Hello
Old passat with a lot of new stuff.
But for some reason I'm not able to code the module. I do not think the EOL would be problem, because I've coded modules before with this fault.
Does the module need somesort of Sec.Access code before accepting coding?
Sunday,05,June,2016,18:04:21:01666
VCDS Version: 16.5.1.3 (x64)
Data version: 20160524 DS251
Dealer/Shop Name: Automart O
VIN: WVWZZZ3CZ7P   License Plate: TIIT 1K8 CAM
Mileage: 174280km-108292mi   Repair Order:
Chassis Type: 3C (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 3C 42 44 46 4F 52 53 5F 61
          62 65 69 6C 72
VIN: WVWZZZ3CZ7P   Mileage: 174280km-108292miles
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 021 LR    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000SG  9248
   Revision: --H06---    Serial number: VWZCZ000000000
   Coding: 0000071
   Shop #: WSC 00028 028 00001
   VCID: 7AFB00AD35D9DB93CC-802E
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --025---    Serial number: 00000795617532
   Coding: 0002305
   Shop #: WSC 12345 123 21345
   VCID: 62CB58CDBD493353F4-8036
   Part No SW: 3AA 907 044 AJ    HW: 3AA 907 044 AJ
   Component: Climatronic   H03 0404
   Revision: 00001K02
   Coding: 001900C002
   Shop #: WSC 12345 123 12345
   VCID: 78FF1AA5C3D5C983BA-802C
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 A    HW: 3AA 937 087 A
   Component: BCM PQ47 H    413 0452
   Revision: BB413001
   Coding: 000800000000000000980080A500028C47F0698855208120E40820200001
   VCID: 387FDAA58B5509837A-806C
   Subsystem 1 - Part No SW: 3C1 955 419 A    HW: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 28110  03  0205
   Coding: 00BF95
   Component: RLS 110213 05  54  0403
   Coding: 8F9028
                    Reset counter: 57
                    Mileage: 174286 km
                    Date: 2016.06.05
                    Time: 17:53:49
                        Term 15 On
                    Voltage: 11.70 V
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 1K8 919 472 A    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0477
   Revision: --------    Serial number: 39391433101285
   Coding: 0031153101
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_EPHVA18VW364GP00 001006
   ROD: EV_EPHVA18VW364GP00.rod
   VCID: 3561D3919447F4EB61-8060
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 0B AIRBAG VW8   031 2522
   Revision: 11031000    Serial number: 003B1P160ZJF
   Coding: 0012354
   VCID: 306FE285A325D1C332-8064
   Subsystem 1 - Serial number: 6332MSME15315C29
   Subsystem 2 - Serial number: 6342MSME16386566
   Subsystem 3 - Serial number: 6351HTS6GIE0EA77
   Subsystem 4 - Serial number: 6361HTS6GIEKAJ77
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AH    HW: 3C0 953 549 AH
   Component: J0527               0030
   Revision: 00035000    Serial number: 3C0953507
   Coding: 0200711
   VCID: 72EB288D6DA9A3D384-8026
   Subsystem 1 - Part No: 3C8 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H1˙ 0020
   Coding: 00000227
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C8 920 880 T    HW: 3C8 920 880 T
   Component: KOMBI         X02 X002
   Coding: 160F010000
   Shop #: WSC 00001 001 104857
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 3D71CBB1AC772CABA9-8068
12851456 - Implausible Data Received from Steering Effort Control Module
          U0419 00 [009] - -
                    Reset counter: 57
                    Mileage: 174286 km
                    Date: 2016.06.05
                    Time: 17:53:47
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 5K0 963 272 A
   Component: Standheizer     043 4707
   Revision: 00043000    Serial number: 09016748000000
   Coding: 0021012
   VCID: 2E53FCFDB911C73320-807A
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1663
   Revision:   H56       Serial number: 270314F2002662
   Coding: 461006
   VCID: 72EB288DADA9A3D384-8026
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         042 0399
   Shop #: WSC 00857 461 999999
   VCID: 76E3149D01C1BFF3A8-8022
Address 3C: Lane Change        Labels: None
   Part No SW: 3AA 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0030
   Revision: 00H02000    Serial number: 6PZ 010 316-09
   Coding: 0010171
   Shop #: WSC 12345 123 45725
