Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 88
Thread: Help TPMS DIRECT
  1. #21
    Jun 2015
    Italy
    I saw that ext canbus wiring diagrams supports TPMS . . . . . AFS . . . . driver assistance all together
  2. #22
    Jun 2015
    Italy
    United States
    Quote Originally Posted by supremo View Post
    The number of the receiver module 3aa907273H
    OK in that case you have more than one TPMS type enabled and that won't work. I would start with these steps:
    1) Make sure all Indirect TPMS configurations are disabled.
    • Remove Address 4C-Tire Pressure II from the GAN Gateway using the [Installation List] function.
    • Remove TPMS from the ABS module coding.
    Cycle the ignition, clear all fault codes and move onto #2.
    2) Make sure all Direct TPMS configurations are disabled.
    • Remove Address 65-Tire Pressure from the GAN Gateway using the [Installation List] function.
    • Remove the incorrect Direct TPMS type in Byte 8 of the BCM coding.
    Again, clear all codes, cycle the ignition and check the MFA/dash to make sure all TPMS menus and lights are gone.
    If you need assistance with suggested the modifications above please post the original condition Auto-Scan from this vehicle so we can see the factory condition. It doesn't matter if that scan isn't in English.
    After doing so you have 2 of the 3 total TPMS systems disabled and we should take a look at a new scan at that point to see if the 3AA 907 273 H controller is communicating or not.
  4. Likes Uwe liked this post
  5. #24
    Jun 2015
    Italy
    Auto scan with tpms 4c-65 off
    Chassis Type: 5N (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 1C 25 42 44 46 52 53 55 56 61 62
              72 77
    VIN: WVGZZZ5NZFW528392   Mileage: 18750km-11650miles
    Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 LE    HW: 03L 907 309 AE
       Component: R4 2,0L EDC   H28 6624
       Revision: 41H28---    Serial number: 00000000000000
       Coding: 00190032042401080000
       ASAM Dataset: EV_ECM20TDI01103L906018LE 003010
       ROD: EV_ECM20TDI01103L906018LE_VW36.rod
       VCID: 78F870D2C3421BFE49-802C
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
       Component: J104   C6 450M VD96 0021
       Revision: --H07---    Serial number: 00000008392044
       Coding: 0034107
       VCID: 78F870D20B421BFE49-802C
       Part No SW: 5K0 907 044 GJ    HW: 5K0 907 044 GJ
       Component: Climatronic   H19 1313
       Revision: 00001004
       Coding: 0010004003
       VCID: 79FE75D6F84802F636-802C
       Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
       Component: BCM PQ35 M    122 0174
       Revision: BC122001
       Coding: 66180A3BE825F3C468C800C0340089EC4BFDAB08477D81B0E48487000041
       VCID: 428CD23ADD1E812E27-8016
       Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B
       Component: WWS316 220714  24  0664
       Coding: 009795
       Component: RLS 250814 05  54  0403
       Coding: 062B4D
    Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
       Part No SW: 3AA 919 475 S    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0043
       Revision: --------    Serial number: 56201421200434
       Coding: 148203
       ASAM Dataset: EV_EPHVA2C000000000 002014
       ROD: EV_EPHVA2C000000000_SE36.rod
       VCID: 4B92FF1EE2544066D4-801E
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__20J VW10 HI   2518
       Revision: 28020000    Serial number: 003L7PFF6Y96
       Coding: 0012362
       VCID: 7CF06CC23F7A37DE2D-8028
       Subsystem 1 - Serial number: 6332MTS651751924
       Subsystem 2 - Serial number: 6342MTS640201924
       Subsystem 3 - Serial number: 6351HTS6HCGC3DKR
       Subsystem 4 - Serial number: 6361HTS6AMVF3DKJ
       Part No SW: 5K0 953 501 DJ    HW: 5K0 953 569 AP
       Revision: FF010042    Serial number: 20140808300307
       Coding: 118A140000
       VCID: 75E679E6D450669652-8020
       Component: E221__MFL-TAS  H31 0037
       Coding: 820000
       Part No SW: 5N0 920 883 E    HW: 5N0 920 883 E
       Component: KOMBI         H03 0705
       Coding: 111F00
       VCID: 3664BEEA89D62D8E9B-8062
       Part No SW: 7N0 907 530 AQ    HW: 7N0 907 530 AL
       Component: J533  Gateway H58 1653
       Revision:   H58       Serial number: 200714F1000622
       Coding: 356002
       VCID: 7F0A9BCEEE6C2CC608-802A
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         002 0002
       Revision: 00002000    Serial number: 1225223RNSRG07
