Results 1 to 10 of 20
Thread: MQB Platform tweaks
    Verified VCDS User andyvee's Avatar
    Rossendale, Lancashire, UK
    MQB Platform tweaks
    All,
    I have a thread running on Briskoda.net for MQB platform tweaks, the ones on Briskoda have been tried and tested on the Octavia III (5E).
    You can find the thread here
    http://www.briskoda.net/forums/topic...ed-and-tested/
    If anyone has anything further to add PM me with details.
    Another good resource (use Google Translate) is
    http://www.stemei.de/pages/coding/vw-golf-7.php
    http://www.stemei.de/pages/coding/seat-leon-5f.php
    http://www.stemei.de/pages/coding/sk...via-iii-5e.php
    Along with
    http://www.golfgtiforum.co.uk/index.php?topic=260248.0
    And with beta 14.6 Rain closing can now be enabled!
  3. Likes Santos, Eric, ertromp, mikeholroyd liked this post
    Has anyone found anything that enables the heated windscreen to automatically turn on below a certain temperature?
    I have seen this option on the infotainment on 2014MY cars with a heated front windscreen, mine is a 2013MY and doesn't have this menu option.
    I can't find a coding or adaptation difference yet that enables this, I am slowly coming to the conclusion that it is software version dependent.
    Apr 2015
    Hong Kong
    i cant found "Rain closing" on S3 8V , any idea? RLFS is empty, even under beta 15.3 ..... any idea ?
    Administrator Andy's Avatar
    Sector 7G
    I've sent people to this handy page (and used it myself) for enabling remote windows in mk7's:
    http://shopdap.com/mk7-gti-remote-wi...o-code-vagcom/
    Keeping the DRL's on with turn signals:
    http://forums.vwvortex.com/showthrea...1#post86453331
    I've added an index to this now
    Index
    How to capture an adaptation channel map
    Enable cornering fogs (inc. vRS)
    Enabling both rear fog lights
    Enabling boot closing from the interior button and keyfob on Combi models with powered tailgate
    Enabling rear teardrop wipe
    Enable rain closing (MY13 and MY14 only)
    Enable refuel quantity in Maxidot
    Enable laptimer in Maxidot
    Enable needle staging (sweep) on Maxidot
    Enable traffic sign recognition
    Enable passenger mirror dip on selecting reverse
    Enable rear lights with DRLs
    Enabling DRLs only on AUTO
    Change the number of flashes for the comfort (lane change) indicator
    Change the upper speed threshold for cornering fogs
    Foglights as CH/LH
    Foglights as DRLs
    Enabling speed limit signs from map data on Columbus
    Enabling fan speed display in AUTO mode
    Heated seat level memory
    MIB Columbus VIM
    Permanently disable Start/Stop
    Various xpower lighting tweaks – LED number plate, DRL LED dimming on indicate, DRL dim on low beam but not sidelight
    LED Fog Light coding
    DRLs flash out of phase with indicators
    DRLs flash in phase with indicators
    Various hravec adaptations – sensitivity of humidity sensor, deactivate AM band, comfort entry for electric seats
    Enabling high beam assist to stay enabled permanently
    Number plate LED coding
    Retro fit footwell lights
    Disable DRLs on Halogen headlights
    Towbar electrics coding
    Enable automatic daylight saving time on Columbus & Amundsen
    Enable direct CD ripping to Columbus jukebox
    Retro fit OEM LED rear lights
    Enable trunk lid lock delay
    LED sidelight bulb coding for Xenons
  8. Likes Uwe, Datatekniker, Nutty 5.0 liked this post
    Verified VCDS User rojas's Avatar
    Sep 2014
    Spain
    thanks friend . I have almost all in my seat leon 5F
  10. #8
    Sep 2014
    Spain
    I want to retrofit heated seats, but I am unclear if they are connected to the BCM or elsewhere.
  11. #9
    Quote Originally Posted by rojas View Post
    rojas: Yes, all the wiring for seat heating is taken to/from the BCM and there is a bunch of adaptation channels in the control module for this facility (there is also a coding change that needs to be done to J519). VW has kindly provided a specific section of the wiring diagram for "seat heating", so it's a good idea (IMO) to check-out the WD before you launch into the project!
    PS: I kind-of lied when I said that ALL the wiring goes to the BCM. There are two wires that are needed between the BCM and the climatronic/heater control module to operate the seat heater buttons and the lamp
  12. #10
    Sep 2014
    Spain
    thank you very much, where I can get these documents? . Some things do not quite understand the language, sometimes the translator is not very precise and makes funny moves.
    I have wiring diagrams, but the thermosensor , I not have unclear where is located
