I'm trying to match remote controls following guide http://www.ross-tech.com/vag-com/cars/vw-remote-matching.html
I always clear all existing first, then do adaption in channel 01. I make sure key fob has new battery. I followed every very step... but still got 01179 fault code every time.
Is there any way in VCDS that I can check my CCM is actually working? Like is there +12 VDC power, aerial receiving signal etc. If no I have to remove lower dash panel and do some test there..
below is a full autoscan. any hint would be appreciated.
Sunday,24,January,2016,14:38:52:01079
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
Mileage: 69790km-43365mi Repair Order: 111
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
76
Mileage: 69790km-43365miles
Address 01: Engine Labels: 06A-906-019-AEH.lbl
Part No: 06A 906 019
Component: 1.6l R4/2V SIMOS HS2272
Coding: 04000
Shop #: WSC 01317
VCID: 60CFC690E047943E11-4AE8
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 D
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 01317
VCID: 326B7CD8FE2B56AEB7-4AE8
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 609
Component: A AIRBAG VW3 SG 0001
Coding: 00065
Shop #: WSC 01317
VCID: 6CD7A2A01C8FC05EBD-4AE8
Address 17: Instruments Labels: 1J0-919-xxx-17.lbl
Part No: 1J0 919 860 D
Component: A4-KOMBIINSTR. VDO V10
Coding: 00143
VCID: 306F76D0F02764BEC1-5140
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0V0223764
IMMO-IDENTNR: VWZ7Z0V0223764
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 5C Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 31480
VCID: 0407EA00141F281E55-4AE8
Subsystem 1 - Part No: 1J1959801A
Component: 01 Tõrsteuerger. FS0022F
Subsystem 2 - Part No: 1J1959802B
Component: 01 Tõrsteuerger. BF0022r
Subsystem 3 - Part No: 1J4959811C
Component: 03 Tõrsteuerger. HL0001H
Subsystem 4 - Part No: 1J4959812A
Component: 01 Tõrsteuerger. HR0022r
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
01179 - Incorrect Key Programming
35-00 - -
35-00 - -
End-------------------------(Elapsed Time: 05:25)--------------------------
