Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 88
Thread: Help TPMS DIRECT
  1. #61
    Jun 2015
    Italy
    i installed module 3aa907273d and doens work. then i installed module 3aa907273d and also this doesn t work. for theese reasons i think that the problem is tires sensors. what do you Think about?
  2. #62
    Jun 2015
    Italy
    Sorry. . Then I installed the 3aa907273H form and even this does not work .
  3. #63
    Mar 2015
    Quote Originally Posted by supremo View Post
    Mine is
    Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
    Part No SW: 3AA 907 273 F HW: 5Q0 907 273
    Component: RDKBERU30 H04 0011
    Serial number: 40000000034895
    ASAM Dataset: EV_RDKBERU30 005005
    ROD: EV_RDKBERU30_VW36.rod
    VCID: 377704618EC83B8680-8062
    I would disconnect it clear all codes plug it back up or the other module if you've sit got it and take it out for a spin for 15 to 30min mine took this long to come online i was worried thought i made an expensive mistake getting coloured clocks for TPMS but it worked in the end. You have enabled CanGateway Extension? As i sure you can't see it on VCDS without it.
  4. #64
    Jun 2015
    Italy
    My unit does not support coding Can Gateway Extension (7N0907530AQ)I replaced unit support with this (7N0907530AS)support coding Can Gateway Extension.I have a problem about Address 17: Instruments Incorrect software version ......
    Which version do i have to use? thank you for your answe.
  5. #65
    Jun 2015
    Italy
    sending scan
    Saturday,27,February,2016,11:27:32:37200
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    Dealer/Shop Name: casa
    VIN: WVGZZZ5NZFW528392   License Plate:
    Mileage: 20370km-12657mi   Repair Order:
    Chassis Type: 5N (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 1C 25 42 44 46 52 53 55 56 61 62
              65 72 77
    VIN: WVGZZZ5NZFW528392   Mileage: 20370km-12657miles
    Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 LE    HW: 03L 907 309 AE
       Component: R4 2,0L EDC   H28 6624
       Revision: 41H28---    Serial number: 00000000000000
       Coding: 00190032042401080000
       ASAM Dataset: EV_ECM20TDI01103L906018LE 003010
       ROD: EV_ECM20TDI01103L906018LE_VW36.rod
       VCID: 78F870D2C3421BFE46-802C
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
       Component: J104   C6 450M VD05 0021
       Revision: --H07---    Serial number: 00000008392044
       Coding: 0034107
       VCID: 78F870D20B421BFE46-802C
       Part No SW: 5K0 907 044 GJ    HW: 5K0 907 044 GJ
       Component: Climatronic   H19 1313
       Revision: 00001004
       Coding: 0010004003
       VCID: 79FE75D6F84802F639-802C
       Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
       Component: BCM PQ35 M    122 0174
       Revision: BC122001
       Coding: 66180A3BE825E1C4E8C800C0350009EC4BFDAB08477D81B0E48487000041
       VCID: 428CD23ADD1E812E28-8016
       Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B
       Component: WWS316 220714  24  0664
       Coding: 009795
       Component: RLS 250814 05  54  0403
       Coding: 062B4D
    Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
       Part No SW: 3AA 919 475 S    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0043
       Revision: --------    Serial number: 56201421200434
       Coding: 148203
       ASAM Dataset: EV_EPHVA2C000000000 002014
       ROD: EV_EPHVA2C000000000_SE36.rod
       VCID: 4B92FF1EE2544066DB-801E
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__20J VW10 HI   2518
       Revision: 28020000    Serial number: 003L7PFF6Y96
       Coding: 0012362
       VCID: 7CF06CC23F7A37DE22-8028
       Subsystem 1 - Serial number: 6332MTS651751924
       Subsystem 2 - Serial number: 6342MTS640201924
       Subsystem 3 - Serial number: 6351HTS6HCGC3DKR
       Subsystem 4 - Serial number: 6361HTS6AMVF3DKJ
       Part No SW: 5K0 953 501 DJ    HW: 5K0 953 569 AP
       Revision: FF010042    Serial number: 20140808300307
       Coding: 118A140000
       VCID: 75E679E6D45066965D-8020
       Component: E221__MFL-TAS  H31 0037
       Coding: 820000
       Part No SW: 5N0 920 883 E    HW: 5N0 920 883 E
       Component: KOMBI         H03 0705
       Coding: 111F00
       VCID: 3664BEEA89D62D8E94-8062
    10486016 - Control module
              B2001 00 [009] - Incorrect software version
                        Reset counter: 5
                        Mileage: 20374 km
                        Date: 2016.02.27
                        Time: 11:22:44
