Results 1 to 2 of 2
Thread: Output Test problem 09 central electrics
    I hope that this is not considered a repeat posting but I thought that I should post in the correct forum the problems that I am having whilst using the lastest beta for output test on 09 central electrics to try to find the cause of a "vehicle lighting" fault.
    Initially I could not get output test to work but have now found that the "actions" are reversed. If the action is set to "on" the output is actually turned off and vica versa. Also for most, if not all, of the car front lights there is only one entry in the list eg "Fog light" which is actually "Left fog light". There are no entries for the right lights. I can only work the front left high beam, low beam & fog light but none of the right as they are not in the list. A full scan is below to give the car details.
    Thursday,08,May,2014,13:41:44:62831
    VCDS Version: 14.5.0.0
    Data version: 20140501
    VIN: TMBKJ7NE2E0017506   License Plate:
    Mileage: 8272km-5139mi   Repair Order:
    Chassis Type: NE (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 20 42 44 52 5F
    VIN: TMBKJ7NE2E0017506   Mileage: 8272km-5139miles
    Address 01: Engine (J623-CKFC)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H22 5514
       Revision: 83H22---
       Coding: 11190012032501090000
       Shop #: WSC 73430 031 00209
       ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
       ROD: EV_ECM20TDI01104L906021DS_SK37.rod
       VCID: F9F3F534782CBDF360-80AC
       Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
       Component: EMB8 EHCB     H31 0356
       Revision: 00000000    Serial number: 615330000000DE
       Coding: 1C078A9124210973007C060041C9243851249000608224F000630070C002
       Shop #: WSC 73430 031 00063
       ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
       VCID: CB9F7FFC6230FF6382-809E
       Part No SW: 5E0 907 044 C    HW: 5E0 907 044 C
       Component: Climatronic   H02 0604
       Revision: 00001K06
       Coding: 02110104000100011005000100100000
       Shop #: WSC 73430 031 00000
       ROD: EV_ACClimaBHBVW37X_SK37.rod
       VCID: A54BE944A414E91374-80F0
       Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
       Component: BCM MQBAB H   H14 0112
       Serial number: 00011315000690
       Coding: 0F000966424702FB07A04082B11C07280000000000000000000000000000
       Shop #: WSC 73430 790 00000
       ROD: EV_BCMBOSCH_SK37.rod
       VCID: F7F7F30C4E38AB8316-80A2
       Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119
       Component: WWS371 130514  041 0570
       Serial number:         130523105227
       Coding: 065DDD
       Component: RLFS  024 0042
       Serial number: Y13M06D11H03M25S31S1
       Coding: 02805D
       Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Component: Sensor, DWA  005 0313
       Serial number: 000000000ZY131002FPU
       Serial number: 00000000000056886695
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H09 0033
       Revision: --------    Serial number: 60831313600748
       Coding: 0001050001
       ASAM Dataset: EV_EPHVA14AU3700000 002018
       ROD: EV_EPHVA14AU3700000_AU37.rod
       VCID: B875303003A664FBDF-80ED
       Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
       Component: Airbag VW20   011 0188
       Revision: --------    Serial number: 003P4PBG1XQF
       Coding: 98CCC000000000005C5400CC008800000065
       Shop #: WSC 73430 790 00209
       ROD: EV_AirbaVW20TS6VW48X_SK37.rod
       VCID: FF071B2C660893C35E-80AA
       Subsystem 1 - Part No SW: -----------    HW: 454 002 105 13
       Serial number: 3576U0000002C84CBC0Q
       Subsystem 2 - Part No SW: -----------    HW: 454 002 405 13
       Serial number: 3586U0000009A25CBC0R
       Subsystem 3 - Part No SW: -----------    HW: 454 801 505 13
       Serial number: 3516RFC8356010000006
       Subsystem 4 - Part No SW: -----------    HW: 454 801 505 13
       Serial number: 3526RE3815601000000
       Subsystem 5 - Part No SW: -----------    HW: 454 802 303 13
       Serial number: 3556VB5355300000000$
       Part No SW: 5Q0 953 507 AC    HW: 5Q0 953 549
       Revision: --------    Serial number: 07061304221522
       Coding: 1400
       ROD: EV_SMLSKLOMQB_SE37.rod
       Part No SW: 5E0 920 971 D    HW: 5E0 920 971 D
       Component: KOMBI         333 2210
       Coding: 27A40A002180A60001086A00000000
       ROD: EV_DashBoardVDDMQBAB_SK37.rod
       VCID: AA511A78CD0AC66B59-80FF
       Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1144
       Revision: --------    Serial number: 0000656970
       Coding: 030100040B087300EF000648080F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 009013
       ROD: EV_GatewLear_AU37.rod
       VCID: BB7F2F3C32904FE332-80EE
       Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
       Component: E221__MFL-PR6  H04 0120
       Serial number: 000000000A0331270513
       Serial number: 2020930603
       Part No SW: 5G0 857 511 D    HW: 5G0 857 511
       Component: FLA           H04 0002
       Revision: AA001001
       Coding: 01028F6B74745D545420363E00
       VCID: AB5F1F7CC2F0DF63A2-80FE
       Part No SW: 5Q4 959 593     HW: 5Q4 959 593
       Component: TSG FS        007 0006
       Serial number: 0000064267946
       Coding: 00150020D001020000001100
       ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
       VCID: 820192D815FAFE2B31-80D7
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
       Component: FOND_FHSG_DRV  005 0004
       Serial number: 00000000000000259164
       Coding: 1D0200
       Coding: 81
       ROD: EV_SteerAssisMQB.rod
       VCID: BD7B21242C8441D30C-80E8
       Part No SW: 5Q4 959 592     HW: 5Q4 959 592
       Component: TSG BFS       007 0006
       Serial number: 0000064351274
       ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
       VCID: 81039DD410FCE53328-80D4
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
       Component: FOND_FHSG_PSG  005 0004
       Serial number: 00000000000000255216
       Coding: 050200
       Part No SW: 5E0 035 874 A    HW: 5E0 035 874 A
       Component: MU-S-ND-ER    040 0407
       Serial number: S7F00606130468
       Coding: 03730201FF0000001111120100A800002F0000860100010046
       ROD: EV_MUStd4CPASE_SE37.rod
       VCID: A649EE48D912E20B7D-80F3
       Media Player Position 1:
       Subsystem 1 - Part No SW: 5E0 919 605 D    HW: 5E0 919 605 D
       Component: ABT_Std_Nav  H50 0022
       Serial number: SKZ8Z9NK80008J
       Engine Control Module 2:
       Subsystem 2 - Part No SW: 5E0 051 236 C    HW: -----------
       Component:  ECE 2014  --- 0036
    I'm not ready to accept that this is a problem with VCDS. See my reply here.
