Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 88
Thread: Help TPMS DIRECT
    Jun 2015
    Italy
    number of sensor TPMS 3aa907275b
  2. #12
    Jun 2015
    Italy
    I purchased the gateway7N0907530ASm waiting to arrive then I'll let you know
  3. #13
    Mar 2015
    What vehicle do you have as i added it to my Tiguan 2011 R Line and it required coloured MFD, TPMS Module and sensors, as well as an updated CAN Gate to get it to work.
  4. Likes Dana liked this post
  5. #14
    Verified VCDS User prako's Avatar
    Sep 2014
    Zagreb Cro
    I think that your current Gateway support TPMS, it support ExtCan-Bus, i see on log that your AFS module is on ExtCan-Bus, otherwise Gateway would not able to se TPMS control unit!
    Oct Wag CRDPFRS l4125
  6. #15
    Mar 2015
    Have you got the TPMS sensors? If not the module switches off then you have to do a 15 to 30min drive with the sensors fitted before the TPMS module activates again.
  7. #16
    Jun 2015
    Italy
    My vehicle is a tigusn 2014 mfa colorful 3d
  8. #17
    Jun 2015
    Italy
    Since my former Can Bus and occupied by the module AFS what can I do ? If I change the gateway module change something or do not solve anything ?
  9. #18
    United States
    I'm not entirely sure if those 3AA TPMS sensors are going to work. Based on the BCM and TPMS part numbers (5K0 937 086 Q) it looks like you tweaked the coding in address 09 to enable 65-TPMS but most RoW market Tiguans with factory direct TPMS would have had a separate 3AA-907-273-? module installed which supports wheel position recognition.
    The Golf based BCM tweak usually requires 1K0 Golf based TPMS sensors and the system does not have wheel position recognition.
    Hopefully someone can correct me if I'm wrong but the VW CC is the only car from this time frame sold in the US with 3AA TPMS. The Tiguan US market switched to ABS based indirect in 2011.
  10. #19
    United States
    I read your initial post again and you called the TPMS system Highline so let us know if a separate TPMS module was installed. If so, the full part number would be helpful.
  11. #20
    Jun 2015
    Italy
    The number of the receiver module 3aa907273H