       Part No SW: 7N0 907 530 AS    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1653
       Revision:   H56       Serial number: 260415F1000033
       Coding: 356002
       VCID: 010E1D3698985A3671-8054
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         002 0002
       Revision: 00002000    Serial number: 1225223RNSRG07
       Shop #: WSC 00070 000 00000
       VCID: 7EF466CA296625CE0C-802A
       Component: IMMO          H03 0705
       VCID: 6ADC5A9A8DEEB96EC0-803E
       Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0503
       Revision: 12110009    Serial number: 0008953860
       Coding: 0214FE
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 397EB5D6B8C8C2F679-806C
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  009 1504
       Serial number: 00000008954642
       Coding: 0004D8
       Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.285 1401
       Revision: 1BH04841    Serial number: 00142090310301
       Coding: 0000258
       VCID: 418EDD3618189A3631-8014
       Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0503
       Revision: 14110009    Serial number: 0008986148
       Coding: 0215FE
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 3A7CAADABDCEC9EE70-806E
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  009 1504
       Serial number: 00000008951184
       Coding: 0004D0
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000000233251
       Coding: 0026167
       VCID: 3878B0D24BC2DBFE86-806C
    Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
       Component: AFS-ECU       H04 0111
       Coding: 049E00000B000000
       ROD: EV_HeadlRegulVWAFSPt_SE36.rod
       VCID: 377AB3EE8EDCD4868F-8062
       Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0010
       Coding: 140000
       Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 0010
       Coding: 140000
    Address 56: Radio
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Component: Batt.regelung H56 1653
       Coding: 030F185A
       VCID: 71EE4DF6A8384AB681-8024
       Component: J367-BDM  H07 0180
    Address 65: Tire Pressure (J502)       Labels: 1K0-937-08x-65.clb
       Component: RDK           122 0821
       Coding: 018704
                        Mileage: 20362 km
                        Date: 2016.02.27
                        Time: 10:27:40
    Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
       Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
       Component: Telefon       022 0982
       Revision: --------    Serial number: 35502105187235
       Coding: 040000000100000000000101
       ASAM Dataset: EV_UHVPremi 002709
       ROD: EV_UHVPremi_SE36.rod
       VCID: 244074A22F4AAF1E3A-8070
    9457427 - Left audio channel for speech/telephone
              B104F 13 [009] - Short to GND
                        Reset counter: 0
                        Mileage: 20255 km
                        Date: 2016.02.25
                        Time: 12:40:55
    9457171 - Right audio channel for speech/telephone
              B104E 13 [009] - Short to GND
                        Reset counter: 0
                        Mileage: 20255 km
                        Date: 2016.02.25
                        Time: 12:40:55
    End-------------------------(Elapsed Time: 03:06)--------------------------
  6. Likes Uwe liked this post
  7. #66
    Jun 2015
    Italy
    Jun 2015
    Italy
    [IMG][/IMG]
    My unit
    I replaced unit with this
  9. #68
    Nov 2014
    Quote Originally Posted by rado20vt View Post
    This is NOT correct, please read my explanation of how the generation 3 Huf system learns and positions the sensors.
    If the ECU only received a single sensor it would have no idea what wheel position the single sensor is because it does not have the other 3 sensors to compare the signals to. Every time the ignition is cycled the ECU will recheck the sensors in case the owner has swapped wheel positions or changed 1 or all the wheels.
    Supremo - Do you see the car with the dashes for pressures?
    If you believe that the sensors are dead you can send them to me (at bf1systems in the UK) and I can check them for you (although I will be out of the office from 10th - 19th Feb)
    I have had the system working with two sensors, when two others were a different part number which was not compatible
  10. #69
    Jun 2015
    Italy
    If the controller does not support activation of can extended the system will never go . . . .
  11. #70
    Jun 2015
    Italy
    I just replaced the wheel sensors with other new
