200 lateral acceleration sensor still seems to not like itself. The yellow ESP light remains solid.
At first after the cluster swap the airbag light was solid yellow, steering wheel light was solid yellow, the ABS and ESP lights were blinking yellow, and the brake light was blinking red. Now I only have the solid yellow ESP light.
My questions: 1) How do I clear the immo fault? 2) How do I clear the ABS faults? 3) How do I perform the ESP basic settings on the 2010 JSW?
Here's the auto scan. Sorry for the extra spaces. I'm doing this on a mobile and Android's copy and paste seems to be extra-line-happy.
Thank you!
-Tom
Thank you!
-Tom
Sunday,24,January,2016,19:16:33:02479
VCDS Version: 15.7.3.0
Data version: 20151216
Dealer/Shop Name: TMH
Workshop Code: 001 00001 000001
VIN: 3VWPL7AJ6AM682903 License Plate:
Mileage: 81942 Repair Order:
Chassis Type: AJ (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 65 72 77
VIN: 3VWPL7AJ6AM682903 Mileage: 131860km-81934miles
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 CL HW: 03L 906 022 TS
Component: R4 2,0L EDC G000SG 9971
Revision: 12H03--- Serial number:
Coding: 0050072
Shop #: WSC 09446 444 85684
VCID: 77FD568706C4EB8640-8022
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B600C492A00FC881406E4921C0042300000
Shop #: WSC 00001 001 00001
VCID: 78FF55BBCBDAE4FE49-802C
Fault Status: 01100101
Reset counter: 219
Mileage: 131869 km
Date: 2010.06.16
Time: 19:05:51
Count: 3
Count: 2
Count: 12800
Count: 279
Count: 51200
Count: 512
Reset counter: 219
Mileage: 131869 km
Date: 2010.06.16
Time: 19:05:51
Count: 3
Count: 2
Count: 12800
Count: 295
Count: 51200
Count: 512
Reset counter: 219
Mileage: 131869 km
Date: 2010.06.16
Time: 19:05:51
Count: 3
Count: 2
Count: 12800
Count: 270
Count: 51200
Count: 512
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00148
ROD: EV_ClimaBasis_VW36.rod
VCID: 75E15C8FD4C8999652-8020
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
Component: BCM PQ35 B++ 111 0129
Revision: BI111001
Coding: 2D380E1A902F3EC480080081400000C401000086535D8560648020000000
VCID: 377D968786442B8680-8062
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 15041 21 0512
Coding: 009795
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4D0AKSX.
Coding: 00003044
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 397990BFB8503DF676-806C
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--00056Y9Q00
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME15454550ZZZM
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME4C22764EZZZ2
Serial number: 3511HSME6A0F3C20ZZZT
Serial number: 3521HSME2B355620ZZZG
Component: F.Sens.Fahr --- ----
Serial number: 35527SME05570921ZZZ5
Component: F.Sens.Beif --- ----
Serial number: 35627SME114C7320ZZZ7
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000532
VCID: 78FF55BB0BDAE4FE49-802C
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Part No SW: 5K0 920 970 Q HW: 5K0 920 970 Q
Component: KOMBI H13 0112
Revision: X0013004 Serial number:
Coding: 270F00
ASAM Dataset: EV_KombiUDSMM9RM10 A04102
ROD: EV_KombiUDSMM9RM10_VW36.rod
VCID: 3C7789ABB76208DE6D-8068
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 260310F2000875
Coding: E9807F07400602002002
VCID: 69D900FF40704D76C6-803C
Part No SW: 5K0 953 234 HW: 5K0 920 970 Q
Component: IMMO H13 0112
ASAM Dataset: EV_ImmoUDSMM9RM10 A01102
ROD: EV_ImmoUDSMM9RM10_SE25.rod
VCID: 6ADB7FF38D76466ECF-803E
9456896 - Incorrect Key Programming
B104D 00 [009] - -
Fault Frequency: 10
Reset counter: 218
Mileage: 102146 km
Date: 2014.06.21
Time: 00:00:01
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 C HW: 3C0 035 684 C
Component: RNS-MID H06 1140
Revision: AB001001 Serial number: VWZ6Z7K9081067
Coding: 040004000400008600
VCID: 234552D722DC57264C-8076
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000659533
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 275D46C75EE4BB0610-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004785599
Coding: 000490
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
VCID: 3169A89FA820F5B6CE-8064
000 - - - MIL ON
Fault Status: 11100000
Mileage: 131869 km
Date: 2010.06.16
Time: 19:09:28
Battery Volts: 14.1 V
DU
Temperature: 26.0°C
Count: 9
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0000667424
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 285F45FB53FAB47E19-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004778495
Coding: 000490
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Component: RDK 111 0821
Coding: 018705
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: USA 051 473 HW: USA 051 473
Component: TELEFON H15 3510
Revision: 1B001001 Serial number: 00007662963969
Coding: 0A00040000010100
Shop #: WSC 20158 444 999999
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 1D31642F0CB861D67A-8048
End
-------------------------(Elapsed Time: 03:00)--------------------------