       Shop #: WSC 00070 000 00000
       VCID: 7EF466CA296625CE03-802A
       Component: IMMO          H03 0705
       VCID: 6ADC5A9A8DEEB96ECF-803E
       Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0503
       Revision: 12110009    Serial number: 0008953860
       Coding: 0214FE
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 397EB5D6B8C8C2F676-806C
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  009 1504
       Serial number: 00000008954642
       Coding: 0004D8
       Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.285 1401
       Revision: 1BH04841    Serial number: 00142090310301
       Coding: 0000258
       VCID: 418EDD3618189A363E-8014
       Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0503
       Revision: 14110009    Serial number: 0008986148
       Coding: 0215FE
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 3A7CAADABDCEC9EE7F-806E
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  009 1504
       Serial number: 00000008951184
       Coding: 0004D0
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000000233251
       Coding: 0026167
       VCID: 3878B0D24BC2DBFE89-806C
    Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
       Component: AFS-ECU       H04 0111
       Coding: 049200000F000000
       ROD: EV_HeadlRegulVWAFSPt_SE36.rod
       VCID: 377AB3EE8EDCD48680-8062
       Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0010
       Coding: 140000
       Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 0010
       Coding: 140000
    Address 56: Radio
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
       Component: Batt.regelung H58 1653
       Coding: 030F185A
       VCID: 71EE4DF6A8384AB68E-8024
       Component: J367-BDM  H07 0180
    Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
       Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
       Component: Telefon       022 0982
       Revision: --------    Serial number: 35502105187235
       Coding: 040000000100000000000101
       ASAM Dataset: EV_UHVPremi 002709
       ROD: EV_UHVPremi_SE36.rod
       VCID: 244074A22F4AAF1E35-8070
    9457427 - Left audio channel for speech/telephone
              B104F 13 [009] - Short to GND
                        Reset counter: 86
                        Mileage: 17556 km
                        Date: 2016.01.07
                        Time: 19:00:32
    9457171 - Right audio channel for speech/telephone
              B104E 13 [009] - Short to GND
                        Reset counter: 86
                        Mileage: 17556 km
                        Date: 2016.01.07
                        Time: 19:00:32
    End-------------------------(Elapsed Time: 03:07)--------------------------
  6. #25
    Jun 2015
    Italy
    Automatic scanning with 65 active TPMS
              65 72 77
       Coding: 0034107
       Revision: 00001004
       Coding: 0010004003
       Revision: BC122001
       Coding: 66180A3BE825F3C4E8C800C0340089EC4BFDAB08477D81B0E48487000041
       Coding: 009795
       Coding: 062B4D
       Coding: 148203
       Coding: 0012362
       Coding: 118A140000
       Coding: 820000
       Coding: 111F01
       Coding: 356002
       Coding: 0214FE
       Slave Driver:
       Coding: 0004D8
       Coding: 0000258
       Coding: 0215FE
       Slave Passenger:
       Coding: 0004D0
       Coding: 0026167
       Coding: 140000
       Coding: 140000
    Address 56: Radio
       Coding: 030F185A
    Address 65: Tire Pressure (J502)       Labels: 1K0-937-08x-65.clb
       Component: RDK           122 0821
       Coding: 018704
                        Mileage: 18759 km
                        Date: 2016.01.30
                        Time: 11:21:46
                        Reset counter: 86
                        Mileage: 17556 km
                        Date: 2016.01.07
                        Time: 19:00:32
                        Reset counter: 86
                        Mileage: 17556 km
                        Date: 2016.01.07
                        Time: 19:00:32
  7. #26
    Jun 2015
    Italy
    I would like to understand on thing. if module 65 doesnt communicate with wheel sensors, could we see or not the graphic on MFA? thank you or the answer
  8. #27
    Mar 2015
    Module 65 shuts down if no sensors are detected and no you won't see the graphics if it has shut down, PS you can have virtual TPMS working with it as well their is no adverse effect on the direct TPMS.
