Results 1 to 6 of 6
Thread: 2015 Jetta Daytime Running Lights + Turn Signal
    Jan 2016
    Canada
    Question 2015 Jetta Daytime Running Lights + Turn Signal
    Hello All,
    When a turn signal is on, the corresponding DRL turns off. The car has factory Bi-Xenons.
    --> I want the DRL not to switch off when a turn light is activated.
    There are many how-tos out there, but they only cover the pre-2015 models.
    Please help me to do it on my car.
    Here is an old auto-scan:
    Sunday,18,October,2015,20:48:08:03993
    VCDS Version: 15.7.1.0 (x64)
    Data version: 20150904
    VIN: 3VWWA7AJ5FM318xxx   License Plate:
    Chassis Type: AJ (6N0)
    Scan: 01 03 05 08 09 15 17 19 25 2B 2E 44 55 56 77 0B
    VIN: 3VWWA7AJ5FM318805   Mileage: 8560km-5318miles
    Address 01: Engine (J623-CVCA)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 016 AJ    HW: 04L 907 309 K
       Component: R4 2,0L EDC   H20 8418
       Revision: 8AH20---
       Coding: 0119001A042410085000
       Shop #: WSC 49906 001 1048576
       ASAM Dataset: EV_ECM20TDI01104L906016AJ 001009
       ROD: EV_ECM20TDI01104L906016AJ.rod
       VCID: 71C70A56A0A683B6A2-8024
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Component: ESP MK60EC1   H46 0166
       Revision: 00H46001
       Coding: A14B400C49230002851302E4921E0042A1100010
       Shop #: WSC 00066 000 00000
       VCID: 042953828714861E79-8050
       Revision: 00092000    Serial number: 0357189963
       Coding: 000F0F
       Shop #: WSC 00066 000 00148
       ROD: EV_KESSYPQ35G.rod
       VCID: 3753F44E8E421D86AC-8062
       Part No SW: 1K8 907 044 E    HW: 1K8 907 044 E
       Component: Climatronic   H05 0102
       Revision: 00001K02
       Coding: 001000C002
       Shop #: WSC 00066 000 00121
       VCID: 3147CA566026C3B6E2-8064
    Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
       Part No SW: 7H0 937 090 E    HW: 7H0 937 090 A
       Component: BCM PQ25 Max3 H78 0725
       Revision: B8078001    Serial number: 78008054150656
       Coding: 7B994BBF082B0F00083820813E0A84CD5286760E608510D0B0A010022844
       Shop #: WSC 00066 123 12345
       VCID: 3041CF52632CCABEED-8064
       Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  006 5461
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  006 5461
       Coding: 820000
       Subsystem 3 - Part No: 5K0 959 591 A
       Component: J245 PS41.402  H02 0003
       Coding: 180000
       Subsystem 4 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
       Component: E221__MFL-TAT  H04 0019
       Coding: 280000
       Subsystem 5 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
       Component: J388__TSG_HL  006 5460
       Coding: 800000
       Subsystem 6 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Component: J389__TSG_HR  006 5460
       Coding: 800000
       Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
       Component: AirbagVW10    500 0975
       Serial number: 003LZD05PEL8
       Coding: 00004B4C
       Shop #: WSC 00066 790 00013
       ASAM Dataset: EV_AirbaVW10SMEVW360 001030
       VCID: 72C5055AA5A0B8AE5B-8026
       Component: BF-Gewichtss.  H10 0021
       Serial number: IBH0000J150002E72L0V
       Coding: 303144
       Serial number: 3572MSME48503C4CZZZ+
       Serial number: 3582MSME04523C4CZZZ-
       Serial number: 3516KSME3E4A7734ZZZ+
       Serial number: 3526KSME19507B34ZZZU
       Serial number: 3556LSME0F521332ZZZP
       Serial number: 3566LSME78431332ZZZQ
       Part No SW: 5C6 920 874 D    HW: 5C6 920 874 D
       Component: KOMBI         H05 0818
       Coding: 371E00
       VCID: 3041CF526B2CCABEED-8064
    Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
       Part No SW: 6N0 909 901     HW: 7H0 937 090 A
       Component: GW-K-CAN TP20 H78 0725
       Revision: B8078001
       Coding: 102200
       VCID: 70C10F52A3AC8ABEAD-8024
       Component: IMMO          H05 0818
       Coding: 000007
       VCID: 6AF51D3A8D70706EE3-803E
       Revision: 00000000    Serial number: 14000352376004
       Coding: 4100000000000000
       ROD: EV_ELVMarquMPVW36X.rod
    Address 2E: Media Player 3
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 306    3501
       Revision: 00H22000
       Shop #: WSC 02069 000 90108
       VCID: 3957F27670560BF65A-806C
    Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
       Coding: 081400010B000200
       Shop #: WSC 01383 790 50316
       ROD: EV_HeadlRegulVWAFSPt_SE36.rod
       Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0004
       Coding: 860000
       Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0004
       Coding: 860000
    Address 56: Radio (J503)       Labels: None
       Part No SW: 1K0 035 188 H    HW: 1K0 035 188 H
       Component: Radio Prem-8  H08 0009
       Revision: -----13S    Serial number: VWZ4Z7R3673400
       Coding: 21000440020006
       VCID: 2D7FD626741EA756C6-8078
                        Reset counter: 218
                        Mileage: 7266 km
                        Date: 2015.09.18
                        Time: 20:56:51
    Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
       Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
       Component: TELEFON       H07 0593
       Revision: 1B001001    Serial number: 00007666970942
       Coding: 0A10030080010110
       ROD: EV_UHVUMI.rod
       VCID: 3245C55A6520F8AE9B-8066
    End-------------------------(Elapsed Time: 02:28)--------------------------
    Jan 2016
    Canada
    Wow, nothing?
    Is this breaking new ground?
    I've seen it for pre-2015 models...
    In [09-Cent. Elect.] change Coding to:
    7B994BBF082B0F00083820813E0A84CD5286760E60851050B0A010022844
    Last edited by Uwe; 02-21-2016 at 09:42 AM. Reason: CODE tags to eliminate stupid space that forum SW puts in long coding strings
  4. Likes Uwe, jhs liked this post
    Jan 2016
    Canada
    Thank you NEtech!
    I am sort of hesitant to replace the whole module coding.
    Can you pinpoint the byte and bit numbers?
    Quote Originally Posted by jhs View Post
    Why, you can paste it below the original and see there is one bit changed.
    Byte 23, value 50 instead of D0
  7. Likes Uwe, jhs liked this post
    Jan 2016
    Canada
    You are right, I should have compared them.
    Many, Many Thanks NEtech!!!
    I did it and it works!
    How come it is known and yet not in the software?
    There are many other "blank" bits across the controller.
    Why aren't they available if they are known?
    Are they held in some sort of a secret?
    Cheers!
