Hi
Looking for some help with this one. Got a 2012 Polo 6R been accident repaired.
Some of the fuses on top of the battery were blown (not sure if this was caused during accident or during repair ) . All replaced and no comms with ABS module, internal fault in control unit maybe from fuses blowing ??
Replaced unit with a second hand one with all matching part no's.
Full communication now but needs long coding (just show's 00000000000000000) hoping somebody might be able to save the day and get the correct code?
Have a feeling the dealers will only want to work with a new ABS Module
Thursday,21,January,2016,11:25:44:26527
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WVWZZZ6RZCU078053 License Plate: LG62GBO
Mileage: 83060km-51611mi Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZCU078053 Mileage: 83060km-51611miles
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 CN HW: 03C 906 024 BH
Component: CGGB MM4HV 8994
Revision: --H09--- Serial number: 00000000000000
Coding: 0000071
Shop #: WSC 31414 790 31414
VCID: 6CD7C0964CEC685EBD-515C
Readiness: 0110 0001
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
VCID: 000F842697649C3E71-8054
Reset counter: 231
Mileage: 83069 km
Date: 2016.01.21
Time: 19:43:04
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3013
Hex Value: 0x1491
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Status: 01100101
Reset counter: 231
Mileage: 83069 km
Date: 2016.01.21
Time: 19:43:04
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3051
Hex Value: 0x1B91
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
Reset counter: 231
Mileage: 83069 km
Date: 2016.01.21
Time: 19:43:04
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x30E1
Hex Value: 0x2091
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
03306 - Coding Not Valid
Reset counter: 15
Mileage: 83069 km
Date: 2016.01.21
Time: 19:49:08
Hex Value: 0x0003
Hex Value: 0x0002
Hex Value: 0x32E7
Hex Value: 0x25B1
Hex Value: 0x00FF
Hex Value: 0x7F85
Hex Value: 0x84F8
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 397929C2B03E0DF676-806C
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 126123931
Coding: 24B02BBF08A10000003008002D2B0CD00040410F60060000200000000000
VCID: 45815532CCC6791602-8010
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1611
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 18BC32
Subsystem 4 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 18BC32
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag027 H10 0020
Revision: -------- Serial number: 003GX017FKJS
Coding: 003237
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4A9B660EEDD8966EEF-801E
Serial number: 3575HRB404V18NQQ91KD
Serial number: 3585HRB404V1BEPUDOI-
Serial number: 3515RRB405D15N42H1C.
Serial number: 3525RRB406717ABUJ1IM
Part No SW: 6R0 920 960 H HW: 6R0 920 960 H
Component: KOMBI H03 0505
Coding: 440A01
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 3A7B36CEBD3806EE7F-806E
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 002300
VCID: 70EFD4E6A3C48CBE81-8024
Component: IMMO H03 0505
VCID: 6ADBC68E8D18766ECF-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7662526379
VCID: 2959F982409EBD7606-807C
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 31414
VCID: 2F6D179AEA7AD346D8-807A
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 042 0082
Revision: 00000001 Serial number: VWZ1Z2M4117278
Coding: 01000400020001
VCID: 33651BEA9252F7A6BC-8066
End-------------------------(Elapsed Time: 02:08)--------------------------