  9. #28
    Dec 2015
    Have you activated the TPMS in the cluster coding and did the cluster accept the coding and read back corretly ?
    I am trying to do the same but my cluster (2010 Golf 6R), despite showing a message saying coding accepted, when I read the coding back the TPMS is not activated on the cluster.
    Quote Originally Posted by Dazza View Post
    Are you sure about that ? If the sensors are not working (not present) then the ECU must indicate a fault by legislation FMVSS 138 and R64
  10. #29
    Mar 2015
    Quote Originally Posted by rado20vt View Post
    If the sensors are fitted after the module was fitted it would be shut down and won't display anything it requires a 15 to 30min drive with the sensors< Note the MFD needs to support Direct TPMS and will automatically display, no coding needed for that. I had to change my MFD to get direct TPMS as it would't display at all with my white MFD, hope that helps, Supremo's TPMS is showing sensor fault also so that is poss the reason why its showing display is also a pos but seen as i only know the Tiguans display i can only comment on that it requires the new 2012 and above display to work. But when i had my 2011 white display no warnings where displayed.
    Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
    Part No SW: 3AA 907 273 F HW: 5Q0 907 273
    Component: RDKBERU30 H04 0011
    Serial number: 40000000034895
    ASAM Dataset: EV_RDKBERU30 005005
    ROD: EV_RDKBERU30_VW36.rod
    VCID: 377704618EC83B8680-8062
  11. #30
    Dec 2015
    I cannot comment on the MFD other than mine has a coding setting which I assumed was for displaying the TPMS page, but as it would not accept the coding I guess I need a newer MFD. I would be interested to know if that is correct and if it is possible to update the firmware in the MFD to a version that will display the TPMS.
    Supremo's TPMS is showing sensor fault also,
    I must be reading that wrong, the ECU has no faults so where are you seeing the sensor fault ?
    This is a common misconception, Just for information the part numbers stated are for the huf generation 3 TPMS which works to recognise, position and display the tyre pressures within 50 seconds, although it can take longer depending on the drive cycle.
    This system works by:
    The Antenna and ECU are in the same case unlike previous BERU/Huf systems which had separate antenna and ECU's (and LF triggers)
    The wheel sensors contain a bi-directional accelerometer which gets set one way for the left side and the other way when on the right side, the direction is transmitted to the ECU so it can determine which side the sensors are fitted.
    The ECU then looks at the signal strength of the RF signal transmitted from the sensors, the stronger pair of sensors will be closer to the ECU so if the ECU is fitted at the rear the rear sensors signal strength will be higher than the front sensors,
    these 2 pieces of information allow the ECU to position the sensors.
    When the car starts moving above approx.15kph the sensors start to transmit what is known as a 'burst' which is 20 RF datagrams at 2 second intervals so the ECU can quickly gather the information required to position the sensors. After the burst has completed the sensors revert to the standard 30 second transmission interval.
    If the ECU has failed to determine the positions during the burst period, it can continue to learn from the 30 second transmissions but it takes longer (can be up to 4 minutes if during continuous driving above 15kph).
    When the car stops moving, the sensors will continue to transmit at 30 second intervals for 4 minutes before stopping transmissions. If the car starts moving within the 4 minutes the sensors will resume the 30 second transmission rate but if the car is stationary for more than 4 minutes the sensors will enter the burst state again when they start moving.
    Each time the ECU is power cycled it will need to go through this process to confirm the sensors fitted or re-learn if a new sensor is fitted.
    The only time the ECU will shut down is when the ignition is switched off, if the ECU will display dashes on the display until the sensor positions are confirmed/learnt, if the ECU fails to receive one or all sensors it will fail to learn and put the warning lamp on.
    For anyone retrofitting one of these specific TPMS systems it is important to position the ECU correctly otherwise the ECU may not determine a difference in the front to rear RF signal strength.
    Hope this is helpful.
  12. Likes Uwe liked this post
