Hello All,
When a turn signal is on, the corresponding DRL turns off. The car has factory Bi-Xenons.
--> I want the DRL not to switch off when a turn light is activated.
There are many how-tos out there, but they only cover the pre-2015 models.
Please help me to do it on my car.
Here is an old auto-scan:
Sunday,18,October,2015,20:48:08:03993
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: 3VWWA7AJ5FM318xxx License Plate:
Chassis Type: AJ (6N0)
Scan: 01 03 05 08 09 15 17 19 25 2B 2E 44 55 56 77 0B
VIN: 3VWWA7AJ5FM318805 Mileage: 8560km-5318miles
Address 01: Engine (J623-CVCA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 016 AJ HW: 04L 907 309 K
Component: R4 2,0L EDC H20 8418
Revision: 8AH20---
Coding: 0119001A042410085000
Shop #: WSC 49906 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906016AJ 001009
ROD: EV_ECM20TDI01104L906016AJ.rod
VCID: 71C70A56A0A683B6A2-8024
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C49230002851302E4921E0042A1100010
VCID: 042953828714861E79-8050
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Revision: 00092000 Serial number: 0357189963
Coding: 000F0F
Shop #: WSC 00066 000 00148
ROD: EV_KESSYPQ35G.rod
VCID: 3753F44E8E421D86AC-8062
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 1K8 907 044 E HW: 1K8 907 044 E
Component: Climatronic H05 0102
Revision: 00001K02
Coding: 001000C002
Shop #: WSC 00066 000 00121
VCID: 3147CA566026C3B6E2-8064
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 E HW: 7H0 937 090 A
Component: BCM PQ25 Max3 H78 0725
Revision: B8078001 Serial number: 78008054150656
Coding: 7B994BBF082B0F00083820813E0A84CD5286760E608510D0B0A010022844
Shop #: WSC 00066 123 12345
VCID: 3041CF52632CCABEED-8064
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Coding: 820000
Subsystem 3 - Part No: 5K0 959 591 A
Component: J245 PS41.402 H02 0003
Coding: 180000
Subsystem 4 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Component: E221__MFL-TAT H04 0019
Coding: 280000
Subsystem 5 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Coding: 800000
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD05PEL8
Coding: 00004B4C
Shop #: WSC 00066 790 00013
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 72C5055AA5A0B8AE5B-8026
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J150002E72L0V
Coding: 303144
Serial number: 3572MSME48503C4CZZZ+
Serial number: 3582MSME04523C4CZZZ-
Serial number: 3516KSME3E4A7734ZZZ+
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME19507B34ZZZU
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME0F521332ZZZP
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME78431332ZZZQ
Part No SW: 5C6 920 874 D HW: 5C6 920 874 D
Component: KOMBI H05 0818
Coding: 371E00
VCID: 3041CF526B2CCABEED-8064
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090 A
Component: GW-K-CAN TP20 H78 0725
Revision: B8078001
Coding: 102200
VCID: 70C10F52A3AC8ABEAD-8024
Component: IMMO H05 0818
Coding: 000007
VCID: 6AF51D3A8D70706EE3-803E
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000352376004
Coding: 4100000000000000
ROD: EV_ELVMarquMPVW36X.rod
Address 2E: Media Player 3
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 306 3501
Revision: 00H22000
VCID: 3957F27670560BF65A-806C
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 081400010B000200
Shop #: WSC 01383 790 50316
ROD: EV_HeadlRegulVWAFSPt_SE36.rod
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 860000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 860000
Address 56: Radio (J503) Labels: None
Part No SW: 1K0 035 188 H HW: 1K0 035 188 H
Component: Radio Prem-8 H08 0009
Revision: -----13S Serial number: VWZ4Z7R3673400
Coding: 21000440020006
VCID: 2D7FD626741EA756C6-8078
Reset counter: 218
Mileage: 7266 km
Date: 2015.09.18
Time: 20:56:51
Address 77: Telephone (J412) Labels: 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666970942
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 3245C55A6520F8AE9B-8066
End-------------------------(Elapsed Time: 02:28)--------------------------