   VCID: 3A7BC0AD75591B938C-806E
   Subsystem 1 - Part No: 3AA 907 568 D
   Component: J770  SWA Slave H02 0030
   Subsystem 2 - Serial number: 6PZ 010 316-29
   Subsystem 3 - Serial number: 5F24.03.1400H02000AMS15170˙
   Subsystem 4 - Serial number: S15170˙
02850 - Control Module 2 for Lane Change Assistance (J770)
                    Fault Status: 01100101
                    Reset counter: 57
                    Mileage: 174286 km
                    Date: 2013.01.01
                    Time: 00:00:00
02849 - Control Module for Lane Change Assistance (J769)
                    Reset counter: 57
                    Mileage: 174286 km
                    Date: 2013.01.01
                    Time: 00:00:00
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0002932146
   Coding: 0011F7
   ROD: EV_TSGFPQ35BRFVW46X.rod
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388__TSG-HL  006 1118
   Serial number: 00000001227586
   Coding: 0000D0
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.134 H07 1806
   VCID: 3467EE95573DEDE356-8060
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 042 0631
   Coding: 18910A000186403F0002951570088F0B607C40
Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
   Component: EZE_2         H56 1663
   Coding: 00000008
   VCID: 6FED21F9BE9B8E3B6B-803A
   Subsystem 1 - Part No SW: 3AD 919 204 A    HW: 3AD 919 204 A
   Component: Analoguhr  003 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0002929027
   Coding: 0011F6
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3663D49D8941FFF368-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389__TSG-HR  006 1118
   Serial number: 00000001266367
   Coding: 000050
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   010       Serial number: 00000000248059
   Coding: 0000057
   VCID: 2C57F6F58F0DB5230E-8078
   Part No SW: 5C0 035 680 B    HW: 5C0 035 680 B
   Component: MU-S-N-ER     H22 0245
   Serial number: VWZAZ2S8218590
   Coding: 02140101FF00000001110001000808001F010084002001008F
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 204F12C53BC56143A2-8074
   Subsystem 1 - Part No SW: 3G0 919 866 M    HW: -----------
   Component: ECE 2016  --- 0521
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [009] - Missing message
                    Reset counter: 57
                    Mileage: 174286 km
                    Date: 2016.06.05
                    Time: 17:56:55
                    Voltage terminal 30: 11.5 V
                    System_Software_Error-SW_Status_Consistency: 01 04 00
                    System_Software_Error-SW_Status_Device:
1552 - Expanded Bus Activity Active
          U1104 00 [009] - -
                    Reset counter: 57
                    Mileage: 174286 km
                    Date: 2016.06.05
                    Time: 17:56:12
                    Voltage terminal 30: 11.6 V
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AN
   Component: Batt.regelung H56 1663
   Coding: 020E185A
   VCID: 71E92781A8AF98CB7D-8024
   Component: J367-BDM  H07 0180
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000179043
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_VW36.rod
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0050
   Revision: 3A002002    Serial number: 00000113173491
   Coding: 0100000100000000
   Shop #: WSC 01316 785 00200
   VCID: 2F6DE1F97E1BCE3B2B-807A
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 000000000000000000
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 306FE2856B25D1C332-8064
10490624 - No End-of-Line Programming
             B2013 00 [009] -  -
                    Reset counter: 57
                    Mileage: 174286 km
                    Date: 2016.06.05
                    Time: 17:44:36
13636352 - Control module not coded
             U1013 00 [009] - -
                    Reset counter: 57
                    Mileage: 174286 km
                    Date: 2016.06.05
                    Time: 17:44:36
10489856 - No Basic Setting
             B2010 00 [009] -  -
                    Reset counter: 57
                    Mileage: 174286 km
                    Date: 2016.06.05
                    Time: 17:44:36
End-------------------------(Elapsed Time: 03:18)--------------------------
